[MOAB-dev] commit/MOAB: rajeeja: Added testcase mergemesh_test.cpp, MergeMesh algorithm needs changes when merging higher dimension entities
commits-noreply at bitbucket.org
Wed Sep 18 13:30:43 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/af3ded8b3f89/
Changeset: af3ded8b3f89
Branch: master
User: rajeeja
Date: 2013-09-18 20:30:33
Summary: Added testcase mergemesh_test.cpp, MergeMesh algorithm needs changes when merging higher dimension entities
Affected #: 2 files
diff --git a/MeshFiles/unittest/16_unmerged_hex.h5m b/MeshFiles/unittest/16_unmerged_hex.h5m
new file mode 100644
index 0000000..9667f23
Binary files /dev/null and b/MeshFiles/unittest/16_unmerged_hex.h5m differ
diff --git a/test/mergemesh_test.cpp b/test/mergemesh_test.cpp
index 0000000..5982453
--- /dev/null
+++ b/test/mergemesh_test.cpp
@@ -0,0 +1,46 @@
+#include "moab/Core.hpp"
+#include "moab/Range.hpp"
+#include "moab/MergeMesh.hpp"
+#include <iostream>
+#define STRINGIFY_(A) #A
+#define STRINGIFY(A) STRINGIFY_(A)
+using namespace moab;
+const char* meshfile = STRINGIFY(MESHDIR) "/16_unmerged_hex.h5m";
+int main( int argc, char* argv[] )
+ Core moab_core;
+ ErrorCode rval;
+ Interface* iface = &moab_core;
+ std::cout << "loading mesh file " << (std::string) meshfile << std::endl;
+ rval = iface->load_mesh(meshfile);
+ if (MB_SUCCESS != rval) {
+ std::cerr << "Error reading file: " << meshfile << std::endl;
+ exit(2);
+ int dim = 3;
+ moab::Range ents;
+ iface->get_entities_by_dimension(0, dim, ents);
+ MergeMesh mm(iface);
+ double merge_tol = 1e-3;
+ bool merge_higher_dim_entities = true;
+ rval = mm.merge_entities(ents, merge_tol, merge_higher_dim_entities);
+ std::cerr << "Error in MergeMesh during merging entities" << std::endl;
+ exit(2);
+ const char *outfile = "mm_out.h5m";
+ rval = iface->write_mesh( outfile);
+ std::cerr << "Error saving file: " << outfile << std::endl;
+ exit(2);
+ return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
