[MOAB-dev] commit/MOAB: danwu: Initial code change to pad polygons for MPAS reader (fill the connectivity array with the last vertex handle). As a result, only one polygon sequence is created instead of multiple sequences. A new read option NO_MIXED_ELEMENTS should be set to test this feature.
    commits-noreply at bitbucket.org
    Fri Oct  4 10:10:55 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b7723a3ed695/
Changeset:   b7723a3ed695
Branch:      master
User:        danwu
Date:        2013-10-04 17:10:37
Summary:     Initial code change to pad polygons for MPAS reader (fill the connectivity array with the last vertex handle). As a result, only one polygon sequence is created instead of multiple sequences. A new read option NO_MIXED_ELEMENTS should be set to test this feature.
Affected #:  4 files
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index c0605e8..0bf9274 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -18,7 +18,7 @@ const int MAX_EDGES_PER_CELL = 10;
 NCHelperMPAS::NCHelperMPAS(ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
 : UcdNCHelper(readNC, fileId, opts, fileSet)
-, maxCellEdges(MAX_EDGES_PER_CELL)
+, maxEdgesPerCell(MAX_EDGES_PER_CELL)
 , numCellGroups(0)
@@ -47,9 +47,9 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
   // Get max edges per cell
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "maxEdges")) != dimNames.end()) {
     idx = vit - dimNames.begin();
-    maxCellEdges = dimLens[idx];
-    if (maxCellEdges > MAX_EDGES_PER_CELL) {
-      ERRORR(MB_FAILURE, "maxEdges read from MPAS file has exceeded the limit");
+    maxEdgesPerCell = dimLens[idx];
+    if (maxEdgesPerCell > MAX_EDGES_PER_CELL) {
+      ERRORR(MB_FAILURE, "maxEdgesPerCell read from MPAS file has exceeded the limit");
@@ -182,6 +182,14 @@ ErrorCode NCHelperMPAS::check_existing_mesh()
   if (noMesh) {
     ErrorCode rval;
+    // Restore numCellGroups
+    if (0 == numCellGroups) {
+      Tag numCellGroupsTag;
+      rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag);
+      if (MB_SUCCESS == rval)
+        rval = mbImpl->tag_get_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
     if (localGidVerts.empty()) {
       // Get all vertices from tmp_set (it is the input set in no_mesh scenario)
       Range local_verts;
@@ -243,20 +251,15 @@ ErrorCode NCHelperMPAS::check_existing_mesh()
         std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidCells));
         nLocalCells = localGidCells.size();
-        // Restore cellHandleToGlobalID
-        Range::const_iterator rit;
-        int i;
-        for (rit = local_cells.begin(), i = 0; rit != local_cells.end(); ++rit, i++)
-          cellHandleToGlobalID[*rit] = gids[i];
+        if (numCellGroups > 1) {
+          // Restore cellHandleToGlobalID
+          Range::const_iterator rit;
+          int i;
+          for (rit = local_cells.begin(), i = 0; rit != local_cells.end(); ++rit, i++)
+            cellHandleToGlobalID[*rit] = gids[i];
-    // Restore numCellGroups
-    if (0 == numCellGroups) {
-      Tag numCellGroupsTag;
-      rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag);
-      rval = mbImpl->tag_get_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
   return MB_SUCCESS;
@@ -268,6 +271,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
   const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
   int& gatherSetRank = _readNC->gatherSetRank;
+  bool& noMixedElements = _readNC->noMixedElements;
   int rank = 0;
   int procs = 1;
@@ -312,8 +316,8 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
   ERRORS(success, "Failed to get variable id of verticesOnCell.");
   NCDF_SIZE tmp_starts_2[2] = {static_cast<NCDF_SIZE>(start_cell_idx - 1), 0};
-  NCDF_SIZE tmp_counts_2[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxCellEdges};
-  std::vector<int> vertices_on_local_cells(nLocalCells * maxCellEdges);
+  NCDF_SIZE tmp_counts_2[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxEdgesPerCell};
+  std::vector<int> vertices_on_local_cells(nLocalCells * maxEdgesPerCell);
   success = NCFUNCAG(_vara_int)(_fileId, verticesOnCellVarId, tmp_starts_2, tmp_counts_2, &vertices_on_local_cells[0]);
   ERRORS(success, "Failed to read variable values of verticesOnCell.");
@@ -322,78 +326,33 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   success = NCFUNC(inq_varid)(_fileId, "edgesOnCell", &edgesOnCellVarId);
   ERRORS(success, "Failed to get variable id of edgesOnCell.");
   NCDF_SIZE tmp_starts_3[2] = {static_cast<NCDF_SIZE>(start_cell_idx - 1), 0};
-  NCDF_SIZE tmp_counts_3[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxCellEdges};
-  std::vector<int> edges_on_local_cells(nLocalCells * maxCellEdges);
+  NCDF_SIZE tmp_counts_3[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxEdgesPerCell};
+  std::vector<int> edges_on_local_cells(nLocalCells * maxEdgesPerCell);
   success = NCFUNCAG(_vara_int)(_fileId, edgesOnCellVarId, tmp_starts_3, tmp_counts_3, &edges_on_local_cells[0]);
   ERRORS(success, "Failed to read variable values of edgesOnCell.");
-  // Divide local cells into groups based on the number of edges
-  std::vector<int> local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
-  for (int i = 0; i < nLocalCells; i++) {
-    int cell_index = start_cell_idx + i; // Global cell index
-    int num_edges = num_edges_on_local_cells[i];
-    local_cells_with_n_edges[num_edges].push_back(cell_index);
-  // For each non-empty cell group, create cells and set connectivity array initially based on file ids
-  ErrorCode rval;
-  EntityHandle start_element;
-  EntityHandle* conn_arr_local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
-  Range tmp_range;
-  void* data;
-  int count;
-  int* gid_data;
+  // Collect localGid for vertices and edges
   std::set<int> local_verts_set;
   std::set<int> local_edges_set;
-  numCellGroups = 0;
-  for (int i = 3; i <= maxCellEdges; i++) {
-    int num_cells = local_cells_with_n_edges[i].size();
-    if (num_cells > 0) {
-      numCellGroups++;
-      rval = _readNC->readMeshIface->get_element_connect(num_cells, i, MBPOLYGON, 0, start_element, conn_arr_local_cells_with_n_edges[i], num_cells);
-      ERRORR(rval, "Couldn't create local cells in MPAS mesh.");
-      Range local_cell_range(start_element, start_element + num_cells - 1);
-      tmp_range.insert(start_element, start_element + num_cells - 1);
-      faces.insert(start_element, start_element + num_cells - 1);
-      // Get ptr to gid memory for local cells
-      rval = mbImpl->tag_iterate(mGlobalIdTag, local_cell_range.begin(), local_cell_range.end(), count, data);
-      ERRORR(rval, "Failed to get tag iterator on global id tag.");
-      assert(count == (int) num_cells);
-      gid_data = (int*) data;
-      std::copy(local_cells_with_n_edges[i].begin(), local_cells_with_n_edges[i].end(), gid_data);
-      for (int j = 0; j < num_cells; j++) {
-        int cell_idx = local_cells_with_n_edges[i][j]; // Global cell index
-        cellHandleToGlobalID[start_element + j] = cell_idx;
-        cell_idx -= start_cell_idx; // Local cell index
-        for (int k = 0; k < i; k++) {
-          conn_arr_local_cells_with_n_edges[i][i * j + k] = vertices_on_local_cells[cell_idx * maxCellEdges + k];
-          local_verts_set.insert(vertices_on_local_cells[cell_idx * maxCellEdges + k]);
-          local_edges_set.insert(edges_on_local_cells[cell_idx * maxCellEdges + k]);
+  for (int i = 0; i < nLocalCells; i++) {
+    int num_edges = num_edges_on_local_cells[i];
+    for (int j = 0; j < num_edges; j++) {
+      local_verts_set.insert(vertices_on_local_cells[i * maxEdgesPerCell + j]);
+      local_edges_set.insert(edges_on_local_cells[i * maxEdgesPerCell + j]);
-  // Set tag for numCellGroups
-  Tag numCellGroupsTag = 0;
-  rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
-  ERRORR(rval, "Trouble creating __NUM_CELL_GROUPS tag.");
-  rval = mbImpl->tag_set_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
-  ERRORR(rval, "Trouble setting data for __NUM_CELL_GROUPS tag.");
-  // Collect localGid for vertices
   std::copy(local_verts_set.rbegin(), local_verts_set.rend(), range_inserter(localGidVerts));
   nLocalVertices = localGidVerts.size();
+  std::copy(local_edges_set.rbegin(), local_edges_set.rend(), range_inserter(localGidEdges));
+  nLocalEdges = localGidEdges.size();
   // Create local vertices
   EntityHandle start_vertex;
   std::vector<double*> arrays;
-  rval = _readNC->readMeshIface->get_node_coords(3, nLocalVertices, 0, start_vertex, arrays,
-                                        // Might have to create gather mesh later
-                                        (create_gathers ? nLocalVertices + nVertices : nLocalVertices));
+  Range tmp_range;
+  ErrorCode rval = _readNC->readMeshIface->get_node_coords(3, nLocalVertices, 0, start_vertex, arrays,
+                                            // Might have to create gather mesh later
+                                            (create_gathers ? nLocalVertices + nVertices : nLocalVertices));
   ERRORR(rval, "Couldn't create local vertices in MPAS mesh.");
   tmp_range.insert(start_vertex, start_vertex + nLocalVertices - 1);
@@ -412,17 +371,19 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   // Get ptr to gid memory for local vertices
   Range local_verts_range(start_vertex, start_vertex + nLocalVertices - 1);
+  int count = 0;
+  void* data = NULL;
   rval = mbImpl->tag_iterate(mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data);
-  assert(count == (int) nLocalVertices);
+  ERRORR(rval, "Failed to get global id tag iterator on local vertices.");
+  assert(count == nLocalVertices);
+  int* gid_data = (int*) data;
   std::copy(localGidVerts.begin(), localGidVerts.end(), gid_data);
   // Duplicate global id data, which will be used to resolve sharing
   if (mpFileIdTag) {
     rval = mbImpl->tag_iterate(*mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data);
-    ERRORR(rval, "Failed to get tag iterator on file id tag.");
+    ERRORR(rval, "Failed to get file id tag iterator on local vertices.");
@@ -432,23 +393,6 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   for (rit = localGidVerts.begin(), vert_idx = 0; rit != localGidVerts.end(); ++rit, vert_idx++)
     vert_handles[*rit] = start_vertex + vert_idx;
-  // For each non-empty cell group, set connectivity array with proper local vertices handles
-          EntityHandle global_vert_id = conn_arr_local_cells_with_n_edges[i][i * j + k];
-          conn_arr_local_cells_with_n_edges[i][i * j + k] = vert_handles[global_vert_id];
-  // Collect localGid for edges
-  std::copy(local_edges_set.rbegin(), local_edges_set.rend(), range_inserter(localGidEdges));
-  nLocalEdges = localGidEdges.size();
   // Create local edges
   EntityHandle start_edge;
   EntityHandle* conn_arr_edges;
@@ -471,11 +415,101 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   // Get ptr to gid memory for edges
   rval = mbImpl->tag_iterate(mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data);
+  ERRORR(rval, "Failed to get global id tag iterator on local edges.");
   assert(count == (int) nLocalEdges);
   std::copy(localGidEdges.begin(), localGidEdges.end(), gid_data);
+  EntityHandle start_element = 0;
+  if (noMixedElements) {
+    // Only one group of cells (each cell is represented by a polygon with maxEdgesPerCell edges)
+    numCellGroups = 1;
+    // Create cells and set connectivity array with proper local vertices handles
+    EntityHandle* conn_arr_local_cells = NULL;
+    rval = _readNC->readMeshIface->get_element_connect(nLocalCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
+                                                       conn_arr_local_cells, nLocalCells);
+    ERRORR(rval, "Couldn't create local cells in MPAS mesh.");
+    Range local_cell_range(start_element, start_element + nLocalCells - 1);
+    tmp_range.insert(start_element, start_element + nLocalCells - 1);
+    faces.insert(start_element, start_element + nLocalCells - 1);
+    // Get ptr to gid memory for local cells
+    rval = mbImpl->tag_iterate(mGlobalIdTag, local_cell_range.begin(), local_cell_range.end(), count, data);
+    ERRORR(rval, "Failed to get global id tag iterator on local cells.");
+    assert(count == nLocalCells);
+    gid_data = (int*) data;
+    std::copy(localGidCells.begin(), localGidCells.end(), gid_data);
+    // Set connectivity array with proper local vertices handles
+    for (int cell_idx = 0; cell_idx < nLocalCells; cell_idx++) {
+      int num_edges = num_edges_on_local_cells[cell_idx];
+      for (int i = 0; i < num_edges; i++) {
+        EntityHandle global_vert_id = vertices_on_local_cells[cell_idx * maxEdgesPerCell + i];
+        conn_arr_local_cells[cell_idx * maxEdgesPerCell + i] = vert_handles[global_vert_id];
+      // Padding: fill connectivity array with last vertex handle
+      EntityHandle last_vert_id = conn_arr_local_cells[cell_idx * maxEdgesPerCell + num_edges - 1];
+      for (int i = num_edges; i < maxEdgesPerCell; i++)
+        conn_arr_local_cells[cell_idx * maxEdgesPerCell + i] = last_vert_id;
+  } // if (noMixedElements)
+  else {
+    // Divide local cells into groups based on the number of edges
+    std::vector<int> local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+      local_cells_with_n_edges[num_edges].push_back(start_cell_idx + i); // Global cell index
+    std::vector<int> num_edges_on_cell_groups;
+    for (int i = 3; i <= maxEdgesPerCell; i++) {
+      if (local_cells_with_n_edges[i].size() > 0)
+        num_edges_on_cell_groups.push_back(i);
+    numCellGroups = num_edges_on_cell_groups.size();
+    // For each non-empty cell group, create cells and set connectivity array with proper local vertices handles
+    EntityHandle* conn_arr_local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+    for (int i = 0; i < numCellGroups; i++) {
+      int num_edges_per_cell = num_edges_on_cell_groups[i];
+      int num_cells = local_cells_with_n_edges[num_edges_per_cell].size();
+      rval = _readNC->readMeshIface->get_element_connect(num_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
+                                                         conn_arr_local_cells_with_n_edges[num_edges_per_cell], num_cells);
+      Range local_cell_range(start_element, start_element + num_cells - 1);
+      tmp_range.insert(start_element, start_element + num_cells - 1);
+      faces.insert(start_element, start_element + num_cells - 1);
+      assert(count == num_cells);
+      std::copy(local_cells_with_n_edges[num_edges_per_cell].begin(), local_cells_with_n_edges[num_edges_per_cell].end(), gid_data);
+      for (int j = 0; j < num_cells; j++) {
+        int cell_idx = local_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index
+          cellHandleToGlobalID[start_element + j] = cell_idx;
+        cell_idx -= start_cell_idx; // Local cell index
+        for (int k = 0; k < num_edges_per_cell; k++) {
+          EntityHandle global_vert_id = vertices_on_local_cells[cell_idx * maxEdgesPerCell + k];
+          conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] = vert_handles[global_vert_id];
+    } // for (int i = 0; i < numCellGroups; i++)
+  // Set tag for numCellGroups
+  Tag numCellGroupsTag = 0;
+  rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+  ERRORR(rval, "Trouble creating __NUM_CELL_GROUPS tag.");
+  rval = mbImpl->tag_set_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
+  ERRORR(rval, "Trouble setting data for __NUM_CELL_GROUPS tag.");
   // Add new vertices, elements and edges to the file set
   rval = _readNC->mbImpl->add_entities(_fileSet, tmp_range);
   ERRORR(rval, "Couldn't add new vertices/faces/edges to file set.");
@@ -503,7 +537,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     // Get ptr to gid memory for gather vertices
     rval = mbImpl->tag_iterate(mGlobalIdTag, gather_verts_range.begin(), gather_verts_range.end(), count, data);
-    ERRORR(rval, "Failed to get tag iterator on global id tag..");
+    ERRORR(rval, "Failed to get global id tag iterator on gather vertices.");
     assert(count == nVertices);
     for (int j = 1; j <= nVertices; j++)
@@ -511,7 +545,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     // Set the file id tag too, it should be bigger something not interfering with global id
     if (mpFileIdTag) {
       rval = mbImpl->tag_iterate(*mpFileIdTag, gather_verts_range.begin(), gather_verts_range.end(), count, data);
+      ERRORR(rval, "Failed to get file id tag iterator on gather vertices.");
@@ -537,12 +571,29 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, tmp_starts_1, tmp_counts_1, &num_edges_on_gather_cells[0]);
     ERRORS(success, "Failed to read variable values of nEdgesOnCell.");
 #endif
+    // Create gather edges
+    EntityHandle* conn_arr_gather_edges;
+    // Don't need to specify allocation number here, because we know enough edges were created before
+    rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
+    ERRORR(rval, "Couldn't create edges in MPAS mesh for gather set.");
+    Range gather_edges_range(start_edge, start_edge + nEdges - 1);
+    std::copy(verticesOnEdge.begin(), verticesOnEdge.end(), conn_arr_gather_edges);
+    for (int i = 0; i < 2 * nEdges; i++)
+      // Connectivity array is shifted by where the gather verts start
+      conn_arr_gather_edges[i] += start_vertex - 1;
+    rval = mbImpl->add_entities(gather_set, gather_edges_range);
+    ERRORR(rval, "Couldn't add edges to gather set.");
     // Read vertices on each gather cell (connectivity)
-    std::vector<int> vertices_on_gather_cells(nCells * maxCellEdges);
+    std::vector<int> vertices_on_gather_cells(nCells * maxEdgesPerCell);
     tmp_starts_2[0] = 0;
     tmp_starts_2[1] = 0;
     tmp_counts_2[0] = nCells;
-    tmp_counts_2[1] = maxCellEdges;
+    tmp_counts_2[1] = maxEdgesPerCell;
 #ifdef PNETCDF_FILE
     // Enter independent I/O mode, since this read is only for the gather processor
     success = NCFUNC(begin_indep_data)(_fileId);
@@ -556,50 +607,57 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
 #endif
-    // Divide gather cells into groups based on the number of edges
-    std::vector<int> gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
-    for (int i = 0; i < nCells; i++) {
-      int num_edges = num_edges_on_gather_cells[i];
-      gather_cells_with_n_edges[num_edges].push_back(i + 1); // 0 based -> 1 based
+    Range gather_cells_range;
+      // Create cells with maxEdgesPerCell vertices per element and set connectivity array
+      EntityHandle* conn_arr_gather_cells = NULL;
+      rval = _readNC->readMeshIface->get_element_connect(nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
+                                                         conn_arr_gather_cells, nCells);
+      ERRORR(rval, "Couldn't create cells in MPAS mesh for gather set.");
+      gather_cells_range.insert(start_element, start_element + nCells - 1);
+      for (int cell_idx = 0; cell_idx < nCells; cell_idx++) {
+        int num_edges = num_edges_on_gather_cells[cell_idx];
+          conn_arr_gather_cells[cell_idx * maxEdgesPerCell + i] = (start_vertex - 1) + vertices_on_gather_cells[cell_idx * maxEdgesPerCell + i];
+        EntityHandle last_vert_id = conn_arr_gather_cells[cell_idx * maxEdgesPerCell + num_edges - 1];
+          conn_arr_gather_cells[cell_idx * maxEdgesPerCell + i] = last_vert_id;
+    else {
+      // Divide gather cells into groups based on the number of edges
+      std::vector<int> gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+      for (int i = 0; i < nCells; i++) {
+        int num_edges = num_edges_on_gather_cells[i];
+        gather_cells_with_n_edges[num_edges].push_back(i + 1); // 0 based -> 1 based
-    EntityHandle* conn_arr_gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
-    Range gather_cells_range;
-      int num_cells = gather_cells_with_n_edges[i].size();
-        rval = _readNC->readMeshIface->get_element_connect(num_cells, i, MBPOLYGON, 0, start_element, conn_arr_gather_cells_with_n_edges[i], num_cells);
-        ERRORR(rval, "Couldn't create cells in MPAS mesh for gather set.");
-        gather_cells_range.insert(start_element, start_element + num_cells - 1);
-          int cell_idx = gather_cells_with_n_edges[i][j]; // Global cell index
-          cell_idx--; // 1 based -> 0 based
-            // Connectivity array is shifted by where the gather verts start
-            conn_arr_gather_cells_with_n_edges[i][i * j + k] = (start_vertex - 1) + vertices_on_gather_cells[cell_idx * maxCellEdges + k];
+      EntityHandle* conn_arr_gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+      for (int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++) {
+        int num_cells = gather_cells_with_n_edges[num_edges_per_cell].size();
+        if (num_cells > 0) {
+                                                             conn_arr_gather_cells_with_n_edges[num_edges_per_cell], num_cells);
+          gather_cells_range.insert(start_element, start_element + num_cells - 1);
+            int cell_idx = gather_cells_with_n_edges[num_edges_per_cell][j];
+            cell_idx--; // 1 based -> 0 based
+              conn_arr_gather_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
+                (start_vertex - 1) + vertices_on_gather_cells[cell_idx * maxEdgesPerCell + k];
     rval = mbImpl->add_entities(gather_set, gather_cells_range);
     ERRORR(rval, "Couldn't add cells to gather set.");
-    // Create gather edges
-    EntityHandle* conn_arr_gather_edges;
-    // Don't need to specify allocation number here, because we know enough edges were created before
-    rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
-    ERRORR(rval, "Couldn't create edges in MPAS mesh for gather set.");
-    Range gather_edges_range(start_edge, start_edge + nEdges - 1);
-    std::copy(verticesOnEdge.begin(), verticesOnEdge.end(), conn_arr_gather_edges);
-    for (int i = 0; i < 2 * nEdges; i++)
-      conn_arr_gather_edges[i] += start_vertex - 1;
-    rval = mbImpl->add_entities(gather_set, gather_edges_range);
-    ERRORR(rval, "Couldn't add edges to gather set.");
   return MB_SUCCESS;
@@ -615,8 +673,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
   if (var_names.empty()) {
     for (mit = varInfo.begin(); mit != varInfo.end(); ++mit) {
       ReadNC::VarData vd = (*mit).second;
-      if (3 == vd.varDims.size())
+      if (3 == vd.varDims.size()) {
         if ((std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(),
             vd.varDims.end(), cDim) != vd.varDims.end()) && (std::find(vd.varDims.begin(), vd.varDims.end(), levDim)
             != vd.varDims.end()))
@@ -667,6 +724,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
     for (int i = 0; i < nTimeSteps; i++)
       tstep_nums.push_back(i);
   if (!tstep_nums.empty()) {
     for (unsigned int i = 0; i < vdatas.size(); i++) {
       vdatas[i].varTags.resize(tstep_nums.size(), 0);
@@ -790,8 +848,10 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
       assert(vdatas[i].readStarts[t].size() == vdatas[i].varDims.size());
       // Get ptr to tag space
-      if (vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1)
+      if (vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1) {
+        // For a cell variable that is NOT on one contiguous chunk of faces, defer its tag space allocation
         vdatas[i].varDatas[t] = NULL;
       else {
         assert(1 == range->psize());
         void* data;
@@ -893,9 +953,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
           success = NCFUNC(wait_all)(_fileId, requests.size(), &requests[0], &statuss[0]);
           ERRORS(success, "Failed on wait_all.");
-          // Local cells are grouped by the number of edges on each cell, e.g. 5, 6 or 7
-          // Tags created for cell variables may have to read data from different groups
+            // For a cell variable that is NOT on one contiguous chunk of faces, allocate tag space for
+            // each cell group, and utilize cellHandleToGlobalID map to read tag data
             Range::iterator iter = facesOwned.begin();
             while (iter != facesOwned.end()) {
               int count;
@@ -1030,9 +1090,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>
           assert(ic == pLocalGid->psize());
               int count;
diff --git a/src/io/NCHelperMPAS.hpp b/src/io/NCHelperMPAS.hpp
index 789a0fb..2c97566 100644
--- a/src/io/NCHelperMPAS.hpp
+++ b/src/io/NCHelperMPAS.hpp
@@ -49,7 +49,7 @@ private:
 #endif
 private:
-  int maxCellEdges;
+  int maxEdgesPerCell;
   int numCellGroups;
   std::vector<int> verticesOnEdge;
   std::map<EntityHandle, int> cellHandleToGlobalID;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index a27a89d..80ad2f1 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -24,7 +24,7 @@ ReadNC::ReadNC(Interface* impl) :
 #ifdef USE_MPI
   myPcomm(NULL),
 #endif
-  noMesh(false), noVars(false), spectralMesh(false), gatherSetRank(-1), myHelper(NULL)
+  noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), gatherSetRank(-1), myHelper(NULL)
   assert(impl != NULL);
   impl->query_interface(readMeshIface);
@@ -214,6 +214,10 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
     spectralMesh = true;
+  rval = opts.get_null_option("NO_MIXED_ELEMENTS");
+    noMixedElements = true;
   if (2 <= dbgOut.get_verbosity()) {
     if (!var_names.empty()) {
       std::cerr << "Variables requested: ";
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index e8b1845..eb470cd 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -207,6 +207,7 @@ private:
   bool noMesh;
   bool noVars;
   bool spectralMesh;
+  bool noMixedElements;
   int gatherSetRank;
   //! Helper class instance
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
