[MOAB-dev] commit/MOAB: danwu: Delete MOAB instance if return early in main() for some examples.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Sep 24 10:45:34 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c5ea1479e283/
Changeset:   c5ea1479e283
Branch:      master
User:        danwu
Date:        2013-09-24 17:45:22
Summary:     Delete MOAB instance if return early in main() for some examples.
Affected #:  4 files
diff --git a/examples/GetEntities.cpp b/examples/GetEntities.cpp
index d9dc34e..5124529 100644
--- a/examples/GetEntities.cpp
+++ b/examples/GetEntities.cpp
@@ -29,19 +29,28 @@ int main(int argc, char **argv) {
     // instantiate & load a mesh from a file
   Core *mb = new Core();
   ErrorCode rval = mb->load_mesh(test_file_name.c_str());
-  if (MB_SUCCESS != rval) return 1;
+  if (MB_SUCCESS != rval) {
+    delete mb;
+    return 1;
   Range ents;
     // get all entities in the database
   rval = mb->get_entities_by_handle(0, ents);
+    delete mb;
+    return 1;
   for (Range::iterator it = ents.begin(); it != ents.end(); it++) {
     if (MBVERTEX == mb->type_from_handle(*it)) {
       Range adjs;
       rval = mb->get_adjacencies(&(*it), 1, 3, false, adjs);
+        delete mb;
+        return 1;
       cout << "Vertex " << mb->id_from_handle(*it) << " adjacencies:" << endl;
       adjs.print();
@@ -49,9 +58,13 @@ int main(int argc, char **argv) {
       const EntityHandle *connect;
       int num_connect;
       rval = mb->get_connectivity(*it, connect, num_connect);
+        delete mb;
+        return 1;
       cout << CN::EntityTypeName(mb->type_from_handle(*it)) << " " << mb->id_from_handle(*it) << " vertex connectivity is: ";
-      for (int i = 0; i < num_connect; i++) cout << mb->id_from_handle(connect[i]) << " ";
+      for (int i = 0; i < num_connect; i++)
+        cout << mb->id_from_handle(connect[i]) << " ";
       cout << endl;
diff --git a/examples/HelloParMOAB.cpp b/examples/HelloParMOAB.cpp
index 03366f9..5bcc4ab 100644
--- a/examples/HelloParMOAB.cpp
+++ b/examples/HelloParMOAB.cpp
@@ -20,20 +20,23 @@ int main(int argc, char **argv)
   string options;
-    // need option handling here for input filename
+  // Need option handling here for input filename
   if (argc > 1){
-    //user has input a mesh file
+    // user has input a mesh file
     test_file_name = argv[1];
   options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
-  // get MOAB instance and read the file with the specified options
-  Interface *mb = new Core;
-  if (NULL == mb) return 1;
-  // get the ParallelComm instance
+  // Get MOAB instance and read the file with the specified options
+  Interface* mb = new Core;
+  if (NULL == mb)
+    return 1;
+  // Get the ParallelComm instance
   ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
-  int nprocs = pcomm->proc_config().proc_size(), rank = pcomm->proc_config().proc_rank();
+  int nprocs = pcomm->proc_config().proc_size();
+  int rank = pcomm->proc_config().proc_rank();
   MPI_Comm comm = pcomm->proc_config().proc_comm();
   if (rank == 0)
@@ -41,59 +44,76 @@ int main(int argc, char **argv)
          << " on " << nprocs << " processors\n";
   ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str());
-  if (rval != MB_SUCCESS) return 1;
+  if (rval != MB_SUCCESS) {
+    delete mb;
+    return 1;
   Range shared_ents;
-    // get entities shared with all other processors
+  // Get entities shared with all other processors
   rval = pcomm->get_shared_entities(-1, shared_ents);
+    delete mb;
+    return 1;
-    // filter shared entities with not not_owned, which means owned
+  // Filter shared entities with not not_owned, which means owned
   Range owned_entities;
   rval = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_entities);
+    delete mb;
+    return 1;
-  unsigned int nums[4]={0}; // to store the owned entities per dimension
-  for (int i=0; i<4; i++) nums[i]=(int)owned_entities.num_of_dimension(i);
+  unsigned int nums[4] = {0}; // to store the owned entities per dimension
+  for (int i = 0; i < 4; i++)
+    nums[i] = (int)owned_entities.num_of_dimension(i);
   vector<int> rbuf(nprocs*4, 0);
-  MPI_Gather( nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
-  // print the stats gathered:
+  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
+  // Print the stats gathered:
   if (rank == 0) {
-    for (int i=0; i<nprocs; i++)
+    for (int i = 0; i < nprocs; i++)
       cout << " Shared, owned entities on proc " << i << ": " << rbuf[4*i] << " verts, " <<
-          rbuf[4*i+1] << " edges, " << rbuf[4*i+2] << " faces, " << rbuf[4*i+3] << " elements" << endl;
+          rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces, " << rbuf[4*i + 3] << " elements" << endl;
-    // Now exchange 1 layer of ghost elements, using vertices as bridge
-    // (we could have done this as part of reading process, using the PARALLEL_GHOSTS read option)
+  // Now exchange 1 layer of ghost elements, using vertices as bridge
+  // (we could have done this as part of reading process, using the PARALLEL_GHOSTS read option)
   rval = pcomm->exchange_ghost_cells(3, // int ghost_dim,
                                      0, // int bridge_dim,
                                      1, //int num_layers,
                                      0, //int addl_ents,
                                      true); // bool store_remote_handles);
+    delete mb;
+    return 1;
-  // repeat the reports, after ghost exchange
+  // Repeat the reports, after ghost exchange
   shared_ents.clear();
   owned_entities.clear();
+    delete mb;
+    return 1;
+    delete mb;
+    return 1;
   // find out how many shared entities of each dimension are owned on this processor
-    nums[i]=(int)owned_entities.num_of_dimension(i);
   // gather the statistics on processor 0
-  MPI_Gather( nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, comm);
-  if (rank == 0)
+  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, comm);
+  if (rank == 0) {
     cout << " \n\n After exchanging one ghost layer: \n";
+    for (int i = 0; i < nprocs; i++) {
diff --git a/examples/old/ObbTree.cpp b/examples/old/ObbTree.cpp
index f83b440..ff4aadf 100644
--- a/examples/old/ObbTree.cpp
+++ b/examples/old/ObbTree.cpp
@@ -22,9 +22,10 @@ int main(int argc, char **argv) {
   moab::Range tris;
   //moab::OrientedBoxTreeTool::Settings settings;
-  rval = mb->get_entities_by_type( 0, moab::MBTRI, tris );
+  rval = mb->get_entities_by_type(0, moab::MBTRI, tris);
   if (rval != moab::MB_SUCCESS) {
     std::cerr << "Couldn't get triangles." << std::endl;
+    delete mb;
     return 1;
@@ -33,7 +34,8 @@ int main(int argc, char **argv) {
   //rval = tool.build(tris, tree_root, &settings);
   rval = tool.build(tris, tree_root);
-    std::cerr << "Could'nt build tree." << std::endl;
+    std::cerr << "Could'nt build tree." << std::endl;
+    delete mb;
     return 1;
@@ -42,6 +44,7 @@ int main(int argc, char **argv) {
   rval = tool.box(tree_root, box_center, box_axis1, box_axis2, box_axis3);
     std::cerr << "Couldn't get box for tree root set.";
+    delete mb;
     return 1;
@@ -52,17 +55,19 @@ int main(int argc, char **argv) {
   std::vector<double> intersections;
   std::vector<moab::EntityHandle> intersection_facets;
-  for (int i=0; i<3; i++)
-    pnt_start[i] = box_center[i]-box_axis1[i];
+  for (int i = 0; i < 3; i++)
+    pnt_start[i] = box_center[i] - box_axis1[i];
-  if (ray_length>0) // normalize ray direction
-    for (int j=0; j<3; j++)
-      box_axis1[j]=2*box_axis1[j]/ray_length;
+  if (ray_length > 0) { // normalize ray direction
+    for (int j = 0; j < 3; j++)
+      box_axis1[j] = 2 * box_axis1[j] / ray_length;
   rval = tool.ray_intersect_triangles(intersections, intersection_facets,
 				      tree_root, 10e-12, pnt_start, box_axis1,
 				      &ray_length);
     std::cerr << "Couldn't ray tracing.";
+    delete mb;
     return 1;
@@ -71,9 +76,8 @@ int main(int argc, char **argv) {
   std::cout << " ray direction: " << box_axis1[0] << " " << box_axis1[1] << " " << box_axis1[2] << "\n";
   std::cout << "# of intersections : " << intersections.size() << std::endl;
   std::cout << "intersection distances are on";
-  for (unsigned int i = 0; i < intersections.size(); i++) {
+  for (unsigned int i = 0; i < intersections.size(); i++)
     std::cout << " " << intersections[i];
   std::cout << " of ray length " << ray_length << std::endl;
   delete mb;
diff --git a/examples/old/simple/GetEntities.cpp b/examples/old/simple/GetEntities.cpp
index 8d235fd..8368d9f 100644
--- a/examples/old/simple/GetEntities.cpp
+++ b/examples/old/simple/GetEntities.cpp
@@ -8,18 +8,20 @@ int main(int argc, char **argv) {
     return 0;
-    // instantiate & load a mesh from a file
+  // Instantiate & load a mesh from a file
   moab::Core *mb = new moab::Core();
   moab::ErrorCode rval = mb->load_mesh(argv[1]);
-  if (moab::MB_SUCCESS != rval) return 1;
+  if (moab::MB_SUCCESS != rval)
+    return 1;
   moab::Range ents;
-    // iterate over dimensions
+  // Iterate over dimensions
   for (int d = 0; d <= 3; d++) {
     ents.clear();
     rval = mb->get_entities_by_dimension(0, d, ents);
+      return 1;
     std::cout << "Found " << ents.size() << " " << d << "-dimensional entities:" << std::endl;
     for (moab::Range::iterator it = ents.begin(); it != ents.end(); it++) {
       moab::EntityHandle ent = *it;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
