[MOAB-dev] commit/MOAB: danwu: Add temporary read option NO_EDGES to test MPAS reader using Zoltan partition.
commits-noreply at bitbucket.org
Mon Oct 21 15:22:29 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/eb9ac92ccd0a/
Changeset: eb9ac92ccd0a
Branch: master
User: danwu
Date: 2013-10-21 22:20:20
Summary: Add temporary read option NO_EDGES to test MPAS reader using Zoltan partition.
Affected #: 3 files
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 497c7f1..7770ee7 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -20,35 +20,49 @@ namespace moab {
const int DEFAULT_MAX_EDGES_PER_CELL = 10;
-// this is used for zoltan only related stuff
+// This is used for Zoltan only related stuff
+#if HAVE_ZOLTAN
#define GET_VAR(name, id, dims) \
- id = -1;\
- int gvfail = NCFUNC(inq_varid)( _fileId, name, &id); \
- if (NC_NOERR == gvfail) { \
- int ndims;\
- gvfail = NCFUNC(inq_varndims)( _fileId, id, &ndims);\
- if (NC_NOERR == gvfail) {\
- dims.resize(ndims); \
- gvfail = NCFUNC(inq_vardimid)( _fileId, id, &dims[0]);}}}
+ id = -1; \
+ int gvfail = NCFUNC(inq_varid)(_fileId, name, &id); \
+ if (NC_NOERR == gvfail) { \
+ int ndims; \
+ gvfail = NCFUNC(inq_varndims)(_fileId, id, &ndims); \
+ dims.resize(ndims); \
+ gvfail = NCFUNC(inq_vardimid)(_fileId, id, &dims[0]); \
#define GET_1D_DBL_VAR_RANGE(name, id, startIndex, endIndex, vals) \
- {std::vector<int> dum_dims; \
- GET_VAR(name, id, dum_dims);\
- if (-1 != id) {\
- if (rank==0) std::cout << " var:" << name << " id: " << id << "\n"; \
- NCDF_SIZE ntmp;\
- int dvfail = NCFUNC(inq_dimlen)(_fileId, dum_dims[0], &ntmp);\
- if (rank==0) std::cout << " prepare read var " << name << " start:" << startIndex << " end:"<< endIndex <<" Actual size:" << \
- ntmp << "\n" ; \
- if (startIndex > (int)ntmp || endIndex > (int) ntmp || startIndex>=endIndex) \
- { std::cout << "bad input \n"; return MB_FAILURE;} \
- vals.resize(endIndex-startIndex);\
- NCDF_SIZE ntmp1 = startIndex; NCDF_SIZE count = endIndex-startIndex; \
- dvfail = NCFUNC(get_vara_double_all)( _fileId, id, &ntmp1, &count, &vals[0]);\
- if (NC_NOERR != dvfail) {\
- std::cout<<"ReadNCDF:: Problem getting variable "<< name<<"\n";\
- return MB_FAILURE;}}}
+ std::vector<int> dum_dims; \
+ GET_VAR(name, id, dum_dims); \
+ if (-1 != id) { \
+ if (0 == rank) \
+ std::cout << "var: " << name << " id: " << id << "\n"; \
+ NCDF_SIZE ntmp; \
+ int dvfail = NCFUNC(inq_dimlen)(_fileId, dum_dims[0], &ntmp); \
+ if (0 == rank) \
+ std::cout << "Prepare reading var " << name << " start: " << startIndex << \
+ " end: " << endIndex << " Actual size: " << ntmp << "\n" ; \
+ if (startIndex > (int)ntmp || endIndex > (int)ntmp || startIndex >= endIndex) { \
+ std::cout << "Bad input\n"; \
+ return MB_FAILURE; \
+ vals.resize(endIndex - startIndex); \
+ NCDF_SIZE ntmp1 = startIndex; \
+ NCDF_SIZE count = endIndex - startIndex; \
+ dvfail = NCFUNC(get_vara_double_all)(_fileId, id, &ntmp1, &count, &vals[0]); \
+ if (NC_NOERR != dvfail) { \
+ std::cout << "ReadNCDF: Problem getting variable " << name << "\n"; \
+#endif
NCHelperMPAS::NCHelperMPAS(ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
: UcdNCHelper(readNC, fileId, opts, fileSet)
@@ -270,7 +284,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
int& gatherSetRank = _readNC->gatherSetRank;
bool& noMixedElements = _readNC->noMixedElements;
+ bool& noEdges = _readNC->noEdges;
DebugOutput& dbgOut = _readNC->dbgOut;
int rank = 0;
@@ -300,35 +314,34 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
nLocalCells++;
start_cell_idx += std::min(rank, iextra);
#ifdef USE_MPI
#ifdef HAVE_ZOLTAN
int& partMethod = _readNC->partMethod;
- if (partMethod==ScdParData::RCBZOLTAN && procs >=2) // it does not make sense to partition
+ if (partMethod == ScdParData::RCBZOLTAN && procs >= 2) // it does not make sense to partition
// if the number of processors is less than 2; trivial partition is good enough
// Zoltan partition using RCB; maybe more studies would be good, as to which partition
// is better
int temp_dim;
- MBZoltan * mbZTool = new MBZoltan(mbImpl, false, 0, NULL);
+ MBZoltan* mbZTool = new MBZoltan(mbImpl, false, 0, NULL);
std::vector<double> x, y, z;
- int end_cell_index=start_cell_idx+nLocalCells;
- GET_1D_DBL_VAR_RANGE("xCell", temp_dim, start_cell_idx, end_cell_index, x) ;
- GET_1D_DBL_VAR_RANGE("yCell", temp_dim, start_cell_idx, end_cell_index, y) ;
- GET_1D_DBL_VAR_RANGE("zCell", temp_dim, start_cell_idx, end_cell_index, z) ;
+ int end_cell_index = start_cell_idx + nLocalCells;
+ GET_1D_DBL_VAR_RANGE("xCell", temp_dim, start_cell_idx, end_cell_index, x);
+ GET_1D_DBL_VAR_RANGE("yCell", temp_dim, start_cell_idx, end_cell_index, y);
+ GET_1D_DBL_VAR_RANGE("zCell", temp_dim, start_cell_idx, end_cell_index, z);
- ErrorCode rval = mbZTool->repartition(x, y, z, start_cell_idx+1, "RCB", localGidCells );
+ ErrorCode rval = mbZTool->repartition(x, y, z, start_cell_idx + 1, "RCB", localGidCells);
//delete mbZTool;
- if (rval !=MB_SUCCESS)
- std::cout <<" error in partitioning\n";
+ if (rval != MB_SUCCESS) {
+ std::cout << "Error in partitioning\n";
return MB_FAILURE;
- dbgOut.tprintf(1, "After partitioning, localGidCells.psize()=%d\n", (int)localGidCells.psize());
- dbgOut.tprintf(1, " localGidCells.size()=%d\n", (int)localGidCells.size());
- // this is important: local cells are now redistributed, so nLocalCells is different!
+ dbgOut.tprintf(1, "After partitioning, localGidCells.psize() = %d\n", (int)localGidCells.psize());
+ dbgOut.tprintf(1, " localGidCells.size() = %d\n", (int)localGidCells.size());
+ // This is important: local cells are now redistributed, so nLocalCells is different!
nLocalCells = localGidCells.size();
else {
@@ -342,6 +355,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
#endif /* end for HAVE_ZOLTAN */
#endif /* end for USE_MPI */
// Read number of edges on each local cell, to calculate actual maxEdgesPerCell
int nEdgesOnCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
@@ -395,17 +409,16 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
assert(local_max_edges_per_cell <= global_max_edges_per_cell);
maxEdgesPerCell = global_max_edges_per_cell;
if (0==rank)
- dbgOut.tprintf(1, " global_max_edges_per_cell=%d\n", global_max_edges_per_cell);
+ dbgOut.tprintf(1, " global_max_edges_per_cell = %d\n", global_max_edges_per_cell);
#endif
// Read edges on each local cell, to get localGidEdges later
int edgesOnCellVarId;
success = NCFUNC(inq_varid)(_fileId, "edgesOnCell", &edgesOnCellVarId);
ERRORS(success, "Failed to get variable id of edgesOnCell.");
std::vector<int> edges_on_local_cells(nLocalCells * maxEdgesPerCell);
- dbgOut.tprintf(1, " edges_on_local_cells.size()=%d\n", (int)edges_on_local_cells.size());
+ dbgOut.tprintf(1, " edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size());
#ifdef PNETCDF_FILE
idxReq = 0;
#endif
@@ -442,8 +455,9 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
std::copy(edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter(localGidEdges));
nLocalEdges = localGidEdges.size();
- dbgOut.tprintf(1, " localGidEdges.psize()=%d\n", (int)localGidEdges.psize());
- dbgOut.tprintf(1, " localGidEdges.size()=%d\n", (int)localGidEdges.size());
+ dbgOut.tprintf(1, " localGidEdges.psize() = %d\n", (int)localGidEdges.psize());
+ dbgOut.tprintf(1, " localGidEdges.size() = %d\n", (int)localGidEdges.size());
// Read vertices on each local cell, to get localGidVerts and cell connectivity later
int verticesOnCellVarId;
success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
@@ -490,8 +504,8 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
std::copy(vertices_on_local_cells_sorted.rbegin(), vertices_on_local_cells_sorted.rend(), range_inserter(localGidVerts));
nLocalVertices = localGidVerts.size();
- dbgOut.tprintf(1, " localGidVerts.psize()=%d\n", (int)localGidVerts.psize());
- dbgOut.tprintf(1, " localGidVerts.size()=%d\n", (int)localGidVerts.size());
+ dbgOut.tprintf(1, " localGidVerts.psize() = %d\n", (int)localGidVerts.psize());
+ dbgOut.tprintf(1, " localGidVerts.size() = %d\n", (int)localGidVerts.size());
// Create local vertices
// We can temporarily use the memory storage allocated before it will be populated
@@ -527,19 +541,21 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
EntityHandle start_edge;
EntityHandle* conn_arr_edges = NULL;
- rval = _readNC->readMeshIface->get_element_connect(nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
+ if (!noEdges) {
+ rval = _readNC->readMeshIface->get_element_connect(nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
// Might have to create gather mesh later
(create_gathers ? nLocalEdges + nEdges : nLocalEdges));
- ERRORR(rval, "Couldn't create local edges in MPAS mesh.");
- Range local_edges_range(start_edge, start_edge + nLocalEdges - 1);
- tmp_range.insert(start_edge, start_edge + nLocalEdges - 1);
- // Get ptr to GID memory for edges
- rval = mbImpl->tag_iterate(mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data);
- ERRORR(rval, "Failed to get global id tag iterator on local edges.");
- assert(count == (int) nLocalEdges);
- gid_data = (int*) data;
- std::copy(localGidEdges.begin(), localGidEdges.end(), gid_data);
+ ERRORR(rval, "Couldn't create local edges in MPAS mesh.");
+ Range local_edges_range(start_edge, start_edge + nLocalEdges - 1);
+ tmp_range.insert(start_edge, start_edge + nLocalEdges - 1);
+ // Get ptr to GID memory for edges
+ rval = mbImpl->tag_iterate(mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data);
+ ERRORR(rval, "Failed to get global id tag iterator on local edges.");
+ assert(count == (int) nLocalEdges);
+ gid_data = (int*) data;
+ std::copy(localGidEdges.begin(), localGidEdges.end(), gid_data);
EntityHandle start_element = 0;
@@ -625,54 +641,56 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
for (rit = localGidVerts.begin(), vert_idx = 0; rit != localGidVerts.end(); ++rit, vert_idx++)
vert_gid_to_local_handle_tmp_map[*rit - 1] = start_vertex + vert_idx;*/
- // Read vertices on each local edge, to get edge connectivity
- // Utilize the memory storage pointed by conn_arr_edges
int verticesOnEdgeVarId;
- success = NCFUNC(inq_varid)(_fileId, "verticesOnEdge", &verticesOnEdgeVarId);
- ERRORS(success, "Failed to get variable id of verticesOnEdge.");
- int* vertices_on_local_edges = (int*) conn_arr_edges;
+ if (!noEdges) {
+ // Read vertices on each local edge, to get edge connectivity
+ // Utilize the memory storage pointed by conn_arr_edges
+ success = NCFUNC(inq_varid)(_fileId, "verticesOnEdge", &verticesOnEdgeVarId);
+ ERRORS(success, "Failed to get variable id of verticesOnEdge.");
+ int* vertices_on_local_edges = (int*) conn_arr_edges;
#ifdef PNETCDF_FILE
- nb_reads = localGidEdges.psize();
- requests.resize(nb_reads);
- statuss.resize(nb_reads);
- idxReq = 0;
+ nb_reads = localGidEdges.psize();
+ requests.resize(nb_reads);
+ statuss.resize(nb_reads);
+ idxReq = 0;
#endif
- indexInArray = 0;
- for (Range::pair_iterator pair_iter = localGidEdges.pair_begin();
- pair_iter != localGidEdges.pair_end();
- pair_iter++) {
- EntityHandle starth = pair_iter->first;
- EntityHandle endh = pair_iter->second;
- NCDF_SIZE tmp_starts[2] = {static_cast<NCDF_SIZE>(starth - 1), 0};
- NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(endh - starth + 1), 2};
- // Do a partial read in each subrange
+ indexInArray = 0;
+ for (Range::pair_iterator pair_iter = localGidEdges.pair_begin();
+ pair_iter != localGidEdges.pair_end();
+ pair_iter++) {
+ EntityHandle starth = pair_iter->first;
+ EntityHandle endh = pair_iter->second;
+ NCDF_SIZE tmp_starts[2] = {static_cast<NCDF_SIZE>(starth - 1), 0};
+ NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(endh - starth + 1), 2};
+ // Do a partial read in each subrange
#ifdef PNETCDF_FILE
- success = NCFUNCREQG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts,
+ success = NCFUNCREQG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts,
&(vertices_on_local_edges[indexInArray]), &requests[idxReq++]);
#else
- success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts,
+ success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts,
&(vertices_on_local_edges[indexInArray]));
#endif
- ERRORS(success, "Failed to read verticesOnEdge data in a loop");
+ ERRORS(success, "Failed to read verticesOnEdge data in a loop");
- // Increment the index for next subrange
- indexInArray += (endh - starth + 1) * 2;
+ // Increment the index for next subrange
+ indexInArray += (endh - starth + 1) * 2;
#ifdef PNETCDF_FILE
- // Wait outside the loop
- success = NCFUNC(wait_all)(_fileId, requests.size(), &requests[0], &statuss[0]);
- ERRORS(success, "Failed on wait_all.");
+ // Wait outside the loop
+ success = NCFUNC(wait_all)(_fileId, requests.size(), &requests[0], &statuss[0]);
+ ERRORS(success, "Failed on wait_all.");
#endif
- // Populate connectivity for local edges
- // Convert in-place from int to EntityHandle type (backward)
- for (int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
- EntityHandle global_vert_id = vertices_on_local_edges[edge_vert];
- int idx_vertex=localGidVerts.index(global_vert_id);
- assert(idx_vertex!=-1);
- conn_arr_edges[edge_vert] = start_vertex+idx_vertex;
+ // Populate connectivity for local edges
+ // Convert in-place from int to EntityHandle type (backward)
+ for (int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
+ EntityHandle global_vert_id = vertices_on_local_edges[edge_vert];
+ int idx_vertex = localGidVerts.index(global_vert_id);
+ assert(idx_vertex != -1);
+ conn_arr_edges[edge_vert] = start_vertex + idx_vertex;
// Populate connectivity for local cells
@@ -863,7 +881,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
rval = _readNC->mbImpl->add_entities(_fileSet, tmp_range);
ERRORR(rval, "Couldn't add new vertices/faces/edges to file set.");
- dbgOut.tprintf(1, " local entities in set: tmp_range.size()=%d\n", (int)tmp_range.size());
+ dbgOut.tprintf(1, " local entities in set: tmp_range.size() = %d\n", (int)tmp_range.size());
if (create_gathers) {
EntityHandle gather_set;
rval = _readNC->readMeshIface->create_gather_set(gather_set);
@@ -964,41 +982,41 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
// Create gather edges
EntityHandle* conn_arr_gather_edges;
- // Don't need to specify allocation number here, because we know enough edges were created before
- rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
- ERRORR(rval, "Couldn't create edges in MPAS mesh for gather set.");
- Range gather_edges_range(start_edge, start_edge + nEdges - 1);
- // Read vertices on each edge
- std::vector<int> vertices_on_gather_edges(nEdges * 2);
- NCDF_SIZE tmp_starts[2] = {0, 0};
- NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(nEdges), 2};
+ if (!noEdges) {
+ // Don't need to specify allocation number here, because we know enough edges were created before
+ rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
+ ERRORR(rval, "Couldn't create edges in MPAS mesh for gather set.");
+ Range gather_edges_range(start_edge, start_edge + nEdges - 1);
+ rval = mbImpl->add_entities(gather_set, gather_edges_range);
+ ERRORR(rval, "Couldn't add edges to gather set.");
+ // Read vertices on each edge
+ std::vector<int> vertices_on_gather_edges(nEdges * 2);
+ NCDF_SIZE tmp_starts[2] = {0, 0};
+ NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(nEdges), 2};
#ifdef PNETCDF_FILE
- // Enter independent I/O mode, since this read is only for the gather processor
- success = NCFUNC(begin_indep_data)(_fileId);
- success = NCFUNCG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts, &vertices_on_gather_edges[0]);
- ERRORS(success, "Failed to read verticesOnEdge data.");
- success = NCFUNC(end_indep_data)(_fileId);
- ERRORS(success, "Failed to end independent I/O mode.");
+ // Enter independent I/O mode, since this read is only for the gather processor
+ success = NCFUNC(begin_indep_data)(_fileId);
+ ERRORS(success, "Failed to begin independent I/O mode.");
+ success = NCFUNCG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts, &vertices_on_gather_edges[0]);
+ ERRORS(success, "Failed to read verticesOnEdge data.");
+ success = NCFUNC(end_indep_data)(_fileId);
+ ERRORS(success, "Failed to end independent I/O mode.");
#else
#endif
- std::copy(vertices_on_gather_edges.begin(), vertices_on_gather_edges.end(), conn_arr_gather_edges);
- for (int i = 0; i < 2 * nEdges; i++)
- // Connectivity array is shifted by where the gather verts start
- conn_arr_gather_edges[i] += start_vertex - 1;
- rval = mbImpl->add_entities(gather_set, gather_edges_range);
- ERRORR(rval, "Couldn't add edges to gather set.");
+ std::copy(vertices_on_gather_edges.begin(), vertices_on_gather_edges.end(), conn_arr_gather_edges);
+ for (int i = 0; i < 2 * nEdges; i++)
+ // Connectivity array is shifted by where the gather verts start
+ conn_arr_gather_edges[i] += start_vertex - 1;
// Read vertices on each gather cell (connectivity)
std::vector<int> vertices_on_gather_cells(nCells * maxEdgesPerCell);
- tmp_starts[0] = 0;
- tmp_starts[1] = 0;
- tmp_counts[0] = nCells;
- tmp_counts[1] = maxEdgesPerCell;
+ NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(nCells), maxEdgesPerCell};
#ifdef PNETCDF_FILE
@@ -1162,6 +1180,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
Interface*& mbImpl = _readNC->mbImpl;
std::vector<int>& dimLens = _readNC->dimLens;
ErrorCode rval = MB_SUCCESS;
@@ -1200,6 +1219,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
#endif
for (unsigned int i = 0; i < vdatas.size(); i++) {
+ if (noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE)
+ continue;
vdatas[i].numLev = nLevels;
for (unsigned int t = 0; t < tstep_nums.size(); t++) {
@@ -1283,6 +1305,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
ErrorCode rval = read_ucd_variable_to_nonset_allocate(vdatas, tstep_nums);
@@ -1293,6 +1316,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
Range* pLocalGid = NULL;
+ continue;
switch (vdatas[i].entLoc) {
case ReadNC::ENTLOCVERT:
pLocalGid = &localGidVerts;
@@ -1409,6 +1435,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
+ continue;
dbgOut.tprintf(2, "Converting variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
ErrorCode tmp_rval = convert_variable(vdatas[i], t);
@@ -1430,6 +1459,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -1440,6 +1470,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>
+ continue;
@@ -1546,6 +1579,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>
+ continue;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index 80ad2f1..e930930 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -19,12 +19,13 @@ ReaderIface* ReadNC::factory(Interface* iface)
ReadNC::ReadNC(Interface* impl) :
- mbImpl(impl), fileId(-1), mGlobalIdTag(0), mpFileIdTag(NULL), dbgOut(stderr), isParallel(false),
- partMethod(ScdParData::ALLJORKORI), scdi(NULL),
+ mbImpl(impl), fileId(-1), mGlobalIdTag(0), mpFileIdTag(NULL), dbgOut(stderr), isParallel(false),
+ partMethod(ScdParData::ALLJORKORI), scdi(NULL),
#ifdef USE_MPI
myPcomm(NULL),
#endif
- noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), gatherSetRank(-1), myHelper(NULL)
+ noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), noEdges(false),
+ gatherSetRank(-1), myHelper(NULL)
assert(impl != NULL);
impl->query_interface(readMeshIface);
@@ -218,6 +219,10 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
if (MB_SUCCESS == rval)
noMixedElements = true;
+ rval = opts.get_null_option("NO_EDGES");
+ if (MB_SUCCESS == rval)
+ noEdges = true;
if (2 <= dbgOut.get_verbosity()) {
if (!var_names.empty()) {
std::cerr << "Variables requested: ";
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index eb470cd..fc75140 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -208,6 +208,7 @@ private:
bool noVars;
bool spectralMesh;
bool noMixedElements;
+ bool noEdges;
int gatherSetRank;
//! Helper class instance
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
