[MOAB-dev] Simple code to reproduce ICC segmentation fault
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Sep 10 14:15:14 CDT 2013
Hmm, I guess I'd still vote for using std::vector for statically-allocated arrays, rather than the alternative of
building -C into all our debug builds.  Thoughts?
- tim
On 09/10/2013 02:03 PM, Vijay S. Mahadevan wrote:
> You need to compile with -C to catch static allocation errors. That
> will specifically turn on range checks.
> Good to know that memcheck doesn't give you invalid read errors on
> statically allocated arrays. Look at faq:
> http://valgrind.org/docs/manual/faq.html
>> Why doesn't Memcheck find the array overruns in this program?
>> Unfortunately, Memcheck doesn't do bounds checking on global or stack arrays. We'd like to, but it's just not possible to do in a reasonable way that fits with how Memcheck works. Sorry.
>> However, the experimental tool SGcheck can detect errors like this. Run Valgrind with the --tool=exp-sgcheck option to try it, but be aware that it is not as robust as Memcheck.
> Vijay
> On Tue, Sep 10, 2013 at 1:51 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> Good catch Danqing, I didn't know that (that valgrind wouldn't catch out of
>> bounds errors on statically-allocated arrays).
>> The preferred way to do this, then, will be to use std::vector, with a
>> static size set at instantiation.  That makes it dynamically allocated but
>> still static size.  I'll remember that one.
>> - tim
>> On 09/10/2013 01:22 PM, Danqing Wu wrote:
>>> Here is what I found online:
>>> What Won't Valgrind Find?
>>> Valgrind doesn't perform bounds checking on static arrays (allocated on
>>> the stack). So if you declare an array inside your function:
>>> int main()
>>>       char x[10];
>>>       x[11] = 'a';
>>> then Valgrind won't alert you! One possible solution for testing purposes
>>> is simply to change your static arrays into dynamically allocated memory
>>> taken from the heap, where you will get bounds-checking, though this could
>>> be a mess of unfreed memory.
>>> ----- Original Message -----
>>> From: "Iulian Grindeanu" <iulian at mcs.anl.gov>
>>> To: "Danqing Wu" <wuda at mcs.anl.gov>
>>> Cc: "Tim Tautges" <tautges at mcs.anl.gov>
>>> Sent: Tuesday, September 10, 2013 1:02:45 PM
>>> Subject: Re: Simple code to reproduce ICC segmentation fault
>>> After correcting that, moab-intel test works fine!
>>> Good job again, Danqing!
>>> Thanks,
>>> Iulian
>>> now the question is why valgrind did not find this ...
>>> I think I found one possible reason.
>>> ErrorCode ScdInterface::get_neighbor_alljkbal(int np, int pfrom,
>>> const int * const gdims, const int * const gperiodic, const int * const
>>> dijk,
>>> int &pto, int *rdims, int *facedims, int *across_bdy)
>>> int ldims[6], pijk[3], lperiodic[2];
>>> ErrorCode rval = compute_partition_alljkbal(np, pfrom, gdims, gperiodic,
>>> ldims, lperiodic, pijk);
>>> Here lperiodic[2] should be lperiodic[3], as the third element will be
>>> accessed inside compute_partition_alljkbal().
>>> The behaviour could be dependent on compilers. Maybe only for ICC 12 and
>>> O2, and when assert is disabled, this out of memory issue causes a
>>> segmentation fault.
>>> I will retest after this fix.
>>> Sent: Tuesday, September 10, 2013 10:17:28 AM
>>> If it works on icc 13 / ubuntu 12, I suggest moving moab-intel build to
>>> jenkins; we may have to rebuild netcdf with icc if there are issues with
>>> libcurl.
>>> Any suggestions?
>>> Iulian
>>> On gnep, icc 12.
>>> Configure option
>>> ./configure --prefix=/homes/fathom/libs/current/moabintel
>>> --with-netcdf=/homes/fathom/3rdparty/netcdf-4.1.3-intel
>>> --with-hdf5=/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel
>>> --with-zlib=/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc --enable-igeom
>>> --enable-imesh CC=icc CXX=icpc F77=ifort FC=ifort F90=ifort
>>> So the flags will include both -O2 and -DNDEBUG
>>> Here since NDEBUG is enabled, all of the assert(...) will do nothing, and
>>> this could make some differences.
>>> On gnep, icc 12, if only -O2, but no NDEBUG, the original test can pass. I
>>> guess ICC 12 would be affected by the assert stuff.
>>> Sent: Tuesday, September 10, 2013 10:04:39 AM
>>> so this is with icc -O2 or what are the compile options?
>>> Is this on gnep? icc 12? icc 13?
>>> Should we try to use ubuntu 12 for intel builds?
>>> (we can do that on jenkins auto build platform)
>>> Iulian
>>> I am still debugging, but it seems that the two calls of
>>> ScdInterface::get_neighbor() caused the crash. If I comment out the second
>>> call, no segmentaion fault.
>>> #include "moab/ScdInterface.hpp"
>>> #include "moab/Core.hpp"
>>> #include <iostream>
>>> using namespace moab;
>>> int main()
>>> Core moab;
>>> ScdInterface* scdi;
>>> ErrorCode rval = moab.Interface::query_interface(scdi);
>>> int gdims[] = {0, 0, 0, 48, 40, 18};
>>> int nprocs = 4;
>>> int pto = 0;
>>> int across_bdy_a[3] = {0};
>>> int rdims_a[6] = {0};
>>> int facedims_a[6] = {0};
>>> ScdParData spd;
>>> int n;
>>> for (n = 0; n < 6; n++)
>>> spd.gDims[n] = gdims[n];
>>> for (n = 0; n < 3; n++)
>>> spd.gPeriodic[n] = 0;
>>> spd.partMethod = ScdParData::ALLJKBAL;
>>> int dijka[3] = {0};
>>> dijka[0] = -1;
>>> dijka[1] = -1;
>>> dijka[2] = -1;
>>> rval = ScdInterface::get_neighbor(nprocs, 0, spd, dijka, pto, rdims_a,
>>> facedims_a, across_bdy_a);
>>> dijka[0] = 0;
>>> dijka[1] = -1;
>>> dijka[2] = -1;
>>> std::cout << "Return from main()" << std::endl;
>>> return 0;
>> "You will keep in perfect peace him whose mind is
>>    steadfast, because he trusts in you."               Isaiah 26:3
>>               Tim Tautges            Argonne National Laboratory
>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>   phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>              fax: (608) 263-4499      Madison, WI 53706
