[MOAB-dev] commit/MOAB: danwu: Add -fstack-protector-all option for g++ and gcc in debug mode, to detect possible stack smashing bugs. If src/ScdInterface.cpp is reverted to a version before the fix for array index out of bounds, unit scdseq_test will terminate during make check, with <stack smashing detected> message.
commits-noreply at bitbucket.org
Wed Sep 18 14:50:09 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d4d0e2bc5f31/
Changeset: d4d0e2bc5f31
Branch: master
User: danwu
Date: 2013-09-18 21:49:48
Summary: Add -fstack-protector-all option for g++ and gcc in debug mode, to detect possible stack smashing bugs. If src/ScdInterface.cpp is reverted to a version before the fix for array index out of bounds, unit scdseq_test will terminate during make check, with <stack smashing detected> message.
Affected #: 1 file
diff --git a/config/compiler.m4 b/config/compiler.m4
index 6a7e2ed..ce83a5f 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -222,6 +222,14 @@ if test "xyes" = "x$enable_debug"; then
CFLAGS="$CFLAGS -g"
FCFLAGS="$FCFLAGS -g"
FFLAGS="$FFLAGS -g"
+ # Add -fstack-protector-all option for g++ in debug mode
+ if test "x$cxx_compiler" = "xGNU"; then
+ CXXFLAGS="$CXXFLAGS -fstack-protector-all"
+ fi
+ # Add -fstack-protector-all option for gcc in debug mode
+ if test "x$cc_compiler" = "xGNU"; then
+ CFLAGS="$CFLAGS -fstack-protector-all"
+ fi
fi
if test "xyes" = "x$enable_cxx_optimize"; then
CXXFLAGS="$CXXFLAGS -O2 -DNDEBUG"
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
