[MOAB-dev] Build failed in Jenkins: moab_serial #82
jenkins-ci at mcs.anl.gov
Mon Sep 16 17:34:55 CDT 2013
See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/82/changes>
Changes:
[tautges] First set of changes from MOABtree repository, from commit b7eea48bccff.
[tautges] Commit from MOABtree repo, to 622f81cef.
[tautges] Many bug fixes, deleting src/ElemUtil.cpp and src/moab/ElemUtil.hpp (keeping
[tautges] Fixing bugs in various places, with a few improvements here and there for other reasons.
[tautges] Was passing wrong argument to inside_nat_space.
[tautges] Adding equivalent calls to the ElemUtil-based functions, for comparison.
[tautges] Merging .gitignore info, sorting it to aid removing duplicates.
[tautges] Changes to overcome conflicts.
[tautges] More conflict-related changes.
[tautges] Some test additions.
[tautges] Work on cleaning up element evaluations and getting the tests of that to work, and
[tautges] Phase 2 of coupling work: Add BVHTree
[tautges] - Adding tree stats keeping and printing
[tautges] - changing SplitData::myDim to a double, which it is meant to be
[tautges] Adding handling for element evaluation to the trees. This can make searching faster in some cases,
[tautges] Big batch of smallish changes working toward performance analysis of tree stuff. Make check runs correctly.
[tautges] Changing name of topological_connectivity arguments to various functions to corners_only;
[tautges] These changes hadn't made it into my previous commits for some reason.
[tautges] Removing these files.
[tautges] in examples/, point_in_elem_search.cpp, makefile: compile errors fixed
[tautges] Some fixes for mbcslam, now things compile, but spec_visu_test fails.
[tautges] point_in_elem_search: multiplying by 100 for %
[...truncated 707 lines...]
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
PASS: test_geom
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in test
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make range_test moab_test homxform_test scdseq_test scd_test_partn test_adj seq_man_test geom_util_test xform_test obb_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test mbcn_test bsp_tree_poly_test reorder_test test_prog_opt coords_connect_iterate elem_eval_test spatial_locator_test test_boundbox mbfacet_test gttool_test cropvol_test mbground_test kd_tree_tool kd_tree_time
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o range_test range_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o range_test range_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o moab_test moab_test-MBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o moab_test moab_test-MBTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o homxform_test homxform_test-HomXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scdseq_test scdseq_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdseq_test scdseq_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scd_test_partn scd_test_partn.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scd_test_partn scd_test_partn.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_adj test_adj.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_adj test_adj.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o seq_man_test TestTypeSequenceManager.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o seq_man_test TestTypeSequenceManager.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o geom_util_test GeomUtilTests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o geom_util_test GeomUtilTests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o xform_test xform_test-AffineXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o xform_test xform_test-AffineXform.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test OBBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test OBBTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o adaptive_kd_tree_tests.cpp
mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_test bsp_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_test bsp_tree_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -DTEST -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT file_options_test-FileOptions.o -MD -MP -MF .deps/file_options_test-FileOptions.Tpo -c -o file_options_test-FileOptions.o `test -f '../src/FileOptions.cpp' || echo './'`../src/FileOptions.cpp
mv -f .deps/file_options_test-FileOptions.Tpo .deps/file_options_test-FileOptions.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o file_options_test file_options_test-FileOptions.o -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o file_options_test file_options_test-FileOptions.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -lm
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT kd_tree_test-kd_tree_test.o -MD -MP -MF .deps/kd_tree_test-kd_tree_test.Tpo -c -o kd_tree_test-kd_tree_test.o `test -f 'kd_tree_test.cpp' || echo './'`kd_tree_test.cpp
mv -f .deps/kd_tree_test-kd_tree_test.Tpo .deps/kd_tree_test-kd_tree_test.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_test kd_tree_test-kd_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_test kd_tree_test-kd_tree_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test VarLenTagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tag_test TagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tag_test TagTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mesh_set_test Test_MBMeshSet.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mesh_set_test Test_MBMeshSet.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT CN.o -MD -MP -MF .deps/CN.Tpo -c -o CN.o `test -f '../src/CN.cpp' || echo './'`../src/CN.cpp
mv -f .deps/CN.Tpo .deps/CN.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbcn_test CN.o mbcn_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbcn_test CN.o mbcn_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_poly_test bsp_tree_poly_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_poly_test bsp_tree_poly_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o reorder_test reorder_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o reorder_test reorder_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_prog_opt test_prog_opt-test_prog_opt.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_prog_opt test_prog_opt-test_prog_opt.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT elem_eval_test.o -MD -MP -MF .deps/elem_eval_test.Tpo -c -o elem_eval_test.o elem_eval_test.cpp
mv -f .deps/elem_eval_test.Tpo .deps/elem_eval_test.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o elem_eval_test elem_eval_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o elem_eval_test elem_eval_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT spatial_locator_test.o -MD -MP -MF .deps/spatial_locator_test.Tpo -c -o spatial_locator_test.o spatial_locator_test.cpp
mv -f .deps/spatial_locator_test.Tpo .deps/spatial_locator_test.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o spatial_locator_test spatial_locator_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o spatial_locator_test spatial_locator_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_boundbox test_boundbox.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_boundbox test_boundbox.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbfacet_test mbfacet_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbfacet_test mbfacet_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gttool_test gttool_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gttool_test gttool_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cropvol_test crop_vol_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cropvol_test crop_vol_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbground_test mbground_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbground_test mbground_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT kd_tree_tool.o -MD -MP -MF .deps/kd_tree_tool.Tpo -c -o kd_tree_tool.o kd_tree_tool.cpp
mv -f .deps/kd_tree_tool.Tpo .deps/kd_tree_tool.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_tool kd_tree_tool.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_tool kd_tree_tool.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT kd_tree_time.o -MD -MP -MF .deps/kd_tree_time.Tpo -c -o kd_tree_time.o kd_tree_time.cpp
mv -f .deps/kd_tree_time.Tpo .deps/kd_tree_time.Po
/bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_time kd_tree_time.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_time kd_tree_time.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make check-TESTS
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
PASS: range_test
PASS: moab_test
PASS: homxform_test
PASS: scdseq_test
PASS: scd_test_partn
PASS: test_adj
PASS: seq_man_test
PASS: geom_util_test
PASS: xform_test
PASS: obb_test
PASS: adaptive_kd_tree_tests
PASS: bsp_tree_test
PASS: file_options_test
PASS: kd_tree_test
PASS: var_len_test
PASS: var_len_test_no_template
PASS: tag_test
PASS: mesh_set_test
PASS: mbcn_test
PASS: bsp_tree_poly_test
PASS: reorder_test
PASS: test_prog_opt
PASS: coords_connect_iterate
PASS: elem_eval_test
PASS: spatial_locator_test
PASS: test_boundbox
PASS: mbfacet_test
PASS: gttool_test
PASS: cropvol_test
PASS: mbground_test
All 30 tests passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
Making check in io
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make readutil_test tqdcfr vtk_test cub_file_test exodus_test gmsh_test nastran_test read_nc read_ucd_nc read_mpas_nc ideas_test stl_test smf_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o readutil_test readutil_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o readutil_test readutil_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f '../../src/io/Tqdcfr.cpp' || echo './'`../../src/io/Tqdcfr.cpp
mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tqdcfr tqdcfr-Tqdcfr.o ../../src/libMOAB.la -lm
libtool: link: g++ -DTEST_TQDCFR -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tqdcfr tqdcfr-Tqdcfr.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o vtk_test VtkTest.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o vtk_test VtkTest.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o cub_file_test cub_file_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o cub_file_test cub_file_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT exodus_test.o -MD -MP -MF .deps/exodus_test.Tpo -c -o exodus_test.o exodus_test.cc
mv -f .deps/exodus_test.Tpo .deps/exodus_test.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o exodus_test exodus_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o exodus_test exodus_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o gmsh_test gmsh_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gmsh_test gmsh_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o nastran_test nastran_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o nastran_test nastran_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_nc read_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_nc read_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_ucd_nc read_ucd_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_ucd_nc read_ucd_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o read_mpas_nc read_mpas_nc.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_mpas_nc read_mpas_nc.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ideas_test ideas_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ideas_test ideas_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o stl_test stl_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o stl_test stl_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o smf_test smf_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o smf_test smf_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
PASS: readutil_test
PASS: tqdcfr
PASS: vtk_test
PASS: cub_file_test
PASS: exodus_test
PASS: gmsh_test
PASS: nastran_test
PASS: read_nc
PASS: read_ucd_nc
PASS: read_mpas_nc
PASS: ideas_test
PASS: stl_test
PASS: smf_test
All 13 tests passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/io'>
Making check in dual
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
make dual_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o dual_test dual_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dual_test dual_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
PASS: dual_test
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/dual'>
Making check in obb
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
make obb_test obb_time obb_tree_tool
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test obb_test.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test obb_test.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_time obb_time.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_time obb_time.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_tree_tool obb_tree_tool.o ../../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_tree_tool obb_tree_tool.o -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
make check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
PASS: obb_test
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/obb'>
Making check in perf
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf'>
Making check in point_location
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
make point_location elem_eval_time tree_searching_perf sploc_searching_perf
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
g++ -DHAVE_CONFIG_H -I. -I../../.. -I../../../src/moab -I../../../src/parallel -I../../../src -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../../src/io/mhdf/include -I../../../ -I../../../include -I../../../src/LocalDiscretization/ -I../../../tools/mbcoupler -I../../../src/moab/point_locator/lotte -I../../../src/LocalDiscretization/moab/ -DIS_BUILDING_MB -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT point_location.o -MD -MP -MF .deps/point_location.Tpo -c -o point_location.o point_location.cpp
mv -f .deps/point_location.Tpo .deps/point_location.Po
make[4]: *** No rule to make target `../../../tools/mbcoupler/libmbcoupler.la', needed by `point_location'. Stop.
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf/point_location'>
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test/perf'>
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make: *** [check-recursive] Error 1
Build step 'Execute shell' marked build as failure
