[MOAB-dev] Bug in kdtree?
Paul Wilson wilsonp at engr.wisc.edu
Wed Jul 24 12:15:27 CDT 2013
Andy,
On 07/24/2013 09:32 AM, Andrew Davis wrote:
> I think I may have found a bug in kdtree.
> My test problem consists of a tet mesh that is composed of some 4000
> tets. The mesh looks like that in mesh.png, a ray starts at position
> (1,0,0) and fires along (1,0,0) and we get the following results back
> from my test program swp.cpp
> Compile the minimum working example as
> g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
Can you share the code?  Or the relevant parts?  What MOAB methods are
you actually using?
Paul
> This is as expected,
> # of intersections : 20
> intersection distances are on 8.5 8.74072 9.25928 9.5 18.5 18.7407
> 19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5 48.5
> 48.7407 49.2593 49.5 of ray length 900
> 8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the mesh.
> However, if we recompile and change the starting position to (1,4,0)
> we get
> # of intersections : 17
> intersection distances are on 8.5 8.63513 9.06064 9.5 18.5 18.6351
> 19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5 48.5
> of ray length 900
> As far this ray is concerned there is no mesh in the 5th slab.
> What have I done wrong?
> Thanks
> Andy
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/2d16e519/attachment.bin>
