[MOAB-dev] commit/MOAB: iulian07: intersection changes
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Oct 8 09:56:44 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d4602b43e08d/
Changeset:   d4602b43e08d
Branch:      master
User:        iulian07
Date:        2013-10-08 16:53:38
Summary:     intersection changes
make it less verbose; output only at most 4 processor results
also, do not report polygon correction, unless in debug flag mode
do not bail out if the intersection points are not settled
Affected #:  2 files
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index 6faa94a..d9db131 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -381,8 +381,12 @@ ErrorCode Intx2Mesh::intersect_meshes(EntityHandle mbset1, EntityHandle mbset2,
   // before cleaning up , we need to settle the position of the intersection points
   // on the boundary edges
+  // this needs to be collective, so we should maybe wait something
   rval = correct_intersection_points_positions();
-  ERRORR(rval, "can't correct position");
+  if (rval!=MB_SUCCESS)
+    std::cout << "can't correct position, Intx2Mesh.cpp \n";
   clean();
   return MB_SUCCESS;
@@ -480,7 +484,6 @@ ErrorCode Intx2Mesh::initialize_local_kdtree(EntityHandle euler_set)
               << dep << std::endl;
   #endif
-    return result;
   return MB_SUCCESS;
 // this will work in parallel only
@@ -1365,11 +1368,14 @@ void Intx2Mesh::correct_polygon(EntityHandle * nodes, int & nP)
     if (nodes[i]==nodes[nextIndex])
       // we need to reduce nP, and collapse nodes
-      std::cout<<" nodes duplicated in list: " ;
-      for (int j=0; j<nP; j++)
-        std::cout<<nodes[j] << " " ;
-      std::cout<<"\n";
-      std::cout<<" node " << nodes[i] << " at index " << i << " is duplicated" << "\n";
+      if (dbg_1)
+        std::cout<<" nodes duplicated in list: " ;
+        for (int j=0; j<nP; j++)
+          std::cout<<nodes[j] << " " ;
+        std::cout<<"\n";
+        std::cout<<" node " << nodes[i] << " at index " << i << " is duplicated" << "\n";
       // this will work even if we start from 1 2 3 1; when i is 3, we find nextIndex is 0, then next thing does nothing
       //  (nP-1 is 3, so k is already >= nP-1); it will result in nodes -> 1, 2, 3
       for (int k=i; k<nP-1; k++)
diff --git a/tools/mbcslam/intx_mpas.cpp b/tools/mbcslam/intx_mpas.cpp
index ab50ce9..6888cb3 100644
--- a/tools/mbcslam/intx_mpas.cpp
+++ b/tools/mbcslam/intx_mpas.cpp
@@ -42,6 +42,7 @@ double gtol = 1.e-9; // this is for geometry tolerance
 double radius = 1.;// in m:  6371220.
 double t = 0.1, delta_t = 0.05; // check the script
+bool Verbose = false;
 ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
@@ -153,6 +154,11 @@ int main(int argc, char **argv)
         flux_form= true;
         index++;
+      if (!strcmp(argv[index], "-v"))
+        Verbose = true;
+        index++;
       index++;
@@ -207,17 +213,22 @@ int main(int argc, char **argv)
   rval = worker.create_departure_mesh_2nd_alg(euler_set, covering_lagr_set);
   CHECK_ERR(rval);
-  std::stringstream lagrIni;
-  lagrIni<<"def0" << rank<<".h5m";
-  rval = mb.write_file(lagrIni.str().c_str(), 0, 0, &covering_lagr_set, 1);
+  if (Verbose)
+    std::stringstream lagrIni;
+    lagrIni<<"def0" << rank<<".h5m";
+    rval = mb.write_file(lagrIni.str().c_str(), 0, 0, &covering_lagr_set, 1);
   rval = enforce_convexity(&mb, covering_lagr_set, rank);
   if (MB_SUCCESS != rval)
     return 1;
-  std::stringstream ste;
-  ste<<"lagr0" << rank<<".h5m";
-  rval = mb.write_file(ste.str().c_str(), 0, 0, &euler_set, 1);
+  if (Verbose)
+    std::stringstream ste;
+    ste<<"lagr0" << rank<<".h5m";
+    rval = mb.write_file(ste.str().c_str(), 0, 0, &euler_set, 1);
     std::cout << "can't write lagr set\n";
@@ -230,12 +241,15 @@ int main(int argc, char **argv)
     return 1;
-  std::string opts_write("");
-  std::stringstream outf;
-  outf << "intersect0" << rank << ".h5m";
-  rval = mb.write_file(outf.str().c_str(), 0, 0, &outputSet, 1);
-  if (MB_SUCCESS != rval)
-    std::cout << "can't write output\n";
+  if (rank<=4)
+    std::string opts_write("");
+    std::stringstream outf;
+    outf << "intersect0" << rank << ".h5m";
+    rval = mb.write_file(outf.str().c_str(), 0, 0, &outputSet, 1);
+    if (MB_SUCCESS != rval)
+      std::cout << "can't write output\n";
   double intx_area = area_on_sphere_lHuiller(&mb, outputSet, radius);
   double arrival_area = area_on_sphere_lHuiller(&mb, euler_set, radius);
   std::cout << " Arrival area: " << arrival_area
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
