[MOAB-dev] commit/MOAB: tautges: Forgot to add this.
commits-noreply at bitbucket.org
Thu Sep 12 13:12:26 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/54aa994d6c09/
Changeset: 54aa994d6c09
Branch: master
User: tautges
Date: 2013-09-12 20:10:22
Summary: Forgot to add this.
Affected #: 1 file
diff --git a/src/moab/FindPtFuncs.h b/src/moab/FindPtFuncs.h
new file mode 100644
index 0000000..60a464d
--- /dev/null
+++ b/src/moab/FindPtFuncs.h
@@ -0,0 +1,673 @@
+#ifndef FINDPTFUNCS_H
+#define FINDPTFUNCS_H
+#include "float.h"
+#include "math.h"
+/ from types.h
+/* integer type to use for everything */
+#if defined(USE_LONG)
+# define INTEGER long
+#elif defined(USE_LONG_LONG)
+# define INTEGER long long
+#elif defined(USE_SHORT)
+# define INTEGER short
+#else
+# define INTEGER int
+#endif
+/* when defined, use the given type for global indices instead of INTEGER */
+#if defined(USE_GLOBAL_LONG_LONG)
+# define GLOBAL_INT long long
+#elif defined(USE_GLOBAL_LONG)
+#else
+#endif
+/* floating point type to use for everything */
+#if defined(USE_FLOAT)
+ typedef float real;
+# define floorr floorf
+# define ceilr ceilf
+# define sqrtr sqrtf
+# define fabsr fabsf
+# define cosr cosf
+# define sinr sinf
+# define EPS (128*FLT_EPSILON)
+# define PI 3.1415926535897932384626433832795028841971693993751058209749445923F
+#elif defined(USE_LONG_DOUBLE)
+ typedef long double real;
+# define floorr floorl
+# define ceilr ceill
+# define sqrtr sqrtl
+# define fabsr fabsl
+# define cosr cosl
+# define sinr sinl
+# define EPS (128*LDBL_EPSILON)
+# define PI 3.1415926535897932384626433832795028841971693993751058209749445923L
+#else
+ typedef double real;
+# define cosr cos
+# define sinr sin
+# define EPS (128*DBL_EPSILON)
+#endif
+/* apparently uint and ulong can be defined already in standard headers */
+#define uint uint_
+#define ulong ulong_
+#define sint sint_
+#define slong slong_
+typedef signed INTEGER sint;
+typedef unsigned INTEGER uint;
+#undef INTEGER
+#ifdef GLOBAL_INT
+ typedef signed GLOBAL_INT slong;
+ typedef unsigned GLOBAL_INT ulong;
+#else
+ typedef sint slong;
+ typedef uint ulong;
+#endif
+/ from poly.h
+ For brevity's sake, some names have been shortened
+ Quadrature rules
+ Gauss -> Gauss-Legendre quadrature (open)
+ Lobatto -> Gauss-Lobatto-Legendre quadrature (closed at both ends)
+ Polynomial bases
+ Legendre -> Legendre basis
+ Gauss -> Lagrangian basis using Gauss quadrature nodes
+ Lobatto -> Lagrangian basis using Lobatto quadrature nodes
+ Legendre Polynomial Matrix Computation
+ (compute P_i(x_j) for i = 0, ..., n and a given set of x)
+/* precondition: n >= 1
+ inner index is x index (0 ... m-1);
+ outer index is Legendre polynomial number (0 ... n)
+void legendre_matrix(const real *x, int m, real *P, int n);
+ inner index is Legendre polynomial number (0 ... n)
+ outer index is x index (0 ... m-1);
+void legendre_matrix_t(const real *x, int m, real *P, int n);
+ compute P_i(x) with i = 0 ... n
+void legendre_row(real x, real *P, int n);
+ Quadrature Nodes and Weights Calculation
+ call the _nodes function before calling the _weights function
+void gauss_nodes(real *z, int n); /* n nodes (order = 2n-1) */
+void lobatto_nodes(real *z, int n); /* n nodes (order = 2n-3) */
+void gauss_weights(const real *z, real *w, int n);
+void lobatto_weights(const real *z, real *w, int n);
+ Lagrangian to Legendre Change-of-basis Matrix
+/* precondition: n >= 2
+ given the Gauss quadrature rule (z,w,n), compute the square matrix J
+ for transforming from the Gauss basis to the Legendre basis:
+ u_legendre(i) = sum_j J(i,j) u_gauss(j)
+ computes J = .5 (2i+1) w P (z )
+ ij j i j
+ in column major format (inner index is i, the Legendre index)
+void gauss_to_legendre(const real *z, const real *w, int n, real *J);
+ same as above, but
+ in row major format (inner index is j, the Gauss index)
+void gauss_to_legendre_t(const real *z, const real *w, int n, real *J);
+/* precondition: n >= 3
+ given the Lobatto quadrature rule (z,w,n), compute the square matrix J
+ for transforming from the Lobatto basis to the Legendre basis:
+ u_legendre(i) = sum_j J(i,j) u_lobatto(j)
+void lobatto_to_legendre(const real *z, const real *w, int n, real *J);
+ Lagrangian basis function evaluation
+/* given the Lagrangian nodes (z,n) and evaluation points (x,m)
+ evaluate all Lagrangian basis functions at all points x
+ inner index of output J is the basis function index (row-major format)
+ provide work array with space for 4*n doubles
+void lagrange_weights(const real *z, unsigned n,
+ const real *x, unsigned m,
+ real *J, real *work);
+ evaluate all Lagrangian basis functions and their derivatives
+ inner index of outputs J,D is the basis function index (row-major format)
+ provide work array with space for 6*n doubles
+void lagrange_weights_deriv(const real *z, unsigned n,
+ real *J, real *D, real *work);
+ Speedy Lagrangian Interpolation
+ Usage:
+ lagrange_data p;
+ lagrange_setup(&p,z,n); * setup for nodes z[0 ... n-1] *
+ the weights
+ p->J [0 ... n-1] interpolation weights
+ p->D [0 ... n-1] 1st derivative weights
+ p->D2[0 ... n-1] 2nd derivative weights
+ are computed for a given x with:
+ lagrange_0(p,x); * compute p->J *
+ lagrange_1(p,x); * compute p->J, p->D *
+ lagrange_2(p,x); * compute p->J, p->D, p->D2 *
+ lagrange_2u(p); * compute p->D2 after call of lagrange_1(p,x); *
+ These functions use the z array supplied to setup
+ (that pointer should not be freed between calls)
+ Weights for x=z[0] and x=z[n-1] are computed during setup; access as:
+ p->J_z0, etc. and p->J_zn, etc.
+ lagrange_free(&p); * deallocate memory allocated by setup *
+typedef struct {
+ unsigned n; /* number of Lagrange nodes */
+ const real *z; /* Lagrange nodes (user-supplied) */
+ real *J, *D, *D2; /* weights for 0th,1st,2nd derivatives */
+ real *J_z0, *D_z0, *D2_z0; /* ditto at z[0] (computed at setup) */
+ real *J_zn, *D_zn, *D2_zn; /* ditto at z[n-1] (computed at setup) */
+ real *w, *d, *u0, *v0, *u1, *v1, *u2, *v2; /* work data */
+} lagrange_data;
+void lagrange_setup(lagrange_data *p, const real *z, unsigned n);
+void lagrange_free(lagrange_data *p);
+void lagrange_0(lagrange_data *p, real x) ;
+void lagrange_1(lagrange_data *p, real x) ;
+void lagrange_2(lagrange_data *p, real x) ;
+void lagrange_2u(lagrange_data *p) ;
+/ from tensor.h
+ 1-,2-,3-d Tensor Application
+ the 3d case:
+ tensor_f3(R,mr,nr, S,ms,ns, T,mt,nt, u,v, work1,work2)
+ gives v = [ R (x) S (x) T ] u
+ where R is mr x nr, S is ms x ns, T is mt x nt,
+ each in row- or column-major format according to f := r | c
+ u is nr x ns x nt in column-major format (inner index is r)
+ v is mr x ms x mt in column-major format (inner index is r)
+void tensor_c1(const real *R, unsigned mr, unsigned nr,
+ const real *u, real *v);
+void tensor_r1(const real *R, unsigned mr, unsigned nr,
+/* work holds mr*ns reals */
+void tensor_c2(const real *R, unsigned mr, unsigned nr,
+ const real *S, unsigned ms, unsigned ns,
+ const real *u, real *v, real *work);
+void tensor_r2(const real *R, unsigned mr, unsigned nr,
+/* work1 holds mr*ns*nt reals,
+ work2 holds mr*ms*nt reals */
+void tensor_c3(const real *R, unsigned mr, unsigned nr,
+ const real *T, unsigned mt, unsigned nt,
+ const real *u, real *v, real *work1, real *work2);
+void tensor_r3(const real *R, unsigned mr, unsigned nr,
+ 1-,2-,3-d Tensor Application of Row Vectors (for Interpolation)
+ the 3d case:
+ v = tensor_i3(Jr,nr, Js,ns, Jt,nt, u, work)
+ same effect as tensor_r3(Jr,1,nr, Js,1,ns, Jt,1,nt, u,&v, work1,work2):
+ gives v = [ Jr (x) Js (x) Jt ] u
+ where Jr, Js, Jt are row vectors (interpolation weights)
+ v is a scalar
+real tensor_i1(const real *Jr, unsigned nr, const real *u);
+/* work holds ns reals */
+real tensor_i2(const real *Jr, unsigned nr,
+ const real *Js, unsigned ns,
+ const real *u, real *work);
+/* work holds ns*nt + nt reals */
+real tensor_i3(const real *Jr, unsigned nr,
+ const real *Jt, unsigned nt,
+ for simultaneous Interpolation and Gradient computation
+ the 3d case:
+ v = tensor_ig3(Jr,Dr,nr, Js,Ds,ns, Jt,Dt,nt, u,g, work)
+ g_0 = [ Dr (x) Js (x) Jt ] u
+ g_1 = [ Jr (x) Ds (x) Jt ] u
+ g_2 = [ Jr (x) Js (x) Dt ] u
+ where Jr,Dr,Js,Ds,Jt,Dt are row vectors
+ (interpolation & derivative weights)
+ v is a scalar, g is an array of 3 reals
+real tensor_ig1(const real *Jr, const real *Dr, unsigned nr,
+ const real *u, real *g);
+/* work holds 2*ns reals */
+real tensor_ig2(const real *Jr, const real *Dr, unsigned nr,
+ const real *Js, const real *Ds, unsigned ns,
+ const real *u, real *g, real *work);
+/* work holds 2*ns*nt + 3*ns reals */
+real tensor_ig3(const real *Jr, const real *Dr, unsigned nr,
+ const real *Jt, const real *Dt, unsigned nt,
+/ from findpt.h
+typedef struct {
+ real x[2], A[4], axis_bnd[4];
+} obbox_2;
+typedef struct {
+ real x[3], A[9], axis_bnd[6];
+} obbox_3;
+typedef struct {
+ unsigned hash_n;
+ real bnd[4]; /* bounds for all elements */
+ real fac[2]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
+ obbox_2 *obb; /* obb[nel] -- bounding box info for each element */
+ uint *offset; /* hash table -- for cell i,j:
+ uint index = j*hash_n+i,
+ b = offset[index ],
+ e = offset[index+1];
+ elements in cell are
+ offset[b], offset[b+1], ..., offset[e-1] */
+ unsigned max; /* maximum # of elements in any cell */
+} hash_data_2;
+typedef struct {
+ unsigned hash_n;
+ real bnd[6]; /* bounds for all elements */
+ real fac[3]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
+ obbox_3 *obb; /* obb[nel] -- bounding box info for each element */
+ uint *offset; /* hash table -- for cell i,j,k:
+ uint index = (k*hash_n+j)*hash_n+i,
+} hash_data_3;
+typedef struct {
+ uint el;
+ real r[3];
+ real dist;
+} findpt_listel;
+typedef struct {
+ unsigned constraints;
+ unsigned de, d1;
+ real *x[2], *fd1[2];
+} opt_edge_data_2;
+typedef struct {
+ real x[2], jac[4];
+} opt_point_data_2;
+typedef struct {
+ lagrange_data *ld;
+ unsigned size[3];
+ const real *elx[2];
+ opt_edge_data_2 ed;
+ opt_point_data_2 pd;
+ real *work;
+} opt_data_2;
+typedef struct {
+ const real *xw[2]; /* geometry data */
+ real *z[2]; /* lobatto nodes */
+ lagrange_data ld[2]; /* interpolation, derivative weights & data */
+ unsigned nptel; /* nodes per element */
+ hash_data_2 *hash; /* geometric hashing data */
+ findpt_listel *list, **sorted, **end;
+ /* pre-allocated list of elements to
+ check (found by hashing), and
+ pre-allocated list of pointers into
+ the first list for sorting */
+ opt_data_2 *od; /* data for the optimization algorithm */
+ real *od_work;
+} findpt_data_2;
+typedef struct {
+ unsigned dn, d1, d2;
+ real *x[3], *fdn[3];
+} opt_face_data_3;
+typedef struct {
+ unsigned de, d1, d2;
+ real *x[3], *fd1[3], *fd2[3];
+} opt_edge_data_3;
+typedef struct {
+ real x[3], jac[9];
+} opt_point_data_3;
+typedef struct {
+ unsigned size[4];
+ const real *elx[3];
+ opt_face_data_3 fd;
+ opt_edge_data_3 ed;
+ opt_point_data_3 pd;
+ real *work;
+} opt_data_3;
+typedef struct {
+ const real *xw[3]; /* geometry data */
+ real *z[3]; /* lobatto nodes */
+ lagrange_data ld[3]; /* interpolation, derivative weights & data */
+ hash_data_3 *hash; /* geometric hashing data */
+ opt_data_3 *od; /* data for the optimization algorithm */
+ real *od_work;
+} findpt_data_3;
+findpt_data_2 *findpt_setup_2(
+ const real *const xw[2], const unsigned n[2], uint nel,
+ uint max_hash_size, real bbox_tol);
+findpt_data_3 *findpt_setup_3(
+ const real *const xw[3], const unsigned n[3], uint nel,
+void findpt_free_2(findpt_data_2 *p);
+void findpt_free_3(findpt_data_3 *p);
+const real *findpt_allbnd_2(const findpt_data_2 *p);
+const real *findpt_allbnd_3(const findpt_data_3 *p);
+typedef int (*findpt_func)(void *, const real *, int, uint *, real *, real *);
+int findpt_2(findpt_data_2 *p, const real x[2], int guess,
+ uint *el, real r[2], real *dist);
+int findpt_3(findpt_data_3 *p, const real x[3], int guess,
+ uint *el, real r[3], real *dist);
+void findpt_weights_2(findpt_data_2 *p, const real r[2]);
+void findpt_weights_3(findpt_data_3 *p, const real r[3]);
+double findpt_eval_2(findpt_data_2 *p, const real *u);
+double findpt_eval_3(findpt_data_3 *p, const real *u);
+/ from extrafindpt.h
+void opt_alloc_3(opt_data_3 *p, lagrange_data *ld);
+void opt_free_3(opt_data_3 *p);
+double opt_findpt_3(opt_data_3 *p, const real *const elx[3],
+ const real xstar[3], real r[3], unsigned *constr);
+void opt_vol_set_intp_3(opt_data_3 *p, const real r[3]);
+/* for 2d spectralQuad */
+ 2 - D
+void opt_alloc_2(opt_data_2 *p, lagrange_data *ld);
+void opt_free_2(opt_data_2 *p);
+double opt_findpt_2(opt_data_2 *p, const real *const elx[2],
+ const real xstar[2], real r[2], unsigned *constr);
+extern const unsigned opt_no_constraints_2;
+extern const unsigned opt_no_constraints_3;
+/ from errmem.h
+/* requires:
+ <stdlib.h> for malloc, calloc, realloc, free
+ Error Reporting
+ Memory Allocation Wrappers to Catch Out-of-memory
+/* #include "malloc.h" */
+#include <stdlib.h>
+#ifdef __GNUC__
+void fail(const char *fmt, ...) __attribute__ ((noreturn));
+#define MAYBE_UNUSED __attribute__ ((unused))
+#else
+void fail(const char *fmt, ...);
+#endif
+#if 0
+#endif
+static void *smalloc(size_t size, const char *file) MAYBE_UNUSED;
+ void *res = malloc(size);
+ if(!res && size) fail("%s: allocation of %d bytes failed\n",file,(int)size);
+ return res;
+static void *scalloc(size_t nmemb, size_t size, const char *file) MAYBE_UNUSED;
+ void *res = calloc(nmemb, size);
+ if(!res && nmemb)
+ fail("%s: allocation of %d bytes failed\n",file,(int)size*nmemb);
+ return res;
+static void *srealloc(void *ptr, size_t size, const char *file) MAYBE_UNUSED;
+ void *res = realloc(ptr, size);
+ return res;
+#define tmalloc(type, count) \
+ ((type*) smalloc((count)*sizeof(type),__FILE__) )
+#define tcalloc(type, count) \
+ ((type*) scalloc((count),sizeof(type),__FILE__) )
+#define trealloc(type, ptr, count) \
+ ((type*) srealloc((ptr),(count)*sizeof(type),__FILE__) )
+typedef struct { size_t size; void *ptr; } buffer;
+static void buffer_init_(buffer *b, size_t size, const char *file) MAYBE_UNUSED;
+ b->size=size, b->ptr=smalloc(size,file);
+static void buffer_reserve_(buffer *b, size_t min, const char *file)
+ MAYBE_UNUSED;
+ size_t size = b->size;
+ if(size<min) {
+ size+=size/2+1;
+ if(size<min) size=min;
+ b->ptr=srealloc(b->ptr,size,file);
+static void buffer_free(buffer *b) MAYBE_UNUSED;
+static void buffer_free(buffer *b) { free(b->ptr); }
+#define buffer_init(b,size) buffer_init_(b,size,__FILE__)
+#define buffer_reserve(b,min) buffer_reserve_(b,min,__FILE__)
+/ from minmax.h
+ Min, Max, Norm
+#ifdef __GNUC__
+#else
+#endif
+#define DECLMINMAX(type, prefix) \
+ static type prefix##min_2(type a, type b) MAYBE_UNUSED; \
+ static type prefix##min_2(type a, type b) { \
+ return b<a?b:a; \
+ static type prefix##max_2(type a, type b) MAYBE_UNUSED; \
+ static type prefix##max_2(type a, type b) { \
+ return a>b?a:b; \
+ static void prefix##minmax_2(type *min, type *max, type a, \
+ type b) MAYBE_UNUSED; \
+ static void prefix##minmax_2(type *min, type *max, type a, type b) { \
+ if(b<a) *min=b, *max=a; \
+ else *min=a, *max=b; \
+ static type prefix##min_3(type a, type b, type c) MAYBE_UNUSED; \
+ static type prefix##min_3(type a, type b, type c) { \
+ return b<a?(c<b?c:b):(c<a?c:a); \
+ static type prefix##max_3(type a, type b, type c) MAYBE_UNUSED; \
+ static type prefix##max_3(type a, type b, type c) { \
+ return a>b?(a>c?a:c):(b>c?b:c); \
+ static void prefix##minmax_3(type *min, type *max, type a, type b, \
+ type c) MAYBE_UNUSED; \
+ type c) { \
+ if(b<a) *min=prefix##min_2(b,c), *max=prefix##max_2(a,c); \
+ else *min=prefix##min_2(a,c), *max=prefix##max_2(b,c); \
+DECLMINMAX(int, i)
+DECLMINMAX(unsigned, u)
+DECLMINMAX(real, r)
+#undef DECLMINMAX
+static real r1norm_1(real a) MAYBE_UNUSED;
+static real r1norm_1(real a) {
+ return fabsr(a);
+static real r1norm_2(real a, real b) MAYBE_UNUSED;
+static real r1norm_2(real a, real b) {
+ return fabsr(a)+fabsr(b);
+static real r1norm_3(real a, real b, real c) MAYBE_UNUSED;
+static real r1norm_3(real a, real b, real c) {
+ return fabsr(a)+fabsr(b)+fabsr(c);
+static real r2norm_1(real a) MAYBE_UNUSED;
+static real r2norm_1(real a) {
+ return sqrtr(a*a);
+static real r2norm_2(real a, real b) MAYBE_UNUSED;
+static real r2norm_2(real a, real b) {
+ return sqrtr(a*a+b*b);
+static real r2norm_3(real a, real b, real c) MAYBE_UNUSED;
+static real r2norm_3(real a, real b, real c) {
+ return sqrtr(a*a+b*b+c*c);
+#endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
