[MOAB-dev] commit/MOAB: danwu: Rename VarData::readDims to readStarts to better indicate its meaning
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Jul 29 16:36:14 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5341d191cdb3/
Changeset:   5341d191cdb3
Branch:      master
User:        danwu
Date:        2013-07-29 23:35:49
Summary:     Rename VarData::readDims to readStarts to better indicate its meaning
Affected #:  4 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 7d1a6c3..d28c824 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -83,12 +83,12 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
         if (vdatas[i].varDims.size() != 1)
-          vdatas[i].readDims[t].push_back(tstep_nums[t]);
+          vdatas[i].readStarts[t].push_back(tstep_nums[t]);
           vdatas[i].readCounts[t].push_back(1);
         else
-          vdatas[i].readDims[t].push_back(0);
+          vdatas[i].readStarts[t].push_back(0);
           vdatas[i].readCounts[t].push_back(tstep_nums.size());
@@ -96,14 +96,14 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
       // Set up other dimensions and counts
       if (vdatas[i].varDims.empty()) {
         // Scalar variable
       else {
         for (unsigned int idx = 0; idx != vdatas[i].varDims.size(); idx++){
           if (tDim != vdatas[i].varDims[idx]){
             // Push other variable dimensions, except time, which was already pushed
             vdatas[i].readCounts[t].push_back(dimVals[vdatas[i].varDims[idx]]);
@@ -158,28 +158,28 @@ ErrorCode NCHelper::read_variable_to_set(EntityHandle file_set, std::vector<Read
       switch (vdatas[i].varDataType) {
         case NC_BYTE:
         case NC_CHAR:
-          success = NCFUNCAG(_vara_text)(_fileId, vdatas[i].varId, &vdatas[i].readDims[t][0], &vdatas[i].readCounts[t][0],
+          success = NCFUNCAG(_vara_text)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
               (char*) data NCREQ);
           ERRORS(success, "Failed to read char data.");
           break;
         case NC_DOUBLE:
-          success = NCFUNCAG(_vara_double)(_fileId, vdatas[i].varId, &vdatas[i].readDims[t][0], &vdatas[i].readCounts[t][0],
+          success = NCFUNCAG(_vara_double)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
               (double*) data NCREQ);
           ERRORS(success, "Failed to read double data.");
           break;
         case NC_FLOAT: {
-          success = NCFUNCAG(_vara_float)(_fileId, vdatas[i].varId, &vdatas[i].readDims[t][0], &vdatas[i].readCounts[t][0],
+          success = NCFUNCAG(_vara_float)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
               (float*) data NCREQ);
           ERRORS(success, "Failed to read float data.");
           break;
         case NC_INT:
-          success = NCFUNCAG(_vara_int)(_fileId, vdatas[i].varId, &vdatas[i].readDims[t][0], &vdatas[i].readCounts[t][0],
+          success = NCFUNCAG(_vara_int)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
               (int*) data NCREQ);
           ERRORS(success, "Failed to read int data.");
           break;
         case NC_SHORT:
-          success = NCFUNCAG(_vara_short)(_fileId, vdatas[i].varId, &vdatas[i].readDims[t][0], &vdatas[i].readCounts[t][0],
+          success = NCFUNCAG(_vara_short)(_fileId, vdatas[i].varId, &vdatas[i].readStarts[t][0], &vdatas[i].readCounts[t][0],
               (short*) data NCREQ);
           ERRORS(success, "Failed to read short data.");
           break;
@@ -545,7 +545,7 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
     for (unsigned int i = 0; i < vdatas.size(); i++) {
       vdatas[i].varTags.resize(tstep_nums.size(), 0);
       vdatas[i].varDatas.resize(tstep_nums.size());
-      vdatas[i].readDims.resize(tstep_nums.size());
+      vdatas[i].readStarts.resize(tstep_nums.size());
       vdatas[i].readCounts.resize(tstep_nums.size());
     for (unsigned int i = 0; i < vsetdatas.size(); i++) {
@@ -553,13 +553,13 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
           && (vsetdatas[i].varDims.size() != 1)) {
         vsetdatas[i].varTags.resize(tstep_nums.size(), 0);
         vsetdatas[i].varDatas.resize(tstep_nums.size());
-        vsetdatas[i].readDims.resize(tstep_nums.size());
+        vsetdatas[i].readStarts.resize(tstep_nums.size());
         vsetdatas[i].readCounts.resize(tstep_nums.size());
       else {
         vsetdatas[i].varTags.resize(1, 0);
         vsetdatas[i].varDatas.resize(1);
-        vsetdatas[i].readDims.resize(1);
+        vsetdatas[i].readStarts.resize(1);
         vsetdatas[i].readCounts.resize(1);
@@ -647,12 +647,12 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_se
       // Set up the dimensions and counts
       // First time
       // then z/y/x
       if (vdatas[i].numLev != 1) {
         vdatas[i].readCounts[t].push_back(vdatas[i].numLev);
@@ -660,11 +660,11 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_se
         case ReadNC::ENTLOCVERT:
           // vertices
           // only structured mesh has j parameter that multiplies i to get total # vertices
-          vdatas[i].readDims[t].push_back(lDims[1]);
+          vdatas[i].readStarts[t].push_back(lDims[1]);
           vdatas[i].readCounts[t].push_back(lDims[4] - lDims[1] + 1);
-          vdatas[i].readDims[t].push_back(lDims[0]);
+          vdatas[i].readStarts[t].push_back(lDims[0]);
           vdatas[i].readCounts[t].push_back(lDims[3] - lDims[0] + 1);
-          assert(vdatas[i].readDims[t].size() == vdatas[i].varDims.size());
+          assert(vdatas[i].readStarts[t].size() == vdatas[i].varDims.size());
           range = &verts;
           break;
         case ReadNC::ENTLOCNSEDGE:
@@ -675,11 +675,11 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(EntityHandle file_se
           break;
         case ReadNC::ENTLOCFACE:
           // faces
-          vdatas[i].readDims[t].push_back(lCDims[1]);
-          vdatas[i].readDims[t].push_back(lCDims[0]);
+          vdatas[i].readStarts[t].push_back(lCDims[1]);
+          vdatas[i].readStarts[t].push_back(lCDims[0]);
           vdatas[i].readCounts[t].push_back(lCDims[4] - lCDims[1] + 1);
           vdatas[i].readCounts[t].push_back(lCDims[3] - lCDims[0] + 1);
 #ifdef USE_MPI
           range = &faces_owned;
 #else
@@ -737,7 +737,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
         case NC_BYTE:
         case NC_CHAR: {
           std::vector<char> tmpchardata(sz);
               &tmpchardata[0] NCREQ);
             // switch from k varying slowest to k varying fastest
@@ -751,7 +751,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
         case NC_DOUBLE: {
           std::vector<double> tmpdoubledata(sz);
               &tmpdoubledata[0] NCREQ);
@@ -765,7 +765,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
         case NC_FLOAT: {
           std::vector<float> tmpfloatdata(sz);
               &tmpfloatdata[0] NCREQ);
             // Switch from k varying slowest to k varying fastest
@@ -779,7 +779,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
         case NC_INT: {
           std::vector<int> tmpintdata(sz);
               &tmpintdata[0] NCREQ);
@@ -793,7 +793,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(EntityHandle file_set, std::v
         case NC_SHORT: {
           std::vector<short> tmpshortdata(sz);
               &tmpshortdata[0] NCREQ);
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index d6659eb..058dfaf 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -582,7 +582,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_setup(std::vector<std::string>& var_n
@@ -590,13 +590,13 @@ ErrorCode NCHelperHOMME::read_ucd_variable_setup(std::vector<std::string>& var_n
       else {
@@ -657,12 +657,12 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(EntityHandle file_
       // First: time
       // Next: numLev
@@ -672,9 +672,9 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(EntityHandle file_
           // vertices
           // we will start from the first localGid, actually; we will reset that
           // later on, anyway, in a loop
-          vdatas[i].readDims[t].push_back(localGid[0] - 1);
+          vdatas[i].readStarts[t].push_back(localGid[0] - 1);
           vdatas[i].readCounts[t].push_back(localGid.size());
           range = &verts;
           break;
         default:
@@ -744,7 +744,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(EntityHandle file_set
           // localGid range;
           // basically, we have to give a different point
           // for data to start, for every subrange :(
-          size_t nbDims = vdatas[i].readDims[t].size();
+          size_t nbDims = vdatas[i].readStarts[t].size();
           // assume that the last dimension is for the ncol,
           // node varying variable
@@ -755,13 +755,13 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(EntityHandle file_set
               pair_iter++, ic++) {
             EntityHandle starth = pair_iter->first;
             EntityHandle endh = pair_iter->second; // inclusive
-            vdatas[i].readDims[t][nbDims - 1] = (NCDF_SIZE) (starth - 1);
+            vdatas[i].readStarts[t][nbDims - 1] = (NCDF_SIZE) (starth - 1);
             vdatas[i].readCounts[t][nbDims - 1] = (NCDF_SIZE) (endh - starth + 1);
             // do a partial read, in each subrange
             // wait outside this loop
             success = NCFUNCAG2(_vara_double)(_fileId, vdatas[i].varId,
-                &(vdatas[i].readDims[t][0]), &(vdatas[i].readCounts[t][0]),
+                &(vdatas[i].readStarts[t][0]), &(vdatas[i].readCounts[t][0]),
                             &(tmpdoubledata[indexInDoubleArray]) NCREQ2);
             ERRORS(success, "Failed to read double data in loop");
             // we need to increment the index in double array for the
@@ -791,7 +791,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(EntityHandle file_set
           // localGid range;
@@ -802,13 +802,13 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(EntityHandle file_set
             success = NCFUNCAG2(_vara_float)(_fileId, vdatas[i].varId,
                             &(tmpfloatdata[indexInFloatArray]) NCREQ2);
             ERRORS(success, "Failed to read float data in loop");
             // we need to increment the index in float array for the
@@ -889,7 +889,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
         case NC_BYTE:
         case NC_CHAR: {
@@ -910,7 +910,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
           // localGid range;
           // Assume that the last dimension is for the ncol
           size_t indexInDoubleArray = 0;
@@ -920,11 +920,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
             EntityHandle endh = pair_iter->second; // Inclusive
                             &(tmpdoubledata[indexInDoubleArray]) NCREQ);
             // We need to increment the index in double array for the
@@ -951,7 +951,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
           // localGid range;
           size_t indexInFloatArray = 0;
@@ -961,11 +961,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
-            vdatas[i].readDims[t][nbDims-1] = (NCDF_SIZE) (starth - 1);
+            vdatas[i].readStarts[t][nbDims-1] = (NCDF_SIZE) (starth - 1);
             vdatas[i].readCounts[t][nbDims-1] = (NCDF_SIZE) (endh - starth + 1);
                             &(tmpfloatdata[indexInFloatArray]) NCREQ);
             // We need to increment the index in float array for the
@@ -986,7 +986,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
         case NC_INT: {
@@ -1000,7 +1000,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(EntityHandle file_set, std:
         case NC_SHORT: {
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 24b7241..3fa43c0 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -155,10 +155,10 @@ ErrorCode NCHelperMPAS::init_mesh_vals(const FileOptions& opts, EntityHandle fil
   int verticesOnEdgeVarId;
   int success = NCFUNC(inq_varid)(_fileId, "verticesOnEdge", &verticesOnEdgeVarId);
   ERRORS(success, "Failed to get variable id of verticesOnEdge.");
-  NCDF_SIZE tmp_dims[2] = {0, 0};
+  NCDF_SIZE tmp_starts[2] = {0, 0};
   NCDF_SIZE tmp_counts[2] = {static_cast<size_t>(nEdges), 2};
   verticesOnEdge.resize(nEdges * 2);
-  success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_dims, tmp_counts, &verticesOnEdge[0] NCREQ);
+  success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, tmp_starts, tmp_counts, &verticesOnEdge[0] NCREQ);
   ERRORS(success, "Failed to read variable values of verticesOnEdge.");
   // Determine the entity location type of a variable
@@ -559,7 +559,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
@@ -567,13 +567,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
       else {
@@ -655,26 +655,26 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(EntityHandle file_s
       // First: Time
       // Next: nCells or nEdges or nVertices
       switch (vdatas[i].entLoc) {
           // vertices
-          vdatas[i].readDims[t].push_back(localGidVerts[0] - 1);
+          vdatas[i].readStarts[t].push_back(localGidVerts[0] - 1);
           vdatas[i].readCounts[t].push_back(nLocalVertices);
           range = &verts;
           break;
           // faces
-          vdatas[i].readDims[t].push_back(localGidCells[0] - 1);
+          vdatas[i].readStarts[t].push_back(localGidCells[0] - 1);
           vdatas[i].readCounts[t].push_back(nLocalCells);
           range = &facesOwned;
           break;
         case ReadNC::ENTLOCEDGE:
           // edges
-          vdatas[i].readDims[t].push_back(localGidEdges[0] - 1);
+          vdatas[i].readStarts[t].push_back(localGidEdges[0] - 1);
           vdatas[i].readCounts[t].push_back(nLocalEdges);
           range = &edges;
           break;
@@ -684,9 +684,9 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(EntityHandle file_s
       // Last, numLev, even if it is 1
       // Get ptr to tag space
       if (vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1)
@@ -766,7 +766,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(EntityHandle file_set,
           // localGid range;
           // Assume that the last dimension is for the nVertLevels
@@ -776,13 +776,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(EntityHandle file_set,
-            vdatas[i].readDims[t][nbDims - 2] = (NCDF_SIZE) (starth - 1);
+            vdatas[i].readStarts[t][nbDims - 2] = (NCDF_SIZE) (starth - 1);
             vdatas[i].readCounts[t][nbDims - 2] = (NCDF_SIZE) (endh - starth + 1);
@@ -909,7 +909,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(EntityHandle file_set, std::
           // localGid range;
@@ -919,11 +919,11 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(EntityHandle file_set, std::
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index abe690f..4efabab 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -127,7 +127,7 @@ private:
     std::string varName;
     std::vector<Tag> varTags; // One tag for each time step, varTags[t]
     std::vector<void*> varDatas;
-    std::vector<std::vector<NCDF_SIZE> > readDims; // Start value for this [t][dim]
+    std::vector<std::vector<NCDF_SIZE> > readStarts; // Start value for this [t][dim]
     std::vector<std::vector<NCDF_SIZE> > readCounts; // Number of data values for this [t][dim]
     int entLoc;
     int numLev;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
