[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Fri Sep 27 16:53:00 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/4e7a43bb646f/
Changeset: 4e7a43bb646f
Branch: None
User: danwu
Date: 2013-09-27 23:50:37
Summary: Several unit tests failed on 3 or more processors, which is caused by commit 4c1554a. This commit partially fixed the issue (unit test mpastrvpart still fails with this fix).
Affected #: 1 file
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index d9e06d5..68b2eb6 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -2565,10 +2565,13 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
if ((new_numps > 2 && !(new_pstat&(PSTATUS_INTERFACE|PSTATUS_GHOST|PSTATUS_NOT_OWNED))) ||
(new_pstat&PSTATUS_INTERFACE && !(new_pstat&PSTATUS_NOT_OWNED))
+ idx = std::min_element(&new_ps[0], &new_ps[0] + new_numps) - &new_ps[0];
std::swap(new_ps[0], new_ps[idx]);
std::swap(new_hs[0], new_hs[idx]);
+ if (new_ps[0] != (int)rank())
+ new_pstat |= PSTATUS_NOT_OWNED;
plist("new_ps", new_ps, new_numps);
plist("new_hs", new_hs, new_numps);
https://bitbucket.org/fathomteam/moab/commits/0b9e97646900/
Changeset: 0b9e97646900
Branch: master
User: danwu
Date: 2013-09-27 23:52:48
Summary: Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #: 1 file
diff --git a/src/MeshTopoUtil.cpp b/src/MeshTopoUtil.cpp
index cef11e3..711cbf5 100644
--- a/src/MeshTopoUtil.cpp
+++ b/src/MeshTopoUtil.cpp
@@ -468,24 +468,40 @@ ErrorCode MeshTopoUtil::get_bridge_adjacencies(const EntityHandle from_entity,
if (bridge_dim < from_dim) {
// looping over each sub-entity of dimension bridge_dim...
- EntityHandle bridge_verts[MAX_SUB_ENTITIES];
- int bridge_indices[MAX_SUB_ENTITIES];
- for (int i = 0; i < CN::NumSubEntities(from_type, bridge_dim); i++) {
- // get the vertices making up this sub-entity
- int num_bridge_verts = CN::VerticesPerEntity( CN::SubEntityType( from_type, bridge_dim, i ) );
- CN::SubEntityVertexIndices( from_type, bridge_dim, i, bridge_indices );
- for (int j = 0; j < num_bridge_verts; ++j)
- bridge_verts[j]= connect[bridge_indices[j]];
- //CN::SubEntityConn(connect, from_type, bridge_dim, i, &bridge_verts[0], num_bridge_verts);
- // get the to_dim entities adjacent
- to_ents.clear();
- ErrorCode tmp_result = mbImpl->get_adjacencies(bridge_verts, num_bridge_verts,
- to_dim, false, to_ents, Interface::INTERSECT);
- if (MB_SUCCESS != tmp_result) result = tmp_result;
- to_adjs.merge(to_ents);
+ if (MBPOLYGON == from_type)
+ for (int i=0; i<num_connect; i++)
+ // loop over edges, and get the vertices
+ EntityHandle verts_on_edge[2]={connect[i], connect[(i+1)%num_connect]};
+ to_ents.clear();
+ ErrorCode tmp_result = mbImpl->get_adjacencies(verts_on_edge, 2,
+ to_dim, false, to_ents, Interface::INTERSECT);
+ if (MB_SUCCESS != tmp_result) result = tmp_result;
+ to_adjs.merge(to_ents);
+ else
+ EntityHandle bridge_verts[MAX_SUB_ENTITIES];
+ int bridge_indices[MAX_SUB_ENTITIES];
+ for (int i = 0; i < CN::NumSubEntities(from_type, bridge_dim); i++) {
+ // get the vertices making up this sub-entity
+ int num_bridge_verts = CN::VerticesPerEntity( CN::SubEntityType( from_type, bridge_dim, i ) );
+ CN::SubEntityVertexIndices( from_type, bridge_dim, i, bridge_indices );
+ for (int j = 0; j < num_bridge_verts; ++j)
+ bridge_verts[j]= connect[bridge_indices[j]];
+ //CN::SubEntityConn(connect, from_type, bridge_dim, i, &bridge_verts[0], num_bridge_verts);
+ // get the to_dim entities adjacent
+ to_ents.clear();
+ ErrorCode tmp_result = mbImpl->get_adjacencies(bridge_verts, num_bridge_verts,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
