[MOAB-dev] commit/MOAB: danwu: Updated parallel unit test mpastrvpart for testing gather set.
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Aug 29 10:24:28 CDT 2013
Danqing, excellent work, everyone should be vigilant about generating unit tests when we fix a bug or add a new capability.
- tim
On 08/29/2013 10:19 AM, commits-noreply at bitbucket.org wrote:
> 1 new commit in MOAB:
> https://bitbucket.org/fathomteam/moab/commits/ceaaadd761a5/
> Changeset:   ceaaadd761a5
> Branch:      master
> User:        danwu
> Date:        2013-08-29 17:18:57
> Summary:     Updated parallel unit test mpastrvpart for testing gather set.
> Affected #:  1 file
> diff --git a/test/parallel/mpastrvpart.cpp b/test/parallel/mpastrvpart.cpp
> index 0999aa0..5cacd2c 100644
> --- a/test/parallel/mpastrvpart.cpp
> +++ b/test/parallel/mpastrvpart.cpp
> @@ -3,7 +3,7 @@
>   #include "moab/ParallelComm.hpp"
>   #include "moab/ProgOptions.hpp"
>   #include "MBParallelConventions.h"
> -#include "moab/Util.hpp"
> +#include "moab/ReadUtilIface.hpp"
>   using namespace moab;
> @@ -33,7 +33,6 @@ int main(int argc, char* argv[])
>   void test_read_parallel_mpas_trivial()
>     partition_method = std::string(";PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS");
>     test_read_parallel(1280, true, 1920, true);
> @@ -46,12 +45,15 @@ void test_read_parallel(int num_verts, bool test_nb_nodes, int num_edges, bool t
>     rval = mb.create_meshset(MESHSET_SET, file_set);
>     CHECK_ERR(rval);
> -  std::string opt = std::string("PARALLEL=READ_PART") +
> -      partition_method;
> +  std::string opt = std::string("PARALLEL=READ_PART") + partition_method;
> +  // Create gather set in processor 0
> +  opt += std::string(";GATHER_SET=0");
>     rval = mb.load_file(example, &file_set, opt.c_str());
>     CHECK_ERR(rval);
>     ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
> +  int procs = pcomm->proc_config().proc_size();
> +  int rank = pcomm->proc_config().proc_rank();
>     rval = pcomm->check_all_shared_handles();
>     CHECK_ERR(rval);
> @@ -60,14 +62,57 @@ void test_read_parallel(int num_verts, bool test_nb_nodes, int num_edges, bool t
>     Range verts;
>     rval = mb.get_entities_by_type(0, MBVERTEX, verts);
>     CHECK_ERR(rval);
> +  int my_verts_num = verts.size();
> +  if (test_nb_nodes && 2 == procs) {
> +    if (0 == rank)
> +      CHECK_EQUAL(2400, my_verts_num); // Gather set vertices included
> +    else if (1 == rank)
> +      CHECK_EQUAL(1122, my_verts_num); // Not owned vertices included
>     rval = pcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT);
>     CHECK_ERR(rval);
> -  int my_verts_num = verts.size(), total_verts;
> -  std::cout << "proc: " << pcomm->proc_config().proc_rank() << " verts:" << my_verts_num << "\n";
> -  MPI_Reduce(&my_verts_num, &total_verts, 1, MPI_INTEGER, MPI_SUM, 0, pcomm->proc_config().proc_comm());
> +  my_verts_num = verts.size();
> +    if (0 == rank)
> +      CHECK_EQUAL(160, my_verts_num); // Not owned vertices excluded
> -  if (0 == pcomm->proc_config().proc_rank())
> +  if (0 == rank) {
> +    // Get gather set
> +    EntityHandle gather_set;
> +    ReadUtilIface* readUtilIface;
> +    rval = mb.query_interface(readUtilIface);
> +    CHECK_ERR(rval);
> +    rval = readUtilIface->get_gather_set(gather_set);
> +    CHECK_ERR(rval);
> +    // Get gather set entities
> +    Range gather_ents;
> +    rval = mb.get_entities_by_handle(gather_set, gather_ents);
> +    CHECK_ERR(rval);
> +    // Remove gather set vertices in processor 0
> +    verts = subtract(verts, gather_ents);
> +    if (0 == rank)
> +      CHECK_EQUAL(1120, my_verts_num); // Gather set vertices excluded
> +  std::cout << "proc: " << rank << " verts:" << my_verts_num << "\n";
> +  int total_verts;
> +  MPI_Reduce(&my_verts_num, &total_verts, 1, MPI_INTEGER, MPI_SUM, 0, pcomm->proc_config().proc_comm());
> +  if (0 == rank)
>       std::cout << "total vertices: " << total_verts << "\n";
>       if (test_nb_nodes)
> @@ -78,14 +123,57 @@ void test_read_parallel(int num_verts, bool test_nb_nodes, int num_edges, bool t
>     Range edges;
>     rval = mb.get_entities_by_type(0, MBEDGE, edges);
>     CHECK_ERR(rval);
> +  int my_edges_num = edges.size();
> +  if (test_nb_edges && 2 == procs) {
> +    if (0 == rank)
> +      CHECK_EQUAL(3358, my_edges_num); // Gather set edges included
> +      CHECK_EQUAL(1444, my_edges_num); // Not owned edges included
>     rval = pcomm->filter_pstatus(edges, PSTATUS_NOT_OWNED, PSTATUS_NOT);
>     CHECK_ERR(rval);
> -  int my_edges_num = edges.size(), total_edges;
> -  std::cout << "proc: " << pcomm->proc_config().proc_rank() << " edges:" << my_edges_num << "\n";
> -  MPI_Reduce(&my_edges_num, &total_edges, 1, MPI_INTEGER, MPI_SUM, 0, pcomm->proc_config().proc_comm());
> +  my_edges_num = edges.size();
> +    if (0 == rank)
> +      CHECK_EQUAL(482, my_edges_num); // Not owned edges excluded
> +  if (0 == rank) {
> +    // Get gather set
> +    CHECK_ERR(rval);
> +    CHECK_ERR(rval);
> +    CHECK_ERR(rval);
> +    // Remove gather set edges in processor 0
> +    edges = subtract(edges, gather_ents);
> +    if (0 == rank)
> +      CHECK_EQUAL(1438, my_edges_num); // Gather set edges excluded
> +  std::cout << "proc: " << rank << " edges:" << my_edges_num << "\n";
> +  int total_edges;
> +  MPI_Reduce(&my_edges_num, &total_edges, 1, MPI_INTEGER, MPI_SUM, 0, pcomm->proc_config().proc_comm());
> +  if (0 == rank)
>       std::cout << "total edges: " << total_edges << "\n";
>       if (test_nb_edges)
> @@ -112,6 +200,8 @@ void test_multiple_loads_of_same_file()
>     // Create mesh, no variable
>     opts="PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD=TRIVIAL;VARIABLE=";
> +  // Create gather set in processor 1
> +  opts += std::string(";GATHER_SET=1");
>     rval = mb.load_file(example, &file_set, opts.c_str());
>     CHECK_ERR(rval);
> @@ -119,4 +209,45 @@ void test_multiple_loads_of_same_file()
>     opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE=ke;TIMESTEP=0";
>     CHECK_ERR(rval);
> +  ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
> +  // Make check runs this test in two processors
> +  if (2 == procs) {
> +    Range verts;
> +    rval = mb.get_entities_by_type(0, MBVERTEX, verts);
> +    CHECK_ERR(rval);
> +    if (0 == rank)
> +      CHECK_EQUAL(2402, my_verts_num); // Gather set vertices included; Not owned vertices included
> +    if (1 == rank) {
> +      // Get gather set
> +      CHECK_ERR(rval);
> +      CHECK_ERR(rval);
> +      CHECK_ERR(rval);
> +      // Remove gather set vertices in processor 1
> +    if (0 == rank)
> +      CHECK_EQUAL(1122, my_verts_num); // Gather set vertices excluded; Not owned vertices included
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
