[MOAB-dev] commit/MOAB: tautges: Adding a CpuTimer class, originally implemented in WriteHDF5.
commits-noreply at bitbucket.org
Wed Sep 11 17:19:42 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fee72829b71b/
Changeset: fee72829b71b
Branch: master
User: tautges
Date: 2013-09-12 00:19:36
Summary: Adding a CpuTimer class, originally implemented in WriteHDF5.
Fixing the Makefile.am, which I'd forgotten to change when I moved FileOptions.hpp.
Passes serial & parallel tests.
Affected #: 3 files
diff --git a/src/Makefile.am b/src/Makefile.am
index 7cebb7c..6c4b890 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -57,7 +57,6 @@ libMOAB_la_SOURCES = \
Factory.cpp \
FBEngine.cpp \
FileOptions.cpp \
- FileOptions.hpp \
GeomUtil.cpp \
GeomTopoTool.cpp \
HigherOrderFactory.cpp \
@@ -152,6 +151,7 @@ nobase_libMOAB_la_include_HEADERS = \
moab/CartVect.hpp \
moab/Compiler.hpp \
moab/Core.hpp \
+ moab/CpuTimer.hpp \
moab/DualTool.hpp \
moab/Error.hpp \
moab/GeomTopoTool.hpp \
@@ -160,6 +160,7 @@ nobase_libMOAB_la_include_HEADERS = \
moab/EntityType.hpp \
moab/EntityHandle.hpp \
moab/FBEngine.hpp \
+ moab/FileOptions.hpp \
moab/Forward.hpp \
moab/GeomUtil.hpp \
moab/Interface.hpp \
diff --git a/src/io/WriteHDF5.cpp b/src/io/WriteHDF5.cpp
index f48399a..337cb96 100644
--- a/src/io/WriteHDF5.cpp
+++ b/src/io/WriteHDF5.cpp
@@ -50,15 +50,10 @@
#include "moab/CN.hpp"
#include "moab/FileOptions.hpp"
#include "moab/Version.h"
+#include "moab/CpuTimer.hpp"
#include "IODebugTrack.hpp"
#include "mhdf.h"
-#ifdef USE_MPI
-#define RUNTIME MPI_Wtime()
-#else
-#define RUNTIME (clock()/(double)CLOCKS_PER_SEC)
-#endif
/* Access HDF5 file handle for debugging
#include <H5Fpublic.h>
struct file { uint32_t magic; hid_t handle; };
@@ -100,15 +95,6 @@ struct file { uint32_t magic; hid_t handle; };
namespace moab {
-class CpuTimer {
-private:
- double atBirth, atLast;
-public:
- CpuTimer() : atBirth(RUNTIME), atLast(atBirth) {}
- double since_birth() { return (atLast = RUNTIME) - atBirth; };
- double elapsed() { double tmp = atLast; return (atLast = RUNTIME) - tmp; }
template <typename T> inline
void VALGRIND_MAKE_VEC_UNDEFINED( std::vector<T>& v ) {
VALGRIND_MAKE_MEM_UNDEFINED( &v[0], v.size() * sizeof(T) );
@@ -601,7 +587,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
topState.end(result);
CHK_MB_ERR_0(result);
- times[GATHER_TIME] = timer.elapsed();
+ times[GATHER_TIME] = timer.time_elapsed();
//if (nodeSet.range.size() == 0)
// return error(MB_ENTITY_NOT_FOUND);
@@ -650,7 +636,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
if (MB_SUCCESS != result)
return error(result);
- times[CREATE_TIME] = timer.elapsed();
+ times[CREATE_TIME] = timer.time_elapsed();
dbgOut.tprint(1,"Writing Nodes.\n");
// Write node coordinates
@@ -662,7 +648,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
- times[COORD_TIME] = timer.elapsed();
+ times[COORD_TIME] = timer.time_elapsed();
dbgOut.tprint(1,"Writing connectivity.\n");
@@ -674,7 +660,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
- times[CONN_TIME] = timer.elapsed();
+ times[CONN_TIME] = timer.time_elapsed();
dbgOut.tprint(1,"Writing sets.\n");
@@ -684,7 +670,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
debug_barrier();
- times[SET_TIME] = timer.elapsed();
+ times[SET_TIME] = timer.time_elapsed();
dbgOut.tprint(1,"Writing adjacencies.\n");
// Write adjacencies
@@ -701,7 +687,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
- times[ADJ_TIME] = timer.elapsed();
+ times[ADJ_TIME] = timer.time_elapsed();
dbgOut.tprint(1,"Writing tags.\n");
@@ -716,9 +702,9 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
- times[TAG_TIME] = timer.elapsed();
+ times[TAG_TIME] = timer.time_elapsed();
- times[TOTAL_TIME] = timer.since_birth();
+ times[TOTAL_TIME] = timer.time_since_birth();
if (cputime) {
print_times( times );
@@ -1374,7 +1360,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
mhdf_closeData( filePtr, table, &status );
CHK_MHDF_ERR_0(status);
- times[SET_PARENT] = timer.elapsed();
+ times[SET_PARENT] = timer.time_elapsed();
track.all_reduce();
@@ -1393,7 +1379,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
- times[SET_CHILD] = timer.elapsed();
+ times[SET_CHILD] = timer.time_elapsed();
track.all_reduce();
@@ -1415,7 +1401,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
- times[SET_CONTENT] = timer.elapsed();
+ times[SET_CONTENT] = timer.time_elapsed();
track.all_reduce();
assert( ranged_sets.size() + null_stripped_sets.size() == set_sizes.size() );
@@ -1544,7 +1530,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
- times[SET_META] = timer.elapsed();
+ times[SET_META] = timer.time_elapsed();
track_meta.all_reduce();
return MB_SUCCESS;
@@ -1881,7 +1867,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
if (array_len == MB_VARIABLE_LENGTH && tag_data.write_sparse) {
dbgOut.printf( 2, "Writing sparse data for var-len tag: \"%s\"\n", name.c_str() );
rval = write_var_len_tag( tag_data, name, moab_type, hdf5_type, elem_size );
- times[VARLEN_TAG_TIME] += timer.elapsed();
+ times[VARLEN_TAG_TIME] += timer.time_elapsed();
else {
int data_len = elem_size;
@@ -1890,7 +1876,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
if (tag_data.write_sparse) {
dbgOut.printf( 2, "Writing sparse data for tag: \"%s\"\n", name.c_str() );
rval = write_sparse_tag( tag_data, name, moab_type, hdf5_type, data_len );
- times[SPARSE_TAG_TIME] += timer.elapsed();
+ times[SPARSE_TAG_TIME] += timer.time_elapsed();
for (size_t i = 0; MB_SUCCESS == rval && i < tag_data.dense_list.size(); ++i) {
const ExportSet* set = find( tag_data.dense_list[i] );
@@ -1901,7 +1887,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
rval = write_dense_tag( tag_data, *set, name, moab_type, hdf5_type, data_len );
subState.end(rval);
- times[DENSE_TAG_TIME] += timer.elapsed();
+ times[DENSE_TAG_TIME] += timer.time_elapsed();
H5Tclose( hdf5_type );
diff --git a/src/moab/CpuTimer.hpp b/src/moab/CpuTimer.hpp
new file mode 100644
index 0000000..cdda903
--- /dev/null
+++ b/src/moab/CpuTimer.hpp
@@ -0,0 +1,63 @@
+#ifndef CPUTIMER_HPP
+#define CPUTIMER_HPP
+#ifdef USE_MPI
+# include "moab_mpi.h"
+#else
+# include <sys/resource.h>
+#endif
+namespace moab
+class CpuTimer {
+private:
+ double tAtBirth, tAtLast;
+ double mAtBirth, mAtLast;
+ long rssAtBirth, rssAtLast;
+ double runtime();
+ long runmem();
+public:
+ CpuTimer() : tAtBirth(runtime()), tAtLast(tAtBirth) {}
+ double time_since_birth() { return (tAtLast = runtime()) - tAtBirth; };
+ double time_elapsed() { double tmp = tAtLast; return (tAtLast = runtime()) - tmp; }
+ long mem_since_birth() {return (mAtLast=runmem()) - mAtBirth;}
+ long mem_elapsed() {long tmp = mAtLast; return (mAtLast=runmem()) - tmp;}
+ inline double CpuTimer::runtime()
+#if defined(_MSC_VER) || defined(__MINGW32__)
+ return (double)clock() / CLOCKS_PER_SEC;
+#elif defined(USE_MPI)
+ return MPI_Wtime();
+#else
+ struct rusage r_usage;
+ getrusage(RUSAGE_SELF, &r_usage);
+ double utime = (double)r_usage.ru_utime.tv_sec +
+ ((double)r_usage.ru_utime.tv_usec/1.e6);
+ double stime = (double)r_usage.ru_stime.tv_sec +
+ ((double)r_usage.ru_stime.tv_usec/1.e6);
+ return utime + stime;
+#endif
+ inline long CpuTimer::runmem()
+ return 0;
+ return 0;
+#else
+ mAtLast = r_usage.ru_maxrss;
+ return mAtLast;
+#endif
+#endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
