[MOAB-dev] Bug in kdtree?
Andrew Davis davisa at engr.wisc.edu
Wed Jul 24 10:49:26 CDT 2013
The problem is on the secondrun, moving the starting point in the to
y=4, then we get no intersections
beyond 48.5.
On 07/24/2013 10:50 AM, Iulian Grindeanu wrote:
> I see no error
> Your fifth slab is at about 49.5;
> (first at 9.5, ..., fifth at 49.5)
> Iulian
>     I think I may have found a bug in kdtree.
>     My test problem consists of a tet mesh that is composed of some 4000
>     tets. The mesh looks like that in mesh.png, a ray starts at position
>     (1,0,0) and fires along (1,0,0) and we get the following results back
>     from my test program swp.cpp
>     Compile the minimum working example as
>     g++ swp.cpp -I/<moab include dir> -L<moab lib dir> -lMOAB
>     This is as expected,
>     # of intersections : 20
>     intersection distances are on 8.5 8.74072 9.25928 9.5 18.5 18.7407
>     19.2593 19.5 28.5 28.7407 29.2593 29.5 38.5 38.7407 39.2593 39.5 48.5
>     48.7407 49.2593 49.5 of ray length 900
>     8.5 9.5 18.5 19.5 etc are the boundaries of the faces of the mesh.
>     However, if we recompile and change the starting position to
>     (1,4,0) we get
>     # of intersections : 17
>     intersection distances are on 8.5 8.63513 9.06064 9.5 18.5 18.6351
>     19.0606 19.5 28.5 28.6351 29.0606 29.5 38.5 38.6351 39.0606 39.5
>     48.5 of
>     ray length 900
>     As far this ray is concerned there is no mesh in the 5th slab.
>     What have I done wrong?
>     Thanks
>     Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130724/5bd2ad25/attachment.html>
