[MOAB-dev] commit/MOAB: danwu: Update unit test read_mpas_nc to test NO_MIXED_ELEMENTS read option in serial mode.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Oct 4 14:43:21 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e63de1833d30/
Changeset:   e63de1833d30
Branch:      master
User:        danwu
Date:        2013-10-04 21:43:08
Summary:     Update unit test read_mpas_nc to test NO_MIXED_ELEMENTS read option in serial mode.
Affected #:  1 file
diff --git a/test/io/read_mpas_nc.cpp b/test/io/read_mpas_nc.cpp
index d442577..0bc2d5a 100644
--- a/test/io/read_mpas_nc.cpp
+++ b/test/io/read_mpas_nc.cpp
@@ -11,6 +11,7 @@ static const char example[] = "/io/mpasx1.642.t.2.nc";
 #ifdef USE_MPI
 #include "moab_mpi.h"
+#include "moab/ParallelComm.hpp"
 #endif
 void test_read_all();
@@ -18,6 +19,7 @@ void test_read_onevar();
 void test_read_onetimestep();
 void test_read_nomesh();
 void test_read_novars();
+void test_read_no_mixed_elements();
 ErrorCode get_options(std::string& opts);
@@ -30,7 +32,7 @@ int main(int argc, char* argv[])
   if (fail)
     return 1;
 #else
-  argv[0] = argv[argc-argc]; // To remove the warnings in serial mode about unused variables
+  argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables
 #endif
   result += RUN_TEST(test_read_all);
@@ -38,6 +40,8 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_read_onetimestep);
   result += RUN_TEST(test_read_nomesh);
   result += RUN_TEST(test_read_novars);
+  // Test read option NO_MIXED_ELEMENTS
+  result += RUN_TEST(test_read_no_mixed_elements);
 #ifdef USE_MPI
   fail = MPI_Finalize();
@@ -69,74 +73,84 @@ void test_read_all()
   rval = mb.tag_get_handle("vorticity1", 1, MB_TYPE_DOUBLE, vorticity_tag1);
   CHECK_ERR(rval);
-  // Get vertices (1280 edges)
-  Range verts;
-  rval = mb.get_entities_by_type(0, MBVERTEX, verts);
-  assert(rval == MB_SUCCESS);
-  CHECK_EQUAL((size_t)1280, verts.size());
-  CHECK_EQUAL((size_t)1, verts.psize());
-  // Check vorticity tag values on first two vertices
-  EntityHandle vert_ents[] = {verts[0], verts[1]};
-  rval = mb.tag_get_data(vorticity_tag0, &vert_ents[0], 2, val);
-  CHECK_REAL_EQUAL(1.1, val[0], eps);
-  CHECK_REAL_EQUAL(1.2, val[1], eps);
-  rval = mb.tag_get_data(vorticity_tag1, &vert_ents[0], 2, val);
-  CHECK_REAL_EQUAL(2.1, val[0], eps);
-  CHECK_REAL_EQUAL(2.2, val[1], eps);
-  // Check tags for edge variable u
-  Tag u_tag0, u_tag1;
-  rval = mb.tag_get_handle("u0", 1, MB_TYPE_DOUBLE, u_tag0);
-  CHECK_ERR(rval);
-  rval = mb.tag_get_handle("u1", 1, MB_TYPE_DOUBLE, u_tag1);
-  CHECK_ERR(rval);
-  // Get edges (1920 edges)
-  Range edges;
-  rval = mb.get_entities_by_type(0, MBEDGE, edges);
-  CHECK_EQUAL((size_t)1920, edges.size());
-  CHECK_EQUAL((size_t)1, edges.psize());
-  // Check u tag values on two specified edges
-  EntityHandle edge_ents[] = {edges[5], edges[6]};
-  rval = mb.tag_get_data(u_tag0, &edge_ents[0], 2, val);
-  CHECK_REAL_EQUAL(1.113138721544778, val[0], eps);
-  CHECK_REAL_EQUAL(-1.113138721930009, val[1], eps);
-  rval = mb.tag_get_data(u_tag1, &edge_ents[0], 2, val);
-  CHECK_REAL_EQUAL(2.113138721544778, val[0], eps);
-  CHECK_REAL_EQUAL(-2.113138721930009, val[1], eps);
-  // Check tags for cell variable ke
-  Tag ke_tag0, ke_tag1;
-  rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0);
-  CHECK_ERR(rval);
-  rval = mb.tag_get_handle("ke1", 1, MB_TYPE_DOUBLE, ke_tag1);
-  CHECK_ERR(rval);
+  // Check values of tag T0 at some strategically chosen places below
+  int procs = 1;
+#ifdef USE_MPI
+  ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+  procs = pcomm->proc_config().proc_size();
+#endif
-  // Get cells (12 pentagons and 630 hexagons)
-  Range cells;
-  rval = mb.get_entities_by_type(0, MBPOLYGON, cells);
-  CHECK_EQUAL((size_t)642, cells.size());
+  // Make check runs this test in one processor
+  if (1 == procs) {
+    // Get vertices (1280 edges)
+    Range verts;
+    rval = mb.get_entities_by_type(0, MBVERTEX, verts);
+    assert(rval == MB_SUCCESS);
+    CHECK_EQUAL((size_t)1280, verts.size());
+    CHECK_EQUAL((size_t)1, verts.psize());
+    // Check vorticity tag values on first two vertices
+    EntityHandle vert_ents[] = {verts[0], verts[1]};
+    rval = mb.tag_get_data(vorticity_tag0, &vert_ents[0], 2, val);
+    CHECK_REAL_EQUAL(1.1, val[0], eps);
+    CHECK_REAL_EQUAL(1.2, val[1], eps);
+    rval = mb.tag_get_data(vorticity_tag1, &vert_ents[0], 2, val);
+    CHECK_REAL_EQUAL(2.1, val[0], eps);
+    CHECK_REAL_EQUAL(2.2, val[1], eps);
+    // Check tags for edge variable u
+    Tag u_tag0, u_tag1;
+    rval = mb.tag_get_handle("u0", 1, MB_TYPE_DOUBLE, u_tag0);
+    CHECK_ERR(rval);
+    rval = mb.tag_get_handle("u1", 1, MB_TYPE_DOUBLE, u_tag1);
+    CHECK_ERR(rval);
+    // Get edges (1920 edges)
+    Range edges;
+    rval = mb.get_entities_by_type(0, MBEDGE, edges);
+    CHECK_EQUAL((size_t)1920, edges.size());
+    CHECK_EQUAL((size_t)1, edges.psize());
+    // Check u tag values on two specified edges
+    EntityHandle edge_ents[] = {edges[5], edges[6]};
+    rval = mb.tag_get_data(u_tag0, &edge_ents[0], 2, val);
+    CHECK_REAL_EQUAL(1.113138721544778, val[0], eps);
+    CHECK_REAL_EQUAL(-1.113138721930009, val[1], eps);
+    rval = mb.tag_get_data(u_tag1, &edge_ents[0], 2, val);
+    CHECK_REAL_EQUAL(2.113138721544778, val[0], eps);
+    CHECK_REAL_EQUAL(-2.113138721930009, val[1], eps);
+    // Check tags for cell variable ke
+    Tag ke_tag0, ke_tag1;
+    rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0);
+    CHECK_ERR(rval);
+    rval = mb.tag_get_handle("ke1", 1, MB_TYPE_DOUBLE, ke_tag1);
+    CHECK_ERR(rval);
+    // Get cells (12 pentagons and 630 hexagons)
+    Range cells;
+    rval = mb.get_entities_by_type(0, MBPOLYGON, cells);
+    CHECK_EQUAL((size_t)642, cells.size());
 #ifdef USE_MPI
-  // If MOAB is compiled parallel, sequence size requested are increased
-  // by a factor of 1.5, to allow for ghosts. This will introduce a gap
-  // between the two face sequences.
-  CHECK_EQUAL((size_t)2, cells.psize());
+    // If MOAB is compiled parallel, sequence size requested are increased
+    // by a factor of 1.5, to allow for ghosts. This will introduce a gap
+    // between the two face sequences.
+    CHECK_EQUAL((size_t)2, cells.psize());
 #else
   CHECK_EQUAL((size_t)1, cells.psize());
 #endif
-  // Check ke tag values on first pentagon and first hexagon
-  EntityHandle cell_ents[] = {cells[0], cells[12]};
-  rval = mb.tag_get_data(ke_tag0, &cell_ents[0], 2, val);
-  CHECK_REAL_EQUAL(1.5, val[0], eps);
-  CHECK_REAL_EQUAL(1.6, val[1], eps);
-  rval = mb.tag_get_data(ke_tag1, &cell_ents[0], 2, val);
-  CHECK_REAL_EQUAL(2.5, val[0], eps);
-  CHECK_REAL_EQUAL(2.6, val[1], eps);
+    // Check ke tag values on first pentagon and first hexagon
+    EntityHandle cell_ents[] = {cells[0], cells[12]};
+    rval = mb.tag_get_data(ke_tag0, &cell_ents[0], 2, val);
+    CHECK_REAL_EQUAL(1.5, val[0], eps);
+    CHECK_REAL_EQUAL(1.6, val[1], eps);
+    rval = mb.tag_get_data(ke_tag1, &cell_ents[0], 2, val);
+    CHECK_REAL_EQUAL(2.5, val[0], eps);
+    CHECK_REAL_EQUAL(2.6, val[1], eps);
@@ -261,6 +275,55 @@ void test_read_novars()
   CHECK_ERR(rval);
+  Core moab;
+  Interface& mb = moab;
+  std::string opts;
+  ErrorCode rval = get_options(opts);
+  CHECK_ERR(rval);
+  opts += std::string(";NO_MIXED_ELEMENTS;VARIABLE=ke");
+  rval = mb.load_file(example, NULL, opts.c_str());
+  CHECK_ERR(rval);
+  // Check for proper tags
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  int procs = 1;
+#ifdef USE_MPI
+#endif
+  if (1 == procs) {
+    Range cells;
+    // Only one group of cells (each cell is actually represented by a 10-vertex polygon)
+    CHECK_EQUAL((size_t)1, cells.psize());
+    const double eps = 1e-20;
+    double val[2];
 ErrorCode get_options(std::string &opts)
 #ifdef USE_MPI
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
