[MOAB-dev] Bug in kdtree?
Iulian Grindeanu
iulian at mcs.anl.gov
Wed Jul 24 16:35:51 CDT 2013
the bug is around that logic, that I try to understand.
It seems that the "ray_end" is reset, which is why some points are missed.
I didn't write that logic, maybe Tim or Paul know who did.
I don't think we should guarantee the order;
The user should order it if needed;
The "leafs" of the tree can come in any order, and we should not try to order it there.
Iulian
----- Original Message -----
| Hi iulian
| Thanks for that, additional side question. When you specify the
| maximum number of intersection to return, the list is ordered in
| distance from the start point, when you specify 0, the list is
| unordered. Should we not expect consistent behavior in both cases?
| Thanks
| Andy
| Sent from my Samsung Galaxy Note™, an AT&T LTE smartphone
| Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
| it works fine if you do not specify the limit 100 for number of
| intersections.
| If you leave it 0, it is fine;
| (so call with kdtree->ray_intersect_triangles( kdtree_root, 1.0e-6,
| dir, box_center,
| intersection_facets
| , intersections);
| I am still looking, but I think I am close :)
| | OK, obb tree works fine with the same model, default setting for
| | everything
| | (you do no have to put tetras in the build, only the faces)
| | So there might be an issue with the kdtree.
| | I will look at it.
| | Iulian
| | | The problem is on the second run, moving the s tarting point in
| | | the
| | | to y=4, then we get no intersections
| | | bey ond 48.5.
| | | On 07/24/2013 10:50 AM, Iulian Grindeanu wrote:
| | | | I see no error
| | | | Your fifth slab is at about 49.5;
| | | | (first at 9.5, ..., fifth at 49.5)
| | | | Iulian
| | | | | I think I may have found a bug in kdtree.
| | | | | My test problem consists of a tet mesh that is composed of
| | | | | some
| | | | | 4000
| | | | | tets. The mesh looks like that in mesh.png, a ray starts at
| | | | | position
| | | | | (1,0,0) and fires along (1,0,0) and we get the following
| | | | | results
| | | | | back
| | | | | from my test program swp.cpp
| | | | | Compile the minimum working example as
| | | | | g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
| | | | | This is as expected,
| | | | | # of intersections : 20
| | | | | intersection distances are on 8.5 8.74072 9.25928 9.5 18.5
| | | | | 18.7407
| | | | | 19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593
| | | | | 39.5
| | | | | 48.5
| | | | | 48.7407 49.2593 49.5 of ray length 900
| | | | | 8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the
| | | | | mesh.
| | | | | However, if we recompile and change the starting position to
| | | | | (1,4,0)
| | | | | we get
| | | | | # of intersections : 17
| | | | | intersection distances are on 8.5 8.63513 9.06064 9.5 18.5
| | | | | 18.6351
| | | | | 19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606
| | | | | 39.5
| | | | | 48.5
| | | | | of
| | | | | ray length 900
| | | | | As far this ray is concerned there is no mesh in the 5th
| | | | | slab.
| | | | | What have I done wrong?
| | | | | Thanks
| | | | | Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/7de475aa/attachment.html>
