[MOAB-dev] Build failed in Jenkins: moab_serial #119
jenkins-ci at mcs.anl.gov
Mon Oct 7 17:22:32 CDT 2013
See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/119/changes>
Changes:
[wuda] Updated MPAS reader and some unit tests. If NO_MIXED_ELEMENTS read option is set, on the processor that creates the gather set, all cells (including the gather cells) will be in one contiguous chunk.
[...truncated 531 lines...]
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make testc_cbind MOAB_iMesh_unit_tests MOAB_iMesh_extensions_tests ScdMeshF90 ScdMeshF77 FindAdjacencyF90
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT testc_cbind.o -MD -MP -MF .deps/testc_cbind.Tpo -c -o testc_cbind.o testc_cbind.cpp
mv -f .deps/testc_cbind.Tpo .deps/testc_cbind.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o testc_cbind testc_cbind.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o testc_cbind testc_cbind.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT MOAB_iMesh_unit_tests.o -MD -MP -MF .deps/MOAB_iMesh_unit_tests.Tpo -c -o MOAB_iMesh_unit_tests.o MOAB_iMesh_unit_tests.cpp
mv -f .deps/MOAB_iMesh_unit_tests.Tpo .deps/MOAB_iMesh_unit_tests.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT MOAB_iMesh_extensions_tests.o -MD -MP -MF .deps/MOAB_iMesh_extensions_tests.Tpo -c -o MOAB_iMesh_extensions_tests.o MOAB_iMesh_extensions_tests.cpp
mv -f .deps/MOAB_iMesh_extensions_tests.Tpo .deps/MOAB_iMesh_extensions_tests.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=FC --mode=link gfortran -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ScdMeshF90 ScdMeshF90.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: gfortran -O2 -fcray-pointer -o ScdMeshF90 ScdMeshF90.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=F77 --mode=link f77 -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ScdMeshF77 ScdMeshF77.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: f77 -O2 -fcray-pointer -o ScdMeshF77 ScdMeshF77.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=FC --mode=link gfortran -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o FindAdjacencyF90 FindAdjacencyF90.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: gfortran -O2 -fcray-pointer -o FindAdjacencyF90 FindAdjacencyF90.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make check-TESTS
make[5]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
PASS: testc_cbind
PASS: MOAB_iMesh_unit_tests
PASS: MOAB_iMesh_extensions_tests
PASS: ScdMeshF90
PASS: ScdMeshF77
PASS: FindAdjacencyF90
All 6 tests passed
make[5]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
Making check in tools
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in dagmc
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make test_geom pt_vol_test ray_fire_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_geom test_geom.o libdagmc.la ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_geom test_geom.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o pt_vol_test pt_vol_test.o libdagmc.la ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o pt_vol_test pt_vol_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ray_fire_test ray_fire_test.o libdagmc.la ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ray_fire_test ray_fire_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
PASS: test_geom
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in test
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make range_test moab_test homxform_test scdseq_test scd_test_partn test_adj seq_man_test geom_util_test xform_test obb_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test mbcn_test bsp_tree_poly_test reorder_test test_prog_opt coords_connect_iterate elem_eval_test spatial_locator_test test_boundbox mbfacet_test gttool_test cropvol_test mergemesh_test mbground_test kd_tree_tool kd_tree_time
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o range_test range_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o range_test range_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o moab_test moab_test-MBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o moab_test moab_test-MBTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o homxform_test homxform_test-HomXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scdseq_test scdseq_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdseq_test scdseq_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scd_test_partn scd_test_partn.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scd_test_partn scd_test_partn.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_adj test_adj.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_adj test_adj.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o seq_man_test TestTypeSequenceManager.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o seq_man_test TestTypeSequenceManager.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o geom_util_test GeomUtilTests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o geom_util_test GeomUtilTests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o xform_test xform_test-AffineXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o xform_test xform_test-AffineXform.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test OBBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test OBBTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_test bsp_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_test bsp_tree_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: `file_options_test' is up to date.
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_test kd_tree_test-kd_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_test kd_tree_test-kd_tree_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test VarLenTagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tag_test TagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tag_test TagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mesh_set_test Test_MBMeshSet.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mesh_set_test Test_MBMeshSet.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT CN.o -MD -MP -MF .deps/CN.Tpo -c -o CN.o `test -f '../src/CN.cpp' || echo './'`../src/CN.cpp
mv -f .deps/CN.Tpo .deps/CN.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbcn_test CN.o mbcn_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbcn_test CN.o mbcn_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_poly_test bsp_tree_poly_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_poly_test bsp_tree_poly_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o reorder_test reorder_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o reorder_test reorder_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_prog_opt test_prog_opt-test_prog_opt.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_prog_opt test_prog_opt-test_prog_opt.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o elem_eval_test elem_eval_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o elem_eval_test elem_eval_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o spatial_locator_test spatial_locator_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o spatial_locator_test spatial_locator_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_boundbox test_boundbox.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_boundbox test_boundbox.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbfacet_test mbfacet_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbfacet_test mbfacet_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gttool_test gttool_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gttool_test gttool_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cropvol_test crop_vol_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cropvol_test crop_vol_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mergemesh_test mergemesh_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mergemesh_test mergemesh_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbground_test mbground_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbground_test mbground_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_tool kd_tree_tool.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_tool kd_tree_tool.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_time kd_tree_time.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_time kd_tree_time.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
PASS: range_test
PASS: moab_test
PASS: homxform_test
PASS: scdseq_test
PASS: scd_test_partn
PASS: test_adj
PASS: seq_man_test
PASS: geom_util_test
PASS: xform_test
PASS: obb_test
PASS: adaptive_kd_tree_tests
PASS: bsp_tree_test
PASS: file_options_test
PASS: kd_tree_test
PASS: var_len_test
PASS: var_len_test_no_template
PASS: tag_test
PASS: mesh_set_test
PASS: mbcn_test
PASS: bsp_tree_poly_test
PASS: reorder_test
PASS: test_prog_opt
PASS: coords_connect_iterate
PASS: elem_eval_test
PASS: spatial_locator_test
PASS: test_boundbox
PASS: mbfacet_test
PASS: gttool_test
PASS: cropvol_test
PASS: mergemesh_test
PASS: mbground_test
All 31 tests passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
Making check in io
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make readutil_test tqdcfr vtk_test cub_file_test exodus_test gmsh_test nastran_test read_nc read_ucd_nc read_mpas_nc ideas_test stl_test smf_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o readutil_test readutil_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o readutil_test readutil_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tqdcfr tqdcfr-Tqdcfr.o ../../src/libMOAB.la -lm
libtool: link: g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tqdcfr tqdcfr-Tqdcfr.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o vtk_test VtkTest.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o vtk_test VtkTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cub_file_test cub_file_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cub_file_test cub_file_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o exodus_test exodus_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o exodus_test exodus_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gmsh_test gmsh_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gmsh_test gmsh_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o nastran_test nastran_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o nastran_test nastran_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_nc read_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_nc read_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT read_ucd_nc.o -MD -MP -MF .deps/read_ucd_nc.Tpo -c -o read_ucd_nc.o read_ucd_nc.cpp
mv -f .deps/read_ucd_nc.Tpo .deps/read_ucd_nc.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_ucd_nc read_ucd_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_ucd_nc read_ucd_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT read_mpas_nc.o -MD -MP -MF .deps/read_mpas_nc.Tpo -c -o read_mpas_nc.o read_mpas_nc.cpp
mv -f .deps/read_mpas_nc.Tpo .deps/read_mpas_nc.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_mpas_nc read_mpas_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_mpas_nc read_mpas_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ideas_test ideas_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ideas_test ideas_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o stl_test stl_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o stl_test stl_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o smf_test smf_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o smf_test smf_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
PASS: readutil_test
PASS: tqdcfr
PASS: vtk_test
PASS: cub_file_test
PASS: exodus_test
PASS: gmsh_test
PASS: nastran_test
PASS: read_nc
PASS: read_ucd_nc
FAIL: read_mpas_nc
PASS: ideas_test
PASS: stl_test
PASS: smf_test
1 of 13 tests failed
See test/io/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make[3]: *** [check-TESTS] Error 2
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make: *** [check-recursive] Error 1
Build step 'Execute shell' marked build as failure
