[MOAB-dev] Bug in kdtree?
Tim Tautges
tautges at mcs.anl.gov
Thu Jul 25 16:21:28 CDT 2013
I do think the entries should be ordered at the end of the call, after tree traversal is done, though.
- tim
On 07/24/2013 04:35 PM, Iulian Grindeanu wrote:
> the bug is around that logic, that I try to understand.
> It seems that the "ray_end" is reset, which is why some points are missed.
> I didn't write that logic, maybe Tim or Paul know who did.
> I don't think we should guarantee the order;
> The user should order it if needed;
> The "leafs" of the tree can come in any order, and we should not try to order it there.
> Iulian
> Hi iulian
> Thanks for that, additional side question. When you specify the maximum number of intersection to return, the list
> is ordered in distance from the start point, when you specify 0, the list is unordered. Should we not expect
> consistent behavior in both cases?
> Thanks
> Andy
> Sent from my Samsung Galaxy Note™, an AT&T LTE smartphone
> Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> it works fine if you do not specify the limit 100 for number of intersections.
> If you leave it 0, it is fine;
> (so call with kdtree->ray_intersect_triangles( kdtree_root, 1.0e-6,
> dir, box_center,
> intersection_facets
> , intersections);
> I am still looking, but I think I am close :)
> OK, obb tree works fine with the same model, default setting for everything
> (you do no have to put tetras in the build, only the faces)
> So there might be an issue with the kdtree.
> I will look at it.
> Iulian
> The problem is on the secondrun, moving the starting point in the to y=4, then we get no intersections
> beyond 48.5.
> On 07/24/2013 10:50 AM, Iulian Grindeanu wrote:
> I see no error
> Your fifth slab is at about 49.5;
> (first at 9.5, ..., fifth at 49.5)
> Iulian
> I think I may have found a bug in kdtree.
> My test problem consists of a tet mesh that is composed of some 4000
> tets. The mesh looks like that in mesh.png, a ray starts at position
> (1,0,0) and fires along (1,0,0) and we get the following results back
> from my test program swp.cpp
> Compile the minimum working example as
> g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
> This is as expected,
> # of intersections : 20
> intersection distances are on 8.5 8.74072 9.25928 9.5 18.5 18.7407
> 19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5 48.5
> 48.7407 49.2593 49.5 of ray length 900
> 8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the mesh.
> However, if we recompile and change the starting position to (1,4,0) we get
> # of intersections : 17
> intersection distances are on 8.5 8.63513 9.06064 9.5 18.5 18.6351
> 19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5 48.5 of
> ray length 900
> As far this ray is concerned there is no mesh in the 5th slab.
> What have I done wrong?
> Thanks
> Andy
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
