[MOAB-dev] commit/MOAB: danwu: Fix Makefile.am that caused build	error
    commits-noreply at bitbucket.org
    Fri Aug  2 11:36:35 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/4ec259eacc9c/
Changeset:   4ec259eacc9c
Branch:      master
User:        danwu
Date:        2013-08-02 18:36:23
Summary:     Fix Makefile.am that caused build error
Affected #:  1 file
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index ec647ef..e1098c5 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -54,9 +54,9 @@ else
 endif
 if PNETCDF_FILE
-  if !NETCDF_FILE
-    NETCDF_TESTS = scdpart read_nc_par ucdtrvpart mpastrvpart
-  endif
+if !NETCDF_FILE
+  NETCDF_TESTS += scdpart read_nc_par ucdtrvpart mpastrvpart
+endif
 endif
 if ENABLE_mbcoupler
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
