[MOAB-dev] commit/MOAB: janehu: Changed the lay-out for the moab main page per Tim's request: showing UG, DG and MetaData as well as Full list of documents' links on the main page.
    commits-noreply at bitbucket.org
    Mon Aug  5 14:22:05 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fc0ba6f67dd1/
Changeset:   fc0ba6f67dd1
Branch:      master
User:        janehu
Date:        2013-08-05 21:20:30
Summary:     Changed the lay-out for the moab main page per Tim's request: showing UG, DG and MetaData as well as Full list of documents' links on the main page.
Affected #:  1 file
diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
index a3f7b15..52be804 100644
--- a/src/moab/Interface.hpp
+++ b/src/moab/Interface.hpp
@@ -25,17 +25,13 @@
  * MOAB's API is documented in the moab::Interface class.  Questions and comments should be sent to moab-dev
  * _at_ mcs.anl.gov.
- * \ref h5mmain "H5M File Format API"
  * \ref userguide "User's Guide (MOAB 4.6)"
  * \ref developerguide "Developer's Guide (MOAB 4.6)"
- * \ref styleguide "Coding Style Guide"
  * \ref metadata "I/O and Meta-Data Storage Conventions in MOAB"
- * \ref The "ITAPS Interfaces"
+ * <a href="pages.html">Full List of Documents</a>
 #ifndef MOAB_INTERFACE_HPP
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
