[MOAB-dev] Trouble Creating AEntities
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Oct 14 16:21:45 CDT 2013
Hello,
Did you call ReadUtil::update_adjacencies?
If you create some elements, when you do the first adjacency call, the internal adjacencies are created .
If you create more elements after the first adjacency call, you have to call "update_adjacencies" for the new elements created, otherwise the up-vertex adjacencies are not updated.
This is my guess, it is hard to figure why it is not working for you with the limited info you sent :(
Best Regards,
Iulian
----- Original Message -----
| Hey MOAB-Dev,
| I am having trouble creating AEntities for a simple 2D planar mesh. I
| adapted ReadTemplate.cpp to create a mesh generator and it appears
| to be working fine (vertices are all present with correct
| vertex-vertex and vertex-face adjacencies and positions, faces are
| all present with correct vertex connectivity). However, when I try
| to create AEntities (ie edges) using the following code (iface is my
| Core instance):
| Range verts;
| result = iface->get_entities_by_type(0, MBVERTEX, verts);
| if (MB_SUCCESS != result) return result;
| result = MeshTopoUtil(iface).construct_aentities(verts);
| //get edge entities, by type
| Range edges;
| rval = iface->get_entities_by_type(0, MBEDGE, edges);
| assert(rval == MB_SUCCESS);
| cout << "Number of edges is " << edges.size() << endl;
| I get the following output:
| Number of edges is 0
| Also, attempting to get vertex-edge adjacencies or bridge adjacencies
| through edges returns null sets.
| Any ideas as to what is going wrong?
| -Chris
| Chris Eldred
| DOE Computational Science Graduate Fellow
| Graduate Student, Atmospheric Science, Colorado State University
| B.S. Applied Computational Physics, Carnegie Mellon University, 2009
| chris.eldred at gmail.com / celdred at atmos.colostate.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131014/93af2ced/attachment.html>
