[MOAB-dev] loading a VTK mesh in parallel (.pvtu)
Tim Tautges tautges at mcs.anl.gov
Wed Oct 30 11:07:37 CDT 2013
The information compiled during resolve_shared_ents can't really be stored in files, because this information includes
the handles a given entity is represented by on other procs, and that depends on load order and (for ghost entities)
message arrival times.  The resolution of shared vertices/non-vertices is done using global ids for the vertices, but
not global ids for the entities (since those entities, like interior edges/faces, may not be explicitly represented in
the mesh file).  However, from our observations, resolve_shared_ents scales rather well, at least up to 16k procs and
32m elements (and probably up to 500k procs and 1b elems, based on some more recent timings).  So, I don't really think
you'll have a timing problem with this.  The trouble is if you don't have a global id for vertices.  In that case,
you'll have to use the ParallelMergeMesh, as Iulian said.  But even that scales pretty well (though we haven't measured
perf on large #'s of procs, just out to maybe a few k procs).
- tim
On 10/30/2013 10:54 AM, Lorenzo Alessio Botti wrote:
>> it will be tough to do it this way. The tags you want to save are all starting with double underscore, (__), and they
>> are not saved in a hdf5 file. My understanding is that you want to save them in your format (vtu?), each part in a
>> different file.
> Yes, exactly what I’d like to do.
>> You will need to restore "MBEntityHandle" type flags, somehow. For example, a node that is shared between 2
>> processors, each processor knows the handle on the other processor, in form of a tag.
> So I need to save for each local shared entity the entity handles of all the non local shared entities. This makes sense.
>> It will be hard to restore the handle on the other processor, from the information you save;  You can search for
>> global id, of course, but then why do it this way, if you can already do it by calling resolve shared ents? Do you
>> want to rewrite all that logic? And replicate that for higher dimensions, edges, faces shared?
> I see, the problem is that I cannot know the entity handle before reading so I need to store the global id to then
> obtain the entity handle.
> And I also need to store the information regarding the shared processors in order to know where I have to search to
> match the global ids.
> Is there a way to ask other processes for all the entities with a specified tag and value? something like
> get_entities_by_type_and_tag() that works in parallel?
> I guess that this is the logic you were referring to.
>> Or maybe you can use a local index in each file; The tags you need to save are the 5 parallel tags.
> Do you mean the bits indicating the ParallelStauts?
>> Is the mesh structured? Do you know about ScdInterface? Maybe your mesh is not structured.
> Yes, my meshes are unstructured.
>> Exchange tags and reduce tags will need to know the handles of entities on the other processors, otherwise you cannot
>> communicate.
>> But maybe I don't understand the question :(
> I think you got the point and you already helped me clarifying what I actually need.
> Thanks.
> Lorenzo
>>     The reason for doing so is that in serial some situations are easier to manage, e.g. tag entities as shared on
>>     periodic boundaries and decide who they are going to communicate with.
>>     The possibility to resolve in parallel is great in case that the mesh is repartitioned in parallel but if the mesh
>>     does not change during the computations doing part of the work in serial in a preliminary phase gives me more
>>     control (at least this is my perception).
>> So in general, we partition in serial (although we will do some repartitioning in parallel, soon; we are using now
>> zoltan for repartition when we read some climate files)
>>     Thanks again.
>>     Bests.
>>     Lorenzo
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
