[MOAB-dev] Build failed in Jenkins: moab_serial #82
Tim Tautges tautges at mcs.anl.gov
Mon Sep 16 18:02:40 CDT 2013
Ok, just pushed a fix.
- tim
On 09/16/2013 05:58 PM, Tim Tautges wrote:
> I'm fixing this, stay tuned...
> - tim
> On 09/16/2013 05:34 PM, jenkins-ci at mcs.anl.gov wrote:
>> See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/82/changes>
>> Changes:
>> [tautges] First set of changes from MOABtree repository, from commit b7eea48bccff.
>> [tautges] Commit from MOABtree repo, to 622f81cef.
>> [tautges] Many bug fixes, deleting src/ElemUtil.cpp and src/moab/ElemUtil.hpp (keeping
>> [tautges] Fixing bugs in various places, with a few improvements here and there for other reasons.
>> [tautges] Was passing wrong argument to inside_nat_space.
>> [tautges] Adding equivalent calls to the ElemUtil-based functions, for comparison.
>> [tautges] Merging .gitignore info, sorting it to aid removing duplicates.
>> [tautges] Changes to overcome conflicts.
>> [tautges] More conflict-related changes.
>> [tautges] Some test additions.
>> [tautges] Work on cleaning up element evaluations and getting the tests of that to work, and
>> [tautges] Phase 2 of coupling work: Add BVHTree
>> [tautges] - Adding tree stats keeping and printing
>> [tautges] - changing SplitData::myDim to a double, which it is meant to be
>> [tautges] Adding handling for element evaluation to the trees.  This can make searching faster in some cases,
>> [tautges] Big batch of smallish changes working toward performance analysis of tree stuff.  Make check runs correctly.
>> [tautges] Changing name of topological_connectivity arguments to various functions to corners_only;
>> [tautges] These changes hadn't made it into my previous commits for some reason.
>> [tautges] Removing these files.
>> [tautges] in examples/, point_in_elem_search.cpp, makefile: compile errors fixed
>> [tautges] Some fixes for mbcslam, now things compile, but spec_visu_test fails.
>> [tautges] point_in_elem_search: multiplying by 100 for %
>> [...truncated 707 lines...]
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
>> PASS: test_geom
>> 1 test passed
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
>> make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
>> Making check in test
>> make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> Making check in .
>> make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> make  range_test moab_test homxform_test scdseq_test scd_test_partn test_adj seq_man_test geom_util_test xform_test
>> obb_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template
>> tag_test mesh_set_test mbcn_test bsp_tree_poly_test reorder_test test_prog_opt coords_connect_iterate elem_eval_test
>> spatial_locator_test test_boundbox mbfacet_test gttool_test cropvol_test mbground_test kd_tree_tool kd_tree_time
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align
>> -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG
>> -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o range_test range_test.o ../src/libMOAB.la -lm
>> libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o range_test range_test.o
>> -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib
>> ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so
>> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib
>> -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so
>> -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
>> /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so
>> -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath
>> -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/
> homes/sha
> rp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath
> -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o moab_test moab_test-MBTest.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o moab_test moab_test-MBTest.o
> -Wl,/home
> s/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
> -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o homxform_test homxform_test-HomXform.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o
> Wl,-rpath
> -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scdseq_test scdseq_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdseq_test scdseq_test.o
> ,/homes/s
> harp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scd_test_partn scd_test_partn.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scd_test_partn scd_test_partn.o
> th -Wl,/h
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_adj test_adj.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_adj test_adj.o
> s/sharp/3
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o seq_man_test TestTypeSequenceManager.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o seq_man_test TestTypeSequenceManager.o
> Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o geom_util_test GeomUtilTests.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o geom_util_test GeomUtilTests.o
> h -Wl,/ho
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o xform_test xform_test-AffineXform.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o xform_test xform_test-AffineXform.o
> -rpath -W
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test OBBTest.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test OBBTest.o
> /sharp/3r
>> g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src
>> -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include
>> -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem
>> /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION
>> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=.
>> -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1
>> -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long
>> -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT
>> adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o
>> adaptive_kd_tree_tests.cpp
>> mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o
> gcc/lib -
> Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_test bsp_tree_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_test bsp_tree_test.o
>   -Wl,/hom
>> g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -DTEST
>> -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1
>> file_options_test-FileOptions.o -MD -MP -MF .deps/file_options_test-FileOptions.Tpo -c -o
>> file_options_test-FileOptions.o `t
> est -f '.
> ./src/FileOptions.cpp' || echo './'`../src/FileOptions.cpp
>> mv -f .deps/file_options_test-FileOptions.Tpo .deps/file_options_test-FileOptions.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o file_options_test file_options_test-FileOptions.o  -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o file_options_test file_options_test-FileOptions.o
>> -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -lm
>> kd_tree_test-kd_tree_test.o -MD -MP -MF .deps/kd_tree_test-kd_tree_test.Tpo -c -o kd_tree_test-kd_tree_test.o `test -f
>> 'kd_tree_te
> st.cpp' |
> | echo './'`kd_tree_test.cpp
>> mv -f .deps/kd_tree_test-kd_tree_test.Tpo .deps/kd_tree_test-kd_tree_test.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_test kd_tree_test-kd_tree_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_test kd_tree_test-kd_tree_test.o
>   -Wl,-rpa
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test VarLenTagTest.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test VarLenTagTest.o
> -Wl,/home
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test_no_template
>> var_len_test_no_template-VarLenTagTest.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test_no_template
>> var_len_test_no_template-VarLenTagTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a
> hdf5-1.8.
> 3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tag_test TagTest.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tag_test TagTest.o
> /sharp/3r
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mesh_set_test Test_MBMeshSet.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mesh_set_test Test_MBMeshSet.o
> h -Wl,/ho
>> -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT CN.o -MD
>> -MP -MF .deps/CN.Tpo -c -o CN.o `test -f '../src/CN.cpp' || echo './'`../src/CN.cpp
>> mv -f .deps/CN.Tpo .deps/CN.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbcn_test CN.o mbcn_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbcn_test CN.o mbcn_test.o
> l,/homes/
> sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_poly_test bsp_tree_poly_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_poly_test bsp_tree_poly_test.o
> -Wl,-rpat
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o reorder_test reorder_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o reorder_test reorder_test.o
> Wl,/homes
> /sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_prog_opt test_prog_opt-test_prog_opt.o
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_prog_opt test_prog_opt-test_prog_opt.o
> lib -Wl,-
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o coords_connect_iterate
>> coords_connect_iterate-coords_connect_iterate.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o coords_connect_iterate
>> coords_connect_iterate-coords_connect_iterate.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
>> -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/
> hdf5/hdf5
> -1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath
>> elem_eval_test.o -MD -MP -MF .deps/elem_eval_test.Tpo -c -o elem_eval_test.o elem_eval_test.cpp
>> mv -f .deps/elem_eval_test.Tpo .deps/elem_eval_test.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o elem_eval_test elem_eval_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o elem_eval_test elem_eval_test.o
> th -Wl,/h
>> spatial_locator_test.o -MD -MP -MF .deps/spatial_locator_test.Tpo -c -o spatial_locator_test.o spatial_locator_test.cpp
>> mv -f .deps/spatial_locator_test.Tpo .deps/spatial_locator_test.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o spatial_locator_test spatial_locator_test.o
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o spatial_locator_test spatial_locator_test.o
> lib -Wl,-
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_boundbox test_boundbox.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_boundbox test_boundbox.o
>   -Wl,/hom
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbfacet_test mbfacet_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbfacet_test mbfacet_test.o
> Wl,/homes
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gttool_test gttool_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gttool_test gttool_test.o
> ,/homes/s
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cropvol_test crop_vol_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cropvol_test crop_vol_test.o
> -Wl,/home
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbground_test mbground_test.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbground_test mbground_test.o
>   -Wl,/hom
>> kd_tree_tool.o -MD -MP -MF .deps/kd_tree_tool.Tpo -c -o kd_tree_tool.o kd_tree_tool.cpp
>> mv -f .deps/kd_tree_tool.Tpo .deps/kd_tree_tool.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_tool kd_tree_tool.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_tool kd_tree_tool.o
> Wl,/homes
>> kd_tree_time.o -MD -MP -MF .deps/kd_tree_time.Tpo -c -o kd_tree_time.o kd_tree_time.cpp
>> mv -f .deps/kd_tree_time.Tpo .deps/kd_tree_time.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_time kd_tree_time.o ../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_time kd_tree_time.o
> Wl,/homes
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> make  check-TESTS
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> PASS: range_test
>> PASS: moab_test
>> PASS: homxform_test
>> PASS: scdseq_test
>> PASS: scd_test_partn
>> PASS: test_adj
>> PASS: seq_man_test
>> PASS: geom_util_test
>> PASS: xform_test
>> PASS: obb_test
>> PASS: adaptive_kd_tree_tests
>> PASS: bsp_tree_test
>> PASS: file_options_test
>> PASS: kd_tree_test
>> PASS: var_len_test
>> PASS: var_len_test_no_template
>> PASS: tag_test
>> PASS: mesh_set_test
>> PASS: mbcn_test
>> PASS: bsp_tree_poly_test
>> PASS: reorder_test
>> PASS: test_prog_opt
>> PASS: coords_connect_iterate
>> PASS: elem_eval_test
>> PASS: spatial_locator_test
>> PASS: test_boundbox
>> PASS: mbfacet_test
>> PASS: gttool_test
>> PASS: cropvol_test
>> PASS: mbground_test
>> All 30 tests passed
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> Making check in io
>> make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> make  readutil_test tqdcfr vtk_test cub_file_test exodus_test gmsh_test nastran_test read_nc read_ucd_nc read_mpas_nc
>> ideas_test stl_test smf_test
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> /bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o readutil_test readutil_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o readutil_test readutil_test.o
>> ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so
> ath -Wl,/
>> g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src
>> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I.
>> -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1
>> -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DTEST_TQDCFR -Wall -pipe -pedantic
>> -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2
>> -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security
>> -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c
> -o tqdcfr
> -Tqdcfr.o `test -f '../../src/io/Tqdcfr.cpp' || echo './'`../../src/io/Tqdcfr.cpp
>> mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
>> /bin/sh ../../libtool  --tag=CXX   --mode=link g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra
>> -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe
>> -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter
>> -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tqdcfr tqdcfr-Tqdcfr.o ../../src/libMOAB.la -lm
>> libtool: link: g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align
>> -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tqdcfr tqdcfr-Tqdcfr.o
>> -lz -l
> m -Wl,-rp
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o vtk_test VtkTest.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o vtk_test VtkTest.o
> mes/sharp
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cub_file_test cub_file_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cub_file_test cub_file_test.o
> ath -Wl,/
>> exodus_test.o -MD -MP -MF .deps/exodus_test.Tpo -c -o exodus_test.o exodus_test.cc
>> mv -f .deps/exodus_test.Tpo .deps/exodus_test.Po
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o exodus_test exodus_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o exodus_test exodus_test.o
> -Wl,/home
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gmsh_test gmsh_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gmsh_test gmsh_test.o
> /homes/sh
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o nastran_test nastran_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o nastran_test nastran_test.o
> h -Wl,/ho
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_nc read_nc.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_nc read_nc.o
> es/sharp/
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_ucd_nc read_ucd_nc.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_ucd_nc read_ucd_nc.o
> -Wl,/home
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_mpas_nc read_mpas_nc.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_mpas_nc read_mpas_nc.o
> h -Wl,/ho
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ideas_test ideas_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ideas_test ideas_test.o
> l,/homes/
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o stl_test stl_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o stl_test stl_test.o
> omes/shar
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o smf_test smf_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o smf_test smf_test.o
> omes/shar
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> make  check-TESTS
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> PASS: readutil_test
>> PASS: tqdcfr
>> PASS: vtk_test
>> PASS: cub_file_test
>> PASS: exodus_test
>> PASS: gmsh_test
>> PASS: nastran_test
>> PASS: read_nc
>> PASS: read_ucd_nc
>> PASS: read_mpas_nc
>> PASS: ideas_test
>> PASS: stl_test
>> PASS: smf_test
>> All 13 tests passed
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
>> Making check in dual
>> make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> make  dual_test
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o dual_test dual_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dual_test dual_test.o
> /homes/sh
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> make  check-TESTS
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> PASS: dual_test
>> 1 test passed
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
>> Making check in obb
>> make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> make  obb_test obb_time obb_tree_tool
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test obb_test.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test obb_test.o
> omes/shar
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_time obb_time.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_time obb_time.o
> omes/shar
>> -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_tree_tool obb_tree_tool.o ../../src/libMOAB.la -lm
>> -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_tree_tool obb_tree_tool.o
> ath -Wl,/
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> make  check-TESTS
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> PASS: obb_test
>> 1 test passed
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
>> Making check in perf
>> make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf'>
>> Making check in point_location
>> make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
>> make  point_location elem_eval_time tree_searching_perf sploc_searching_perf
>> make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
>> g++ -DHAVE_CONFIG_H -I. -I../../.. -I../../../src/moab -I../../../src/parallel -I../../../src
>> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../../src/io/mhdf/include
>> -I../../../ -I../../../include -I../../../src/LocalDiscretization/ -I../../../tools/mbcoupler
>> -I../../../src/moab/point_locator/lotte -I../../../src/LocalDiscretization/moab/ -DIS_BUILDING_MB
>> -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe
>> -O2 -DNDEBUG -MT point_location.o -MD -MP -MF .deps/point_location.Tpo -c -o point_location.o point
> _location
> .cpp
>> mv -f .deps/point_location.Tpo .deps/point_location.Po
>> make[4]: *** No rule to make target `../../../tools/mbcoupler/libmbcoupler.la', needed by `point_location'.  Stop.
>> make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
>> make[3]: *** [check-am] Error 2
>> make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
>> make[2]: *** [check-recursive] Error 1
>> make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf'>
>> make[1]: *** [check-recursive] Error 1
>> make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
>> make: *** [check-recursive] Error 1
>> Build step 'Execute shell' marked build as failure
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
