[MOAB-dev] mixed mesh question
Carlos Breviglieri carbrevi at gmail.com
Sun Oct 13 14:19:12 CDT 2013
Iulian,
thanks for checking this out. I will be following the trac ticket. The mesh
I used is attached, partitioned for 8 procs (all tri). I noticed that are
much simpler sample meshes you created to investigate this issue. Anyway,
you can use the airfoil mesh if you find it useful.
I use a separate code to compute elements adjacency and then pass those to
metis. To write the partitions into h5m I followed the code form mbzoltan
tool. The partitioning code is correct (element-based) since I have used
this code previously with other applications...
I am from Brazil indeed, utc -3h. I'm a PhD candidate from Technological
Institute of Aeronautics in Sao Jose dos Campos.
Now I am building/adapting parts of my research code (high-order
unstructured CFD) to use MOAB. I will stick with 462 for this, working with
non-mixed meshes for this transition period. In the near feature I will
also look into the structured meshes capability of the library, as well as
the high-order elements implementation.
The CGNS reader/writer is in the works too and I will submit those as well.
My co-worker Junior, cc'ed here, is dealing with the writer part and we are
almos done.
Carlos Breviglieri
On Sat, Oct 12, 2013 at 5:40 PM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Hi Carlos,
> I am seeing a problem with ghosting, thank you for pointing it out.
> Danqing and I messed up with that code :( to fix some other issues we were
> seeing.
> http://trac.mcs.anl.gov/projects/ITAPS/ticket/284
> It may take a while to fix it properly.
> Thanks again,
> Iulian
> Hmmmm,
> Can you send me the 2d_naca0012.h5m with your partition?
> If you do ghosting after reading, did you get the same results?
> The elements/processors should not change ownership after ghosting, but
> maybe they do.
> It is indeed a work in progress, you may have found another issue :(
> Not being able to write is probably the biggest problem.
> On what time zone do you work? :) Also, where are you from? The name looks
> Brazilian, Portuguese, or Italian ? Or Spanish?
> Thanks,
> Iulian
> Hi Iulian,
> I have just ran some tests with the latest clone of the master repo
> (saturday morning). Here are my findings with MOAB 470pre:
> Now I am able to read partitined mixed meshes without errors. However, if
> I plot the owned entitied for a given proc, even for non-mixed meshes, they
> are different from the ones obtained by the partitioner, see below
> Mesh distribution for 2d_naca0012.h5m (all tri mesh) from partitioner,
> over 8 procs:
> proc[0] has 866 elements
> proc[1] has 863 elements
> proc[2] has 866 elements
> proc[3] has 869 elements
> proc[4] has 872 elements
> proc[5] has 869 elements
> proc[6] has 862 elements
> proc[7] has 877 elements
> Mesh distribution seen by MOAB 470pre
> ("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1")
> owned_entities[5], size = 864
> owned_entities[6], size = 853
> owned_entities[7], size = 871
> owned_entities[1], size = 859
> owned_entities[3], size = 860
> owned_entities[4], size = 867
> owned_entities[0], size = 866
> owned_entities[2], size = 861
> besides procs 0, all other report wrong number of entities. Code to
> compute such distribution is below (based on example/HelloParMOAB.cpp). The
> mixed mesh (2d_naca0012_mixed.h5m) now is read  (does not crash) but the
> distribution is off as well. With MOAB 462 the distribution is OK for
> homogeneous meshes.
> Moreover, with MOAB 470pre, no output is written to disk with
> PARALLEL=WRITE_PART, regardless of the mesh type. Using PARALLEL=NONE
> works, but only one part of the domain is written, as expected.
> I understand that this is a work in progress. If you need more
> information, let me know.
> Regards,
> Carlos Breviglieri
>     read_options =
> "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1";
>     moab::Interface* mb = new Core;
>     // Create root sets for each mesh.  Then pass these
>     // to the load_file functions to be populated.
>     EntityHandle rootset, partnset;
>     mb->create_meshset(MESHSET_SET, rootset);
>     mb->create_meshset(MESHSET_SET, partnset);
>     // Create the parallel communicator object with the partition handle
> associated with MOAB
>     ParallelComm *pcomm = ParallelComm::get_pcomm(mb, partnset, &myComm);
>     // Load the file from disk with given options
>     mb->load_file(meshFile.c_str(), &rootset, read_options.c_str());
>     // Get all entities of dimension = dim
>     Range elemRange, owned_entities;
>     int dim = 2;
>     mb->get_entities_by_dimension(rootset, dim, elemRange, false);
>     pcomm->filter_pstatus(elemRange, // pass entities that we want to
> filter
>                           PSTATUS_NOT_OWNED, // status we are looking for
>                           PSTATUS_NOT, // operation applied ; so it will
> return owned entities (!not_owned = owned)
>                           -1, // this means all processors
>                           &owned_entities);
>     std::vector<int> procID(owned_entities.size(), myRank);
>     std::cout << "owned_entities[" << myRank << "], size = " <<
> owned_entities.size() << std::endl;
>     Tag procID_tag;
>     mb->tag_get_handle("PROC_ID", 1, MB_TYPE_INTEGER, procID_tag,
> MB_TAG_CREAT | MB_TAG_DENSE, &procID[0]);
>     mb->tag_set_data(procID_tag, owned_entities, &procID[0]);
>     // WRITE_PART writes all partitions to a single output file (only h5m
> format supports parallel IO at the moment).
>     // One can use the mbconvert tool to convert the output to other
> formats.
>     mb->write_file(outputFile.c_str(), "H5M", "PARALLEL=WRITE_PART");
> On Thu, Oct 10, 2013 at 10:37 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> Yeah, too complicated to backport, and latest works for Carlos anyway.
>> - tim
>> On 10/09/2013 09:41 PM, Iulian Grindeanu wrote:
>>>     Both worked for me, with the current code (4.7.0pre)
>>>     I don't get your error :(
>>>     What version are you using? I will try 4.6.2, but it should be fine
>>> there too :(
>>>     OK, I got an error with more quads, on 4.6.2 maybe I mixed them up
>>> when I saved :(
>>>       mpiexec -np 2 /home/iulian/source/MOAB46/**tools/mbconvert -O
>>> PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O
>>>     PARALLEL_RESOLVE_SHARED_ENTS -O  PARALLEL_GHOSTS=2.0.1  -o
>>> PARALLEL=WRITE_PART
>>>     /home/iulian/tmp/2d_naca0012_**mixed2.h5m 2.h5m
>>>     Leaked HDF5 object handle in function at
>>> ../../../moab46source/src/io/**ReadHDF5.cpp:1523
>>>     Open at entrance: 1
>>>     Open at exit:     2
>>> ../../../moab46source/src/io/**ReadHDF5.cpp:827
>>>     Open at entrance: 1
>>>     Open at exit:     2
>>>     Failed to load "/home/iulian/tmp/2d_naca0012_**mixed2.h5m".
>>>     Error code: MB_INDEX_OUT_OF_RANGE (1)
>>>     Error message: Failed in step PARALLEL READ PART
>>>     Cannot close file with open handles: 0 file, 1 data, 0 group, 0
>>> type, 0 attr
>>>     I will look into it.
>>> Hi Carlos,
>>> It looks like it is a bug in 4.6.2.
>>> I don't know if it will be fixed, there are some important changes in
>>> ghosting in current version.
>>> So for Version4.6 branch, the model with 17 quads works fine if you
>>> don't do ghosting:
>>> iulian at T520-iuli:~/source/**MOAB46$ mpiexec -np 2
>>> /home/iulian/source/MOAB46/**tools/mbconvert -O PARALLEL=READ_PART -O
>>> PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS  -o
>>> PARALLEL=WRITE_PART
>>> /home/iulian/tmp/2d_naca0012_**mixed_invert.h5m 2.h5m
>>> Read "/home/iulian/tmp/2d_naca0012_**mixed_invert.h5m"
>>> Wrote "2.h5m"
>>> I would recommend upgrading to current version.
>>> That code is pretty complicated, and I am not sure if we will backport
>>> changes to Version4.6 branch.
>>> Tim, what do you suggest? Should I try to backport some changes in
>>> ParallelComm? I know you are working on that code.
>>> Thanks,
>>> Iulian
>> "You will keep in perfect peace him whose mind is
>>   steadfast, because he trusts in you."               Isaiah 26:3
>>              Tim Tautges            Argonne National Laboratory
>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131013/7c6545f0/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131013/7c6545f0/attachment-0001.bin>
