[MOAB-dev] commit/MOAB: danwu: Fix a compile warning from	tools/mbcslam/process_arm.cpp
    commits-noreply at bitbucket.org
    Fri Sep  6 09:55:14 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b0819c59afdd/
Changeset:   b0819c59afdd
Branch:      master
User:        danwu
Date:        2013-09-06 16:55:01
Summary:     Fix a compile warning from tools/mbcslam/process_arm.cpp
Affected #:  1 file
diff --git a/tools/mbcslam/process_arm.cpp b/tools/mbcslam/process_arm.cpp
index ba7642c..06472a9 100644
--- a/tools/mbcslam/process_arm.cpp
+++ b/tools/mbcslam/process_arm.cpp
@@ -354,8 +354,10 @@ int main(int argc, char ** argv)
     gidels[k]=k+1;
   mb.tag_set_data(gid2, erange, &gidels[0]);
-  int times;
-  GET_DIM(temp_dim, "time", times);
+  // For now, comment out times to remove compile warning (variable ‘times’ set but not used)
+  //int times;
+  //GET_DIM(temp_dim, "time", times);
   Tag velotag;
   rval = mb.tag_get_handle("VELO", 3, MB_TYPE_DOUBLE,
             velotag, MB_TAG_DENSE|MB_TAG_CREAT);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
