[MOAB-dev] MOAB git branching model
Tim Tautges
tautges at mcs.anl.gov
Thu Sep 19 11:40:51 CDT 2013
I'm reluctant at the moment to institutionalize this, though for large changes or design changes I agree that it's
helpful. The reviews by Iulian and Danqing recently were very helpful for the big merge I just did.
-- tim
On 09/17/2013 09:19 PM, Paul Wilson wrote:
> On 09/17/2013 05:28 PM, Tim Tautges wrote:
>> Hi all,
>> The recent instability of the master branch of the MOAB repository (due entirely to me pushing large gobs of code)
>> has gotten me thinking about our current repository branching model, or really lack thereof. I think it's probably
>> time to get a bit more formalized about this, in spite of my distaste for explicit processes in general.
>> To review, in our current repo, we have a master branch, and several branches for previous releases. In general,
>> other MOAB developers have been using either direct clones (w/o named branches) or forks and pull requests. The
>> advantage of this is simplicity, but the disadvantage is having a master branch that could be unstable.
>> There are two things I'd like to propose or at least start a discussion on in this email:
>> 1) For developers on the project, I think we should always do that development in branches, either feature branches or
>> hotfix branches. That will make it easier to figure out what's going on at any point in time, and for associating
>> individual merges with specific development features or fixes. External developers (those w/o credentials to push
>> directly into MOAB master) would continue to submit pull requests as before.
> I'm not a particularly active developer at the moment, but I would suggest that all developers - internal and external -
> merge changes with a pull request process. There are at least 2 benefits:
> * pre-commit code review by another developer
> * a more distributed knowledge of the code base as a result
> There is at least one real disadvantage:
> * delay in merging changes because potential reviewers are too busy
> In the projects I work on, it has been very successful.
> Note - this doesn't meant that those developers need to work in a fork (although there is no practical difference).
> They can work in a branch of the main repo and issue a pull request from the branch to the main line (whatever it is
> called following item 2 and Jed's response).
> Paul
>> 2) I think we should go to a more formalized repo structure and branching/release process, similar to what is
>> described in http://nvie.com/posts/a-successful-git-branching-model/. Mostly what this would mean is that the master
>> branch would be come our "stable" or last-released version, while a development branch would be the one receiving
>> day-to-day changes (and receiving the most autotesting). This wouldn't prevent the kind of instability on that branch
>> that I caused recently, but at least would protect non-developers from these problems.
>> Comments?
>> - tim
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
