[MOAB-dev] commit/MOAB: tautges: Cosmetic improvements to the test, and adding exchange tags iterations.
commits-noreply at bitbucket.org
Fri Sep 6 13:56:58 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/50e57285fa0f/
Changeset: 50e57285fa0f
Branch: master
User: tautges
Date: 2013-09-06 20:56:46
Summary: Cosmetic improvements to the test, and adding exchange tags iterations.
Affected #: 1 file
diff --git a/test/parallel/structured3.cpp b/test/parallel/structured3.cpp
index 151aa34..5a059fe 100644
--- a/test/parallel/structured3.cpp
+++ b/test/parallel/structured3.cpp
@@ -32,7 +32,7 @@ void create_parallel_mesh()
ScdInterface *scdi;
ErrorCode rval = mbint.query_interface(scdi);
CHECK_ERR(rval);
- pc.set_debug_verbosity(2);
+ //pc.set_debug_verbosity(2);
// create a structured mesh in parallel
ScdBox *new_box;
@@ -50,7 +50,7 @@ void create_parallel_mesh()
rval = pc.exchange_ghost_cells(-1, -1, 0, 0, true, true);
CHECK_ERR(rval);
- pc.list_entities(0,-1);
+// pc.list_entities(0,-1);
rval = pc.exchange_ghost_cells(-1, 0, 1, 0, true);
if (MB_SUCCESS != rval) {
@@ -60,10 +60,8 @@ void create_parallel_mesh()
CHECK_ERR(rval);
- return;
// Create a tag, used in exchange_tags
Tag tag;
int def_val = 1.0;
@@ -71,8 +69,11 @@ void create_parallel_mesh()
CHECK_ERR(rval);
Range empty_range;
+ std::cout << "Exchanging tags: ";
for(int i = 0; i < ITERS; i++) {
+ std::cout << i << ";";
pc.exchange_tags(tag, empty_range);
CHECK_ERR(rval);
+ std::cout << std::endl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
