[MOAB-dev] commit/MOAB: tautges: Getting rid of all the individual .h files in src/moab/point_locator/lotte/
commits-noreply at bitbucket.org
Thu Sep 12 11:33:20 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/96041dbdbb25/
Changeset: 96041dbdbb25
Branch: master
User: tautges
Date: 2013-09-12 18:33:01
Summary: Getting rid of all the individual .h files in src/moab/point_locator/lotte/
(i.e. types.h, findpt.h, etc), putting them in a new FindPtFuncs.h, and updating all the
associated uses of those headers.
Passes tests on debug, optimized, and parallel builds.
Affected #: 20 files
diff --git a/src/Makefile.am b/src/Makefile.am
index 6c4b890..28ef5c2 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -74,16 +74,10 @@ libMOAB_la_SOURCES = \
OrientedBox.cpp \
OrientedBox.hpp \
OrientedBoxTreeTool.cpp \
- moab/point_locater/lotte/minmax.h \
- moab/point_locater/lotte/extrafindpt.h \
lotte/poly.c \
- moab/point_locater/lotte/poly.h \
lotte/findpt.c \
- moab/point_locater/lotte/findpt.h \
lotte/errmem.c \
- moab/point_locater/lotte/errmem.h \
lotte/tensor.c \
- moab/point_locater/lotte/tensor.h \
PolyElementSeq.cpp \
PolyElementSeq.hpp \
ProgOptions.cpp \
@@ -173,10 +167,6 @@ nobase_libMOAB_la_include_HEADERS = \
moab/point_locater/element_maps/linear_tet_map.hpp \
moab/point_locater/element_maps/spectral_hex_map.hpp \
moab/point_locater/element_maps/quadratic_hex_map.hpp \
- moab/point_locater/lotte/types.h \
moab/point_locater/point_locater.hpp \
moab/point_locater/parametrizer.hpp \
moab/Matrix3.hpp \
diff --git a/src/lotte/errmem.c b/src/lotte/errmem.c
index 0196d83..b890bce 100644
--- a/src/lotte/errmem.c
+++ b/src/lotte/errmem.c
@@ -1,6 +1,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
+#include "moab/FindPtFuncs.h"
void fail(const char *fmt, ...)
diff --git a/src/lotte/findpt.c b/src/lotte/findpt.c
index 00fe8b7..160c7ab 100644
--- a/src/lotte/findpt.c
+++ b/src/lotte/findpt.c
@@ -5,12 +5,10 @@
#include <float.h>
#include <string.h> /* for memcpy */
-#include "errmem.h"
-#include "types.h"
-#include "minmax.h"
-#include "poly.h"
-#include "tensor.h"
-#include "extrafindpt.h"
+const unsigned opt_no_constraints_2 = 3+1;
+const unsigned opt_no_constraints_3 = 9+3+1;
Lobatto Polynomial Bounds
@@ -484,14 +482,6 @@ static void obbox_free_3(obbox_data_3 *p)
free(p);
-typedef struct {
- real x[2], A[4], axis_bnd[4];
-} obbox_2;
-typedef struct {
- real x[3], A[9], axis_bnd[6];
-} obbox_3;
int obbox_axis_test_2(const obbox_2 *p, const real x[2])
return (x[0]<p->axis_bnd[0] || x[0]>p->axis_bnd[1] ||
@@ -767,34 +757,6 @@ void obbox_calc_3(const obbox_data_3 *p, real tol,
-typedef struct {
- unsigned hash_n;
- real bnd[4]; /* bounds for all elements */
- real fac[2]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
- obbox_2 *obb; /* obb[nel] -- bounding box info for each element */
- uint *offset; /* hash table -- for cell i,j:
- uint index = j*hash_n+i,
- b = offset[index ],
- e = offset[index+1];
- elements in cell are
- offset[b], offset[b+1], ..., offset[e-1] */
- unsigned max; /* maximum # of elements in any cell */
-} hash_data_2;
-typedef struct {
- unsigned hash_n;
- real bnd[6]; /* bounds for all elements */
- real fac[3]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
- obbox_3 *obb; /* obb[nel] -- bounding box info for each element */
- uint *offset; /* hash table -- for cell i,j,k:
- uint index = (k*hash_n+j)*hash_n+i,
-} hash_data_3;
static int ifloor(real x)
@@ -1885,12 +1847,6 @@ double opt_findpt_2(opt_data_2 *p, const real *const elx[2],
-typedef struct {
- uint el;
- real r[3];
- real dist;
-} findpt_listel;
/* heap sort on A[0:n-1] with key A[i]->dist
precondition: n!=0 */
static void findpt_list_sort(findpt_listel **A, unsigned n)
@@ -1925,34 +1881,6 @@ static void findpt_list_sort(findpt_listel **A, unsigned n)
-typedef struct {
- const real *xw[2]; /* geometry data */
- real *z[2]; /* lobatto nodes */
- lagrange_data ld[2]; /* interpolation, derivative weights & data */
- unsigned nptel; /* nodes per element */
- hash_data_2 *hash; /* geometric hashing data */
- findpt_listel *list, **sorted, **end; /* pre-allocated list of elements to
- check (found by hashing), and
- pre-allocated list of pointers into
- the first list for sorting */
- opt_data_2 *od; /* data for the optimization algorithm */
- real *od_work;
-} findpt_data_2;
-typedef struct {
- const real *xw[3]; /* geometry data */
- real *z[3]; /* lobatto nodes */
- lagrange_data ld[3]; /* interpolation, derivative weights & data */
- hash_data_3 *hash; /* geometric hashing data */
- opt_data_3 *od; /* data for the optimization algorithm */
- real *od_work;
-} findpt_data_3;
findpt_data_2 *findpt_setup_2(
const real *const xw[2], const unsigned n[2], uint nel,
uint max_hash_size, real bbox_tol)
diff --git a/src/lotte/poly.c b/src/lotte/poly.c
index 6b5cba6..b8a93b7 100644
--- a/src/lotte/poly.c
+++ b/src/lotte/poly.c
@@ -5,8 +5,7 @@
#include <float.h>
-#include "types.h"
For brevity's sake, some names have been shortened
@@ -354,15 +353,6 @@ void lagrange_weights_deriv(const real *z, unsigned n,
lagrange_free(&p); // deallocate memory allocated by setup
-typedef struct {
- unsigned n; /* number of Lagrange nodes */
- const real *z; /* Lagrange nodes (user-supplied) */
- real *J, *D, *D2; /* weights for 0th,1st,2nd derivatives */
- real *J_z0, *D_z0, *D2_z0; /* ditto at z[0] (computed at setup) */
- real *J_zn, *D_zn, *D2_zn; /* ditto at z[n-1] (computed at setup) */
- real *w, *d, *u0, *v0, *u1, *v1, *u2, *v2; /* work data */
-} lagrange_data;
void lagrange_0(lagrange_data *p, real x)
unsigned i, n=p->n;
diff --git a/src/lotte/tensor.c b/src/lotte/tensor.c
index 19e54b7..510dc38 100644
--- a/src/lotte/tensor.c
+++ b/src/lotte/tensor.c
@@ -1,4 +1,4 @@
-#include "types.h"
Matrix-Matrix Multiplication
diff --git a/src/moab/point_locater/element_maps/spectral_hex_map.hpp b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
index 11bd573..895bc36 100644
--- a/src/moab/point_locater/element_maps/spectral_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
@@ -3,14 +3,7 @@
#include "moab/Matrix3.hpp"
#include "moab/CartVect.hpp"
-extern "C"{
- #include "moab/point_locater/lotte/types.h"
- #include "moab/point_locater/lotte/poly.h"
- #include "moab/point_locater/lotte/tensor.h"
- #include "moab/point_locater/lotte/findpt.h"
- #include "moab/point_locater/lotte/extrafindpt.h"
- #include "moab/point_locater/lotte/errmem.h"
#include <sstream>
#include <iomanip>
#include <iostream>
diff --git a/src/moab/point_locater/lotte/errmem.h b/src/moab/point_locater/lotte/errmem.h
deleted file mode 100644
index d881f4a..0000000
--- a/src/moab/point_locater/lotte/errmem.h
+++ /dev/null
@@ -1,85 +0,0 @@
-#ifndef ERRMEM_H
-#define ERRMEM_H
-/* requires:
- <stdlib.h> for malloc, calloc, realloc, free
- Error Reporting
- Memory Allocation Wrappers to Catch Out-of-memory
-/* #include "malloc.h" */
-#include <stdlib.h>
-#ifdef __GNUC__
-void fail(const char *fmt, ...) __attribute__ ((noreturn));
-#define MAYBE_UNUSED __attribute__ ((unused))
-#else
-void fail(const char *fmt, ...);
-#endif
-#if 0
-#endif
-static void *smalloc(size_t size, const char *file) MAYBE_UNUSED;
- void *res = malloc(size);
- if(!res && size) fail("%s: allocation of %d bytes failed\n",file,(int)size);
- return res;
-static void *scalloc(size_t nmemb, size_t size, const char *file) MAYBE_UNUSED;
- void *res = calloc(nmemb, size);
- if(!res && nmemb)
- fail("%s: allocation of %d bytes failed\n",file,(int)size*nmemb);
- return res;
-static void *srealloc(void *ptr, size_t size, const char *file) MAYBE_UNUSED;
- void *res = realloc(ptr, size);
- return res;
-#define tmalloc(type, count) \
- ((type*) smalloc((count)*sizeof(type),__FILE__) )
-#define tcalloc(type, count) \
- ((type*) scalloc((count),sizeof(type),__FILE__) )
-#define trealloc(type, ptr, count) \
- ((type*) srealloc((ptr),(count)*sizeof(type),__FILE__) )
-typedef struct { size_t size; void *ptr; } buffer;
-static void buffer_init_(buffer *b, size_t size, const char *file) MAYBE_UNUSED;
- b->size=size, b->ptr=smalloc(size,file);
-static void buffer_reserve_(buffer *b, size_t min, const char *file)
- MAYBE_UNUSED;
- size_t size = b->size;
- if(size<min) {
- size+=size/2+1;
- if(size<min) size=min;
- b->ptr=srealloc(b->ptr,size,file);
-static void buffer_free(buffer *b) MAYBE_UNUSED;
-static void buffer_free(buffer *b) { free(b->ptr); }
-#define buffer_init(b,size) buffer_init_(b,size,__FILE__)
-#define buffer_reserve(b,min) buffer_reserve_(b,min,__FILE__)
-#endif
diff --git a/src/moab/point_locater/lotte/extrafindpt.h b/src/moab/point_locater/lotte/extrafindpt.h
index 38aa1a1..0000000
--- a/src/moab/point_locater/lotte/extrafindpt.h
+++ /dev/null
@@ -1,77 +0,0 @@
-#ifndef EXTRA_FINDPT_H
-#define EXTRA_FINDPT_H
-/* extra stuff that james didn't expose */
-typedef struct {
- unsigned constraints;
- unsigned dn, d1, d2;
- real *x[3], *fdn[3];
-} opt_face_data_3;
-typedef struct {
- unsigned de, d1, d2;
- real *x[3], *fd1[3], *fd2[3];
-} opt_edge_data_3;
-typedef struct {
- real x[3], jac[9];
-} opt_point_data_3;
-typedef struct {
- lagrange_data *ld;
- unsigned size[4];
- const real *elx[3];
- opt_face_data_3 fd;
- opt_edge_data_3 ed;
- opt_point_data_3 pd;
- real *work;
-} opt_data_3;
-void opt_alloc_3(opt_data_3 *p, lagrange_data *ld);
-void opt_free_3(opt_data_3 *p);
-double opt_findpt_3(opt_data_3 *p, const real *const elx[3],
- const real xstar[3], real r[3], unsigned *constr);
-void opt_vol_set_intp_3(opt_data_3 *p, const real r[3]);
-const unsigned opt_no_constraints_2 = 3+1;
-const unsigned opt_no_constraints_3 = 9+3+1;
-/* for 2d spectralQuad */
- 2 - D
-typedef struct {
- unsigned de, d1;
- real *x[2], *fd1[2];
-} opt_edge_data_2;
-typedef struct {
- real x[2], jac[4];
-} opt_point_data_2;
-typedef struct {
- unsigned size[3];
- const real *elx[2];
- opt_edge_data_2 ed;
- opt_point_data_2 pd;
- real *work;
-} opt_data_2;
-void opt_alloc_2(opt_data_2 *p, lagrange_data *ld);
-void opt_free_2(opt_data_2 *p);
-double opt_findpt_2(opt_data_2 *p, const real *const elx[2],
- const real xstar[2], real r[2], unsigned *constr);
-#endif /*EXTRA_FINDPT_H */
diff --git a/src/moab/point_locater/lotte/findpt.h b/src/moab/point_locater/lotte/findpt.h
index 477e49e..0000000
--- a/src/moab/point_locater/lotte/findpt.h
+++ /dev/null
@@ -1,67 +0,0 @@
-#ifndef FINDPT_H
-#define FINDPT_H
-/* requires "types.h", "poly.h", "tensor.h" */
-#if !defined(TYPES_H) || !defined(POLY_H) || !defined(TENSOR_H)
-#warning "findpt.h" requires "types.h", "poly.h", "tensor.h"
-#endif
-typedef struct {
- struct findpt_hash_data_2 *hash; /* geometric hashing data */
- struct findpt_listel *list, **sorted, **end;
- /* pre-allocated list of elements to
- struct findpt_opt_data_2 *od; /* data for the optimization algorithm */
- real *od_work;
-} findpt_data_2;
-typedef struct {
- struct findpt_hash_data_3 *hash; /* geometric hashing data */
- struct findpt_opt_data_3 *od; /* data for the optimization algorithm */
- real *od_work;
-} findpt_data_3;
-findpt_data_2 *findpt_setup_2(
- const real *const xw[2], const unsigned n[2], uint nel,
- uint max_hash_size, real bbox_tol);
-findpt_data_3 *findpt_setup_3(
- const real *const xw[3], const unsigned n[3], uint nel,
-void findpt_free_2(findpt_data_2 *p);
-void findpt_free_3(findpt_data_3 *p);
-const real *findpt_allbnd_2(const findpt_data_2 *p);
-const real *findpt_allbnd_3(const findpt_data_3 *p);
-typedef int (*findpt_func)(void *, const real *, int, uint *, real *, real *);
-int findpt_2(findpt_data_2 *p, const real x[2], int guess,
- uint *el, real r[2], real *dist);
-int findpt_3(findpt_data_3 *p, const real x[3], int guess,
- uint *el, real r[3], real *dist);
-void findpt_weights_2(findpt_data_2 *p, const real r[2]) ;
-void findpt_weights_3(findpt_data_3 *p, const real r[3]);
-double findpt_eval_2(findpt_data_2 *p, const real *u);
-double findpt_eval_3(findpt_data_3 *p, const real *u);
-#endif
diff --git a/src/moab/point_locater/lotte/minmax.h b/src/moab/point_locater/lotte/minmax.h
index 9fb5ed1..0000000
--- a/src/moab/point_locater/lotte/minmax.h
+++ /dev/null
@@ -1,82 +0,0 @@
-#ifndef MINMAX_H
-#define MINMAX_H
-/* requires <math.h> and "types.h" */
-#ifndef TYPES_H
-#warning "minmax.h" depends on "types.h"
-#endif
- Min, Max, Norm
-#ifdef __GNUC__
-#else
-#endif
-#define DECLMINMAX(type, prefix) \
- static type prefix##min_2(type a, type b) MAYBE_UNUSED; \
- static type prefix##min_2(type a, type b) { \
- return b<a?b:a; \
- static type prefix##max_2(type a, type b) MAYBE_UNUSED; \
- static type prefix##max_2(type a, type b) { \
- return a>b?a:b; \
- static void prefix##minmax_2(type *min, type *max, type a, \
- type b) MAYBE_UNUSED; \
- static void prefix##minmax_2(type *min, type *max, type a, type b) { \
- if(b<a) *min=b, *max=a; \
- else *min=a, *max=b; \
- static type prefix##min_3(type a, type b, type c) MAYBE_UNUSED; \
- static type prefix##min_3(type a, type b, type c) { \
- return b<a?(c<b?c:b):(c<a?c:a); \
- static type prefix##max_3(type a, type b, type c) MAYBE_UNUSED; \
- static type prefix##max_3(type a, type b, type c) { \
- return a>b?(a>c?a:c):(b>c?b:c); \
- static void prefix##minmax_3(type *min, type *max, type a, type b, \
- type c) MAYBE_UNUSED; \
- type c) { \
- if(b<a) *min=prefix##min_2(b,c), *max=prefix##max_2(a,c); \
- else *min=prefix##min_2(a,c), *max=prefix##max_2(b,c); \
-DECLMINMAX(int, i)
-DECLMINMAX(unsigned, u)
-DECLMINMAX(real, r)
-#undef DECLMINMAX
-static real r1norm_1(real a) MAYBE_UNUSED;
-static real r1norm_1(real a) {
- return fabsr(a);
-static real r1norm_2(real a, real b) MAYBE_UNUSED;
-static real r1norm_2(real a, real b) {
- return fabsr(a)+fabsr(b);
-static real r1norm_3(real a, real b, real c) MAYBE_UNUSED;
-static real r1norm_3(real a, real b, real c) {
- return fabsr(a)+fabsr(b)+fabsr(c);
-static real r2norm_1(real a) MAYBE_UNUSED;
-static real r2norm_1(real a) {
- return sqrtr(a*a);
-static real r2norm_2(real a, real b) MAYBE_UNUSED;
-static real r2norm_2(real a, real b) {
- return sqrtr(a*a+b*b);
-static real r2norm_3(real a, real b, real c) MAYBE_UNUSED;
-static real r2norm_3(real a, real b, real c) {
- return sqrtr(a*a+b*b+c*c);
-#endif
diff --git a/src/moab/point_locater/lotte/poly.h b/src/moab/point_locater/lotte/poly.h
index ef3bf6c..0000000
--- a/src/moab/point_locater/lotte/poly.h
+++ /dev/null
@@ -1,155 +0,0 @@
-#ifndef POLY_H
-#define POLY_H
-/* requires "types.h" */
-#ifndef TYPES_H
-#warning "poly.h" requires "types.h"
-#endif
- For brevity's sake, some names have been shortened
- Quadrature rules
- Gauss -> Gauss-Legendre quadrature (open)
- Lobatto -> Gauss-Lobatto-Legendre quadrature (closed at both ends)
- Polynomial bases
- Legendre -> Legendre basis
- Gauss -> Lagrangian basis using Gauss quadrature nodes
- Lobatto -> Lagrangian basis using Lobatto quadrature nodes
- Legendre Polynomial Matrix Computation
- (compute P_i(x_j) for i = 0, ..., n and a given set of x)
-/* precondition: n >= 1
- inner index is x index (0 ... m-1);
- outer index is Legendre polynomial number (0 ... n)
-void legendre_matrix(const real *x, int m, real *P, int n);
- inner index is Legendre polynomial number (0 ... n)
- outer index is x index (0 ... m-1);
-void legendre_matrix_t(const real *x, int m, real *P, int n);
- compute P_i(x) with i = 0 ... n
-void legendre_row(real x, real *P, int n);
- Quadrature Nodes and Weights Calculation
- call the _nodes function before calling the _weights function
-void gauss_nodes(real *z, int n); /* n nodes (order = 2n-1) */
-void lobatto_nodes(real *z, int n); /* n nodes (order = 2n-3) */
-void gauss_weights(const real *z, real *w, int n);
-void lobatto_weights(const real *z, real *w, int n);
- Lagrangian to Legendre Change-of-basis Matrix
-/* precondition: n >= 2
- given the Gauss quadrature rule (z,w,n), compute the square matrix J
- for transforming from the Gauss basis to the Legendre basis:
- u_legendre(i) = sum_j J(i,j) u_gauss(j)
- computes J = .5 (2i+1) w P (z )
- ij j i j
- in column major format (inner index is i, the Legendre index)
-void gauss_to_legendre(const real *z, const real *w, int n, real *J);
- same as above, but
- in row major format (inner index is j, the Gauss index)
-void gauss_to_legendre_t(const real *z, const real *w, int n, real *J);
-/* precondition: n >= 3
- given the Lobatto quadrature rule (z,w,n), compute the square matrix J
- for transforming from the Lobatto basis to the Legendre basis:
- u_legendre(i) = sum_j J(i,j) u_lobatto(j)
-void lobatto_to_legendre(const real *z, const real *w, int n, real *J);
- Lagrangian basis function evaluation
-/* given the Lagrangian nodes (z,n) and evaluation points (x,m)
- evaluate all Lagrangian basis functions at all points x
- inner index of output J is the basis function index (row-major format)
- provide work array with space for 4*n doubles
-void lagrange_weights(const real *z, unsigned n,
- const real *x, unsigned m,
- real *J, real *work);
- evaluate all Lagrangian basis functions and their derivatives
- inner index of outputs J,D is the basis function index (row-major format)
- provide work array with space for 6*n doubles
-void lagrange_weights_deriv(const real *z, unsigned n,
- real *J, real *D, real *work);
- Speedy Lagrangian Interpolation
- Usage:
- lagrange_data p;
- lagrange_setup(&p,z,n); * setup for nodes z[0 ... n-1] *
- the weights
- p->J [0 ... n-1] interpolation weights
- p->D [0 ... n-1] 1st derivative weights
- p->D2[0 ... n-1] 2nd derivative weights
- are computed for a given x with:
- lagrange_0(p,x); * compute p->J *
- lagrange_1(p,x); * compute p->J, p->D *
- lagrange_2(p,x); * compute p->J, p->D, p->D2 *
- lagrange_2u(p); * compute p->D2 after call of lagrange_1(p,x); *
- These functions use the z array supplied to setup
- (that pointer should not be freed between calls)
- Weights for x=z[0] and x=z[n-1] are computed during setup; access as:
- p->J_z0, etc. and p->J_zn, etc.
- lagrange_free(&p); * deallocate memory allocated by setup *
-typedef struct {
-} lagrange_data;
-void lagrange_setup(lagrange_data *p, const real *z, unsigned n);
-void lagrange_free(lagrange_data *p);
-void lagrange_0(lagrange_data *p, real x) ;
-void lagrange_1(lagrange_data *p, real x) ;
-void lagrange_2(lagrange_data *p, real x) ;
-void lagrange_2u(lagrange_data *p) ;
-#endif
diff --git a/src/moab/point_locater/lotte/tensor.h b/src/moab/point_locater/lotte/tensor.h
index c5dd010..0000000
--- a/src/moab/point_locater/lotte/tensor.h
+++ /dev/null
@@ -1,102 +0,0 @@
-#ifndef TENSOR_H
-#define TENSOR_H
-#ifndef TYPES_H
-#warning "tensor.h" requires "types.h"
-#endif
- 1-,2-,3-d Tensor Application
- the 3d case:
- tensor_f3(R,mr,nr, S,ms,ns, T,mt,nt, u,v, work1,work2)
- gives v = [ R (x) S (x) T ] u
- where R is mr x nr, S is ms x ns, T is mt x nt,
- each in row- or column-major format according to f := r | c
- u is nr x ns x nt in column-major format (inner index is r)
- v is mr x ms x mt in column-major format (inner index is r)
-void tensor_c1(const real *R, unsigned mr, unsigned nr,
- const real *u, real *v);
-void tensor_r1(const real *R, unsigned mr, unsigned nr,
-/* work holds mr*ns reals */
-void tensor_c2(const real *R, unsigned mr, unsigned nr,
- const real *S, unsigned ms, unsigned ns,
- const real *u, real *v, real *work);
-void tensor_r2(const real *R, unsigned mr, unsigned nr,
-/* work1 holds mr*ns*nt reals,
- work2 holds mr*ms*nt reals */
-void tensor_c3(const real *R, unsigned mr, unsigned nr,
- const real *T, unsigned mt, unsigned nt,
- const real *u, real *v, real *work1, real *work2);
-void tensor_r3(const real *R, unsigned mr, unsigned nr,
- 1-,2-,3-d Tensor Application of Row Vectors (for Interpolation)
- the 3d case:
- v = tensor_i3(Jr,nr, Js,ns, Jt,nt, u, work)
- same effect as tensor_r3(Jr,1,nr, Js,1,ns, Jt,1,nt, u,&v, work1,work2):
- gives v = [ Jr (x) Js (x) Jt ] u
- where Jr, Js, Jt are row vectors (interpolation weights)
- v is a scalar
-real tensor_i1(const real *Jr, unsigned nr, const real *u);
-/* work holds ns reals */
-real tensor_i2(const real *Jr, unsigned nr,
- const real *Js, unsigned ns,
- const real *u, real *work);
-/* work holds ns*nt + nt reals */
-real tensor_i3(const real *Jr, unsigned nr,
- const real *Jt, unsigned nt,
- for simultaneous Interpolation and Gradient computation
- the 3d case:
- v = tensor_ig3(Jr,Dr,nr, Js,Ds,ns, Jt,Dt,nt, u,g, work)
- g_0 = [ Dr (x) Js (x) Jt ] u
- g_1 = [ Jr (x) Ds (x) Jt ] u
- g_2 = [ Jr (x) Js (x) Dt ] u
- where Jr,Dr,Js,Ds,Jt,Dt are row vectors
- (interpolation & derivative weights)
- v is a scalar, g is an array of 3 reals
-real tensor_ig1(const real *Jr, const real *Dr, unsigned nr,
- const real *u, real *g);
-/* work holds 2*ns reals */
-real tensor_ig2(const real *Jr, const real *Dr, unsigned nr,
- const real *Js, const real *Ds, unsigned ns,
- const real *u, real *g, real *work);
-/* work holds 2*ns*nt + 3*ns reals */
-real tensor_ig3(const real *Jr, const real *Dr, unsigned nr,
- const real *Jt, const real *Dt, unsigned nt,
-#endif
diff --git a/src/moab/point_locater/lotte/types.h b/src/moab/point_locater/lotte/types.h
index c17018e..0000000
--- a/src/moab/point_locater/lotte/types.h
+++ /dev/null
@@ -1,77 +0,0 @@
-#ifndef TYPES_H
-#define TYPES_H
-#include "float.h"
-/* integer type to use for everything */
-#if defined(USE_LONG)
-# define INTEGER long
-#elif defined(USE_LONG_LONG)
-# define INTEGER long long
-#elif defined(USE_SHORT)
-# define INTEGER short
-#else
-# define INTEGER int
-#endif
-/* when defined, use the given type for global indices instead of INTEGER */
-#if defined(USE_GLOBAL_LONG_LONG)
-# define GLOBAL_INT long long
-#elif defined(USE_GLOBAL_LONG)
-#else
-#endif
-/* floating point type to use for everything */
-#if defined(USE_FLOAT)
- typedef float real;
-# define floorr floorf
-# define ceilr ceilf
-# define sqrtr sqrtf
-# define fabsr fabsf
-# define cosr cosf
-# define sinr sinf
-# define EPS (128*FLT_EPSILON)
-# define PI 3.1415926535897932384626433832795028841971693993751058209749445923F
-#elif defined(USE_LONG_DOUBLE)
- typedef long double real;
-# define floorr floorl
-# define ceilr ceill
-# define sqrtr sqrtl
-# define fabsr fabsl
-# define cosr cosl
-# define sinr sinl
-# define EPS (128*LDBL_EPSILON)
-# define PI 3.1415926535897932384626433832795028841971693993751058209749445923L
-#else
- typedef double real;
-# define cosr cos
-# define sinr sin
-# define EPS (128*DBL_EPSILON)
-#endif
-/* apparently uint and ulong can be defined already in standard headers */
-#define uint uint_
-#define ulong ulong_
-#define sint sint_
-#define slong slong_
-typedef signed INTEGER sint;
-typedef unsigned INTEGER uint;
-#undef INTEGER
-#ifdef GLOBAL_INT
- typedef signed GLOBAL_INT slong;
- typedef unsigned GLOBAL_INT ulong;
-#else
- typedef sint slong;
- typedef uint ulong;
-#endif
-#endif
diff --git a/test/scdtest2.cpp b/test/scdtest2.cpp
new file mode 100644
index 0000000..e744746
--- /dev/null
+++ b/test/scdtest2.cpp
@@ -0,0 +1,80 @@
+#include "moab/ScdInterface.hpp"
+#include "moab/Core.hpp"
+#include "TestUtil.hpp"
+#include <iostream>
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#endif
+using namespace moab;
+void test_john()
+ Core moab;
+ ScdInterface *scd;
+ ErrorCode rval = moab.Interface::query_interface(scd);
+ CHECK_ERR(rval);
+ int gdims[] = {0, 0, 0, 48, 40, 0};
+ int ldims[6];
+ std::cout << "x dims are " << gdims[3] << "\n";
+ std::cout << "y dims are " << gdims[4] << "\n";
+#ifdef USE_MPI
+ ParallelComm pcomm(&moab, MPI_COMM_WORLD);
+ int procs = pcomm.proc_config().proc_size(),
+ rank = pcomm.proc_config().proc_rank();
+ ScdParData pardata;
+ std::copy(gdims, gdims+6, pardata.gDims);
+ pardata.gPeriodic[0] = pardata.gPeriodic[1] = 0;
+ pardata.partMethod = ScdParData::SQIJ;
+ int pDims[2];
+ rval = ScdInterface::compute_partition(procs, rank, pardata, ldims, NULL, pDims); CHECK_ERR(rval);
+ std::cout << "processors in x are " << pDims[0] << "\n";
+ std::cout << "processors in y are " << pDims[1] << "\n";
+#else
+ std::copy(gdims, gdims+6, ldims);
+#endif
+ std::cout << "local dims are "
+ << ldims[0] << " " << ldims[1] << " " << ldims[2] << " "
+ << ldims[3] << " " << ldims[4] << " " << ldims[5] << "\n";
+ ScdBox* box;
+#ifdef USE_MPI
+ rval = scd->construct_box(HomCoord(ldims, 3), HomCoord(ldims+3, 3), NULL, 0, box, NULL, &pardata); CHECK_ERR(rval);
+ rval = pcomm.resolve_shared_ents(0); CHECK_ERR(rval);
+#else
+ rval = scd->construct_box(HomCoord(ldims, 3), HomCoord(ldims+3, 3), NULL, 0, box); CHECK_ERR(rval);
+#endif
+ moab.list_entities(0,0);
+ std::vector<EntityHandle> conn;
+ Range quads, verts;
+ rval = moab.get_entities_by_type(0, MBQUAD, quads); CHECK_ERR(rval);
+ rval = moab.get_adjacencies(quads, 0, false, verts, Interface::UNION); CHECK_ERR(rval);
+ Tag gid_tag;
+ rval = moab.tag_get_handle("GLOBAL_ID", gid_tag); CHECK_ERR(rval);
+ int *qgids, *vgids, count;
+ rval = moab.tag_iterate(gid_tag, quads.begin(), quads.end(), count, (void*&)qgids);
+ CHECK_ERR(rval); CHECK_EQUAL(count, (int)quads.size());
+ rval = moab.tag_iterate(gid_tag, verts.begin(), verts.end(), count, (void*&)vgids);
+ CHECK_ERR(rval); CHECK_EQUAL(count, (int)verts.size());
+ for (Range::iterator rit = quads.begin(); rit != quads.end(); rit++) {
+ rval = moab.get_connectivity(&(*rit), 1, conn); CHECK_ERR(rval);
+ std::cout << "Connectivity array for quad " << qgids[*rit-*quads.begin()] << " is: ";
+ for (int i = 0; i < 4; i++) std::cout << vgids[conn[i]-*verts.begin()] << " ";
+ std::cout << std::endl;
+int main(int, char**)
+ // test partition methods
+ RUN_TEST(test_john);
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index 7f9a3f6..223991c 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -10,11 +10,6 @@
#include <stdio.h>
#include <algorithm>
-//extern "C"
- //#include "minmax.h"
#include "assert.h"
#define ERROR(a) {if (iBase_SUCCESS != err) std::cerr << a << std::endl;}
diff --git a/tools/mbcoupler/ElemUtil.cpp b/tools/mbcoupler/ElemUtil.cpp
index c0010d0..873cc44 100644
--- a/tools/mbcoupler/ElemUtil.cpp
+++ b/tools/mbcoupler/ElemUtil.cpp
@@ -3,7 +3,6 @@
#include <assert.h>
#include "ElemUtil.hpp"
-#include "types.h"
namespace moab {
namespace ElemUtil {
diff --git a/tools/mbcoupler/ElemUtil.hpp b/tools/mbcoupler/ElemUtil.hpp
index a3f9a1c..9b4bf9a 100644
--- a/tools/mbcoupler/ElemUtil.hpp
+++ b/tools/mbcoupler/ElemUtil.hpp
@@ -7,13 +7,9 @@
// to access data structures for spectral elements
-extern "C"{
-#include "moab/point_locater/lotte/types.h"
-#include "moab/point_locater/lotte/poly.h"
-#include "moab/point_locater/lotte/tensor.h"
-//#include "findpt.h"
-#include "moab/point_locater/lotte/extrafindpt.h"
-#include "moab/point_locater/lotte/errmem.h"
+extern "C"
namespace moab {
diff --git a/tools/mbcoupler/findpt_test.cpp b/tools/mbcoupler/findpt_test.cpp
index 1322df5..2f884a7 100644
--- a/tools/mbcoupler/findpt_test.cpp
+++ b/tools/mbcoupler/findpt_test.cpp
@@ -6,8 +6,7 @@ using namespace moab;
using namespace ElemUtil;
extern "C"{
-#include "errmem.h" //for tmalloc, convenient but not C++
-#include "types.h"
diff --git a/tools/mbcoupler/ssn_test.cpp b/tools/mbcoupler/ssn_test.cpp
index 426c91e..21adf72 100644
--- a/tools/mbcoupler/ssn_test.cpp
+++ b/tools/mbcoupler/ssn_test.cpp
@@ -13,14 +13,10 @@
#include <sstream>
#include <cstring>
#include <cstdlib>
extern "C"
-#include "types.h"
#include "moab/TupleList.hpp"
#include "moab/gs.hpp"
#include "moab/Types.hpp"
diff --git a/tools/point_search.cpp b/tools/point_search.cpp
index 63b272e..97cfdf2 100644
--- a/tools/point_search.cpp
+++ b/tools/point_search.cpp
@@ -14,6 +14,11 @@
//Point Locater
+extern "C"
#include "moab/point_locater/point_locater.hpp"
#include "moab/point_locater/io.hpp"
#include "moab/point_locater/tree/element_tree.hpp"
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
