[MOAB-dev] Fortran interface to MOAB
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Tue Oct 22 17:56:38 CDT 2013
True. The linker needs both the C++ MPI and runtime libraries. Else
the build fails.
-lmpi -lmpi_cxx  -lstdc++
Should we create a IMESH_FLIBS variable that combines IMESH_LIBS and
these extra runtime libraries ?
Vijay
On Tue, Oct 22, 2013 at 5:01 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> One caveat, on other systems/compilers than Mac/Linux + Gnu, sometimes
> linking with the Fortran compiler, as is done below, fails to include the
> C++ runtime, leading to all sorts of errors about missing externals, usually
> from the C++ std library.  You can fix this either by specifying the C++
> runtime libs on the end of the link line below, or by linking with C++
> linker and specifying the Fortran runtime libs on the end of the link line.
> Either can be simpler than the other, depending on the system.
> - tim
> On 10/22/2013 04:18 PM, Vijay S. Mahadevan wrote:
>> A simple makefile along the lines of the one in the examples folder
>> should work. Here's one that I tested on some fortran code. Let me
>> know if that helps.
>> # MOAB_DIR points to top-level install dir, below which MOAB's lib/
>> and include/ are located
>> include ${MOAB_DIR}/lib/moab.make
>> include ${MOAB_DIR}/lib/iMesh-Defs.inc
>> .SUFFIXES: .o .F90 .F
>> EXAMPLES = ScdMeshF77
>> default: ${EXAMPLES}
>> ScdMeshF77: ScdMeshF77.o
>>    ${MOAB_FC} -o $@ $< ${IMESH_LIBS}
>> clean:
>>    rm -rf *.o ${EXAMPLES}
>> .F90.o :
>>    ${IMESH_FC} ${IMESH_FCFLAGS} ${IMESH_INCLUDES} ${IMESH_FCDEFS} -c $<
>> .F.o :
>> Vijay
>> On Tue, Oct 22, 2013 at 4:03 PM,  <kanaev at ibrae.ac.ru> wrote:
>>> so some examples are in itaps/imesh/ScdMeshF77
>>> How do i build ScdMeshF77.F from scratch?
>>> Thanks,
>>> Anton Kanaev
>>> The Nuclear Safety Institute (IBRAE)
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
