[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Sat Aug 3 13:01:15 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7134355f2c22/
Changeset:   7134355f2c22
Branch:      None
User:        iulian07
Date:        2013-08-03 19:26:00
Summary:     doxygenize comments in fortran
also include *.F90 to file patters
fortran example now shows up in the list
still don't know why the example is not referenced in iMesh
Affected #:  2 files
diff --git a/doc/user.dox.in b/doc/user.dox.in
index 07f707f..4e1c773 100644
--- a/doc/user.dox.in
+++ b/doc/user.dox.in
@@ -321,7 +321,7 @@ INPUT                  = @top_srcdir@/src @top_srcdir@/src/moab \
 # and *.h) to filter out the source-files in the directories. If left
 # blank all files are included.
-FILE_PATTERNS          = *.cpp *.hpp *.h *.dox
+FILE_PATTERNS          = *.cpp *.hpp *.h *.dox *.F90
 #FILE_PATTERNS          = *.dox
 # The RECURSIVE tag can be used to turn specify whether or not subdirectories
diff --git a/examples/DirectAccessNoHolesF90.F90 b/examples/DirectAccessNoHolesF90.F90
index 3cf5fa7..c3cceeb 100644
--- a/examples/DirectAccessNoHolesF90.F90
+++ b/examples/DirectAccessNoHolesF90.F90
@@ -1,42 +1,41 @@
-! @example DirectAccessNoHolesF90.F90 \n
-! \brief Use direct access to MOAB data to avoid calling through API, in Fortran90 \n
-! This example creates a 1d row of quad elements, such that all quad and vertex handles
-! are contiguous in the handle space and in the database.  Then it shows how to get access
-! to pointers to MOAB-native data for vertex coordinates, quad connectivity, and tag storage
-! (vertex to quad adjacency lists aren't accessible from Fortran because they are std::vector's).
-! This allows applications to access this data directly
-! without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
-! vertices are moving), this can save significant execution time in applications.
-! Using direct access (or MOAB in general) from Fortran is complicated in two specific ways:
-! 1) There is no way to use arrays with specified dimension starting/ending values with ISO_C_BINDING;
-!    therefore, all arrays passed back from MOAB/iMesh must use 1-based indices; this makes it a bit
-!    more difficult to traverse the direct arrays.  In this example, I explicitly use indices that
-!    look like my_array(1+v_ind...) to remind users of this.
-! 2) Arithmetic on handles is complicated by the fact that Fortran has no unsigned integer type.  I get
-!    around this by assigning to a C-typed variable first, before the handle arithmetic.  This seems to
-!    work fine.  C-typed variables are part of the Fortran95 standard.
-!    -#  Initialize MOAB \n
-!    -#  Create a quad mesh, as depicted above
-!    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
-!    -#  Get connectivity, coordinate, tag1 iterators
-!    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
-!    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
-!    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
-! <b>To compile</b>: \n
-!    make DirectAccessNoHolesF90 MOAB_DIR=<installdir>  \n
-! <b>To run</b>: ./DirectAccessNoHolesF90 [-nquads <# quads>]\n
+!> @example DirectAccessNoHolesF90.F90
+!! \brief Use direct access to MOAB data to avoid calling through API, in Fortran90 \n
+!! This example creates a 1d row of quad elements, such that all quad and vertex handles
+!! are contiguous in the handle space and in the database.  Then it shows how to get access
+!! to pointers to MOAB-native data for vertex coordinates, quad connectivity, and tag storage
+!! (vertex to quad adjacency lists aren't accessible from Fortran because they are std::vector's).
+!! This allows applications to access this data directly
+!! without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+!! vertices are moving), this can save significant execution time in applications.
+!! Using direct access (or MOAB in general) from Fortran is complicated in two specific ways:
+!! 1) There is no way to use arrays with specified dimension starting/ending values with ISO_C_BINDING;
+!!    therefore, all arrays passed back from MOAB/iMesh must use 1-based indices; this makes it a bit
+!!    more difficult to traverse the direct arrays.  In this example, I explicitly use indices that
+!!    look like my_array(1+v_ind...) to remind users of this.
+!! 2) Arithmetic on handles is complicated by the fact that Fortran has no unsigned integer type.  I get
+!!    around this by assigning to a C-typed variable first, before the handle arithmetic.  This seems to
+!!    work fine.  C-typed variables are part of the Fortran95 standard.
+!!    -#  Initialize MOAB \n
+!!    -#  Create a quad mesh, as depicted above
+!!    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+!!    -#  Get connectivity, coordinate, tag1 iterators
+!!    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+!!    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+!!    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+!! <b>To compile</b>: \n
+!!    make DirectAccessNoHolesF90 MOAB_DIR=<installdir>  \n
+!! <b>To run</b>: ./DirectAccessNoHolesF90 [-nquads <# quads>]\n
 #define CHECK(a) \
   if (a .ne. iBase_SUCCESS) call exit(a)
https://bitbucket.org/fathomteam/moab/commits/c39f3e9e60dc/
Changeset:   c39f3e9e60dc
Branch:      master
User:        iulian07
Date:        2013-08-03 20:00:22
Summary:     add references to the user guide and and dev guide to the main page
Affected #:  2 files
diff --git a/doc/UG/moabUG.h b/doc/UG/moabUG.h
index c5231fa..a6a6f4a 100644
--- a/doc/UG/moabUG.h
+++ b/doc/UG/moabUG.h
@@ -18,7 +18,7 @@
  - Timothy J. Tautges (Argonne National Lab, Univ Wisconsin-Madison)
  - Iulian Grindeanu (Argonne National Lab)
  - Rajeev Jain (Argonne National Lab)
- - Xiabing Xu (Argonne National Lab)
+ - Danqing Wu  (Argonne National Lab)
  <h2>Emeritus members:</h2>
@@ -27,6 +27,7 @@
  - Brandon M. Smith
  - Hong-Jun Kim
  - Jim Porter
+ - Xiabing Xu
   \page contents Table of Contents
diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
index d7ad8aa..1decd7a 100644
--- a/src/moab/Interface.hpp
+++ b/src/moab/Interface.hpp
@@ -22,9 +22,12 @@
  * together to describe geometric topology, boundary condition, and inter-processor interface
  * groupings in a mesh.
- * MOAB's API is documented in the moab::Interface class.  The User's Guide and Developer's Guide are located in
- * <a href="pages.html">related pages</a>.  Questions and comments should be sent to moab-dev
+ * MOAB's API is documented in the moab::Interface class.  Questions and comments should be sent to moab-dev
  * _at_ mcs.anl.gov.
+ * \ref userguide "User's Guide (MOAB 4.6)"
+ * \ref developerguide "Developer's Guide (MOAB 4.6)"
 #ifndef MOAB_INTERFACE_HPP
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
