[MOAB-dev] mixed mesh question
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed Oct  9 12:14:23 CDT 2013
----- Original Message -----
Hello again and thanks for the quick reply!
I have been able to find a bug with my code (the one that loaded data to h5m) and seems to be fine for mixed meshes. I have used the mbsize -ll trick and understood the fault, thanks Iulian!
The h5mvalidade tool still complains but I can see past that.
OK, thanks for reporting it. Something is not right :(
<blockquote>
The attached file is the one that seems to work for me now (naca0012 airfoil with 6910 tris + 17 quads, no parallel partitions, 2d_naca0012_mixed.h5m).
I also use METIS to partition my mesh and then push the PARALLEL_PARTITION tag/set data to h5m. It works ok for homogeneous mesh but I have problems with mixed meshes. I am looking into it right now. If I can figure out what I am doing wrong with mixed elements (actually multiple ranges) I'll let you know. I used the mbZoltan.cpp code to base my implementation on the parallel data creation.
</blockquote>
can you try something like:
mbpart 4 -p PartKway 2d_naca0012_mixed.h5m naca4.h5m
it does get a partition, which you can see in visit :)
<blockquote>
If all goes well, I will test it against mbzoltan. By the way, is there a way to use mbzoltan in parallel with graph partitioners (parmetis, ptscotch)? mbzoltan tests if mpiComm.nprocs > 1 and then quits if otherwise...
</blockquote>
yes, we use it in serial only
<blockquote>
I would be glad to share the CGNS reader code back to you. I need to fix the current issues and improve the code (add global_id data, etc). I read each CGNS section into a different tag/set in h5m, so I can easily retrieve those in application code. Not sure if this is the right way to do so (should follow the convention to place data into MATERIAL_SET / DIRICHILET NEUMANN ?) but seemed straightforward to me.
I have a CGNS writer class also in the works that I'll push back to the repo once it is working along with some sample meshes for unit tests.
I have patched the 4.6.2 sources to also include configuration flags (going the autotools way here) to point to cgns libraries and include paths. Is the CMake toolchain the official one?
</blockquote>
autotools is the official build tool.
<blockquote>
Thank you,
regards,
Carlos
</blockquote>
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131009/b8ca31cd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131009/b8ca31cd/attachment-0001.png>
