[MOAB-dev] mixed mesh question
Iulian Grindeanu iulian at mcs.anl.gov
Wed Oct 9 17:32:38 CDT 2013
Both worked for me, with the current code (4.7.0pre)
I don't get your error :(
What version are you using? I will try 4.6.2, but it should be fine there too :(
mpiexec -np 2 mbconvert -O PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=2.0.1 -o PARALLEL=WRITE_PART /home/iulian/tmp/2d_naca0012_mixed2.h5m 2.h5m
Read "/home/iulian/tmp/2d_naca0012_mixed2.h5m"
Wrote "2.h5m"
iulian at T520-iuli:~/tmp$ mpiexec -np 2 mbconvert -O PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=2.0.1 -o PARALLEL=WRITE_PART /home/iulian/tmp/2d_naca0012_mixed_invert.h5m 2.h5m
Read "/home/iulian/tmp/2d_naca0012_mixed_invert.h5m"
Wrote "2.h5m"
It worked on 4.6.2 too
mpiexec -np 2 /home/iulian/source/MOAB46/tools/mbconvert -O PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=2.0.1 -o PARALLEL=WRITE_PART /home/iulian/tmp/2d_naca0012_mixed_invert.h5m 2.h5m
OK, I got an error with more quads, on 4.6.2 maybe I mixed them up when I saved :(
mpiexec -np 2 /home/iulian/source/MOAB46/tools/mbconvert -O PARALLEL=READ_PART -O PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=2.0.1 -o PARALLEL=WRITE_PART /home/iulian/tmp/2d_naca0012_mixed2.h5m 2.h5m
Leaked HDF5 object handle in function at ../../../moab46source/src/io/ReadHDF5.cpp:1523
Open at entrance: 1
Open at exit: 2
Leaked HDF5 object handle in function at ../../../moab46source/src/io/ReadHDF5.cpp:827
Open at entrance: 1
Open at exit: 2
Failed to load "/home/iulian/tmp/2d_naca0012_mixed2.h5m".
Error code: MB_INDEX_OUT_OF_RANGE (1)
Error message: Failed in step PARALLEL READ PART
Cannot close file with open handles: 0 file, 1 data, 0 group, 0 type, 0 attr
I will look into it.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131009/09ab7150/attachment.html>
