[MOAB-dev] commit/MOAB: danwu: Create gather set for MPAS if specified in the read option. For PNetCDF, use independent I/O mode to read a variable, if this read is only for the gather processor.
commits-noreply at bitbucket.org
Fri Aug 23 16:09:52 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b6e882f56fff/
Changeset: b6e882f56fff
Branch: master
User: danwu
Date: 2013-08-23 23:09:38
Summary: Create gather set for MPAS if specified in the read option. For PNetCDF, use independent I/O mode to read a variable, if this read is only for the gather processor.
Affected #: 2 files
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 9825d86..c78956c 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -147,7 +147,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
int success = NCFUNC(inq_varid)(_fileId, "verticesOnEdge", &verticesOnEdgeVarId);
ERRORS(success, "Failed to get variable id of verticesOnEdge.");
NCDF_SIZE tmp_starts[2] = {0, 0};
- NCDF_SIZE tmp_counts[2] = {static_cast<size_t>(nEdges), 2};
+ NCDF_SIZE tmp_counts[2] = {static_cast<NCDF_SIZE>(nEdges), 2};
verticesOnEdge.resize(nEdges * 2);
success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts, &verticesOnEdge[0]);
ERRORS(success, "Failed to read variable values of verticesOnEdge.");
@@ -267,8 +267,10 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
Interface*& mbImpl = _readNC->mbImpl;
Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
+ int& gatherSetRank = _readNC->gatherSetRank;
- int rank = 0, procs = 1;
+ int rank = 0;
+ int procs = 1;
#ifdef USE_MPI
bool& isParallel = _readNC->isParallel;
if (isParallel) {
@@ -278,11 +280,14 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
#endif
- ErrorCode rval;
+ // Need to know whether we'll be creating gather mesh
+ bool create_gathers = false;
+ if (rank == gatherSetRank)
+ create_gathers = true;
// Compute the number of local cells on this proc
nLocalCells = int(std::floor(1.0 * nCells / procs));
- // start_cell_idx is the starting cell index in the MPAS file for this proc
+ // start_cell_idx is the starting global cell index in the MPAS file for this proc
int start_cell_idx = rank * nLocalCells;
// iextra = # cells extra after equal split over procs
int iextra = nCells % procs;
@@ -290,82 +295,83 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
nLocalCells++;
start_cell_idx += std::min(rank, iextra);
start_cell_idx++; // 0 based -> 1 based
localGidCells.insert(start_cell_idx, start_cell_idx + nLocalCells - 1);
- // Read number of edges on each cell
+ // Read number of edges on each local cell
int nEdgesOnCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
ERRORS(success, "Failed to get variable id of nEdgesOnCell.");
- NCDF_SIZE tmp_starts_1[1] = {static_cast<size_t>(start_cell_idx - 1)};
- NCDF_SIZE tmp_counts_1[1] = {static_cast<size_t>(nLocalCells)};
- std::vector<int> num_edges_on_cell(nLocalCells);
- success = NCFUNCAG(_vara_int)(_fileId, nEdgesOnCellVarId, tmp_starts_1, tmp_counts_1, &num_edges_on_cell[0]);
+ NCDF_SIZE tmp_starts_1[1] = {static_cast<NCDF_SIZE>(start_cell_idx - 1)};
+ NCDF_SIZE tmp_counts_1[1] = {static_cast<NCDF_SIZE>(nLocalCells)};
+ std::vector<int> num_edges_on_local_cells(nLocalCells);
+ success = NCFUNCAG(_vara_int)(_fileId, nEdgesOnCellVarId, tmp_starts_1, tmp_counts_1, &num_edges_on_local_cells[0]);
ERRORS(success, "Failed to read variable values of nEdgesOnCell.");
- // Read vertices on each cell (connectivity)
+ // Read vertices on each local cell (connectivity)
int verticesOnCellVarId;
success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
ERRORS(success, "Failed to get variable id of verticesOnCell.");
- NCDF_SIZE tmp_starts_2[2] = {static_cast<size_t>(start_cell_idx - 1), 0};
- NCDF_SIZE tmp_counts_2[2] = {static_cast<size_t>(nLocalCells), maxCellEdges};
- std::vector<int> vertices_on_cell(nLocalCells * maxCellEdges);
- success = NCFUNCAG(_vara_int)(_fileId, verticesOnCellVarId, tmp_starts_2, tmp_counts_2, &vertices_on_cell[0]);
+ NCDF_SIZE tmp_starts_2[2] = {static_cast<NCDF_SIZE>(start_cell_idx - 1), 0};
+ NCDF_SIZE tmp_counts_2[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxCellEdges};
+ std::vector<int> vertices_on_local_cells(nLocalCells * maxCellEdges);
+ success = NCFUNCAG(_vara_int)(_fileId, verticesOnCellVarId, tmp_starts_2, tmp_counts_2, &vertices_on_local_cells[0]);
ERRORS(success, "Failed to read variable values of verticesOnCell.");
- // Read edges on each cell
+ // Read edges on each local cell
int edgesOnCellVarId;
success = NCFUNC(inq_varid)(_fileId, "edgesOnCell", &edgesOnCellVarId);
ERRORS(success, "Failed to get variable id of edgesOnCell.");
- NCDF_SIZE tmp_starts_3[2] = {static_cast<size_t>(start_cell_idx - 1), 0};
- NCDF_SIZE tmp_counts_3[2] = {static_cast<size_t>(nLocalCells), maxCellEdges};
- std::vector<int> edges_on_cell(nLocalCells * maxCellEdges);
- success = NCFUNCAG(_vara_int)(_fileId, edgesOnCellVarId, tmp_starts_3, tmp_counts_3, &edges_on_cell[0]);
+ NCDF_SIZE tmp_starts_3[2] = {static_cast<NCDF_SIZE>(start_cell_idx - 1), 0};
+ NCDF_SIZE tmp_counts_3[2] = {static_cast<NCDF_SIZE>(nLocalCells), maxCellEdges};
+ std::vector<int> edges_on_local_cells(nLocalCells * maxCellEdges);
+ success = NCFUNCAG(_vara_int)(_fileId, edgesOnCellVarId, tmp_starts_3, tmp_counts_3, &edges_on_local_cells[0]);
ERRORS(success, "Failed to read variable values of edgesOnCell.");
- // Divide cells into groups based on the number of edges
- std::vector<int> cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+ // Divide local cells into groups based on the number of edges
+ std::vector<int> local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
for (int i = 0; i < nLocalCells; i++) {
int cell_index = start_cell_idx + i; // Global cell index
- int num_edges = num_edges_on_cell[i];
- cells_with_n_edges[num_edges].push_back(cell_index);
+ int num_edges = num_edges_on_local_cells[i];
+ local_cells_with_n_edges[num_edges].push_back(cell_index);
// For each non-empty cell group, create cells and set connectivity array initially based on file ids
+ ErrorCode rval;
EntityHandle start_element;
- EntityHandle* conn_arr_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+ EntityHandle* conn_arr_local_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
Range tmp_range;
void* data;
int count;
int* gid_data;
- std::set<int> local_vertices_set;
+ std::set<int> local_verts_set;
std::set<int> local_edges_set;
numCellGroups = 0;
for (int i = 3; i <= maxCellEdges; i++) {
- int num_cells = cells_with_n_edges[i].size();
+ int num_cells = local_cells_with_n_edges[i].size();
if (num_cells > 0) {
numCellGroups++;
- rval = _readNC->readMeshIface->get_element_connect(num_cells, i, MBPOLYGON, 0, start_element, conn_arr_cells_with_n_edges[i], num_cells);
+ rval = _readNC->readMeshIface->get_element_connect(num_cells, i, MBPOLYGON, 0, start_element, conn_arr_local_cells_with_n_edges[i], num_cells);
+ ERRORR(rval, "Couldn't create local cells in MPAS mesh.");
+ Range local_cell_range(start_element, start_element + num_cells - 1);
tmp_range.insert(start_element, start_element + num_cells - 1);
faces.insert(start_element, start_element + num_cells - 1);
- // Get ptr to gid memory for cells
- Range cell_range(start_element, start_element + num_cells - 1);
- rval = mbImpl->tag_iterate(mGlobalIdTag, cell_range.begin(), cell_range.end(), count, data);
+ // Get ptr to gid memory for local cells
+ rval = mbImpl->tag_iterate(mGlobalIdTag, local_cell_range.begin(), local_cell_range.end(), count, data);
ERRORR(rval, "Failed to get tag iterator on global id tag.");
assert(count == (int) num_cells);
gid_data = (int*) data;
- std::copy(cells_with_n_edges[i].begin(), cells_with_n_edges[i].end(), gid_data);
+ std::copy(local_cells_with_n_edges[i].begin(), local_cells_with_n_edges[i].end(), gid_data);
for (int j = 0; j < num_cells; j++) {
- int cell_idx = cells_with_n_edges[i][j]; // Global cell index
+ int cell_idx = local_cells_with_n_edges[i][j]; // Global cell index
cellHandleToGlobalID[start_element + j] = cell_idx;
cell_idx -= start_cell_idx; // Local cell index
for (int k = 0; k < i; k++) {
- conn_arr_cells_with_n_edges[i][i * j + k] = vertices_on_cell[cell_idx * maxCellEdges + k];
- local_vertices_set.insert(vertices_on_cell[cell_idx * maxCellEdges + k]);
- local_edges_set.insert(edges_on_cell[cell_idx * maxCellEdges + k]);
+ conn_arr_local_cells_with_n_edges[i][i * j + k] = vertices_on_local_cells[cell_idx * maxCellEdges + k];
+ local_verts_set.insert(vertices_on_local_cells[cell_idx * maxCellEdges + k]);
+ local_edges_set.insert(edges_on_local_cells[cell_idx * maxCellEdges + k]);
@@ -379,13 +385,16 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
ERRORR(rval, "Trouble setting data for __NUM_CELL_GROUPS tag.");
// Collect localGid for vertices
- std::copy(local_vertices_set.rbegin(), local_vertices_set.rend(), range_inserter(localGidVerts));
+ std::copy(local_verts_set.rbegin(), local_verts_set.rend(), range_inserter(localGidVerts));
nLocalVertices = localGidVerts.size();
// Create local vertices
EntityHandle start_vertex;
std::vector<double*> arrays;
- rval = _readNC->readMeshIface->get_node_coords(3, nLocalVertices, 0, start_vertex, arrays);
+ rval = _readNC->readMeshIface->get_node_coords(3, nLocalVertices, 0, start_vertex, arrays,
+ // Might have to create gather mesh later
+ (create_gathers ? nLocalVertices + nVertices : nLocalVertices));
+ ERRORR(rval, "Couldn't create local vertices in MPAS mesh.");
tmp_range.insert(start_vertex, start_vertex + nLocalVertices - 1);
// Set coordinates for local vertices
@@ -401,9 +410,9 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
zptr[vert_idx] = zVertVals[(*rit) - 1];
- // Get ptr to gid memory for vertices
- Range vert_range(start_vertex, start_vertex + nLocalVertices - 1);
- rval = mbImpl->tag_iterate(mGlobalIdTag, vert_range.begin(), vert_range.end(), count, data);
+ // Get ptr to gid memory for local vertices
+ Range local_verts_range(start_vertex, start_vertex + nLocalVertices - 1);
+ rval = mbImpl->tag_iterate(mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data);
assert(count == (int) nLocalVertices);
@@ -411,7 +420,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
// Duplicate global id data, which will be used to resolve sharing
if (mpFileIdTag) {
- rval = mbImpl->tag_iterate(*mpFileIdTag, vert_range.begin(), vert_range.end(), count, data);
+ rval = mbImpl->tag_iterate(*mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data);
ERRORR(rval, "Failed to get tag iterator on file id tag.");
@@ -425,12 +434,12 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
// For each non-empty cell group, set connectivity array with proper local vertices handles
- EntityHandle global_vert_id = conn_arr_cells_with_n_edges[i][i * j + k];
- conn_arr_cells_with_n_edges[i][i * j + k] = vert_handles[global_vert_id];
+ EntityHandle global_vert_id = conn_arr_local_cells_with_n_edges[i][i * j + k];
+ conn_arr_local_cells_with_n_edges[i][i * j + k] = vert_handles[global_vert_id];
@@ -443,22 +452,25 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
// Create local edges
EntityHandle start_edge;
EntityHandle* conn_arr_edges;
- rval = _readNC->readMeshIface->get_element_connect(nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges);
+ rval = _readNC->readMeshIface->get_element_connect(nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
+ (create_gathers ? nLocalEdges + nEdges : nLocalEdges));
+ ERRORR(rval, "Couldn't create local edges in MPAS mesh.");
+ Range local_edges_range(start_edge, start_edge + nLocalEdges - 1);
tmp_range.insert(start_edge, start_edge + nLocalEdges - 1);
// Set vertices for local edges
int edge_idx;
- for (rit = localGidEdges.begin(), edge_idx = 0; rit != localGidEdges.end(); ++rit, edge_idx += 2) {
+ for (rit = localGidEdges.begin(), edge_idx = 0; rit != localGidEdges.end(); ++rit, edge_idx++) {
EntityHandle gloabl_edge_id = *rit;
EntityHandle gloabl_vert_id_1 = verticesOnEdge[(gloabl_edge_id - 1) * 2 + 0];
EntityHandle gloabl_vert_id_2 = verticesOnEdge[(gloabl_edge_id - 1) * 2 + 1];
- conn_arr_edges[edge_idx] = vert_handles[gloabl_vert_id_1];
- conn_arr_edges[edge_idx + 1] = vert_handles[gloabl_vert_id_2];
+ conn_arr_edges[edge_idx * 2 + 0] = vert_handles[gloabl_vert_id_1];
+ conn_arr_edges[edge_idx * 2 + 1] = vert_handles[gloabl_vert_id_2];
// Get ptr to gid memory for edges
- Range edge_range(start_edge, start_edge + nLocalEdges - 1);
- rval = mbImpl->tag_iterate(mGlobalIdTag, edge_range.begin(), edge_range.end(), count, data);
+ rval = mbImpl->tag_iterate(mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data);
assert(count == (int) nLocalEdges);
@@ -468,6 +480,128 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
rval = _readNC->mbImpl->add_entities(_fileSet, tmp_range);
ERRORR(rval, "Couldn't add new vertices/faces/edges to file set.");
+ if (create_gathers) {
+ EntityHandle gather_set;
+ rval = _readNC->readMeshIface->create_gather_set(gather_set);
+ ERRORR(rval, "Trouble creating gather set.");
+ // Create gather vertices
+ arrays.clear();
+ // Don't need to specify allocation number here, because we know enough verts were created before
+ rval = _readNC->readMeshIface->get_node_coords(3, nVertices, 0, start_vertex, arrays);
+ ERRORR(rval, "Couldn't create vertices in MPAS mesh for gather set.");
+ Range gather_verts_range(start_vertex, start_vertex + nVertices - 1);
+ xptr = arrays[0];
+ yptr = arrays[1];
+ zptr = arrays[2];
+ for (vert_idx = 0; vert_idx < nVertices; vert_idx++) {
+ xptr[vert_idx] = xVertVals[vert_idx];
+ yptr[vert_idx] = yVertVals[vert_idx];
+ zptr[vert_idx] = zVertVals[vert_idx];
+ // Get ptr to gid memory for gather vertices
+ rval = mbImpl->tag_iterate(mGlobalIdTag, gather_verts_range.begin(), gather_verts_range.end(), count, data);
+ ERRORR(rval, "Failed to get tag iterator on global id tag..");
+ assert(count == nVertices);
+ gid_data = (int*) data;
+ for (int j = 1; j <= nVertices; j++)
+ gid_data[j - 1] = j;
+ // Set the file id tag too, it should be bigger something not interfering with global id
+ if (mpFileIdTag) {
+ rval = mbImpl->tag_iterate(*mpFileIdTag, gather_verts_range.begin(), gather_verts_range.end(), count, data);
+ ERRORR(rval, "Failed to get tag iterator on file id tag.");
+ gid_data[j - 1] = nVertices + j; // Bigger than global id tag
+ rval = mbImpl->add_entities(gather_set, gather_verts_range);
+ ERRORR(rval, "Couldn't add vertices to gather set.");
+ // Read number of edges on each gather cell
+ std::vector<int> num_edges_on_gather_cells(nCells);
+ tmp_starts_1[0] = 0;
+ tmp_counts_1[0] = static_cast<NCDF_SIZE>(nCells);
+#ifdef PNETCDF_FILE
+ // Enter independent I/O mode, since this read is only for the gather processor
+ success = NCFUNC(begin_indep_data)(_fileId);
+ ERRORS(success, "Failed to begin independent I/O mode.");
+ success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, tmp_starts_1, tmp_counts_1, &num_edges_on_gather_cells[0]);
+ ERRORS(success, "Failed to read variable values of nEdgesOnCell.");
+ success = NCFUNC(end_indep_data)(_fileId);
+ ERRORS(success, "Failed to end independent I/O mode.");
+#else
+#endif
+ // Read vertices on each gather cell (connectivity)
+ std::vector<int> vertices_on_gather_cells(nCells * maxCellEdges);
+ tmp_starts_2[0] = 0;
+ tmp_starts_2[1] = 0;
+ tmp_counts_2[0] = nCells;
+ tmp_counts_2[1] = maxCellEdges;
+ success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, tmp_starts_2, tmp_counts_2, &vertices_on_gather_cells[0]);
+ ERRORS(success, "Failed to read variable values of verticesOnCell.");
+#else
+#endif
+ // Divide gather cells into groups based on the number of edges
+ std::vector<int> gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+ for (int i = 0; i < nCells; i++) {
+ int num_edges = num_edges_on_gather_cells[i];
+ gather_cells_with_n_edges[num_edges].push_back(i + 1); // 0 based -> 1 based
+ // For each non-empty cell group, create cells and set connectivity array
+ EntityHandle* conn_arr_gather_cells_with_n_edges[MAX_EDGES_PER_CELL + 1];
+ Range gather_cells_range;
+ for (int i = 3; i <= maxCellEdges; i++) {
+ int num_cells = gather_cells_with_n_edges[i].size();
+ if (num_cells > 0) {
+ rval = _readNC->readMeshIface->get_element_connect(num_cells, i, MBPOLYGON, 0, start_element, conn_arr_gather_cells_with_n_edges[i], num_cells);
+ ERRORR(rval, "Couldn't create cells in MPAS mesh for gather set.");
+ gather_cells_range.insert(start_element, start_element + num_cells - 1);
+ for (int j = 0; j < num_cells; j++) {
+ int cell_idx = gather_cells_with_n_edges[i][j]; // Global cell index
+ cell_idx--; // 1 based -> 0 based
+ for (int k = 0; k < i; k++)
+ // Connectivity array is shifted by where the gather verts start
+ conn_arr_gather_cells_with_n_edges[i][i * j + k] = (start_vertex - 1) + vertices_on_gather_cells[cell_idx * maxCellEdges + k];
+ rval = mbImpl->add_entities(gather_set, gather_cells_range);
+ ERRORR(rval, "Couldn't add cells to gather set.");
+ // Create gather edges
+ EntityHandle* conn_arr_gather_edges;
+ // Don't need to specify allocation number here, because we know enough edges were created before
+ rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
+ ERRORR(rval, "Couldn't create edges in MPAS mesh for gather set.");
+ Range gather_edges_range(start_edge, start_edge + nEdges - 1);
+ std::copy(verticesOnEdge.begin(), verticesOnEdge.end(), conn_arr_gather_edges);
+ for (int i = 0; i < 2 * nEdges; i++)
+ conn_arr_gather_edges[i] += start_vertex - 1;
+ rval = mbImpl->add_entities(gather_set, gather_edges_range);
+ ERRORR(rval, "Couldn't add edges to gather set.");
return MB_SUCCESS;
@@ -756,7 +890,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
assert(ic == pLocalGid->psize());
- success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
+ success = NCFUNC(wait_all)(_fileId, requests.size(), &requests[0], &statuss[0]);
ERRORS(success, "Failed on wait_all.");
// Local cells are grouped by the number of edges on each cell, e.g. 5, 6 or 7
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index e4636e7..6776b45 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -31,24 +31,24 @@
#include "pnetcdf.h"
#define NCFUNC(func) ncmpi_ ## func
-// Collective get
+//! Collective I/O mode get
#define NCFUNCAG(func) ncmpi_get ## func ## _all
-// Independent get
+//! Independent I/O mode get
#define NCFUNCG(func) ncmpi_get ## func
-// Nonblocking get (request aggregation), used so far only for ucd mesh
+//! Nonblocking get (request aggregation), used so far only for ucd mesh
#define NCFUNCREQG(func) ncmpi_iget ## func
#define NCDF_SIZE MPI_Offset
#define NCDF_DIFF MPI_Offset
#else
-# include "netcdf.h"
-# define NCFUNC(func) nc_ ## func
-# define NCFUNCAG(func) nc_get ## func
-# define NCFUNCG(func) nc_get ## func
-# define NCDF_SIZE size_t
-# define NCDF_DIFF ptrdiff_t
+#include "netcdf.h"
+#define NCFUNC(func) nc_ ## func
+#define NCFUNCAG(func) nc_get ## func
+#define NCFUNCG(func) nc_get ## func
+#define NCDF_SIZE size_t
+#define NCDF_DIFF ptrdiff_t
#endif
namespace moab {
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
