[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Tue Jul 23 13:49:18 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8b568e1ce64b/
Changeset: 8b568e1ce64b
Branch: None
User: danwu
Date: 2013-07-23 20:48:50
Summary: Check some values of tag T0 in unit tests read_ucd_nc (serial) and ucdtrvpart (parallel) for HOMME. A bug inside NCHelper::convert_variable() (fixed by revision d018f20) would fail the parallel test ucdtrvpart.
Affected #: 2 files
diff --git a/test/io/read_ucd_nc.cpp b/test/io/read_ucd_nc.cpp
index 4678540..a468ad2 100644
--- a/test/io/read_ucd_nc.cpp
+++ b/test/io/read_ucd_nc.cpp
@@ -1,5 +1,6 @@
#include "TestUtil.hpp"
#include "moab/Core.hpp"
+#include "moab/Util.hpp"
using namespace moab;
@@ -11,42 +12,44 @@ static const char example[] = "/io/homme26x3458.t.3.nc";
#ifdef USE_MPI
#include "moab_mpi.h"
+#include "moab/ParallelComm.hpp"
#endif
-void read_file( Interface& moab, const char* input_file );
void test_read_all();
void test_read_onevar();
void test_read_onetimestep();
void test_read_nomesh();
void test_read_novars();
-ErrorCode get_options(std::string &opts);
-int main(int argc, char *argv[])
+ErrorCode get_options(std::string& opts);
+int main(int argc, char* argv[])
int result = 0;
#ifdef USE_MPI
int fail = MPI_Init(&argc, &argv);
- if (fail) return 1;
+ if (fail)
+ return 1;
#else
- argv[0]=argv[argc-argc];// to remove the warnings in serial mode about unused variables
+ argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables
#endif
result += RUN_TEST(test_read_all);
result += RUN_TEST(test_read_onevar);
result += RUN_TEST(test_read_onetimestep);
result += RUN_TEST(test_read_nomesh);
result += RUN_TEST(test_read_novars);
#ifdef USE_MPI
fail = MPI_Finalize();
+ if (fail)
+ return 1;
#endif
return result;
Core moab;
@@ -55,15 +58,15 @@ void test_read_all()
std::string opts;
ErrorCode rval = get_options(opts);
CHECK_ERR(rval);
- rval = mb.load_file( example, NULL, opts.c_str());
+ rval = mb.load_file(example, NULL, opts.c_str());
CHECK_ERR(rval);
- // check for proper tags
+ // Check for proper tags
Tag Ttag0, Ttag1;
rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
CHECK_ERR(rval);
rval = mb.tag_get_handle("T1", 26, MB_TYPE_DOUBLE, Ttag1);
CHECK_ERR(rval);
@@ -77,16 +80,52 @@ void test_read_onevar()
CHECK_ERR(rval);
opts += std::string(";VARIABLE=T");
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
CHECK_ERR(rval);
+ // Check values of tag T0 (first level) at some strategically chosen places below
+ int procs = 1;
+#ifdef USE_MPI
+ ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+ procs = pcomm->proc_config().proc_size();
+#endif
+ // Make check runs this test in one processor
+ if (1 == procs) {
+ Range verts;
+ rval = mb.get_entities_by_type(0, MBVERTEX, verts);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)6916, verts.size());
+ // Remove from vertices the gather set entities
+ EntityHandle gather_set;
+ Range gather_ents;
+ rval = Util::gather_set_entities(&mb, gather_set, gather_ents);
+ CHECK_ERR(rval);
+ verts = subtract(verts, gather_ents);
+ CHECK_EQUAL((size_t)3458, verts.size());
+ int count;
+ void* Tbuf;
+ rval = mb.tag_iterate(Ttag0, verts.begin(), verts.end(), count, Tbuf);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)count, verts.size());
+ const double eps = 0.0001;
+ double* data = (double*) Tbuf;
+ CHECK_REAL_EQUAL(233.1136, data[0 * 26], eps); // First vert
+ CHECK_REAL_EQUAL(236.1505, data[1728 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(235.7722, data[1729 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, data[3457 * 26], eps); // Last vert
@@ -98,14 +137,14 @@ void test_read_onetimestep()
CHECK_ERR(rval);
opts += std::string(";TIMESTEP=1");
- rval = mb.load_file( example, NULL, opts.c_str() );
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_EQUAL(rval, MB_TAG_NOT_FOUND);
CHECK_ERR(rval);
@@ -115,33 +154,33 @@ void test_read_nomesh()
Core moab;
Interface& mb = moab;
- // need a set for nomesh to work right
+ // Need a set for nomesh to work right
EntityHandle set;
ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
CHECK_ERR(rval);
std::string orig, opts;
rval = get_options(orig);
CHECK_ERR(rval);
opts = orig + std::string(";TIMESTEP=0");
- rval = mb.load_file( example, &set, opts.c_str() );
+ rval = mb.load_file(example, &set, opts.c_str());
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
- // now read 2nd timestep with nomesh option
+ // Now read 2nd timestep with nomesh option
opts = orig + std::string(";TIMESTEP=1;NOMESH");
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -151,7 +190,7 @@ void test_read_novars()
Core moab;
EntityHandle set;
CHECK_ERR(rval);
@@ -161,20 +200,20 @@ void test_read_novars()
CHECK_ERR(rval);
opts = orig + std::string(";NOMESH;VARIABLE=");
CHECK_ERR(rval);
opts = orig + std::string(";VARIABLE=;TIMESTEP=0");
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
opts = orig + std::string(";VARIABLE=T;TIMESTEP=0;NOMESH");
CHECK_ERR(rval);
@@ -183,20 +222,20 @@ void test_read_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
#ifdef USE_MPI
- // use parallel options
+ // Use parallel options
opts = std::string(";;PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL_PARTITION");
return MB_SUCCESS;
#else
diff --git a/test/parallel/ucdtrvpart.cpp b/test/parallel/ucdtrvpart.cpp
index 3f54e5f..abf52c5 100644
--- a/test/parallel/ucdtrvpart.cpp
+++ b/test/parallel/ucdtrvpart.cpp
@@ -19,7 +19,7 @@ void test_multiple_loads_of_same_file();
std::string partition_method;
-int main(int argc, char **argv)
int result = 0;
@@ -32,12 +32,11 @@ int main(int argc, char **argv)
return result;
void test_read_parallel_ucd_trivial()
- // disable spectral mesh for the time being, it is not ready yet
- partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS");
+ // Disable spectral mesh for the time being, it is not ready yet
//partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;SPECTRAL_MESH;PARALLEL_RESOLVE_SHARED_ENTS");
+ partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS");
test_read_parallel(3458, true);
@@ -56,8 +55,7 @@ void test_read_parallel(int num_verts, bool test_nb_nodes)
rval = mb.create_meshset(MESHSET_SET, file_set);
CHECK_ERR(rval);
- std::string opt = std::string("PARALLEL=READ_PART") +
- partition_method;
+ std::string opt = std::string("PARALLEL=READ_PART") + partition_method;
rval = mb.load_file(example, &file_set, opt.c_str());
CHECK_ERR(rval);
@@ -66,34 +64,35 @@ void test_read_parallel(int num_verts, bool test_nb_nodes)
rval = pcomm->check_all_shared_handles();
CHECK_ERR(rval);
- // get the total # owned verts
+ // Get the total # owned verts
Range verts;
CHECK_ERR(rval);
rval = pcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT);
CHECK_ERR(rval);
- int proc=pcomm->proc_config().proc_rank();
- if (0==proc)
- // remove from verts the gather set ents
+ int rank = pcomm->proc_config().proc_rank();
+ if (0 == rank) {
+ // Remove from verts the gather set ents
Range gth_ents;
rval = Util::gather_set_entities(&mb, gather_set, gth_ents);
CHECK_ERR(rval);
verts = subtract(verts, gth_ents);
int my_num = verts.size(), total_verts;
- std::cout<<"proc: " << pcomm->proc_config().proc_rank() << " verts:" << my_num << "\n";
+ std::cout << "proc: " << rank << " verts:" << my_num << "\n";
MPI_Reduce(&my_num, &total_verts, 1, MPI_INTEGER, MPI_SUM, 0, pcomm->proc_config().proc_comm());
- if (0 == pcomm->proc_config().proc_rank())
- std::cout<<"total vertices: " << total_verts << "\n";
+ if (0 == rank) {
+ std::cout << "total vertices: " << total_verts << "\n";
if (test_nb_nodes)
CHECK_EQUAL(total_verts, num_verts);
std::string write_options("PARALLEL=WRITE_PART;");
- mb.write_file( "test.h5m", NULL, write_options.c_str() );
+ mb.write_file("test.h5m", NULL, write_options.c_str());
@@ -105,7 +104,7 @@ void test_multiple_loads_of_same_file()
CHECK_ERR(rval);
- // read first only header information, no mesh, no variable
+ // Read first only header information, no mesh, no variable
std::string opts("PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL_PARTITION");
rval = mb.load_file(example, &file_set, opts.c_str());
CHECK_ERR(rval);
@@ -114,8 +113,53 @@ void test_multiple_loads_of_same_file()
CHECK_ERR(rval);
opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL_PARTITION;NOMESH;VARIABLE=T;TIMESTEP=0";
CHECK_ERR(rval);
+ int procs = pcomm->proc_config().proc_size();
+ // Make check runs this test in two processors
+ if (2 == procs) {
+ Range verts;
+ CHECK_ERR(rval);
+ if (0 == rank) {
+ Range gth_ents;
+ rval = Util::gather_set_entities(&mb, gather_set, gth_ents);
+ CHECK_ERR(rval);
+ verts = subtract(verts, gth_ents);
+ CHECK_EQUAL((size_t)1825, verts.size());
+ Tag Ttag0;
+ rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0, MB_TAG_DENSE);
+ CHECK_ERR(rval);
+ int count;
+ void* Tbuf;
+ CHECK_ERR(rval);
+ if (0 == rank) {
+ CHECK_REAL_EQUAL(237.1977, data[912 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(234.9711, data[1824 * 26], eps); // Last vert
+ else if (1 == rank) {
+ CHECK_REAL_EQUAL(231.0446, data[912 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, data[1824 * 26], eps); // Last vert
https://bitbucket.org/fathomteam/moab/commits/6e69b9ab0187/
Changeset: 6e69b9ab0187
Branch: master
User: danwu
Date: 2013-07-23 20:49:01
Summary: Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #: 6 files
diff --git a/src/io/ReadHDF5.cpp b/src/io/ReadHDF5.cpp
index 5e90822..916b69a 100644
--- a/src/io/ReadHDF5.cpp
+++ b/src/io/ReadHDF5.cpp
@@ -842,7 +842,7 @@ ErrorCode ReadHDF5::load_file_partial( const ReaderIface::IDTag* subset_list,
dbgOut.printf( 2, "Partition with num_parts = %d and part_number = %d\n",
num_parts, part_number );
- dbgOut.tprint( 1, "RETREIVING TAGGED ENTITIES\n" );
+ dbgOut.tprint( 1, "RETRIEVING TAGGED ENTITIES\n" );
Range file_ids;
ErrorCode rval = get_subset_ids( subset_list, subset_list_length, file_ids );
@@ -964,7 +964,6 @@ ErrorCode ReadHDF5::load_file_partial( const ReaderIface::IDTag* subset_list,
Range subset;
intersect( fileInfo->elems[i].desc, file_ids, subset );
mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle );
// If dimension is max_dim, then we can create the elements now
@@ -1544,7 +1543,8 @@ ErrorCode ReadHDF5::read_elems( const mhdf_ElemDesc& elems, const Range& file_id
EntityHandle handle;
EntityHandle* array = 0;
- rval = readUtil->get_element_connect( count, nodes_per_elem, type,
+ if (count>0)
+ rval = readUtil->get_element_connect( count, nodes_per_elem, type,
0, handle, array );
if (MB_SUCCESS != rval)
return error(rval);
diff --git a/test/parallel/par_intx_sph.cpp b/test/parallel/par_intx_sph.cpp
index dca936e..a6721a2 100644
--- a/test/parallel/par_intx_sph.cpp
+++ b/test/parallel/par_intx_sph.cpp
@@ -280,7 +280,7 @@ void test_intx_mpas()
std::stringstream ss;
ss<<"partial" << rank<<".vtk";
mb.write_file(ss.str().c_str(), 0, 0, &covering_lagr_set, 1);
- rval = enforce_convexity(&mb, covering_lagr_set);
+ rval = enforce_convexity(&mb, covering_lagr_set, rank);
CHECK_ERR(rval);
std::stringstream ss2;
ss2<<"partialConvex" << rank<<".vtk";
diff --git a/tools/mbcslam/CslamUtils.cpp b/tools/mbcslam/CslamUtils.cpp
index 70d81ed..ad30c9d 100644
--- a/tools/mbcslam/CslamUtils.cpp
+++ b/tools/mbcslam/CslamUtils.cpp
@@ -864,7 +864,7 @@ void departure_point_case1(CartVect & arrival_point, double t, double delta_t, C
// break the nonconvex quads into triangles; remove the quad from the set? yes.
// maybe radius is not needed;
-ErrorCode enforce_convexity(Interface * mb, EntityHandle lset)
+ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
// look at each quad; compute all 4 angles; if one is reflex, break along that diagonal
// replace it with 2 triangles, and remove from set;
@@ -989,7 +989,7 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset)
- std::cout << brokenPolys << " concave polygons were decomposed in convex ones \n";
+ std::cout << "on rank " << my_rank << " " << brokenPolys << " concave polygons were decomposed in convex ones \n";
return MB_SUCCESS;
ErrorCode create_span_quads(Interface * mb, EntityHandle euler_set, int rank)
diff --git a/tools/mbcslam/CslamUtils.hpp b/tools/mbcslam/CslamUtils.hpp
index 241fe84..e039d96 100644
--- a/tools/mbcslam/CslamUtils.hpp
+++ b/tools/mbcslam/CslamUtils.hpp
@@ -129,7 +129,7 @@ void departure_point_case1(CartVect & arrival_point, double t, double delta_t, C
-ErrorCode enforce_convexity(Interface * mb, EntityHandle set);
+ErrorCode enforce_convexity(Interface * mb, EntityHandle set, int rank = 0);
// looking at DP tag, create the spanning quads, write a file (with rank) and
// then delete the new entities (vertices) and the set of quads
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index fadbaa3..6ddadfb 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -1268,8 +1268,10 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
globalID_to_handle[globalId]= new_vert;
- // now, all dep points should be at their place
- // look in the local list of q for this proc, and create all those quads and vertices if needed
+ // now, all dep points should be at their place
+ // look in the local list of q for this proc, and create all those quads and vertices if needed
+ // it may be an overkill, but because it does not involve communication, we do it anyway
Range & local=Rto[my_rank];
Range local_q = local.subset_by_dimension(2);
// the local should have all the vertices in local_verts
diff --git a/tools/mbcslam/intx_mpas.cpp b/tools/mbcslam/intx_mpas.cpp
index 827871b..679bd03 100644
--- a/tools/mbcslam/intx_mpas.cpp
+++ b/tools/mbcslam/intx_mpas.cpp
@@ -39,9 +39,9 @@ using namespace moab;
// some input data
double gtol = 1.e-9; // this is for geometry tolerance
-// radius is always 1?
-//double CubeSide = 6.; // the above file starts with cube side 6; radius depends on cube side
-double t = 0.1, delta_t = 0.1; // check the script
+double radius = 1.;// in m: 6371220.
+double t = 0.1, delta_t = 0.05; // check the script
ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
EntityHandle euler_set)
@@ -50,10 +50,9 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
* get all plys first, then vertices, then move them on the surface of the sphere
- * radius is 1., always
+ * radius is 1., most of the time
- double radius = 1.;
Range polygons;
rval = mb->get_entities_by_dimension(euler_set, 2, polygons);
@@ -82,8 +81,8 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
// now put the vertices in the right place....
//int vix=0; // vertex index in new array
- double t=0.1, T=5;// check the script
- double time =0.05;
+ double T=5;// check the script
double rot= M_PI/10;
for (Range::iterator vit=connecVerts.begin();vit!=connecVerts.end(); vit++ )
@@ -95,12 +94,12 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
SphereCoords sphCoord = cart_to_spherical(posi);
double lat1 = sphCoord.lat-2*M_PI*t/T; // 0.1/5
double uu = 3*radius/ T * pow(sin(lat1), 2)*sin(2*sphCoord.lon)*cos(M_PI*t/T);
- uu+=2*M_PI*cos(sphCoord.lon)/T;
+ uu+=2*radius*M_PI*cos(sphCoord.lon)/T;
double vv = 3*radius/T*(sin(2*lat1))*cos(sphCoord.lon)*cos(M_PI*t/T);
double vx = -uu*sin(sphCoord.lon)-vv*sin(sphCoord.lat)*cos(sphCoord.lon);
double vy = -uu*cos(sphCoord.lon)-vv*sin(sphCoord.lat)*sin(sphCoord.lon);
double vz = vv*cos(sphCoord.lat);
- posi = posi + time * CartVect(vx, vy, vz);
+ posi = posi + delta_t * CartVect(vx, vy, vz);
double x2= posi[0]*cos(rot)-posi[1]*sin(rot);
double y2= posi[0]*sin(rot) + posi[1]*cos(rot);
CartVect newPos(x2, y2, posi[2]);
@@ -120,6 +119,7 @@ int main(int argc, char **argv)
+ std::string extra_read_opts;
std::string fileN= TestDir + "/mpas_p8.h5m";
const char *filename_mesh1 = fileN.c_str();
if (argc > 1)
@@ -139,12 +139,21 @@ int main(int argc, char **argv)
filename_mesh1 = argv[++index];
+ if (!strcmp(argv[index], "-R"))
+ radius = atof(argv[++index]);
+ if (!strcmp(argv[index], "-O"))
+ extra_read_opts = std::string(argv[++index]);
index++;
// start copy
std::string opts = std::string("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION")+
- std::string(";PARALLEL_RESOLVE_SHARED_ENTS");
+ std::string(";PARALLEL_RESOLVE_SHARED_ENTS")+extra_read_opts;
Core moab;
Interface & mb = moab;
EntityHandle euler_set;
@@ -165,7 +174,7 @@ int main(int argc, char **argv)
if (0==rank)
std::cout << " case 1: use -gtol " << gtol << " -dt " << delta_t <<
- " -input " << filename_mesh1 << "\n";
+ " -R " << radius << " -input " << filename_mesh1 << "\n";
rval = manufacture_lagrange_mesh_on_sphere(&mb, euler_set);
@@ -181,7 +190,7 @@ int main(int argc, char **argv)
CHECK_ERR(rval);
Intx2MeshOnSphere worker(&mb);
- double radius = 1.; // input
+ //double radius = 1.; // input
worker.SetRadius(radius);
@@ -189,7 +198,11 @@ int main(int argc, char **argv)
rval = worker.create_departure_mesh_2nd_alg(euler_set, covering_lagr_set);
CHECK_ERR(rval);
+ std::stringstream lagrIni;
+ lagrIni<<"def0" << rank<<".h5m";
+ rval = mb.write_file(lagrIni.str().c_str(), 0, 0, &covering_lagr_set, 1);
return 1;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
