[MOAB-dev] loading a VTK mesh in parallel (.pvtu)
Iulian Grindeanu
iulian at mcs.anl.gov
Wed Oct 30 11:48:26 CDT 2013
----- Original Message -----
| I see, thanks for sharing these infos.
| I understand that in your opinion what I had planned to do is not
| useful, at least not for efficiency considerations, since the
| scaling in parallel is quite good.
| Makes sense. I don’t want to reinvent the wheel.
| That leaves me with the problem of dealing with periodic boundaries.
| How can I force entities on the domain boundaries to be shared
| across (possibly) different processors?
| Is there a way to tag the boundary vertices with some
| periodic_global_id tag and then resolve share entities based on this
| tag?
You do not have to do anything extra. As long the global ID is the same, the periodic vertices will be resolved correctly.
| Thanks for help.
| Lorenzo
| On 30 Oct 2013, at 17:07, Tim Tautges <tautges at mcs.anl.gov> wrote:
| > The information compiled during resolve_shared_ents can't really be
| > stored in files, because this information includes the handles a
| > given entity is represented by on other procs, and that depends on
| > load order and (for ghost entities) message arrival times. The
| > resolution of shared vertices/non-vertices is done using global
| > ids for the vertices, but not global ids for the entities (since
| > those entities, like interior edges/faces, may not be explicitly
| > represented in the mesh file). However, from our observations,
| > resolve_shared_ents scales rather well, at least up to 16k procs
| > and 32m elements (and probably up to 500k procs and 1b elems,
| > based on some more recent timings). So, I don't really think
| > you'll have a timing problem with this. The trouble is if you
| > don't have a global id for vertices. In that case, you'll have to
| > use the ParallelMergeMesh, as Iulian said. But even that scales
| > pretty well (though we haven't measured perf on large #'s of
| > procs, just out to maybe a few k procs).
| > - tim
| > On 10/30/2013 10:54 AM, Lorenzo Alessio Botti wrote:
| >>> it will be tough to do it this way. The tags you want to save are
| >>> all starting with double underscore, (__), and they
| >>> are not saved in a hdf5 file. My understanding is that you want
| >>> to save them in your format (vtu?), each part in a
| >>> different file.
| >> Yes, exactly what I’d like to do.
| >>> You will need to restore "MBEntityHandle" type flags, somehow.
| >>> For example, a node that is shared between 2
| >>> processors, each processor knows the handle on the other
| >>> processor, in form of a tag.
| >> So I need to save for each local shared entity the entity handles
| >> of all the non local shared entities. This makes sense.
| >>> It will be hard to restore the handle on the other processor,
| >>> from the information you save; You can search for
| >>> global id, of course, but then why do it this way, if you can
| >>> already do it by calling resolve shared ents? Do you
| >>> want to rewrite all that logic? And replicate that for higher
| >>> dimensions, edges, faces shared?
| >> I see, the problem is that I cannot know the entity handle before
| >> reading so I need to store the global id to then
| >> obtain the entity handle.
| >> And I also need to store the information regarding the shared
| >> processors in order to know where I have to search to
| >> match the global ids.
| >> Is there a way to ask other processes for all the entities with a
| >> specified tag and value? something like
| >> get_entities_by_type_and_tag() that works in parallel?
| >> I guess that this is the logic you were referring to.
| >>> Or maybe you can use a local index in each file; The tags you
| >>> need to save are the 5 parallel tags.
| >> Do you mean the bits indicating the ParallelStauts?
| >>> Is the mesh structured? Do you know about ScdInterface? Maybe
| >>> your mesh is not structured.
| >> Yes, my meshes are unstructured.
| >>> Exchange tags and reduce tags will need to know the handles of
| >>> entities on the other processors, otherwise you cannot
| >>> communicate.
| >>> But maybe I don't understand the question :(
| >> I think you got the point and you already helped me clarifying
| >> what I actually need.
| >> Thanks.
| >> Lorenzo
| >>> The reason for doing so is that in serial some situations are
| >>> easier to manage, e.g. tag entities as shared on
| >>> periodic boundaries and decide who they are going to communicate
| >>> with.
| >>> The possibility to resolve in parallel is great in case that the
| >>> mesh is repartitioned in parallel but if the mesh
| >>> does not change during the computations doing part of the work in
| >>> serial in a preliminary phase gives me more
| >>> control (at least this is my perception).
| >>> So in general, we partition in serial (although we will do some
| >>> repartitioning in parallel, soon; we are using now
| >>> zoltan for repartition when we read some climate files)
| >>> Thanks again.
| >>> Bests.
| >>> Lorenzo
| > "You will keep in perfect peace him whose mind is
| > steadfast, because he trusts in you." Isaiah 26:3
| > Tim Tautges Argonne National Laboratory
| > (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| > phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| > fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131030/159c8572/attachment-0001.html>
