[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Wed Jul 31 11:08:22 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8f46f1e4be1d/
Changeset: 8f46f1e4be1d
Branch: None
User: danwu
Date: 2013-07-31 18:06:32
Summary: Updated unit test read_nc to check some values of tag T0 read from fv26x46x72.t.3.nc and camEul26x48x96.t3.nc.
Affected #: 1 file
diff --git a/test/io/read_nc.cpp b/test/io/read_nc.cpp
index caff6a4..0e9adf8 100644
--- a/test/io/read_nc.cpp
+++ b/test/io/read_nc.cpp
@@ -120,7 +120,7 @@ void test_read_eul_onevar()
#endif
const double eps = 0.0001;
- double val[4 * 26];
+ double val[8 * 26];
if (1 == procs) {
Range global_quads;
@@ -128,13 +128,18 @@ void test_read_eul_onevar()
CHECK_ERR(rval);
CHECK_EQUAL((size_t)4608, global_quads.size());
- EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[4559], global_quads[48], global_quads[4607]};
- rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 4, val);
- CHECK_REAL_EQUAL(252.8529, val[0], eps); // First global quad
- CHECK_REAL_EQUAL(205.3905, val[26], eps); // 4660th global quad
- CHECK_REAL_EQUAL(252.7116, val[52], eps); // 49th global quad
- CHECK_REAL_EQUAL(200.6828, val[78], eps); // Last global quad
+ EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[2255], global_quads[2304], global_quads[4559],
+ global_quads[48], global_quads[2303], global_quads[2352], global_quads[4607]};
+ rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 8, val);
+ CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // 2256th global quad
+ CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // 2305th global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // 4560th global quad
+ CHECK_REAL_EQUAL(252.7116, val[4 * 26], eps); // 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[5 * 26], eps); // 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[6 * 26], eps); // 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[7 * 26], eps); // Last global quad
else if (2 == procs) {
Range local_quads;
@@ -142,16 +147,20 @@ void test_read_eul_onevar()
CHECK_ERR(rval);
CHECK_EQUAL((size_t)2304, local_quads.size());
- EntityHandle local_quad_ents[] = {local_quads[0], local_quads[2303]};
- rval = mb.tag_get_data(Ttag0, &local_quad_ents[0], 2, val);
+ EntityHandle local_quad_ents[] = {local_quads[0], local_quads[1151], local_quads[1152], local_quads[2303]};
+ rval = mb.tag_get_data(Ttag0, &local_quad_ents[0], 4, val);
if (0 == rank) {
- CHECK_REAL_EQUAL(252.8529, val[0], eps); // First local quad, first global quad
- CHECK_REAL_EQUAL(205.3905, val[26], eps); // Last local quad, 4660th global quad
+ CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // Median local quad, 2256th global quad
+ CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // Median local quad, 2305th global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // Last local quad, 4560th global quad
else if (1 == rank) {
- CHECK_REAL_EQUAL(252.7116, val[0], eps); // First local quad, 49th global quad
- CHECK_REAL_EQUAL(200.6828, val[26], eps); // Last local quad, last global quad
+ CHECK_REAL_EQUAL(252.7116, val[0 * 26], eps); // First local quad, 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[1 * 26], eps); // Median local quad, 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[2 * 26], eps); // Median local quad, 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[3 * 26], eps); // Last local quad, last global quad
@@ -303,6 +312,60 @@ void test_read_fv_onevar()
rval = mb.tag_get_handle("T1", 26, MB_TYPE_DOUBLE, Ttag1);
CHECK_ERR(rval);
+ // Check values of tag T0 (first level) at some strategically chosen places below
+ int rank = 0;
+ int procs = 1;
+#ifdef USE_MPI
+ ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+ rank = pcomm->proc_config().proc_rank();
+ procs = pcomm->proc_config().proc_size();
+#endif
+ const double eps = 0.0001;
+ if (1 == procs) {
+ Range global_quads;
+ rval = mb.get_entities_by_type(0, MBQUAD, global_quads);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)3312, global_quads.size());
+ EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[1619], global_quads[1656], global_quads[3275],
+ global_quads[36], global_quads[1655], global_quads[1692], global_quads[3311]};
+ CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First global quad
+ CHECK_REAL_EQUAL(232.2170, val[1 * 26], eps); // 1620th global quad
+ CHECK_REAL_EQUAL(232.7454, val[2 * 26], eps); // 1657th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // 3276th global quad
+ CHECK_REAL_EQUAL(253.6048, val[4 * 26], eps); // 37th global quad
+ CHECK_REAL_EQUAL(232.9553, val[5 * 26], eps); // 1656th global quad
+ CHECK_REAL_EQUAL(232.1704, val[6 * 26], eps); // 1693th global quad
+ CHECK_REAL_EQUAL(210.2581, val[7 * 26], eps); // Last global quad
+ else if (2 == procs) {
+ Range local_quads;
+ rval = mb.get_entities_by_type(0, MBQUAD, local_quads);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)1656, local_quads.size());
+ EntityHandle local_quad_ents[] = {local_quads[0], local_quads[827], local_quads[828], local_quads[1655]};
+ if (0 == rank) {
+ CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(232.2170, val[1 * 26], eps); // Median local quad, 1620th global quad
+ CHECK_REAL_EQUAL(232.7454, val[2 * 26], eps); // Median local quad, 1657th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // Last local quad, 3276th global quad
+ else if (1 == rank) {
+ CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First local quad, 37th global quad
+ CHECK_REAL_EQUAL(232.9553, val[1 * 26], eps); // Median local quad, 1656th global quad
+ CHECK_REAL_EQUAL(232.1704, val[2 * 26], eps); // Median local quad, 1693th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // Last local quad, last global quad
void test_read_fv_onetimestep()
https://bitbucket.org/fathomteam/moab/commits/2fc9b574564b/
Changeset: 2fc9b574564b
Branch: master
User: danwu
Date: 2013-07-31 18:06:47
Summary: Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #: 2 files
diff --git a/doc/DG/moabDG.h b/doc/DG/moabDG.h
index ed23052..32d7fe1 100644
--- a/doc/DG/moabDG.h
+++ b/doc/DG/moabDG.h
@@ -29,7 +29,7 @@
\section sequence EntitySequence & SequenceData
\subsection figure1 Figure 1: EntitySequences For One SequenceData
- <img src="../DG/figure1.jpg">
\ref dg-figures "List of Figures"
@@ -108,7 +108,7 @@ enforces the following four rules on its contained data:
\subsection figure2 Figure 2: SequenceManager and Related Classes
- <img src="../DG/figure2.jpg">
@@ -187,7 +187,7 @@ than is required at a given time for contained objects.
- MeshSet
\subsection figure3 Figure 3: SequenceManager and Related Classes
- <img src="../DG/figure3.jpg">
diff --git a/doc/user.dox.in b/doc/user.dox.in
index adb22ef..07f707f 100644
--- a/doc/user.dox.in
+++ b/doc/user.dox.in
@@ -359,7 +359,7 @@ EXAMPLE_PATTERNS =
# directories that contain image that are included in the documentation (see
# the \image command).
-IMAGE_PATH =
+IMAGE_PATH = @top_srcdir@/doc/DG/
# The INPUT_FILTER tag can be used to specify a program that doxygen should
# invoke to filter for each input file. Doxygen will invoke the filter program
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
