[MOAB-dev] commit/MOAB: danwu: Refined NCHelperFV and NCHelperEuler, especially some legacy code from ReadNC.cpp that are inconsistent or redundant.
    commits-noreply at bitbucket.org
    Mon Aug 12 13:33:10 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8b911b60e636/
Changeset:   8b911b60e636
Branch:      master
User:        danwu
Date:        2013-08-12 20:32:56
Summary:     Refined NCHelperFV and NCHelperEuler, especially some legacy code from ReadNC.cpp that are inconsistent or redundant.
Affected #:  3 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 69e24eb..851d9b1 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -488,25 +488,32 @@ ErrorCode NCHelper::read_coordinate(const char* var_name, int lmin, int lmax, st
   if (varInfo.end() == vmit)
     return MB_FAILURE;
-  // Check to make sure it's a float or double
-  int fail;
-  NCDF_SIZE tmin = lmin, tcount = lmax - lmin + 1;
+  assert(lmin >= 0 && lmax >= lmin);
+  NCDF_SIZE tstart = lmin;
+  NCDF_SIZE tcount = lmax - lmin + 1;
   NCDF_DIFF dum_stride = 1;
-  if (NC_DOUBLE == (*vmit).second.varDataType) {
+  int fail;
+  // Check size
+  if (tcount != cvals.size())
     cvals.resize(tcount);
-    fail = NCFUNCA(get_vars_double)(_fileId, (*vmit).second.varId, &tmin, &tcount, &dum_stride, &cvals[0]);
+  // Check to make sure it's a float or double
+  if (NC_DOUBLE == (*vmit).second.varDataType) {
+    fail = NCFUNCA(get_vars_double)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &cvals[0]);
     if (fail)
       ERRORS(MB_FAILURE, "Failed to get coordinate values.");
   else if (NC_FLOAT == (*vmit).second.varDataType) {
     std::vector<float> tcvals(tcount);
-    fail = NCFUNCA(get_vars_float)(_fileId, (*vmit).second.varId, &tmin, &tcount, &dum_stride, &tcvals[0]);
+    fail = NCFUNCA(get_vars_float)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &tcvals[0]);
     if (fail)
-    cvals.resize(tcount);
     std::copy(tcvals.begin(), tcvals.end(), cvals.begin());
-  else ERRORR(MB_FAILURE, "Wrong data type for coordinate variable.");
+  else {
+    ERRORR(MB_FAILURE, "Wrong data type for coordinate variable.");
   return MB_SUCCESS;
@@ -673,7 +680,7 @@ void NCHelper::init_dims_with_no_cvars_info()
     data.varName = std::string(var_name);
     data.varId =sizeTotalVar;
     data.varTags.resize(1, 0);
-    data.varDataType = NC_DOUBLE; // could be int, actually, but we do not really need the type
+    data.varDataType = NC_DOUBLE; // Could be int, actually, but we do not really need the type
     data.varDims.resize(1);
     data.varDims[0]= (int)i;
     data.numAtts=0;
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index f0489a7..307dcf5 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -59,11 +59,9 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   bool& isParallel = _readNC->isParallel;
   int& partMethod = _readNC->partMethod;
   ScdParData& parData = _readNC->parData;
-#ifdef USE_MPI
-  ParallelComm*& myPcomm = _readNC->myPcomm;
-#endif
   // Look for names of center i/j dimensions
+  // First i
   std::vector<std::string>::iterator vit;
   unsigned int idx;
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "lon")) != dimNames.end())
@@ -72,32 +70,32 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     ERRORR(MB_FAILURE, "Couldn't find 'lon' dimension.");
   iCDim = idx;
+  gCDims[0] = 0;
+  gCDims[3] = dimVals[idx] - 1;
-  // Decide on i periodicity using math for now
-  std::vector<double> tilVals(dimVals[idx]);
-  ErrorCode rval = read_coordinate("lon", 0, dimVals[idx] - 1, tilVals);
+  // Check i periodicity and set globallyPeriodic[0]
+  std::vector<double> til_vals(2);
+  ErrorCode rval = read_coordinate("lon", gCDims[3] - 1, gCDims[3], til_vals);
   ERRORR(rval, "Trouble reading 'lon' variable.");
-  if (std::fabs(2 * (*(tilVals.rbegin())) - *(tilVals.rbegin() + 1) - 360) < 0.001)
+  if (std::fabs(2 * til_vals[1] - til_vals[0] - 360) < 0.001)
     globallyPeriodic[0] = 1;
-  // Now we can set gCDims and gDims for i
-  gCDims[0] = 0;
+  // Now we can set gDims for i
   gDims[0] = 0;
-  gCDims[3] = dimVals[idx] - 1; // These are stored directly in file
   gDims[3] = gCDims[3] + (globallyPeriodic[0] ? 0 : 1); // Only if not periodic is vertex param max > elem param max
-  // Now j
+  // Then j
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "lat")) != dimNames.end())
     idx = vit - dimNames.begin();
   else {
     ERRORR(MB_FAILURE, "Couldn't find 'lat' dimension.");
   jCDim = idx;
+  gCDims[1] = 0;
+  gCDims[4] = dimVals[idx] - 1;
   // For Eul models, will always be non-periodic in j
-  gCDims[1] = 0;
   gDims[1] = 0;
-  gCDims[4] = dimVals[idx] - 1;
   gDims[4] = gCDims[4] + 1;
   // Try a truly 2D mesh
@@ -127,8 +125,15 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   nLevels = dimVals[idx];
   // Parse options to get subset
-  if (isParallel) {
+  int rank = 0, procs = 1;
 #ifdef USE_MPI
+  if (isParallel) {
+    ParallelComm*& myPcomm = _readNC->myPcomm;
+    rank = myPcomm->proc_config().proc_rank();
+    procs = myPcomm->proc_config().proc_size();
+#endif
+  if (procs > 1) {
     for (int i = 0; i < 6; i++)
       parData.gDims[i] = gDims[i];
     for (int i = 0; i < 2; i++)
@@ -136,9 +141,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     parData.partMethod = partMethod;
     int pdims[3];
-    rval = ScdInterface::compute_partition(myPcomm->proc_config().proc_size(),
-        myPcomm->proc_config().proc_rank(),
-        parData, lDims, locallyPeriodic, pdims);
+    rval = ScdInterface::compute_partition(procs, rank, parData, lDims, locallyPeriodic, pdims);
     if (MB_SUCCESS != rval)
       return rval;
     for (int i = 0; i < 3; i++)
@@ -147,9 +150,8 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
     dbgOut.tprintf(1, "Partition: %dx%d (out of %dx%d)\n",
         lDims[3] - lDims[0] + 1, lDims[4] - lDims[1] + 1,
         gDims[3] - gDims[0] + 1, gDims[4] - gDims[1] + 1);
-    if (myPcomm->proc_config().proc_rank() == 0)
+    if (0 == rank)
       dbgOut.tprintf(1, "Contiguous chunks of size %d bytes.\n", 8 * (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1));
-#endif
   else {
@@ -162,44 +164,35 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
   opts.get_int_option("JMIN", lDims[1]);
   opts.get_int_option("JMAX", lDims[4]);
-  // Now get actual coordinate values for vertices and cell centers; first resize
-  if (locallyPeriodic[0]) {
+  // Now get actual coordinate values for vertices and cell centers
+  lCDims[0] = lDims[0];
+  if (locallyPeriodic[0])
     // If locally periodic, doesn't matter what global periodicity is, # vertex coords = # elem coords
-    ilVals.resize(lDims[3] - lDims[0] + 1);
-    ilCVals.resize(lDims[3] - lDims[0] + 1);
     lCDims[3] = lDims[3];
-  else {
-    if (!locallyPeriodic[0] && globallyPeriodic[0] && lDims[3] > gDims[3]) {
-      // Globally periodic and I'm the last proc, get fewer vertex coords than vertices in i
-      ilCVals.resize(lDims[3] - lDims[0]);
-      lCDims[3] = lDims[3] - 1;
-    else {
+  else
+    lCDims[3] = lDims[3] - 1;
-  lCDims[0] = lDims[0];
+  // For Eul models, will always be non-periodic in j
   lCDims[1] = lDims[1];
   lCDims[4] = lDims[4] - 1;
-  if (-1 != lDims[1]) {
+  // Resize vectors to store values later
+  if (-1 != lDims[0])
+    ilVals.resize(lDims[3] - lDims[0] + 1);
+  if (-1 != lCDims[0])
+    ilCVals.resize(lCDims[3] - lCDims[0] + 1);
+  if (-1 != lDims[1])
     jlVals.resize(lDims[4] - lDims[1] + 1);
+  if (-1 != lCDims[1])
     jlCVals.resize(lCDims[4] - lCDims[1] + 1);
   if (nTimeSteps > 0)
     tVals.resize(nTimeSteps);
   // Now read coord values
   std::map<std::string, ReadNC::VarData>::iterator vmit;
-  if (!ilCVals.empty()) {
+  if (-1 != lCDims[0]) {
     if ((vmit = varInfo.find("lon")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      rval = read_coordinate("lon", lDims[0], lDims[0] + ilCVals.size() - 1, ilCVals);
+      rval = read_coordinate("lon", lCDims[0], lCDims[3], ilCVals);
     else {
@@ -207,9 +200,9 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
-  if (!jlCVals.empty()) {
+  if (-1 != lCDims[1]) {
     if ((vmit = varInfo.find("lat")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-      rval = read_coordinate("lat", lDims[1], lDims[1] + jlCVals.size() - 1, jlCVals);
+      rval = read_coordinate("lat", lCDims[1], lCDims[4], jlCVals);
       ERRORR(rval, "Trouble reading 'lat' variable.");
     else {
@@ -217,7 +210,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
-  if (lDims[0] != -1) {
+  if (-1 != lDims[0]) {
       double dif = (ilCVals[1] - ilCVals[0]) / 2;
       std::size_t i;
@@ -232,7 +225,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
-  if (lDims[1] != -1) {
+  if (-1 != lDims[1]) {
       if (!isParallel || ((gDims[4] - gDims[1]) == (lDims[4] - lDims[1]))) {
         std::string gwName("gw");
@@ -241,10 +234,10 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
         ERRORR(rval, "Trouble reading 'gw' variable.");
         // Copy the correct piece
         jlVals[0] = -(M_PI / 2) * 180 / M_PI;
-        unsigned int i = 0;
+        std::size_t i = 0;
         double gwSum = -1;
         for (i = 1; i != gwVals.size() + 1; i++) {
-          gwSum = gwSum + gwVals[i - 1];
+          gwSum += gwVals[i - 1];
           jlVals[i] = std::asin(gwSum) * 180 / M_PI;
         jlVals[i] = 90.0; // Using value of i after loop exits.
@@ -262,7 +255,7 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
           gwSum = -1;
           for (std::size_t i = 1; i != jlVals.size(); i++) {
@@ -273,12 +266,11 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
           // copy the correct piece
           gwSum = -1;
-          for (int j = 0; j != lDims[1] - 1; j++) {
-            gwSum = gwSum + gwVals[j];
+          for (int j = 0; j != lDims[1] - 1; j++)
+            gwSum += gwVals[j];
           std::size_t i = 0;
           for (; i != jlVals.size() - 1; i++) {
-            gwSum = gwSum + gwVals[lDims[1] - 1 + i];
+            gwSum += gwVals[lDims[1] - 1 + i];
@@ -291,12 +283,11 @@ ErrorCode NCHelperEuler::init_mesh_vals(const FileOptions& opts, EntityHandle fi
           rval = read_coordinate(gwName.c_str(), 0, end - 1, gwVals);
           gwSum = -1;
-          for (int j = 0; j != start - 1; j++) {
+          for (int j = 0; j != start - 1; j++)
           std::size_t i = 0;
           for (; i != jlVals.size(); i++) {
-            gwSum = gwSum + gwVals[start - 1 + i];
+            gwSum += gwVals[start - 1 + i];
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index 48d5f4b..fd228af 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -52,10 +52,9 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
-#ifdef USE_MPI
-#endif
+  // Look for names of i/j dimensions
+  // First i
   unsigned int idx;
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "slon")) != dimNames.end())
@@ -64,31 +63,33 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     ERRORR(MB_FAILURE, "Couldn't find 'slon' variable.");
   iDim = idx;
-  gDims[3] = dimVals[idx] - 1;
   gDims[0] = 0;
+  gDims[3] = dimVals[idx] - 1;
+  // Then j
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "slat")) != dimNames.end())
   else {
     ERRORR(MB_FAILURE, "Couldn't find 'slat' variable.");
   jDim = idx;
-  gDims[4] = dimVals[idx] - 1 + 2; // Add 2 for the pole points
   gDims[1] = 0;
+  gDims[4] = dimVals[idx] - 1 + 2; // Add 2 for the pole points
+  // First i
   else {
     ERRORR(MB_FAILURE, "Couldn't find 'lon' variable.");
   iCDim = idx;
   gCDims[0] = 0;
-  // Check and set globallyPeriodic[0]
-  ErrorCode rval = read_coordinate("lon", dimVals[idx] - 2, dimVals[idx] - 1, til_vals);
@@ -97,23 +98,22 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
   else
     assert("Number of vertices should equal to number of edges plus one" && gDims[3] == gCDims[3] + 1);
-#ifdef USE_MPI
-  // If serial, use a locally-periodic representation only if local mesh is periodic, otherwise don't
-  if ((isParallel && myPcomm->proc_config().proc_size() == 1) && globallyPeriodic[0])
-    locallyPeriodic[0] = 1;
-#else
-  if (globallyPeriodic[0])
-#endif
+  // Then j
   else {
-    ERRORR(MB_FAILURE, "Couldn't find 'lat' variable.");
+    ERRORR(MB_FAILURE, "Couldn't find 'lat' dimension.");
   jCDim = idx;
   gCDims[1] = 0;
+  // For FV models, will always be non-periodic in j
+  assert(gDims[4] == gCDims[4] + 1);
+  // Try a truly 2D mesh
+  gDims[2] = -1;
+  gDims[5] = -1;
   // Look for time dimension
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
@@ -138,8 +138,15 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
-  if (isParallel) {
 #ifdef USE_MPI
+  if (isParallel) {
+#endif
+  if (procs > 1) {
@@ -147,9 +154,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     int pdims[3];
       return rval;
@@ -158,56 +163,47 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
+    if (0 == rank)
-#endif
   else {
       lDims[i] = gDims[i];
     locallyPeriodic[0] = globallyPeriodic[0];
   opts.get_int_option("IMIN", lDims[0]);
   opts.get_int_option("IMAX", lDims[3]);
-  else {
-    else {
+  else
   if (nTimeSteps > 0)
-  // ... then read actual values
+  // Now read coord values
-  if (lCDims[0] != -1) {
@@ -217,7 +213,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
-  if (lCDims[1] != -1) {
@@ -227,16 +223,17 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     if ((vmit = varInfo.find("slon")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
       // Last column
-        til_vals.resize(ilVals.size() - 1, 0.0);
-        rval = read_coordinate("slon", lDims[0], lDims[3] - 1, til_vals);
-        double dif = til_vals[1] - til_vals[0];
+        assert(lDims[3] == gDims[3] + 1);
+        std::vector<double> dummyVar(lDims[3] - lDims[0]);
+        rval = read_coordinate("slon", lDims[0], lDims[3] - 1, dummyVar);
+        double dif = dummyVar[1] - dummyVar[0];
         std::size_t i;
-        for (i = 0; i != til_vals.size(); i++)
-          ilVals[i] = til_vals[i];
+        for (i = 0; i != dummyVar.size(); i++)
+          ilVals[i] = dummyVar[i];
         ilVals[i] = ilVals[i - 1] + dif;
       else {
@@ -249,7 +246,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
     if ((vmit = varInfo.find("slat")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
         std::vector<double> dummyVar(lDims[4] - lDims[1] - 1);
@@ -257,7 +254,7 @@ ErrorCode NCHelperFV::init_mesh_vals(const FileOptions& opts, EntityHandle file_
         ERRORR(rval, "Trouble reading 'slat' variable.");
         jlVals[0] = -90.0;
         for (i = 1; i != dummyVar.size() + 1; i++)
           jlVals[i] = dummyVar[i - 1];
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
