[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Aug 12 14:53:35 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d011d558c33a/
Changeset:   d011d558c33a
Branch:      None
User:        tautges
Date:        2013-08-12 20:52:45
Summary:     Changes to ScdInterface, mostly to support new partitioning method (sqijk) but also to allow
for periodic meshes in all 3 directions.
NOTE: all applications using structured mesh functions in parallel should check parameters to
ScdInterface::compute_partition and ScdInterface::get_neighbor; the parameters for periodicity and
across_bdy have changed dimension from 2 to 3.
Also, fixed a problem in scdseq_test where returned value didn't reflect #errors, so tests
were passing when they should have been failing.
Affected #:  10 files
diff --git a/src/ScdInterface.cpp b/src/ScdInterface.cpp
index 8084640..7c91ab7 100644
--- a/src/ScdInterface.cpp
+++ b/src/ScdInterface.cpp
@@ -248,7 +248,7 @@ Tag ScdInterface::box_periodic_tag(bool create_if_missing)
   if (boxPeriodicTag || !create_if_missing) return boxPeriodicTag;
-  ErrorCode rval = mbImpl->tag_get_handle("BOX_PERIODIC", 2, MB_TYPE_INTEGER,
+  ErrorCode rval = mbImpl->tag_get_handle("BOX_PERIODIC", 3, MB_TYPE_INTEGER,
                                           boxPeriodicTag, MB_TAG_SPARSE|MB_TAG_CREAT);
   if (MB_SUCCESS != rval) return 0;
@@ -693,7 +693,7 @@ ErrorCode ScdInterface::get_neighbor_alljkbal(int np, int pfrom,
   pto = -1;
-  across_bdy[0] = across_bdy[1] = 0;
+  across_bdy[0] = across_bdy[1] = across_bdy[2] = 0;
   int ldims[6], pijk[3], lperiodic[2];
   ErrorCode rval = compute_partition_alljkbal(np, pfrom, gdims, gperiodic,
@@ -801,7 +801,7 @@ ErrorCode ScdInterface::get_neighbor_sqij(int np, int pfrom,
   pto = -1;
   int lperiodic[3], pijk[3], ldims[6];
   ErrorCode rval = compute_partition_sqij(np, pfrom, gdims, gperiodic, ldims, lperiodic, pijk);
   if (MB_SUCCESS != rval) return rval;
@@ -929,7 +929,7 @@ ErrorCode ScdInterface::get_neighbor_sqjk(int np, int pfrom,
   pto = -1;
   int pijk[3], lperiodic[3], ldims[6];
   ErrorCode rval = compute_partition_sqjk(np, pfrom, gdims, gperiodic, ldims, lperiodic, pijk);
@@ -952,7 +952,7 @@ ErrorCode ScdInterface::get_neighbor_sqjk(int np, int pfrom,
   pto = pfrom;
   int dj = (gdims[4] - gdims[1]) / pijk[1], jextra = (gdims[4] - gdims[1]) % dj,
       dk = (gdims[5] == gdims[2] ? 0 : (gdims[5] - gdims[2]) / pijk[2]), kextra = (gdims[5] - gdims[2]) - dk*pijk[2];
+  assert((dj*pijk[1] + jextra == (gdims[4]-gdims[1])) && (dk*pijk[2] + kextra == (gdims[5]-gdims[2])));
   if (0 != dijk[1]) {
     pto = (nj + dijk[1] + pijk[1]) % pijk[1]; // get pto's ni value
     pto = nk*pijk[1] + pto;  // then convert to pto
@@ -993,7 +993,7 @@ ErrorCode ScdInterface::get_neighbor_sqjk(int np, int pfrom,
       facedims[5] = facedims[2];
       rdims[5] = ldims[2];
       rdims[2] -= dk;
-      if (nk < kextra) rdims[2]--;
+      if (pto/pijk[1] < kextra) rdims[2]--;
     else {
       facedims[2] = facedims[5];
@@ -1019,6 +1019,97 @@ ErrorCode ScdInterface::get_neighbor_sqjk(int np, int pfrom,
 #ifndef USE_MPI
+ErrorCode ScdInterface::get_neighbor_sqijk(int , int ,
+                                          const int * const , const int * const , const int * const ,
+                                          int &, int *, int *, int *)
+  return MB_FAILURE;
+#else
+ErrorCode ScdInterface::get_neighbor_sqijk(int np, int pfrom,
+                                           const int * const gdims, const int * const gperiodic, const int * const dijk,
+                                           int &pto, int *rdims, int *facedims, int *across_bdy)
+  if (gperiodic[0] || gperiodic[1] || gperiodic[2]) return MB_FAILURE;
+  pto = -1;
+  int pijk[3], lperiodic[3], ldims[6];
+  ErrorCode rval = compute_partition_sqijk(np, pfrom, gdims, gperiodic, ldims, lperiodic, pijk);
+  if (MB_SUCCESS != rval) return rval;
+  assert(pijk[0] * pijk[1] * pijk[2] == np);
+  pto = -1;
+  bool top[3] = {false, false, false}, bot[3] = {false, false, false};
+    // nijk: rank in i/j/k direction
+  int nijk[3] = {pfrom%pijk[0], (pfrom%(pijk[0]*pijk[1]))/pijk[0], pfrom/(pijk[0]*pijk[1])};
+  for (int i = 0; i < 3; i++) {
+    if (nijk[i] == pijk[i]-1) top[i] = true;
+    if (!nijk[i]) bot[i] = true;
+    if ((!gperiodic[i] && bot[i] && -1 == dijk[i]) || // downward && not periodic
+        (!gperiodic[i] && top[i] && 1 == dijk[i])) // upward && not periodic
+      return MB_SUCCESS;
+  std::copy(ldims, ldims+6, facedims);
+  std::copy(ldims, ldims+6, rdims);
+  pto = pfrom;
+  int delijk[3], extra[3];
+    // nijk_to: rank of pto in i/j/k direction
+  int nijk_to[3];
+    delijk[i] = (gdims[i+3] == gdims[i] ? 0 : (gdims[i+3] - gdims[i])/pijk[i]);
+    extra[i] = (gdims[i+3]-gdims[i]) % delijk[i];
+    nijk_to[i] = (nijk[i]+dijk[i]+pijk[i]) % pijk[i];
+  pto = nijk_to[2]*pijk[0]*pijk[1] + nijk_to[1]*pijk[0] + nijk_to[0];
+  assert (pto >= 0 && pto < np);
+    if (0 != dijk[i]) {
+      if (-1 == dijk[i]) {
+        facedims[i+3] = facedims[i];
+        if (bot[i]) {
+            // going across lower periodic bdy in i
+          rdims[i+3] = gdims[i+3]+1; // +1 because ldims[4] on remote proc is gdims[4]+1
+          across_bdy[i] = -1;
+        else {
+          rdims[i+3] = ldims[i];
+        rdims[i] = rdims[i+3] - delijk[i];
+        if (nijk[i] < extra[i]) rdims[i]--;
+      else {
+        if (top[i]) {
+          // going across upper periodic bdy in i
+          rdims[i] = gdims[i];
+          facedims[i+3] = gdims[i];
+          across_bdy[i] = 1;
+        else {
+          rdims[i] = ldims[i+3];
+        facedims[i] = facedims[i+3];
+        rdims[i+3] = rdims[i] + delijk[i];
+        if (nijk[i] < extra[i]) rdims[i+3]++;
+        if (gperiodic[i] && nijk[i] == dijk[i]-2) rdims[i+3]++; // +1 because next proc is on periodic bdy
+  assert(-1 != pto);
+#ifndef NDEBUG
+    assert((rdims[i] >= gdims[i] && (rdims[i+3] <= gdims[i+3] || (across_bdy[i] && bot[i]))));
+    assert(((facedims[i] >= rdims[i]  || (gperiodic[i] && rdims[i+3] == gdims[i+3] && facedims[i] == gdims[i]))));
+    assert((facedims[i] >= ldims[i] && facedims[i+3] <= ldims[i+3]));
+#endif
+#endif
+#ifndef USE_MPI
 ErrorCode ScdInterface::get_neighbor_alljorkori(int , int ,
@@ -1038,7 +1129,7 @@ ErrorCode ScdInterface::get_neighbor_alljorkori(int np, int pfrom,
   int ind = -1;
     if (pijk[i] > 1) {
@@ -1126,7 +1217,7 @@ ErrorCode ScdInterface::get_shared_vertices(ParallelComm *pcomm, ScdBox *box,
     // get index of partitioned dimension
   const int *ldims = box->box_dims();
   ErrorCode rval;
-  int ijkrem[6], ijkface[6], across_bdy[2];
+  int ijkrem[6], ijkface[6], across_bdy[3];
   for (int k = -1; k <= 1; k ++) {
     for (int j = -1; j <= 1; j ++) {
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index b6158a9..c3cd286 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -365,8 +365,8 @@ ErrorCode ScdNCHelper::create_mesh(ScdInterface* scdi, const FileOptions& opts,
   std::vector<double>& klVals = _readNC->klVals;
   Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
   DebugOutput& dbgOut = _readNC->dbgOut;
-  int (&locallyPeriodic)[2] = _readNC->locallyPeriodic;
-  int (&globallyPeriodic)[2] = _readNC->globallyPeriodic;
+  int (&locallyPeriodic)[3] = _readNC->locallyPeriodic;
+  int (&globallyPeriodic)[3] = _readNC->globallyPeriodic;
   ScdParData& parData = _readNC->parData;
   Range tmp_range;
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 7336fa9..8de0818 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -77,8 +77,8 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   bool& isParallel = _readNC->isParallel;
   int& partMethod = _readNC->partMethod;
 #ifdef USE_MPI
   ParallelComm*& myPcomm = _readNC->myPcomm;
@@ -147,7 +147,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
 #ifdef USE_MPI
     for (int i = 0; i < 6; i++)
       parData.gDims[i] = gDims[i];
-    for (int i = 0; i < 2; i++)
       parData.gPeriodic[i] = globallyPeriodic[i];
     parData.partMethod = partMethod;
     int pdims[3];
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index cb6229e..8b9be3f 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -72,8 +72,8 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
 #ifdef USE_MPI
@@ -159,7 +159,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
 #ifdef USE_MPI
     int pdims[3];
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index 882fd98..2909ba2 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -264,10 +264,10 @@ private:
   int partMethod;
   //! whether mesh is locally periodic in i or j
-  int locallyPeriodic[2];
+  int locallyPeriodic[3];
   //! whether mesh is globally periodic in i or j
-  int globallyPeriodic[2];
+  int globallyPeriodic[3];
   //! parallel data object, to be cached with ScdBox
   ScdParData parData;
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index 833b15b..dc841fc 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -2491,6 +2491,8 @@ ErrorCode Tqdcfr::parse_acis_attribs(const unsigned int entity_rec_num,
   if (records[entity_rec_num].entity == 0) {
     records[entity_rec_num].entity = uidSetMap[uid];
+  assert(records[entity_rec_num].entity);
     // set the id
   if (id != -1) {
diff --git a/src/moab/ScdInterface.hpp b/src/moab/ScdInterface.hpp
index 3c3e6d1..9612946 100644
--- a/src/moab/ScdInterface.hpp
+++ b/src/moab/ScdInterface.hpp
@@ -106,13 +106,13 @@ class ScdParData {
 public:
   ScdParData() : partMethod(NOPART) {
     gDims[0] = gDims[1] = gDims[2] = gDims[3] = gDims[4] = gDims[5] = -1;
-    gPeriodic[0] = gPeriodic[1] = -1;
+    gPeriodic[0] = gPeriodic[1] = gPeriodic[2] = -1;
     pDims[0] = pDims[1] = pDims[2] = -1;
     //! Partition method enumeration; these strategies are described in comments for
     //! compute_partition_alljorkori, compute_partition_alljkbal, compute_partition_sqij, and compute_partition_sqjk
-  enum PartitionMethod {NOPART=-1, ALLJORKORI=0, ALLJKBAL, SQIJ, SQJK};
+  enum PartitionMethod {NOPART=0, ALLJORKORI, ALLJKBAL, SQIJ, SQJK, SQIJK};
     //! partition method used to partition global parametric space
   int partMethod;
@@ -121,10 +121,11 @@ public:
   int gDims[6];
     //! is globally periodic in i or j
-  int gPeriodic[2];
+  int gPeriodic[3];
     //! number of procs in each direction
   int pDims[3];
 class ScdInterface
@@ -325,6 +326,13 @@ private:
   inline static ErrorCode compute_partition_sqjk(int np, int nr, const int * const gijk, const int * const gperiodic,
                                                  int *lijk, int *lperiodic, int *pijk);
+    //! Compute a partition of structured parameter space
+    /** Partitions the structured parametric space by seeking square ijk partitions
+     * For description of arguments, see ScdInterface::compute_partition.
+  inline static ErrorCode compute_partition_sqijk(int np, int nr, const int * const gijk, const int * const gperiodic,
+                                                  int *lijk, int *lperiodic, int *pijk);
     //! Get vertices shared with other processors
     /** Shared vertices returned as indices into each proc's handle space
      * \param box Box used to get parametric space info
@@ -354,6 +362,10 @@ private:
                                      int &pto, int *rdims, int *facedims, int *across_bdy);
+  static ErrorCode get_neighbor_sqijk(int np, int pfrom,
+                                      int &pto, int *rdims, int *facedims, int *across_bdy);
   static int gtol(const int *gijk, int i, int j, int k);
   //! interface instance
@@ -597,11 +609,17 @@ public:
   bool locally_periodic_j() const;
+    //! Return whether box is locally periodic in k
+    /** Return whether box is locally periodic in k
+     * \return True if box is locally periodic in k direction
+  bool locally_periodic_k() const;
     //! Return whether box is locally periodic in i and j
     /** Return whether box is locally periodic in i and j
      * \param lperiodic Non-zero if locally periodic in i [0] or j [1]
-  void locally_periodic(bool lperiodic[2]) const;
+  void locally_periodic(bool lperiodic[3]) const;
     //! Return parallel data
     /** Return parallel data, if there is any
@@ -685,7 +703,7 @@ private:
   int boxDims[6];
     //! is locally periodic in i or j
     //! parallel data associated with this box, if any
   ScdParData parData;
@@ -722,6 +740,10 @@ inline ErrorCode ScdInterface::compute_partition(int np, int nr, const ScdParDat
         rval = compute_partition_sqjk(np, nr, par_data.gDims, par_data.gPeriodic,
                                       ldims, lperiodic, pdims);
         break;
+    case ScdParData::SQIJK:
+        rval = compute_partition_sqijk(np, nr, par_data.gDims, par_data.gPeriodic,
+                                      ldims, lperiodic, pdims);
+        break;
     default:
         rval = MB_FAILURE;
         break;
@@ -740,8 +762,7 @@ inline ErrorCode ScdInterface::compute_partition_alljorkori(int np, int nr,
   if (!lperiodic) lperiodic = tmp_lp;
   if (!pijk) pijk = tmp_pijk;
-  lperiodic[0] = gperiodic[0];
-  lperiodic[1] = gperiodic[1];
+  for (int i = 0; i < 3; i++) lperiodic[i] = gperiodic[i];
   if (np == 1) {
     if (ldims) {
@@ -822,8 +843,7 @@ inline ErrorCode ScdInterface::compute_partition_alljkbal(int np, int nr,
   if (np == 1) {
     if (ldims) {
@@ -899,8 +919,7 @@ inline ErrorCode ScdInterface::compute_partition_sqij(int np, int nr,
     // square IxJ partition
   if (np == 1) {
     if (ldims) {
@@ -979,8 +998,7 @@ inline ErrorCode ScdInterface::compute_partition_sqjk(int np, int nr,
     // square JxK partition
   if (np == 1) {
     if (ldims) {
@@ -1042,6 +1060,91 @@ inline ErrorCode ScdInterface::compute_partition_sqjk(int np, int nr,
   return MB_SUCCESS;
+inline ErrorCode ScdInterface::compute_partition_sqijk(int np, int nr,
+                                                       const int * const gijk, const int * const gperiodic,
+                                                       int *ldims, int *lperiodic, int *pijk)
+  int tmp_lp[3], tmp_pijk[3];
+  if (!lperiodic) lperiodic = tmp_lp;
+  if (!pijk) pijk = tmp_pijk;
+    // square IxJxK partition
+  if (np == 1) {
+    if (ldims)
+      for (int i = 0; i < 6; i++) ldims[i] = gijk[i];
+    pijk[0] = pijk[1] = pijk[2] = 1;
+  std::vector<int> pfactors;
+  pfactors.push_back(1);
+  for (int i = 2; i <= np/2; i++)
+    if (!(np%i)) pfactors.push_back(i);
+  pfactors.push_back(np);
+    // test for IJ, JK, IK
+  int IJK[3], dIJK[3];
+    IJK[i] = std::max(gijk[3+i] - gijk[i], 1);
+    // order IJK from lo to hi
+  int lo = 0, hi = 0;
+  for (int i = 1; i < 3; i++) {
+    if (IJK[i] < IJK[lo]) lo = i;
+    if (IJK[i] > IJK[hi]) hi = i;
+  if (lo == hi) hi = (lo+1)%3;
+  int mid = 3 - lo - hi;
+    // search for perfect subdivision of np that balances #cells
+  int perfa_best = -1, perfb_best = -1;
+  double ratio = 0.0;
+  for (int po = 0; po < (int)pfactors.size(); po++) {
+    for (int pi = po; pi < (int)pfactors.size() && np/(pfactors[po]*pfactors[pi]) >= pfactors[pi]; pi++) {
+      int p3 = std::find(pfactors.begin(), pfactors.end(), np/(pfactors[po]*pfactors[pi])) - pfactors.begin();
+      if (p3 == (int)pfactors.size() || pfactors[po]*pfactors[pi]*pfactors[p3] != np) continue; // po*pi should exactly factor np
+      assert(po <= pi && pi <= p3);
+        // by definition, po <= pi <= p3
+      double minl = std::min(std::min(IJK[lo]/pfactors[po], IJK[mid]/pfactors[pi]), IJK[hi]/pfactors[p3]),
+          maxl = std::max(std::max(IJK[lo]/pfactors[po], IJK[mid]/pfactors[pi]), IJK[hi]/pfactors[p3]);
+      if (minl/maxl > ratio) {
+        ratio = minl/maxl;
+        perfa_best = po; perfb_best = pi;
+  if (perfa_best == -1 || perfb_best == -1) return MB_FAILURE;
+    // VARIABLES DESCRIBING THE MESH:
+    // pijk[i] = # procs in direction i
+    // numr[i] = my proc's position in direction i
+    // dIJK[i] = # edges/elements in direction i
+    // extra[i]= # procs having extra edge in direction i
+    // top[i] = if true, I'm the last proc in direction i
+  pijk[lo] = pfactors[perfa_best]; pijk[mid] = pfactors[perfb_best];
+  pijk[hi] = (np/(pfactors[perfa_best]*pfactors[perfb_best]));
+  int extra[3] = {0, 0, 0}, numr[3];
+    dIJK[i] = IJK[i] / pijk[i];
+    extra[i] = IJK[i]%pijk[i];
+  numr[2] = nr / (pijk[0]*pijk[1]);
+  int rem = nr % (pijk[0] * pijk[1]);
+  numr[1] = rem / pijk[0];
+  numr[0] = rem % pijk[0];
+    extra[i] = IJK[i] % dIJK[i];
+    ldims[i] = gijk[i] + numr[i]*dIJK[i] + std::min(extra[i], numr[i]);
+    ldims[3+i] = ldims[i] + dIJK[i] + (numr[i] < extra[i] ? 1 : 0);
 inline int ScdInterface::gtol(const int *gijk, int i, int j, int k)
   return ((k-gijk[2])*(gijk[3]-gijk[0]+1)*(gijk[4]-gijk[1]+1) + (j-gijk[1])*(gijk[3]-gijk[0]+1) + i-gijk[0]);
@@ -1097,6 +1200,9 @@ inline ErrorCode ScdInterface::get_neighbor(int np, int pfrom, const ScdParData
     case ScdParData::SQJK:
         return get_neighbor_sqjk(np, pfrom, spd.gDims, spd.gPeriodic, dijk,
                                  pto, rdims, facedims, across_bdy);
+        return get_neighbor_sqijk(np, pfrom, spd.gDims, spd.gPeriodic, dijk,
+                                  pto, rdims, facedims, across_bdy);
     default:
         break;
@@ -1134,7 +1240,7 @@ inline int ScdBox::num_elements() const
   return (!startElem ? 0 :
           (boxSize[0]- (locallyPeriodic[0] ? 0 : 1)) *
           (-1 == boxSize[1] ? 1 : (boxSize[1]-(locallyPeriodic[1] ? 0 : 1))) *
-          (boxSize[2] == -1 || boxSize[2] == 1 ? 1 : (boxSize[2]-1)));
+          (boxSize[2] == -1 || boxSize[2] == 1 ? 1 : (boxSize[2]-(locallyPeriodic[2] ? 0 : 1))));
 inline int ScdBox::num_vertices() const
@@ -1267,11 +1373,27 @@ inline bool ScdBox::locally_periodic_j() const
   return locallyPeriodic[1];
-inline void ScdBox::locally_periodic(bool lperiodic[2]) const
+inline bool ScdBox::locally_periodic_k() const
+  return locallyPeriodic[2];
+inline void ScdBox::locally_periodic(bool lperiodic[3]) const
     lperiodic[i] = locallyPeriodic[i];
+inline std::ostream &operator<<(std::ostream &str, const ScdParData &pd)
+  static const char *PartitionMethodNames[] = {"NOPART", "ALLJORKORI", "ALLJKBAL", "SQIJ", "SQJK", "SQIJK"};
+  str << "Partition method = " << PartitionMethodNames[pd.partMethod] << ", gDims = ("
+      << pd.gDims[0] << "," << pd.gDims[1] << "," << pd.gDims[2] << ")-("
+      << pd.gDims[3] << "," << pd.gDims[4] << "," << pd.gDims[5] << "), gPeriodic = ("
+      << pd.gPeriodic[0] << ", " << pd.gPeriodic[1] << "," << pd.gPeriodic[2] << "), pDims = ("
+      << pd.pDims[0] << "," << pd.pDims[1] << "," << pd.pDims[2] << ")" << std::endl;
+  return str;
 } // namespace moab
 #endif
diff --git a/test/Makefile.am b/test/Makefile.am
index fbf76e1..5b63e9e 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -27,6 +27,7 @@ TESTS = range_test \
         moab_test \
         homxform_test \
         scdseq_test \
+        scd_test_partn \
         test_adj \
         seq_man_test \
         geom_util_test \
@@ -87,6 +88,7 @@ homxform_test_SOURCES = $(top_srcdir)/src/HomXform.cpp
 homxform_test_CPPFLAGS = -DTEST $(AM_CPPFLAGS) $(CPPFLAGS)
 scdseq_test_SOURCES = scdseq_test.cpp
+scd_test_partn_SOURCES = scd_test_partn.cpp
 #scdseq_timing_SOURCES = scdseq_timing.cpp
 #merge_test_SOURCES = merge_test.cpp
 #test_exo_SOURCES = test_exo.cpp
diff --git a/test/scd_test_partn.cpp b/test/scd_test_partn.cpp
new file mode 100644
index 0000000..59a63c5
--- /dev/null
+++ b/test/scd_test_partn.cpp
@@ -0,0 +1,68 @@
+#include "moab/ScdInterface.hpp"
+#include "moab/Core.hpp"
+#include "TestUtil.hpp"
+#include <iostream>
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#endif
+using namespace moab;
+int gdims[6], np;
+void test_sqijk()
+  Core moab;
+  ScdInterface *scd;
+  ErrorCode rval = moab.Interface::query_interface(scd);
+  CHECK_ERR(rval);
+  int ldims[6];
+  ScdParData par_data;
+  std::copy(gdims, gdims+6, par_data.gDims);
+  for (int i = 0; i < 3; i++) par_data.gPeriodic[i] = 0;
+  par_data.partMethod = ScdParData::SQIJK;
+  std::cout << "gDims =  (" << par_data.gDims[0] << "," << par_data.gDims[1] << "," << par_data.gDims[2] << ")--("
+            << par_data.gDims[3] << "," << par_data.gDims[4] << "," << par_data.gDims[5] << ")" << std::endl;
+  int lperiodic[3], pijk[3];
+  rval = ScdInterface::compute_partition(np, 0, par_data, ldims, lperiodic, pijk); CHECK_ERR(rval);
+  std::cout << "#proc in 3 directions = (" << pijk[0] << "," << pijk[1] << "," << pijk[2] << ")" << std::endl;
+  std::cout << "local dims are ("
+            << ldims[0] << "," << ldims[1] << "," << ldims[2] << ")--("
+            << ldims[3] << "," << ldims[4] << "," << ldims[5] << ")\n";
+int main(int argc, char**argv)
+  if (argc < 2) {
+    std::cout << "Usage: " << argv[0] << " <#proc> [<imax> [<jmax><kmax>]]" << std::endl;
+    exit(1);
+  if (argc < 3) {
+    np = atoi(argv[1]);
+    gdims[0] = gdims[1] = gdims[2] = 0;
+    gdims[3] = gdims[4] = gdims[5] = 100;
+  else if (argc < 4) {
+    gdims[3] = gdims[4] = gdims[5] = atoi(argv[2]);
+  else if (argc < 6) {
+    gdims[3] = atoi(argv[2]);
+    gdims[4] = atoi(argv[3]);
+    gdims[5] = atoi(argv[4]);
+    // test partition method
+  RUN_TEST(test_sqijk);
diff --git a/test/scdseq_test.cpp b/test/scdseq_test.cpp
index 651eec9..e5acb0d 100644
--- a/test/scdseq_test.cpp
+++ b/test/scdseq_test.cpp
@@ -264,17 +264,18 @@ ErrorCode evaluate_element_sequence(ScdBox *this_box)
 int main(int, char**)
     // test partition methods
-  RUN_TEST(test_parallel_partitions);
+  int err = RUN_TEST(test_parallel_partitions);
     // test creating and evaluating vertex sequences
-  RUN_TEST(test_vertex_seq);
+  err += RUN_TEST(test_vertex_seq);
     // test creating and evaluating element sequences
-  RUN_TEST(test_element_seq);
+  err += RUN_TEST(test_element_seq);
     // test periodic sequences
-  RUN_TEST(test_periodic_seq);
+  err += RUN_TEST(test_periodic_seq);
+  return err;
 void test_vertex_seq()
@@ -1324,38 +1325,48 @@ void test_parallel_partitions()
 #ifndef NDEBUG
   maxpow = 4;
 #endif
+  int fails = 0;
   for (int exp = 2; exp <= maxpow; exp += 2) {
     int nprocs = 0.1 + pow(2.0, (double)exp);
     // alljorkori
     rval = test_parallel_partition(gdims, nprocs, ScdParData::ALLJORKORI);
-    CHECK_ERR(rval);
+    if (MB_SUCCESS != rval) fails++;
     // alljkbal
     rval = test_parallel_partition(gdims, nprocs, ScdParData::ALLJKBAL);
-    CHECK_ERR(rval);
     // sqij
     rval = test_parallel_partition(gdims, nprocs, ScdParData::SQIJ);
-    CHECK_ERR(rval);
     // sqjk
     rval = test_parallel_partition(gdims, nprocs, ScdParData::SQJK);
-    CHECK_ERR(rval);
+      // sqijk
+    rval = test_parallel_partition(gdims, nprocs, ScdParData::SQIJK);
+  if (fails) CHECK_ERR(MB_FAILURE);
 ErrorCode test_parallel_partition(int *gdims, int nprocs, int part_method)
   ErrorCode rval;
-  int pto, pfrom, across_bdy_a[2], across_bdy_b[2], rdims_a[6], rdims_b[6], facedims_a[6], facedims_b[6], ldims[6];
+  int pto, pfrom, across_bdy_a[2], across_bdy_b[2], rdims_a[6], rdims_b[6], facedims_a[6], facedims_b[6], ldims[6],
+      lper[2], pijk[3];
   ScdParData spd;
   for (int i = 0; i < 6; i++) spd.gDims[i] = gdims[i];
-  for (int i = 0; i < 2; i++) spd.gPeriodic[i] = 0;
+  for (int i = 0; i < 3; i++) spd.gPeriodic[i] = 0;
   spd.partMethod = part_method;
+  int fails = 0;
   for (int p = 0; p < nprocs/2; p++) {
-    rval = ScdInterface::compute_partition(nprocs, p, spd, ldims);
+    rval = ScdInterface::compute_partition(nprocs, p, spd, ldims, lper, pijk);
     if (MB_SUCCESS != rval) continue;
     for (int k = -1; k <= 1; k++) {
@@ -1367,9 +1378,10 @@ ErrorCode test_parallel_partition(int *gdims, int nprocs, int part_method)
           if (-1 == pto) continue;
+          bool fail = false;
           if (facedims_a[0] < rdims_a[0] || facedims_a[0] > rdims_a[3] ||
               facedims_a[1] < rdims_a[1] || facedims_a[1] > rdims_a[4] ||
-              facedims_a[2] < rdims_a[2] || facedims_a[2] > rdims_a[5]) CHECK_ERR(MB_FAILURE);
+              facedims_a[2] < rdims_a[2] || facedims_a[2] > rdims_a[5]) fail = true;
             // non-negative value of pto; check corresponding input from that proc to this
@@ -1378,18 +1390,29 @@ ErrorCode test_parallel_partition(int *gdims, int nprocs, int part_method)
                                             pfrom, rdims_b, facedims_b, across_bdy_b);
           for (int ind = 0; ind < 3; ind++)
-            if (facedims_a[ind] < rdims_b[ind] || facedims_b[ind] > rdims_b[ind+3]) CHECK_ERR(MB_FAILURE);
+            if (facedims_a[ind] < rdims_b[ind] || facedims_b[ind] > rdims_b[ind+3]) fail = true;
           for (int ind = 0; ind < 6; ind++) {
-            if (facedims_a[ind] != facedims_b[ind]) CHECK_ERR(MB_FAILURE);
-            if (rdims_b[ind] != ldims[ind]) CHECK_ERR(MB_FAILURE);
+            if (facedims_a[ind] != facedims_b[ind] || rdims_b[ind] != ldims[ind]) fail = true;
+          if (across_bdy_a[0] != across_bdy_b[0] || across_bdy_a[1] != across_bdy_b[1]) fail = true;
+#define PARRAY(a) "(" << a[0] << "," << a[1] << "," << a[2] << ")"
+#define PARRAY3(a,b,c) "(" << a << "," << b << "," << c << ")"
+#define PARRAY6(a) PARRAY(a) << "-" << PARRAY((a+3))
+          if (fail) {
+            fails++;
+            for (int l = 0; l < 3; l++) spd.pDims[l] = pijk[l];
+            std::cerr << "partMeth = " << part_method << ", p/np = " << p << "/" << nprocs
+                      << ", (i,j,k) = " << PARRAY3(i,j,k) << ", ldims = " << PARRAY6(ldims) << std::endl
+                      << "facedims_a = " << PARRAY6(facedims_a)
+                      << ", facedims_b = " << PARRAY6(facedims_b) << std::endl
+                      << "rdims_a = " << PARRAY6(rdims_a) << ", rdims_b = " << PARRAY6(rdims_b) << std::endl;
+            std::cerr << "ScdParData: " << spd << std::endl;
-          if (across_bdy_a[0] != across_bdy_b[0] || across_bdy_a[1] != across_bdy_b[1]) CHECK_ERR(MB_FAILURE);
         } // i
       } // j
     } // k
   } // p
-  return MB_SUCCESS;
+  return (fails ? MB_FAILURE : MB_SUCCESS);
https://bitbucket.org/fathomteam/moab/commits/0a8790877bff/
Changeset:   0a8790877bff
Branch:      master
User:        tautges
Date:        2013-08-12 21:53:17
Summary:     Merge branch 'master' of git at bitbucket.org:fathomteam/moab.git
Conflicts:
	src/io/NCHelper.cpp
	src/io/ReadNC.hpp
Affected #:  9 files
index c3cd286..851d9b1 100644
@@ -4,6 +4,8 @@
 #include "NCHelperHOMME.hpp"
 #include "NCHelperMPAS.hpp"
+#include <sstream>
 #include "moab/ReadUtilIface.hpp"
 #include "MBTagConventions.hpp"
@@ -52,89 +54,254 @@ NCHelper* NCHelper::get_nc_helper(ReadNC* readNC, int fileId, const FileOptions&
   return NULL;
-ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelper::create_conventional_tags(ScdInterface* scdi, EntityHandle file_set, const std::vector<int>& tstep_nums) {
+  Interface*& mbImpl = _readNC->mbImpl;
+  std::vector<std::string>& dimNames = _readNC->dimNames;
   std::vector<int>& dimVals = _readNC->dimVals;
-  int tDim = _readNC->tDim;
+  std::map<std::string, ReadNC::AttData>& globalAtts = _readNC->globalAtts;
+  std::map<std::string, ReadNC::VarData>& varInfo = _readNC->varInfo;
+  int& partMethod = _readNC->partMethod;
+  ErrorCode rval;
+  std::string tag_name;
+  // <__NUM_DIMS>
+  Tag numDimsTag = 0;
+  tag_name = "__NUM_DIMS";
+  int numDims = dimNames.size();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 1, MB_TYPE_INTEGER, numDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+  ERRORR(rval, "Trouble creating __NUM_DIMS tag.");
+  rval = mbImpl->tag_set_data(numDimsTag, &file_set, 1, &numDims);
+  ERRORR(rval, "Trouble setting data for __NUM_DIMS tag.");
+  if (MB_SUCCESS == rval)
+    dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
+  // <__NUM_VARS>
+  Tag numVarsTag = 0;
+  tag_name = "__NUM_VARS";
+  int numVars = varInfo.size();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 1, MB_TYPE_INTEGER, numVarsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+  ERRORR(rval, "Trouble creating __NUM_VARS tag.");
+  rval = mbImpl->tag_set_data(numVarsTag, &file_set, 1, &numVars);
+  ERRORR(rval, "Trouble setting data for __NUM_VARS tag.");
+  // <__DIM_NAMES>
+  Tag dimNamesTag = 0;
+  tag_name = "__DIM_NAMES";
+  std::string dimnames;
+  unsigned int dimNamesSz = dimNames.size();
+  for (unsigned int i = 0; i != dimNamesSz; ++i) {
+    dimnames.append(dimNames[i]);
+    dimnames.push_back('\0');
+  int dimnamesSz = dimnames.size();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, dimNamesTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __DIM_NAMES tag.");
+  const void* ptr = dimnames.c_str();
+  rval = mbImpl->tag_set_by_ptr(dimNamesTag, &file_set, 1, &ptr, &dimnamesSz);
+  ERRORR(rval, "Trouble setting data for __DIM_NAMES tag.");
+  // <__DIM_VALUES>
+  Tag dimValsTag = 0;
+  tag_name = "__DIM_VALUES";
+  int dimValsSz = (int)dimVals.size();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_INTEGER, dimValsTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __DIM_VALUES tag.");
+  ptr = &(dimVals[0]);
+  rval = mbImpl->tag_set_by_ptr(dimValsTag, &file_set, 1, &ptr, &dimValsSz);
+  ERRORR(rval, "Trouble setting data for __DIM_VALUES tag.");
+  // <__VAR_NAMES>
+  Tag varNamesTag = 0;
+  tag_name = "__VAR_NAMES";
+  std::string varnames;
+  std::map<std::string, ReadNC::VarData>::iterator mapIter;
+  for (mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter) {
+    varnames.append(mapIter->first);
+    varnames.push_back('\0');
+  int varnamesSz = varnames.size();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, varNamesTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __VAR_NAMES tag.");
+  ptr = varnames.c_str();
+  rval = mbImpl->tag_set_by_ptr(varNamesTag, &file_set, 1, &ptr, &varnamesSz);
+  ERRORR(rval, "Trouble setting data for __VAR_NAMES tag.");
+  // __<dim_name>_LOC_MINMAX
+    if (dimNames[i] == "time") {
+      std::stringstream ss_tag_name;
+      ss_tag_name << "__" << dimNames[i] << "_LOC_MINMAX";
+      tag_name = ss_tag_name.str();
+      Tag tagh = 0;
+      std::vector<int> val(2, 0);
+      val[0] = 0;
+      val[1] = nTimeSteps - 1;
+      rval = mbImpl->tag_get_handle(tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
+      ERRORR(rval, "Trouble creating __<dim_name>_LOC_MINMAX tag.");
+      rval = mbImpl->tag_set_data(tagh, &file_set, 1, &val[0]);
+      ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_MINMAX tag.");
-  ErrorCode rval = MB_SUCCESS;
-  for (unsigned int i = 0; i < vdatas.size(); i++) {
-    if ((std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim) != vdatas[i].varDims.end()))
-      vdatas[i].has_t = true;
-    for (unsigned int t = 0; t < tstep_nums.size(); t++) {
-      dbgOut.tprintf(2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
-      // Get the tag to read into
-      if (!vdatas[i].varTags[t]) {
-        rval = _readNC->get_tag_to_set(vdatas[i], tstep_nums[t], vdatas[i].varTags[t]);
-        ERRORR(rval, "Trouble getting tag.");
+  // __<dim_name>_LOC_VALS
+    if (dimNames[i] != "time")
+      continue;
+    std::vector<int> val;
+    if (!tstep_nums.empty())
+      val = tstep_nums;
+    else {
+      val.resize(tVals.size());
+      for (unsigned int j = 0; j != tVals.size(); ++j)
+        val[j] = j;
+    Tag tagh = 0;
+    ss_tag_name << "__" << dimNames[i] << "_LOC_VALS";
+    rval = mbImpl->tag_get_handle(tag_name.c_str(), val.size(), MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
+    ERRORR(rval, "Trouble creating __<dim_name>_LOC_VALS tag.");
+    ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_VALS tag.");
-      // Assume point-based values for now?
-      if (-1 == tDim || dimVals[tDim] <= (int) t)
-        ERRORR(MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number.");
+  // __<var_name>_DIMS
+    Tag varNamesDimsTag = 0;
+    ss_tag_name << "__" << mapIter->first << "_DIMS";
+    unsigned int varDimSz = varInfo[mapIter->first].varDims.size();
+    if (varDimSz == 0)
+      continue;
+    varInfo[mapIter->first].varTags.resize(varDimSz, 0);
+    for (unsigned int i = 0; i != varDimSz; ++i) {
+      Tag tmptag = 0;
+      std::string tmptagname = dimNames[varInfo[mapIter->first].varDims[i]];
+      mbImpl->tag_get_handle(tmptagname.c_str(), 0, MB_TYPE_OPAQUE, tmptag, MB_TAG_ANY);
+      varInfo[mapIter->first].varTags[i] = tmptag;
+    rval = mbImpl->tag_get_handle(tag_name.c_str(), varDimSz, MB_TYPE_HANDLE, varNamesDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+    ERRORR(rval, "Trouble creating __<var_name>_DIMS tag.");
+    rval = mbImpl->tag_set_data(varNamesDimsTag, &file_set, 1, &(varInfo[mapIter->first].varTags[0]));
+    ERRORR(rval, "Trouble setting data for __<var_name>_DIMS tag.");
-      // Set up the dimensions and counts
-      // First variable dimension is time, if it exists
-      if (vdatas[i].has_t)
-        if (vdatas[i].varDims.size() != 1)
-          vdatas[i].readStarts[t].push_back(tstep_nums[t]);
-          vdatas[i].readCounts[t].push_back(1);
-        else
-          vdatas[i].readStarts[t].push_back(0);
-          vdatas[i].readCounts[t].push_back(tstep_nums.size());
+  // <PARTITION_METHOD>
+  Tag part_tag = scdi->part_method_tag();
+  if (!part_tag)
+    ERRORR(MB_FAILURE, "Trouble getting partition method tag.");
+  rval = mbImpl->tag_set_data(part_tag, &file_set, 1, &partMethod);
+  ERRORR(rval, "Trouble setting data for PARTITION_METHOD tag.");
+  // <__GLOBAL_ATTRIBS>
+  tag_name = "__GLOBAL_ATTRIBS";
+  Tag globalAttTag = 0;
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __GLOBAL_ATTRIBS tag.");
+  std::string gattVal;
+  std::vector<int> gattLen;
+  rval = create_attrib_string(globalAtts, gattVal, gattLen);
+  ERRORR(rval, "Trouble creating attribute strings.");
+  const void* gattptr = gattVal.c_str();
+  int globalAttSz = gattVal.size();
+  rval = mbImpl->tag_set_by_ptr(globalAttTag, &file_set, 1, &gattptr, &globalAttSz);
+  ERRORR(rval, "Trouble setting data for __GLOBAL_ATTRIBS tag.");
+  // <__GLOBAL_ATTRIBS_LEN>
+  tag_name = "__GLOBAL_ATTRIBS_LEN";
+  Tag globalAttLenTag = 0;
+  if (gattLen.size() == 0)
+    gattLen.push_back(0);
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), gattLen.size(), MB_TYPE_INTEGER, globalAttLenTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+  ERRORR(rval, "Trouble creating __GLOBAL_ATTRIBS_LEN tag.");
+  rval = mbImpl->tag_set_data(globalAttLenTag, &file_set, 1, &gattLen[0]);
+  ERRORR(rval, "Trouble setting data for __GLOBAL_ATTRIBS_LEN tag.");
+  // __<var_name>_ATTRIBS and __<var_name>_ATTRIBS_LEN
+    std::stringstream ssTagName;
+    ssTagName << "__" << mapIter->first << "_ATTRIBS";
+    tag_name = ssTagName.str();
+    Tag varAttTag = 0;
+    rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+    ERRORR(rval, "Trouble creating __<var_name>_ATTRIBS tag.");
+    std::string varAttVal;
+    std::vector<int> varAttLen;
+    rval = create_attrib_string(mapIter->second.varAtts, varAttVal, varAttLen);
+    const void* varAttPtr = varAttVal.c_str();
+    int varAttSz = varAttVal.size();
+    rval = mbImpl->tag_set_by_ptr(varAttTag, &file_set, 1, &varAttPtr, &varAttSz);
+    ERRORR(rval, "Trouble setting data for __<var_name>_ATTRIBS tag.");
+    if (varAttLen.size() == 0)
+      varAttLen.push_back(0);
+    ssTagName << "_LEN";
+    Tag varAttLenTag = 0;
+    rval = mbImpl->tag_get_handle(tag_name.c_str(), varAttLen.size(), MB_TYPE_INTEGER, varAttLenTag, MB_TAG_SPARSE | MB_TAG_CREAT);
+    ERRORR(rval, "Trouble creating __<var_name>_ATTRIBS_LEN tag.");
+    rval = mbImpl->tag_set_data(varAttLenTag, &file_set, 1, &varAttLen[0]);
+    ERRORR(rval, "Trouble setting data for __<var_name>_ATTRIBS_LEN tag.");
-      // Set up other dimensions and counts
-      if (vdatas[i].varDims.empty()) {
-        // Scalar variable
-      else {
-        for (unsigned int idx = 0; idx != vdatas[i].varDims.size(); idx++){
-          if (tDim != vdatas[i].varDims[idx]){
-            // Push other variable dimensions, except time, which was already pushed
-            vdatas[i].readCounts[t].push_back(dimVals[vdatas[i].varDims[idx]]);
-      std::size_t sz = 1;
-      for (std::size_t idx = 0; idx != vdatas[i].readCounts[t].size(); idx++)
-        sz *= vdatas[i].readCounts[t][idx];
-      vdatas[i].sz = sz;
-      switch (vdatas[i].varDataType) {
-        case NC_BYTE:
-        case NC_CHAR:
-          vdatas[i].varDatas[t] = new char[sz];
-          break;
-        case NC_DOUBLE:
-        case NC_FLOAT:
-          vdatas[i].varDatas[t] = new double[sz];
-          break;
-        case NC_INT:
-        case NC_SHORT:
-          vdatas[i].varDatas[t] = new int[sz];
-          break;
-        default:
-          std::cerr << "Unrecognized data type for tag " << std::endl;
-          rval = MB_FAILURE;
-      if (vdatas[i].varDims.size() <= 1)
-        break;
+  // <__VAR_NAMES_LOCATIONS>
+  tag_name = "__VAR_NAMES_LOCATIONS";
+  Tag varNamesLocsTag = 0;
+  std::vector<int> varNamesLocs(varInfo.size());
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), varNamesLocs.size(), MB_TYPE_INTEGER, varNamesLocsTag, MB_TAG_CREAT
+      | MB_TAG_SPARSE);
+  ERRORR(rval, "Trouble creating __VAR_NAMES_LOCATIONS tag.");
+    varNamesLocs[std::distance(varInfo.begin(), mapIter)] = mapIter->second.entLoc;
+  rval = mbImpl->tag_set_data(varNamesLocsTag, &file_set, 1, &varNamesLocs[0]);
+  ERRORR(rval, "Trouble setting data for __VAR_NAMES_LOCATIONS tag.");
+  // <__MESH_TYPE>
+  Tag meshTypeTag = 0;
+  tag_name = "__MESH_TYPE";
+  std::string meshTypeName = get_mesh_type_name();
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __MESH_TYPE tag.");
+  ptr = meshTypeName.c_str();
+  int leng= meshTypeName.size();
+  rval = mbImpl->tag_set_by_ptr(meshTypeTag, &file_set, 1, &ptr, &leng);
+  ERRORR(rval, "Trouble setting data for __MESH_TYPE tag.");
-  return rval;
 ErrorCode NCHelper::read_variable_to_set(EntityHandle file_set, std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -314,9 +481,301 @@ ErrorCode NCHelper::convert_variable(ReadNC::VarData& var_data, int tstep_num)
   return MB_SUCCESS;
+ErrorCode NCHelper::read_coordinate(const char* var_name, int lmin, int lmax, std::vector<double>& cvals)
+  std::map<std::string, ReadNC::VarData>::iterator vmit = varInfo.find(var_name);
+  if (varInfo.end() == vmit)
+  assert(lmin >= 0 && lmax >= lmin);
+  NCDF_SIZE tstart = lmin;
+  NCDF_SIZE tcount = lmax - lmin + 1;
+  NCDF_DIFF dum_stride = 1;
+  int fail;
+  // Check size
+  if (tcount != cvals.size())
+    cvals.resize(tcount);
+  // Check to make sure it's a float or double
+  if (NC_DOUBLE == (*vmit).second.varDataType) {
+    fail = NCFUNCA(get_vars_double)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &cvals[0]);
+    if (fail)
+      ERRORS(MB_FAILURE, "Failed to get coordinate values.");
+  else if (NC_FLOAT == (*vmit).second.varDataType) {
+    std::vector<float> tcvals(tcount);
+    fail = NCFUNCA(get_vars_float)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &tcvals[0]);
+    if (fail)
+    std::copy(tcvals.begin(), tcvals.end(), cvals.begin());
+  else {
+    ERRORR(MB_FAILURE, "Wrong data type for coordinate variable.");
+ErrorCode NCHelper::get_tag_to_set(ReadNC::VarData& var_data, int tstep_num, Tag& tagh)
+  DebugOutput& dbgOut = _readNC->dbgOut;
+  std::ostringstream tag_name;
+  if ((!var_data.has_t) || (var_data.varDims.size() <= 1))
+    tag_name << var_data.varName;
+  else if (!tstep_num) {
+    std::string tmp_name = var_data.varName + "0";
+    tag_name << tmp_name.c_str();
+  else
+    tag_name << var_data.varName << tstep_num;
+  ErrorCode rval = MB_SUCCESS;
+  tagh = 0;
+  switch (var_data.varDataType) {
+    case NC_BYTE:
+    case NC_CHAR:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), 0, MB_TYPE_OPAQUE, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+      break;
+    case NC_DOUBLE:
+    case NC_FLOAT:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), 0, MB_TYPE_DOUBLE, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+      break;
+    case NC_INT:
+    case NC_SHORT:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), 0, MB_TYPE_INTEGER, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+      break;
+    default:
+      std::cerr << "Unrecognized data type for tag " << tag_name << std::endl;
+      rval = MB_FAILURE;
+    dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.str().c_str());
+  return rval;
+ErrorCode NCHelper::get_tag_to_nonset(ReadNC::VarData& var_data, int tstep_num, Tag& tagh, int num_lev)
+  if (!tstep_num) {
+  else
+  tagh = 0;
+    case NC_BYTE:
+    case NC_CHAR:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), num_lev, MB_TYPE_OPAQUE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+      break;
+    case NC_DOUBLE:
+    case NC_FLOAT:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), num_lev, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+      break;
+    case NC_INT:
+    case NC_SHORT:
+      rval = mbImpl->tag_get_handle(tag_name.str().c_str(), num_lev, MB_TYPE_INTEGER, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+      break;
+    default:
+      std::cerr << "Unrecognized data type for tag " << tag_name.str() << std::endl;
+  return rval;
+ErrorCode NCHelper::create_attrib_string(const std::map<std::string, ReadNC::AttData>& attMap, std::string& attVal, std::vector<int>& attLen)
+  int success;
+  std::stringstream ssAtt;
+  unsigned int sz = 0;
+  std::map<std::string, ReadNC::AttData>::const_iterator attIt = attMap.begin();
+  for (; attIt != attMap.end(); ++attIt) {
+    ssAtt << attIt->second.attName;
+    ssAtt << '\0';
+    void* attData = NULL;
+    switch (attIt->second.attDataType) {
+      case NC_BYTE:
+      case NC_CHAR:
+        sz = attIt->second.attLen;
+        attData = (char *) malloc(sz);
+        success = NCFUNC(get_att_text)(_fileId, attIt->second.attVarId, attIt->second.attName.c_str(), (char*) attData);
+        ERRORS(success, "Failed to read attribute char data.");
+        ssAtt << "char;";
+        break;
+      case NC_DOUBLE:
+        sz = attIt->second.attLen * sizeof(double);
+        attData = (double *) malloc(sz);
+        success = NCFUNC(get_att_double)(_fileId, attIt->second.attVarId, attIt->second.attName.c_str(), (double*) attData);
+        ERRORS(success, "Failed to read attribute double data.");
+        ssAtt << "double;";
+        break;
+      case NC_FLOAT:
+        sz = attIt->second.attLen * sizeof(float);
+        attData = (float *) malloc(sz);
+        success = NCFUNC(get_att_float)(_fileId, attIt->second.attVarId, attIt->second.attName.c_str(), (float*) attData);
+        ERRORS(success, "Failed to read attribute float data.");
+        ssAtt << "float;";
+        break;
+      case NC_INT:
+        sz = attIt->second.attLen * sizeof(int);
+        attData = (int *) malloc(sz);
+        success = NCFUNC(get_att_int)(_fileId, attIt->second.attVarId, attIt->second.attName.c_str(), (int*) attData);
+        ERRORS(success, "Failed to read attribute int data.");
+        ssAtt << "int;";
+        break;
+      case NC_SHORT:
+        sz = attIt->second.attLen * sizeof(short);
+        attData = (short *) malloc(sz);
+        success = NCFUNC(get_att_short)(_fileId, attIt->second.attVarId, attIt->second.attName.c_str(), (short*) attData);
+        ERRORS(success, "Failed to read attribute short data.");
+        ssAtt << "short;";
+        break;
+      default:
+        success = 1;
+    char* tmpc = (char *) attData;
+    for (unsigned int counter = 0; counter != sz; ++counter)
+      ssAtt << tmpc[counter];
+    free(attData);
+    ssAtt << ';';
+    attLen.push_back(ssAtt.str().size() - 1);
+  attVal = ssAtt.str();
+void NCHelper::init_dims_with_no_cvars_info()
+  std::set<std::string>& dummyVarNames = _readNC->dummyVarNames;
+  // Hack: look at all dimensions, and see if we have one that does not appear in the list of varInfo names
+  // right now, candidates are ncol and nbnd
+  // for them, create dummy tags
+  for (unsigned int i = 0; i < dimNames.size(); i++)
+    // If there is a var with this name, skip, we are fine; if not, create a varInfo...
+    if (varInfo.find(dimNames[i]) != varInfo.end())
+      continue; // We already have a variable with this dimension name
+    int sizeTotalVar = varInfo.size();
+    std::string var_name(dimNames[i]);
+    ReadNC::VarData &data = varInfo[var_name];
+    data.varName = std::string(var_name);
+    data.varId =sizeTotalVar;
+    data.varTags.resize(1, 0);
+    data.varDataType = NC_DOUBLE; // Could be int, actually, but we do not really need the type
+    data.varDims.resize(1);
+    data.varDims[0]= (int)i;
+    data.numAtts=0;
+    data.entLoc = ReadNC::ENTLOCSET;
+    dbgOut.tprintf(2, "Dummy varInfo created for dimension %s\n", dimNames[i].c_str());
+    dummyVarNames.insert(dimNames[i]);
+ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+  std::vector<int>& dimVals = _readNC->dimVals;
+  for (unsigned int i = 0; i < vdatas.size(); i++) {
+    if ((std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim) != vdatas[i].varDims.end()))
+      vdatas[i].has_t = true;
+    for (unsigned int t = 0; t < tstep_nums.size(); t++) {
+      dbgOut.tprintf(2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
+      // Get the tag to read into
+      if (!vdatas[i].varTags[t]) {
+        rval = get_tag_to_set(vdatas[i], tstep_nums[t], vdatas[i].varTags[t]);
+        ERRORR(rval, "Trouble getting tag.");
+      // Assume point-based values for now?
+      if (-1 == tDim || dimVals[tDim] <= (int) t)
+        ERRORR(MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number.");
+      // Set up the dimensions and counts
+      // First variable dimension is time, if it exists
+      if (vdatas[i].has_t)
+        if (vdatas[i].varDims.size() != 1)
+          vdatas[i].readStarts[t].push_back(tstep_nums[t]);
+          vdatas[i].readCounts[t].push_back(1);
+        else
+          vdatas[i].readStarts[t].push_back(0);
+          vdatas[i].readCounts[t].push_back(tstep_nums.size());
+      // Set up other dimensions and counts
+      if (vdatas[i].varDims.empty()) {
+        // Scalar variable
+      else {
+        for (unsigned int idx = 0; idx != vdatas[i].varDims.size(); idx++){
+          if (tDim != vdatas[i].varDims[idx]){
+            // Push other variable dimensions, except time, which was already pushed
+            vdatas[i].readCounts[t].push_back(dimVals[vdatas[i].varDims[idx]]);
+      std::size_t sz = 1;
+      for (std::size_t idx = 0; idx != vdatas[i].readCounts[t].size(); idx++)
+        sz *= vdatas[i].readCounts[t][idx];
+      vdatas[i].sz = sz;
+      switch (vdatas[i].varDataType) {
+        case NC_BYTE:
+        case NC_CHAR:
+          vdatas[i].varDatas[t] = new char[sz];
+          break;
+        case NC_DOUBLE:
+        case NC_FLOAT:
+          vdatas[i].varDatas[t] = new double[sz];
+          break;
+        case NC_INT:
+        case NC_SHORT:
+          vdatas[i].varDatas[t] = new int[sz];
+          break;
+        default:
+          std::cerr << "Unrecognized data type for tag " << std::endl;
+      if (vdatas[i].varDims.size() <= 1)
+        break;
+  return rval;
 ErrorCode ScdNCHelper::check_existing_mesh(EntityHandle file_set) {
-  int (&lDims)[6] = _readNC->lDims;
   // Get the number of vertices
   int num_verts;
@@ -358,15 +817,8 @@ ErrorCode ScdNCHelper::check_existing_mesh(EntityHandle file_set) {
 ErrorCode ScdNCHelper::create_mesh(ScdInterface* scdi, const FileOptions& opts, EntityHandle file_set, Range& faces)
-  int (&gDims)[6] = _readNC->gDims;
-  std::vector<double>& ilVals = _readNC->ilVals;
-  std::vector<double>& jlVals = _readNC->jlVals;
-  std::vector<double>& klVals = _readNC->klVals;
-  int (&locallyPeriodic)[3] = _readNC->locallyPeriodic;
-  int (&globallyPeriodic)[3] = _readNC->globallyPeriodic;
   Range tmp_range;
@@ -406,7 +858,7 @@ ErrorCode ScdNCHelper::create_mesh(ScdInterface* scdi, const FileOptions& opts,
   int di = gDims[3] - gDims[0] + 1;
   int dj = gDims[4] - gDims[1] + 1;
   assert(dil == (int)ilVals.size() && djl == (int)jlVals.size() &&
-      (-1 == lDims[2] || lDims[5]-lDims[2]+1 == (int)klVals.size()));
+      (-1 == lDims[2] || lDims[5]-lDims[2] + 1 == (int)levVals.size()));
 #define INDEX(i, j, k) ()
   for (kl = lDims[2]; kl <= lDims[5]; kl++) {
     k = kl - lDims[2];
@@ -417,7 +869,7 @@ ErrorCode ScdNCHelper::create_mesh(ScdInterface* scdi, const FileOptions& opts,
         unsigned int pos = i + j * dil + k * dil * djl;
         xc[pos] = ilVals[i];
         yc[pos] = jlVals[j];
-        zc[pos] = (-1 == lDims[2] ? 0.0 : klVals[k]);
+        zc[pos] = (-1 == lDims[2] ? 0.0 : levVals[k]);
         itmp = (!locallyPeriodic[0] && globallyPeriodic[0] && il == gDims[3] ? gDims[0] : il);
         *gid_data = (-1 != kl ? kl * di * dj : 0) + jl * di + itmp + 1;
         gid_data++;
@@ -468,7 +920,7 @@ ErrorCode ScdNCHelper::read_variables(EntityHandle file_set, std::vector<std::st
   ERRORR(rval, "Trouble setting up read variable.");
   // Create COORDS tag for quads
-  rval = _readNC->create_quad_coordinate_tag(file_set);
+  rval = create_quad_coordinate_tag(file_set);
   ERRORR(rval, "Trouble creating coordinate tags to entities quads");
   if (!vsetdatas.empty()) {
@@ -488,14 +940,6 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
                                                std::vector<ReadNC::VarData>& vdatas, std::vector<ReadNC::VarData>& vsetdatas)
-  int& tMin = _readNC->tMin;
-  int& tMax = _readNC->tMax;
-  int& iDim = _readNC->iDim;
-  int& jDim = _readNC->jDim;
-  int& tDim = _readNC->tDim;
-  int& iCDim = _readNC->iCDim;
-  int& jCDim = _readNC->jCDim;
   std::map<std::string, ReadNC::VarData>::iterator mit;
   // If empty read them all
@@ -536,9 +980,9 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
-  if (tstep_nums.empty() && -1 != tMin) {
+  if (tstep_nums.empty() && nTimeSteps > 0) {
     // No timesteps input, get them all
-    for (int i = tMin; i <= tMax; i++)
+    for (int i = 0; i < nTimeSteps; i++)
       tstep_nums.push_back(i);
   if (!tstep_nums.empty()) {
@@ -571,16 +1015,9 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
 ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_set, std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
-  std::vector<std::string>& dimNames = _readNC->dimNames;
-  int (&lCDims)[6] = _readNC->lCDims;
- #ifdef USE_MPI
-  ParallelComm*& myPcomm = _readNC->myPcomm;
-#endif
@@ -606,8 +1043,8 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_se
 #ifdef USE_MPI
   moab::Range faces_owned;
-  if (isParallel)
+  if (isParallel) {
+    ParallelComm*& myPcomm = _readNC->myPcomm;
     rval = myPcomm->filter_pstatus(faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &faces_owned);
     ERRORR(rval, "Trouble getting owned faces in set.");
@@ -616,24 +1053,14 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_se
 #endif
+    vdatas[i].numLev = nLevels;
-      std::vector<std::string>::iterator vit;
-      int idx_lev = -1;
-      int idx_ilev = -1;
-      if ((vit = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
-        idx_lev = vit - dimNames.begin();
-      if ((vit = std::find(dimNames.begin(), dimNames.end(), "ilev")) != dimNames.end())
-        idx_ilev = vit - dimNames.begin();
-      if (std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), idx_lev) != vdatas[i].varDims.end())
-        vdatas[i].numLev = dimVals[idx_lev];
-      else if (std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), idx_ilev) != vdatas[i].varDims.end())
-        vdatas[i].numLev = dimVals[idx_ilev];
-        rval = _readNC->get_tag_to_nonset(vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev);
+        rval = get_tag_to_nonset(vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev);
@@ -838,6 +1265,66 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
   return rval;
+ErrorCode ScdNCHelper::create_quad_coordinate_tag(EntityHandle file_set) {
+  bool& isParallel = _readNC->isParallel;
+  Range ents;
+  ErrorCode rval = mbImpl->get_entities_by_type(file_set, moab::MBQUAD, ents);
+  ERRORR(rval, "Trouble getting QUAD entity.");
+  std::size_t numOwnedEnts = 0;
+#ifdef USE_MPI
+  Range ents_owned;
+  if (isParallel) {
+    rval = myPcomm->filter_pstatus(ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &ents_owned);
+    ERRORR(rval, "Trouble getting owned QUAD entity.");
+    numOwnedEnts = ents_owned.size();
+  else
+    numOwnedEnts = ents.size();
+    ents_owned = ents;
+#else
+#endif
+  if (numOwnedEnts == 0)
+  assert(numOwnedEnts == ilCVals.size() * jlCVals.size());
+  std::vector<double> coords(numOwnedEnts * 3);
+  std::size_t pos = 0;
+  for (std::size_t j = 0; j != jlCVals.size(); ++j) {
+    for (std::size_t i = 0; i != ilCVals.size(); ++i) {
+      pos = j * ilCVals.size() * 3 + i * 3;
+      coords[pos] = ilCVals[i];
+      coords[pos + 1] = jlCVals[j];
+      coords[pos + 2] = 0.0;
+  std::string tag_name = "COORDS";
+  Tag tagh = 0;
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+  ERRORR(rval, "Trouble creating COORDS tag.");
+  void *data;
+  int count;
+#ifdef USE_MPI
+  rval = mbImpl->tag_iterate(tagh, ents_owned.begin(), ents_owned.end(), count, data);
+#else
+  rval = mbImpl->tag_iterate(tagh, ents.begin(), ents.end(), count, data);
+#endif
+  ERRORR(rval, "Failed to get COORDS tag iterator.");
+  assert(count == (int)numOwnedEnts);
+  double* quad_data = (double*) data;
+  std::copy(coords.begin(), coords.end(), quad_data);
 ErrorCode UcdNCHelper::read_variables(EntityHandle file_set, std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
   std::vector<ReadNC::VarData> vdatas;
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index f59663e..83fcec1 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -17,7 +17,8 @@ namespace moab {
 class NCHelper
 public:
-  NCHelper(ReadNC* readNC, int fileId) : _readNC(readNC), _fileId(fileId) {}
+  NCHelper(ReadNC* readNC, int fileId) :_readNC(readNC), _fileId(fileId),
+  nTimeSteps(0), nLevels(1), tDim(-1), levDim(-1) {}
   virtual ~NCHelper() {}
   //! Get appropriate helper instance for ReadNC class
@@ -30,6 +31,10 @@ public:
   virtual ErrorCode read_variables(EntityHandle file_set, std::vector<std::string>& var_names, std::vector<int>& tstep_nums) = 0;
   virtual std::string get_mesh_type_name() = 0;
+  //! Create NC conventional tags
+  ErrorCode create_conventional_tags(ScdInterface* scdi, EntityHandle file_set,
+                                     const std::vector<int>& tstep_nums);
 protected:
   //! Read set variables, common to scd mesh and ucd mesh
   ErrorCode read_variable_to_set(EntityHandle file_set, std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
@@ -37,20 +42,62 @@ protected:
   //! Convert variables in place
   ErrorCode convert_variable(ReadNC::VarData& var_data, int tstep_num);
+  ErrorCode read_coordinate(const char* var_name, int lmin, int lmax,
+                            std::vector<double>& cvals);
+  ErrorCode get_tag_to_set(ReadNC::VarData& var_data, int tstep_num, Tag& tagh);
+  ErrorCode get_tag_to_nonset(ReadNC::VarData& var_data, int tstep_num, Tag& tagh, int num_lev);
+  //! Create a character string attString of attMap.  with '\0'
+  //! terminating each attribute name, ';' separating the data type
+  //! and value, and ';' separating one name/data type/value from
+  //! the next'.  attLen stores the end position for each name/data
+  //! type/ value.
+  ErrorCode create_attrib_string(const std::map<std::string, ReadNC::AttData>& attMap,
+                                 std::string& attString,
+                                 std::vector<int>& attLen);
+  //! Init info for dimensions that don't have corresponding
+  //! coordinate variables - this info is used for creating tags
+  void init_dims_with_no_cvars_info();
 private:
   //! Used by read_variable_to_set()
   ErrorCode read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
 protected:
   ReadNC* _readNC;
   int _fileId;
+  //! Dimensions of time and level
+  int nTimeSteps, nLevels;
+  //! Values for time and level
+  std::vector<double> tVals, levVals;
+  //! Dimension numbers for time and level
+  int tDim, levDim;
 //! Child helper class for scd mesh, e.g. CAM_EL or CAM_FV
 class ScdNCHelper : public NCHelper
 public:
-  ScdNCHelper(ReadNC* readNC, int fileId) : NCHelper(readNC, fileId) {}
+  ScdNCHelper(ReadNC* readNC, int fileId) : NCHelper(readNC, fileId),
+  iDim(-1), jDim(-1), iCDim(-1), jCDim(-1)
+    for (unsigned int i = 0; i < 6; i++) {
+      gDims[i] = -1;
+      lDims[i] = -1;
+      gCDims[i] = -1;
+      lCDims[i] = -1;
+    locallyPeriodic[0] = locallyPeriodic[1] = 0;
+    globallyPeriodic[0] = globallyPeriodic[1] = 0;
   virtual ~ScdNCHelper() {}
 private:
@@ -73,6 +120,9 @@ private:
   ErrorCode read_scd_variable_to_nonset(EntityHandle file_set, std::vector<ReadNC::VarData>& vdatas,
+  //! Create COORDS tag for quads coordinate
+  ErrorCode create_quad_coordinate_tag(EntityHandle file_set);
   template <typename T> ErrorCode kji_to_jik(size_t ni, size_t nj, size_t nk, void* dest, T* source)
     size_t nik = ni * nk, nij = ni * nj;
@@ -83,6 +133,37 @@ private:
           tmp_data[j*nik + i*nk + k] = source[k*nij + j*ni + i];
     return MB_SUCCESS;
+protected:
+  //! Dimensions of global grid in file
+  int gDims[6];
+  //! Dimensions of my local part of grid
+  int lDims[6];
+  //! Center dimensions of global grid in file
+  int gCDims[6];
+  //! Center dimensions of my local part of grid
+  int lCDims[6];
+  //! Values for i/j
+  std::vector<double> ilVals, jlVals;
+  //! Center values for i/j
+  std::vector<double> ilCVals, jlCVals;
+  //! Dimension numbers for i/j
+  int iDim, jDim;
+  //! Center dimension numbers for i/j
+  int iCDim, jCDim;
+  //! Whether mesh is locally periodic in i or j
+  int locallyPeriodic[2];
+  //! Whether mesh is globally periodic in i or j
+  int globallyPeriodic[2];
 //! Child helper class for ucd mesh, e.g. CAM_SE (HOMME) or MPAS
@@ -90,9 +171,9 @@ class UcdNCHelper : public NCHelper
 public:
   UcdNCHelper(ReadNC* readNC, int fileId) : NCHelper(readNC, fileId),
-  cDim(-1), eDim(-1), vDim(-1), levDim(-1),
   nCells(0), nEdges(0), nVertices(0),
-  nLocalCells(0), nLocalEdges(0), nLocalVertices(0) {}
+  nLocalCells(0), nLocalEdges(0), nLocalVertices(0),
+  cDim(-1), eDim(-1), vDim(-1) {}
   virtual ~UcdNCHelper() {}
 private:
@@ -139,20 +220,23 @@ protected:
     return MB_SUCCESS;
-  //! Dimension numbers for nCells, nEdges, nVertices, nLevels
-  int cDim, eDim, vDim, levDim;
-  //! Coordinate values for vertices
-  std::vector<double> xVertVals, yVertVals, zVertVals;
   int nCells;
   int nEdges;
   int nVertices;
   int nLocalCells;
   int nLocalEdges;
   int nLocalVertices;
+  //! Coordinate values for vertices
+  std::vector<double> xVertVals, yVertVals, zVertVals;
+  //! Dimension numbers for nCells, nEdges and nVertices
+  int cDim, eDim, vDim;
+  //! Local global ID for cells, edges and vertices
   Range localGidCells, localGidEdges, localGidVerts;
index 8de0818..51094dd 100644
@@ -54,78 +54,51 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
-  std::string& iName = _readNC->iName;
-  std::string& jName = _readNC->jName;
-  std::string& tName = _readNC->tName;
-  std::string& iCName = _readNC->iCName;
-  std::string& jCName = _readNC->jCName;
-  int (&gCDims)[6] = _readNC->gCDims;
-  std::vector<double>& tVals = _readNC->tVals;
-  std::vector<double>& ilCVals = _readNC->ilCVals;
-  std::vector<double>& jlCVals = _readNC->jlCVals;
-#ifdef USE_MPI
-#endif
-  // look for names of center i/j dimensions
+  // Look for names of center i/j dimensions
+  // First i
   unsigned int idx;
-  iCName = std::string("lon");
-  iName = std::string("slon");
-  if ((vit = std::find(dimNames.begin(), dimNames.end(), iCName.c_str())) != dimNames.end())
+  if ((vit = std::find(dimNames.begin(), dimNames.end(), "lon")) != dimNames.end())
     idx = vit - dimNames.begin();
   else {
-    ERRORR(MB_FAILURE, "Couldn't find center i variable.");
+    ERRORR(MB_FAILURE, "Couldn't find 'lon' dimension.");
   iCDim = idx;
+  gCDims[0] = 0;
+  gCDims[3] = dimVals[idx] - 1;
-  // decide on i periodicity using math for now
-  std::vector<double> tilVals(dimVals[idx]);
-  ErrorCode rval = _readNC->read_coordinate(iCName.c_str(), 0, dimVals[idx] - 1, tilVals);
-  ERRORR(rval, "Trouble reading lon variable.");
-  if (std::fabs(2 * (*(tilVals.rbegin())) - *(tilVals.rbegin() + 1) - 360) < 0.001)
+  // Check i periodicity and set globallyPeriodic[0]
+  std::vector<double> til_vals(2);
+  ErrorCode rval = read_coordinate("lon", gCDims[3] - 1, gCDims[3], til_vals);
+  ERRORR(rval, "Trouble reading 'lon' variable.");
+  if (std::fabs(2 * til_vals[1] - til_vals[0] - 360) < 0.001)
     globallyPeriodic[0] = 1;
-  // now we can set gCDims and gDims for i
-  gCDims[0] = 0;
+  // Now we can set gDims for i
   gDims[0] = 0;
-  gCDims[3] = dimVals[idx] - 1; // these are stored directly in file
-  gDims[3] = gCDims[3] + (globallyPeriodic[0] ? 0 : 1); // only if not periodic is vertex param max > elem param max
+  gDims[3] = gCDims[3] + (globallyPeriodic[0] ? 0 : 1); // Only if not periodic is vertex param max > elem param max
-  // now j
-  jCName = std::string("lat");
-  jName = std::string("slat");
-  if ((vit = std::find(dimNames.begin(), dimNames.end(), jCName.c_str())) != dimNames.end())
+  // Then j
+  if ((vit = std::find(dimNames.begin(), dimNames.end(), "lat")) != dimNames.end())
   else {
-    ERRORR(MB_FAILURE, "Couldn't find center j variable.");
+    ERRORR(MB_FAILURE, "Couldn't find 'lat' dimension.");
   jCDim = idx;
-  // for Eul models, will always be non-periodic in j
   gCDims[1] = 0;
-  gDims[1] = 0;
   gCDims[4] = dimVals[idx] - 1;
+  // For Eul models, will always be non-periodic in j
+  gDims[1] = 0;
   gDims[4] = gCDims[4] + 1;
-  // try a truly 2d mesh
+  // Try a truly 2D mesh
   gDims[2] = -1;
   gDims[5] = -1;
@@ -135,16 +108,32 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   else if ((vit = std::find(dimNames.begin(), dimNames.end(), "t")) != dimNames.end())
   else {
-    ERRORR(MB_FAILURE, "Couldn't find time dimension.");
+    ERRORR(MB_FAILURE, "Couldn't find 'time' or 't' dimension.");
   tDim = idx;
-  tMax = dimVals[idx] - 1;
-  tMin = 0;
-  tName = dimNames[idx];
+  nTimeSteps = dimVals[idx];
-  // parse options to get subset
-  if (isParallel) {
+  // Look for level dimension
+  if ((vit = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
+    idx = vit - dimNames.begin();
+  else if ((vit = std::find(dimNames.begin(), dimNames.end(), "ilev")) != dimNames.end())
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension.");
+  levDim = idx;
+  nLevels = dimVals[idx];
+  // Parse options to get subset
+  int rank = 0, procs = 1;
 #ifdef USE_MPI
+  if (isParallel) {
+    rank = myPcomm->proc_config().proc_rank();
+    procs = myPcomm->proc_config().proc_size();
+#endif
+  if (procs > 1) {
@@ -152,9 +141,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     int pdims[3];
-    rval = ScdInterface::compute_partition(myPcomm->proc_config().proc_size(),
-        myPcomm->proc_config().proc_rank(),
-        parData, lDims, locallyPeriodic, pdims);
+    rval = ScdInterface::compute_partition(procs, rank, parData, lDims, locallyPeriodic, pdims);
       return rval;
@@ -163,9 +150,8 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     dbgOut.tprintf(1, "Partition: %dx%d (out of %dx%d)\n",
         lDims[3] - lDims[0] + 1, lDims[4] - lDims[1] + 1,
         gDims[3] - gDims[0] + 1, gDims[4] - gDims[1] + 1);
-    if (myPcomm->proc_config().proc_rank() == 0)
+    if (0 == rank)
       dbgOut.tprintf(1, "Contiguous chunks of size %d bytes.\n", 8 * (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1));
-#endif
   else {
@@ -178,92 +164,83 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   opts.get_int_option("JMIN", lDims[1]);
   opts.get_int_option("JMAX", lDims[4]);
-  // now get actual coordinate values for vertices and cell centers; first resize
-  if (locallyPeriodic[0]) {
-    // if locally periodic, doesn't matter what global periodicity is, # vertex coords = # elem coords
-    ilVals.resize(lDims[3] - lDims[0] + 1);
-    ilCVals.resize(lDims[3] - lDims[0] + 1);
+  // Now get actual coordinate values for vertices and cell centers
+  lCDims[0] = lDims[0];
+  if (locallyPeriodic[0])
+    // If locally periodic, doesn't matter what global periodicity is, # vertex coords = # elem coords
     lCDims[3] = lDims[3];
-  else {
-    if (!locallyPeriodic[0] && globallyPeriodic[0] && lDims[3] > gDims[3]) {
-      // globally periodic and I'm the last proc, get fewer vertex coords than vertices in i
-      ilCVals.resize(lDims[3] - lDims[0]);
-      lCDims[3] = lDims[3] - 1;
-    else {
+  else
+    lCDims[3] = lDims[3] - 1;
-  lCDims[0] = lDims[0];
-  lCDims[4] = lDims[4] - 1;
   lCDims[1] = lDims[1];
+  lCDims[4] = lDims[4] - 1;
-  if (-1 != lDims[1]) {
+  // Resize vectors to store values later
+  if (-1 != lDims[0])
+    ilVals.resize(lDims[3] - lDims[0] + 1);
+  if (-1 != lCDims[0])
+    ilCVals.resize(lCDims[3] - lCDims[0] + 1);
+  if (-1 != lDims[1])
     jlVals.resize(lDims[4] - lDims[1] + 1);
+  if (-1 != lCDims[1])
     jlCVals.resize(lCDims[4] - lCDims[1] + 1);
+  if (nTimeSteps > 0)
+    tVals.resize(nTimeSteps);
-  if (-1 != tMin)
-    tVals.resize(tMax - tMin + 1);
-  // now read coord values
+  // Now read coord values
   std::map<std::string, ReadNC::VarData>::iterator vmit;
-  if (!ilCVals.empty()) {
-    if ((vmit = varInfo.find(iCName)) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      rval = _readNC->read_coordinate(iCName.c_str(), lDims[0], lDims[0] + ilCVals.size() - 1, ilCVals);
+  if (-1 != lCDims[0]) {
+    if ((vmit = varInfo.find("lon")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("lon", lCDims[0], lCDims[3], ilCVals);
     else {
-      ERRORR(MB_FAILURE, "Couldn't find lon coordinate.");
+      ERRORR(MB_FAILURE, "Couldn't find 'lon' variable.");
-  if (!jlCVals.empty()) {
-    if ((vmit = varInfo.find(jCName)) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      rval = _readNC->read_coordinate(jCName.c_str(), lDims[1], lDims[1] + jlCVals.size() - 1, jlCVals);
-      ERRORR(rval, "Trouble reading lat variable.");
+  if (-1 != lCDims[1]) {
+    if ((vmit = varInfo.find("lat")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("lat", lCDims[1], lCDims[4], jlCVals);
+      ERRORR(rval, "Trouble reading 'lat' variable.");
     else {
-      ERRORR(MB_FAILURE, "Couldn't find lat coordinate.");
+      ERRORR(MB_FAILURE, "Couldn't find 'lat' variable.");
-  if (lDims[0] != -1) {
+  if (-1 != lDims[0]) {
       double dif = (ilCVals[1] - ilCVals[0]) / 2;
       std::size_t i;
       for (i = 0; i != ilCVals.size(); i++)
         ilVals[i] = ilCVals[i] - dif;
-      // the last one is needed only if not periodic
+      // The last one is needed only if not periodic
       if (!locallyPeriodic[0])
         ilVals[i] = ilCVals[i - 1] + dif;
     else {
-      ERRORR(MB_FAILURE, "Couldn't find x coordinate.");
-  if (lDims[1] != -1) {
+  if (-1 != lDims[1]) {
       if (!isParallel || ((gDims[4] - gDims[1]) == (lDims[4] - lDims[1]))) {
         std::string gwName("gw");
         std::vector<double> gwVals(lDims[4] - lDims[1] - 1);
-        rval = _readNC->read_coordinate(gwName.c_str(), lDims[1], lDims[4] - 2, gwVals);
-        ERRORR(rval, "Trouble reading gw variable.");
-        // copy the correct piece
+        rval = read_coordinate(gwName.c_str(), lDims[1], lDims[4] - 2, gwVals);
+        ERRORR(rval, "Trouble reading 'gw' variable.");
+        // Copy the correct piece
         jlVals[0] = -(M_PI / 2) * 180 / M_PI;
-        unsigned int i = 0;
+        std::size_t i = 0;
         double gwSum = -1;
         for (i = 1; i != gwVals.size() + 1; i++) {
-          gwSum = gwSum + gwVals[i - 1];
+          gwSum += gwVals[i - 1];
           jlVals[i] = std::asin(gwSum) * 180 / M_PI;
-        jlVals[i] = 90.0; // using value of i after loop exits.
+        jlVals[i] = 90.0; // Using value of i after loop exits.
       else {
@@ -272,66 +249,68 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
         // If this is the first row
         if (lDims[1] == gDims[1]) {
           std::vector<double> gwVals(lDims[4]);
-          rval = _readNC->read_coordinate(gwName.c_str(), 0, lDims[4] - 1, gwVals);
+          rval = read_coordinate(gwName.c_str(), 0, lDims[4] - 1, gwVals);
           gwSum = -1;
           for (std::size_t i = 1; i != jlVals.size(); i++) {
-        // or if it's the last row
+        // Or if it's the last row
         else if (lDims[4] == gDims[4]) {
           std::vector<double> gwVals(lDims[4] - 1);
-          rval = _readNC->read_coordinate(gwName.c_str(), 0, lDims[4] - 2, gwVals);
+          rval = read_coordinate(gwName.c_str(), 0, lDims[4] - 2, gwVals);
           gwSum = -1;
-          for (int j = 0; j != lDims[1] - 1; j++) {
-            gwSum = gwSum + gwVals[j];
+          for (int j = 0; j != lDims[1] - 1; j++)
+            gwSum += gwVals[j];
           std::size_t i = 0;
           for (; i != jlVals.size() - 1; i++) {
-            gwSum = gwSum + gwVals[lDims[1] - 1 + i];
+            gwSum += gwVals[lDims[1] - 1 + i];
-        // it's in the middle
+        // It's in the middle
         else {
           int start = lDims[1] - 1;
           int end = lDims[4] - 1;
           std::vector<double> gwVals(end);
-          rval = _readNC->read_coordinate(gwName.c_str(), 0, end - 1, gwVals);
+          rval = read_coordinate(gwName.c_str(), 0, end - 1, gwVals);
           gwSum = -1;
-          for (int j = 0; j != start - 1; j++) {
+          for (int j = 0; j != start - 1; j++)
           std::size_t i = 0;
           for (; i != jlVals.size(); i++) {
-            gwSum = gwSum + gwVals[start - 1 + i];
+            gwSum += gwVals[start - 1 + i];
     else {
-      ERRORR(MB_FAILURE, "Couldn't find y coordinate.");
   // Store time coordinate values in tVals
-  if (tMin != -1) {
-    if ((vmit = varInfo.find(tName)) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      rval = _readNC->read_coordinate(tName.c_str(), tMin, tMax, tVals);
-      ERRORR(rval, "Trouble reading time variable.");
+  if (nTimeSteps > 0) {
+    if ((vmit = varInfo.find("time")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("time", 0, nTimeSteps - 1, tVals);
+      ERRORR(rval, "Trouble reading 'time' variable.");
+    else if ((vmit = varInfo.find("t")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("t", 0, nTimeSteps - 1, tVals);
+      ERRORR(rval, "Trouble reading 't' variable.");
     else {
       // If expected time variable is not available, set dummy time coordinate values to tVals
-      for (int t = tMin; t <= tMax; t++)
+      for (int t = 0; t < nTimeSteps; t++)
         tVals.push_back((double)t);
@@ -340,7 +319,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   dbgOut.tprintf(1, "%d elements, %d vertices\n", (lDims[3] - lDims[0]) * (lDims[4] - lDims[1]), (lDims[3] - lDims[0] + 1)
-  // determine the entity location type of a variable
+  // Determine the entity location type of a variable
   for (mit = varInfo.begin(); mit != varInfo.end(); ++mit) {
     ReadNC::VarData& vd = (*mit).second;
@@ -360,7 +339,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   int val_len = 0;
   for (unsigned int i = 0; i != ijdimNames.size(); i++) {
     tag_name = ijdimNames[i];
-    void * val = NULL;
+    void* val = NULL;
     if (tag_name == "__slon") {
       val = &ilVals[0];
       val_len = ilVals.size();
@@ -380,7 +359,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     Tag tagh = 0;
     DataType data_type;
-    // assume all has same data type as lon
+    // Assume all has same data type as lon
     switch (varInfo["lon"].varDataType) {
       case NC_BYTE:
       case NC_CHAR:
@@ -469,9 +448,8 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
-  // hack: create dummy tags, if needed, for variables like nbnd
-  // with no corresponding variables
-  _readNC->init_dims_with_no_cvars_info();
+  // Hack: create dummy tags, if needed, for variables with no corresponding variables
+  init_dims_with_no_cvars_info();
   return MB_SUCCESS;
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index 8b9be3f..ccae4e3 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -47,76 +47,50 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
   ScdParData& parData = _readNC->parData;
-#ifdef USE_MPI
-#endif
+  // Look for names of i/j dimensions
+  // First i
   unsigned int idx;
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "slon")) != dimNames.end())
   else {
-    ERRORR(MB_FAILURE, "Couldn't find slon variable.");
+    ERRORR(MB_FAILURE, "Couldn't find 'slon' variable.");
   iDim = idx;
-  gDims[3] = dimVals[idx] - 1;
   gDims[0] = 0;
-  iName = dimNames[idx];
+  gDims[3] = dimVals[idx] - 1;
+  // Then j
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "slat")) != dimNames.end())
   else {
-    ERRORR(MB_FAILURE, "Couldn't find slat variable.");
+    ERRORR(MB_FAILURE, "Couldn't find 'slat' variable.");
   jDim = idx;
-  gDims[4] = dimVals[idx] - 1 + 2; // add 2 for the pole points
   gDims[1] = 0;
-  jName = dimNames[idx];
+  gDims[4] = dimVals[idx] - 1 + 2; // Add 2 for the pole points
+  // First i
   else {
-    ERRORR(MB_FAILURE, "Couldn't find lon variable.");
   iCDim = idx;
   gCDims[0] = 0;
-  iCName = dimNames[idx];
-  // check and set globallyPeriodic[0]
-  ErrorCode rval = _readNC->read_coordinate(iCName.c_str(), dimVals[idx] - 2, dimVals[idx] - 1, til_vals);
-  ERRORR(rval, "Trouble reading slon variable.");
   if (globallyPeriodic[0])
@@ -124,39 +98,55 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
   else
     assert("Number of vertices should equal to number of edges plus one" && gDims[3] == gCDims[3] + 1);
-#ifdef USE_MPI
-  // if serial, use a locally-periodic representation only if local mesh is periodic, otherwise don't
-  if ((isParallel && myPcomm->proc_config().proc_size() == 1) && globallyPeriodic[0])
-    locallyPeriodic[0] = 1;
-#else
-  if (globallyPeriodic[0])
-#endif
+  // Then j
   else {
-    ERRORR(MB_FAILURE, "Couldn't find lat variable.");
   jCDim = idx;
-  gCDims[4] = dimVals[idx] - 1;
   gCDims[1] = 0;
-  jCName = dimNames[idx];
+  gCDims[4] = dimVals[idx] - 1;
+  // For FV models, will always be non-periodic in j
+  assert(gDims[4] == gCDims[4] + 1);
+  gDims[2] = -1;
+  gDims[5] = -1;
   // Look for time dimension
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
+  else if ((vit = std::find(dimNames.begin(), dimNames.end(), "t")) != dimNames.end())
   else {
   tDim = idx;
-  tMin = 0;
-  if (isParallel) {
+  // Get number of levels
+  else {
+  levDim = idx;
 #ifdef USE_MPI
+  if (isParallel) {
+#endif
+  if (procs > 1) {
       parData.gDims[i] = gDims[i];
@@ -164,9 +154,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     parData.partMethod = partMethod;
     int pdims[3];
       return rval;
@@ -175,154 +163,150 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
+    if (0 == rank)
-#endif
   else {
       lDims[i] = gDims[i];
     locallyPeriodic[0] = globallyPeriodic[0];
   opts.get_int_option("IMIN", lDims[0]);
   opts.get_int_option("IMAX", lDims[3]);
-  else {
-    else {
+  else
-  if (-1 != tMin)
-  // ... then read actual values
-  if (lCDims[0] != -1) {
-      rval = _readNC->read_coordinate(iCName.c_str(), lCDims[0], lCDims[3], ilCVals);
     else {
-  if (lCDims[1] != -1) {
-      rval = _readNC->read_coordinate(jCName.c_str(), lCDims[1], lCDims[4], jlCVals);
     else {
-    if ((vmit = varInfo.find(iName)) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      // last column
+    if ((vmit = varInfo.find("slon")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      // Last column
-        til_vals.resize(ilVals.size() - 1, 0.0);
-        rval = _readNC->read_coordinate(iName.c_str(), lDims[0], lDims[3] - 1, til_vals);
-        double dif = til_vals[1] - til_vals[0];
+        assert(lDims[3] == gDims[3] + 1);
+        std::vector<double> dummyVar(lDims[3] - lDims[0]);
+        rval = read_coordinate("slon", lDims[0], lDims[3] - 1, dummyVar);
+        double dif = dummyVar[1] - dummyVar[0];
         std::size_t i;
-        for (i = 0; i != til_vals.size(); i++)
-          ilVals[i] = til_vals[i];
+        for (i = 0; i != dummyVar.size(); i++)
+          ilVals[i] = dummyVar[i];
         ilVals[i] = ilVals[i - 1] + dif;
       else {
-        rval = _readNC->read_coordinate(iName.c_str(), lDims[0], lDims[3], ilVals);
-        ERRORR(rval, "Trouble reading x variable.");
+        rval = read_coordinate("slon", lDims[0], lDims[3], ilVals);
+        ERRORR(rval, "Trouble reading 'slon' variable.");
     else {
-    if ((vmit = varInfo.find(jName)) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+    if ((vmit = varInfo.find("slat")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
         std::vector<double> dummyVar(lDims[4] - lDims[1] - 1);
-        rval = _readNC->read_coordinate(jName.c_str(), lDims[1], lDims[4] - 2, dummyVar);
-        ERRORR(rval, "Trouble reading y variable.");
+        rval = read_coordinate("slat", lDims[1], lDims[4] - 2, dummyVar);
+        ERRORR(rval, "Trouble reading 'slat' variable.");
         jlVals[0] = -90.0;
         for (i = 1; i != dummyVar.size() + 1; i++)
           jlVals[i] = dummyVar[i - 1];
       else {
-        // need to read one less then available and read it into a dummy var
+        // Need to read one less then available and read it into a dummy var
           std::vector<double> dummyVar(lDims[4] - lDims[1]);
-          rval = _readNC->read_coordinate(jName.c_str(), lDims[1], lDims[4] - 1, dummyVar);
+          rval = read_coordinate("slat", lDims[1], lDims[4] - 1, dummyVar);
           jlVals[0] = -90.0;
           for (int i = 1; i < lDims[4] + 1; i++)
-          rval = _readNC->read_coordinate(jName.c_str(), lDims[1] - 1, lDims[4] - 2, dummyVar);
+          rval = read_coordinate("slat", lDims[1] - 1, lDims[4] - 2, dummyVar);
           std::size_t i = 0;
             jlVals[i] = dummyVar[i];
         else {
-          rval = _readNC->read_coordinate(jCName.c_str(), lDims[1] - 1, lDims[4] - 1, jlVals);
+          rval = read_coordinate("slat", lDims[1] - 1, lDims[4] - 1, jlVals);
     else {
-  if (tMin != -1) {
     else {
@@ -331,7 +315,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
@@ -357,7 +341,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
   int val_len = 0;
+    void* val = NULL;
       val = &ilVals[0];
@@ -377,7 +361,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     Tag tagh = 0;
     DataType data_type;
       case NC_BYTE:
       case NC_CHAR:
@@ -466,9 +450,8 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
-  // hack: create dummy tags, if needed, for dimensions like nbnd
+  // Hack: create dummy tags, if needed, for dimensions with no corresponding variables
   return MB_SUCCESS;
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
