[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Fri Jul 19 10:19:55 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/baf2406c1313/
Changeset:   baf2406c1313
Branch:      None
User:        janehu
Date:        2013-07-19 16:25:17
Summary:     Minor changes for MetaData's table of contents;
Removed dev.dox.in since it's been combined in user.dox.in.
Affected #:  3 files
diff --git a/configure.ac b/configure.ac
index b642189..8a308cb 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1207,7 +1207,6 @@ AC_CONFIG_FILES([Makefile
 		 tools/vtkMOABReaderNew/CMakeLists.txt
                  doc/Makefile
                  doc/user.dox
-                 doc/dev.dox
                  doc/config.tex
                  MeshFiles/Makefile
                  MeshFiles/unittest/Makefile
diff --git a/doc/MetaData/metadata.h b/doc/MetaData/metadata.h
index 5f53ecc..3bcd47e 100644
--- a/doc/MetaData/metadata.h
+++ b/doc/MetaData/metadata.h
@@ -9,23 +9,23 @@
 /*!  \page md-contents Table of Contents
-	\ref meta-introduction
+  \ref meta-introduction
-	\ref meta-conventions
+  \ref meta-conventions
-	\ref meta-options
+  \ref meta-options
-	\ref meta-references
+  \ref meta-references
-	\ref appendixA
+  \ref appendixA
-	\ref appendixB
+  \ref appendixB
-	\ref appendixC
+  \ref appendixC
-	\ref appendixD
+  \ref appendixD
-	\ref appendixE
+  \ref appendixE
   \section meta-introduction  Introduction
diff --git a/doc/dev.dox.in b/doc/dev.dox.in
deleted file mode 100644
index ecc27fa..0000000
--- a/doc/dev.dox.in
+++ /dev/null
@@ -1,842 +0,0 @@
- # Doxyfile 1.2.11.1
-# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
-# All text after a hash (#) is considered a comment and will be ignored
-# The format is:
-#       TAG = value [value, ...]
-# For lists items can also be appended using:
-#       TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
-# General configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
-PROJECT_NAME           = moab
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
-# if some version control system is used.
-PROJECT_NUMBER         =
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
-# where doxygen was started. If left blank the current directory will be used.
-OUTPUT_DIRECTORY       = dev
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Chinese, Croatian, Czech, Danish, Dutch, Finnish, French,
-# German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish,
-# Portuguese, Romanian, Russian, Slovak, Slovene, Spanish and Swedish.
-OUTPUT_LANGUAGE        = English
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
-# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL            = YES
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
-# will be included in the documentation.
-EXTRACT_PRIVATE        = YES
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC         = YES
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
-# This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_MEMBERS     = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these class will be included in the various
-# overviews. This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_CLASSES     = NO
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
-# Set to NO to disable this.
-BRIEF_MEMBER_DESC      = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
-# brief descriptions will be completely suppressed.
-REPEAT_BRIEF           = YES
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
-# description.
-ALWAYS_DETAILED_SEC    = YES
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
-# to NO the shortest path that makes the file name unique will be used.
-FULL_PATH_NAMES        = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. It is allowed to use relative paths in the argument list.
-STRIP_FROM_PATH        =
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
-# Set it to YES to include the internal documentation.
-INTERNAL_DOCS          = NO
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a class diagram (in Html and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off.
-CLASS_DIAGRAMS         = YES
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-SOURCE_BROWSER         = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
-# of functions and classes directly in the documentation.
-INLINE_SOURCES         = YES
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
-# fragments. Normal C and C++ comments will always remain visible.
-STRIP_CODE_COMMENTS    = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower case letters. If set to YES upper case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
-# users are adviced to set this option to NO.
-CASE_SENSE_NAMES       = YES
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
-# doesn't support long names like on DOS, Mac, or CD-ROM.
-SHORT_NAMES            = NO
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
-# documentation. If set to YES the scope will be hidden.
-HIDE_SCOPE_NAMES       = NO
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
-# which an include is specified. Set to NO to disable this.
-VERBATIM_HEADERS       = YES
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put list of the files that are included by a file in the documentation
-# of that file.
-SHOW_INCLUDE_FILES     = YES
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments  will behave just like the Qt-style comments (thus requiring an
-# explict @brief command for a brief description.
-JAVADOC_AUTOBRIEF      = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
-# reimplements.
-INHERIT_DOCS           = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
-# is inserted in the documentation for inline members.
-INLINE_INFO            = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
-# declaration order.
-SORT_MEMBER_DOCS       = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
-DISTRIBUTE_GROUP_DOC   = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
-# Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE               = 8
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
-# commands in the documentation.
-GENERATE_TODOLIST      = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
-GENERATE_TESTLIST      = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
-GENERATE_BUGLIST       = YES
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user defined paragraph with heading "Side Effects:".
-# You can put \n's in the value part of an alias to insert newlines.
-ALIASES                =
-# The ENABLED_SECTIONS tag can be used to enable conditional
-# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS       =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consist of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
-# command in the documentation regardless of this setting.
-MAX_INITIALIZER_LINES  = 30
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance some of the names that are used will be different. The list
-# of all members will be omitted, etc.
-OPTIMIZE_OUTPUT_FOR_C  = NO
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
-# list will mention the files that were used to generate the documentation.
-SHOW_USED_FILES        = YES
-# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
-# by doxygen. Possible values are YES and NO. If left blank NO is used.
-QUIET                  = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
-# NO is used.
-WARNINGS               = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
-# automatically be disabled.
-WARN_IF_UNDOCUMENTED   = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
-WARN_FORMAT            =
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
-# to stderr.
-WARN_LOGFILE           =
-# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
-# with spaces.
-INPUT                  = @top_srcdir@/src \
-                         @top_srcdir@/tools \
-                         @top_srcdir@/itaps \
-			 @top_srcdir@/examples
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank all files are included.
-FILE_PATTERNS          = *.cpp *.hpp *.h *.dox
-#FILE_PATTERNS          = *.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
-# If left blank NO is used.
-RECURSIVE              = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
-# subdirectory from a directory tree whose root is specified with the INPUT tag.
-EXCLUDE                =
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories.
-EXCLUDE_PATTERNS       =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
-# the \include command).
-EXAMPLE_PATH           =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-EXAMPLE_PATTERNS       =
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
-# the \image command).
-IMAGE_PATH             =
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter><input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output.
-INPUT_FILTER           =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
-# files to browse.
-FILTER_SOURCE_FILES    = NO
-# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
-# contains a lot of classes, structs, unions or interfaces.
-ALPHABETICAL_INDEX     = YES
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
-# in which this list will be split (can be a number in the range [1..20])
-COLS_IN_ALPHA_INDEX    = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
-# should be ignored while generating the index headers.
-IGNORE_PREFIX          =
-# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
-# generate HTML output.
-GENERATE_HTML          = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
-# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT            =
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
-HTML_HEADER            =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
-# standard footer.
-HTML_FOOTER            =
-# The HTML_STYLESHEET tag can be used to specify a user defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet
-HTML_STYLESHEET        =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
-HTML_ALIGN_MEMBERS     = YES
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
-# of the generated HTML documentation.
-GENERATE_HTMLHELP      = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
-# it should be included in the master .chm file (NO).
-GENERATE_CHI           = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
-# normal table of contents (NO) in the .chm file.
-BINARY_TOC             = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
-# to the contents of the Html help documentation and to the tree view.
-TOC_EXPAND             = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
-DISABLE_INDEX          = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
-ENUM_VALUES_PER_LINE   = 4
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript and frames is required (for instance Netscape 4.0+
-# or Internet explorer 4.0+).
-GENERATE_TREEVIEW      = YES
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
-# is shown.
-TREEVIEW_WIDTH         = 250
-# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
-# generate Latex output.
-GENERATE_LATEX         = NO
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
-# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT           =
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
-# save some trees in general.
-COMPACT_LATEX          = NO
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
-# executive. If left blank a4wide will be used.
-PAPER_TYPE             = letter
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
-# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES         =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
-# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER           =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
-# This makes the output suitable for online browsing using a pdf viewer.
-PDF_HYPERLINKS         = NO
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
-# higher quality PDF documentation.
-USE_PDFLATEX           = NO
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
-# This option is also used when generating formulas in HTML.
-LATEX_BATCHMODE        = NO
-# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimised for Word 97 and may not look very pretty with
-# other RTF readers or editors.
-GENERATE_RTF           = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
-# put in front of it. If left blank `rtf' will be used as the default path.
-RTF_OUTPUT             =
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
-COMPACT_RTF            = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
-# Note: wordpad (write) and others do not support links.
-RTF_HYPERLINKS         = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assigments. You only have to provide
-# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE    =
-# Set optional variables used in the generation of an rtf document.
-# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE    =
-# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
-# generate man pages
-GENERATE_MAN           = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
-# put in front of it. If left blank `man' will be used as the default path.
-MAN_OUTPUT             =
-# The MAN_EXTENSION tag determines the extension that is added to
-# the generated man pages (default is the subroutine's section .3)
-MAN_EXTENSION          =
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
-# would be unable to find the correct page. The default is NO.
-MAN_LINKS              = NO
-# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
-# moment.
-GENERATE_XML           = NO
-# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
-# files.
-ENABLE_PREPROCESSING   = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
-# way by setting EXPAND_ONLY_PREDEF to YES.
-MACRO_EXPANSION        = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
-EXPAND_ONLY_PREDEF     = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
-SEARCH_INCLUDES        = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
-# the preprocessor.
-INCLUDE_PATH           =
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
-# be used.
-INCLUDE_FILE_PATTERNS  =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed.
-PREDEFINED             =
-# If the MACRO_EXPANSION and EXPAND_PREDEF_ONLY tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
-EXPAND_AS_DEFINED      =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line and do not end with a semicolon. Such function macros are typically
-# used for boiler-plate code, and will confuse the parser if not removed.
-SKIP_FUNCTION_MACROS   = YES
-# Configuration::addtions related to external references
-# The TAGFILES tag can be used to specify one or more tagfiles.
-TAGFILES               =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
-# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE       =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
-# will be listed.
-ALLEXTERNALS           = NO
-# The PERL_PATH should be the absolute path and name of the perl script
-# interpreter (i.e. the result of `which perl').
-PERL_PATH              =
-# Configuration options related to the dot tool
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
-# have no effect if this option is set to NO (the default)
-HAVE_DOT               = NO
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
-CLASS_GRAPH            = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
-# class references variables) of the class with other documented classes.
-COLLABORATION_GRAPH    = YES
-# If set to YES, the inheritance and collaboration graphs will show the
-# relations between templates and their instances.
-TEMPLATE_RELATIONS     = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
-# other documented files.
-INCLUDE_GRAPH          = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
-# indirectly include this file.
-INCLUDED_BY_GRAPH      = YES
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
-GRAPHICAL_HIERARCHY    = YES
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
-DOT_PATH               =
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
-# \dotfile command).
-DOTFILE_DIRS           =
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
-MAX_DOT_GRAPH_WIDTH    = 1024
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
-MAX_DOT_GRAPH_HEIGHT   = 1024
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
-# arrows in the dot generated graphs.
-GENERATE_LEGEND        = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermedate dot files that are used to generate
-# the various graphs.
-DOT_CLEANUP            = YES
-# Configuration::addtions related to the search engine
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
-# The CGI_NAME tag should be the name of the CGI script that
-# starts the search engine (doxysearch) with the correct parameters.
-# A script with this name will be generated by doxygen.
-CGI_NAME               =
-# The CGI_URL tag should be the absolute URL to the directory where the
-# cgi binaries are located. See the documentation of your http daemon for
-# details.
-CGI_URL                =
-# The DOC_URL tag should be the absolute URL to the directory where the
-# documentation is located. If left blank the absolute path to the
-# documentation, with file:// prepended to it, will be used.
-DOC_URL                =
-# The DOC_ABSPATH tag should be the absolute path to the directory where the
-# documentation is located. If left blank the directory on the local machine
-# will be used.
-DOC_ABSPATH            =
-# The BIN_ABSPATH tag must point to the directory where the doxysearch binary
-# is installed.
-BIN_ABSPATH            =
-# The EXT_DOC_PATHS tag can be used to specify one or more paths to
-# documentation generated for other projects. This allows doxysearch to search
-# the documentation for these projects as well.
-EXT_DOC_PATHS          =
https://bitbucket.org/fathomteam/moab/commits/29c557d88ee6/
Changeset:   29c557d88ee6
Branch:      master
User:        janehu
Date:        2013-07-19 17:17:44
Summary:     Added a coding style guide for moab based on MeshKit's guide. May need to add more details for it.
Affected #:  1 file
diff --git a/doc/DG/styleguide.h b/doc/DG/styleguide.h
new file mode 100644
index 0000000..e3cf6f9
--- /dev/null
+++ b/doc/DG/styleguide.h
@@ -0,0 +1,91 @@
+  \page styleguide Coding Style Guide
+Code developed in %MOAB should follow the coding styles described here.  Any deviations from this style
+guide will result in severe berating and other verbal abuse.
+\section dirstructure MOAB Directory Structure
+%MOAB source code is organized in the following directory structure: \n
+ - doc: Documentation is put here, along with the input file for Doxygen.  Most %MOAB documentation is doxygen-processed.
+ - examples: Examples of %MOAB usage, both small and large.  These programs are not meant to be used as unit tests, but
+     rather as further documentation on %MOAB usage.
+ - src : Mesh related source codes. It includes:
+   - io: %MOAB Input/Output classes.
+   - moab: %MOAB core classes.
+   - lotte: Computational Meshing basics.
+   - parallel: Parallel mesh computation, i/o data processing methods.
+ - test: All unit test programs should go below this directory.
+   Please put the unit tests into their related subdirectories based on the test's
+   purpose if possible.
+If you're designing a new class or other code for %MOAB and are not sure where to put it, try to find something similar
+and put it there.  Otherwise, email the %MOAB email list for pointers.  <em> In general, you should not need to create new
+subdirectories in the %MOAB source code, except when implementing a new algorithm with more than about 2 files.</em>
+\section sourcestyle Source Code Style and Best Practices
+%MOAB code should abide by the following general rules:
+ - Names:
+   - Class names should be in the CamelBack style, e.g. EdgeMesh or VertexMesher.
+   - Class member variables should be camelBack, e.g. EdgeMesh::schemeType; each member variable, e.g. int memberVariable,
+   should have set/get functions void member_variable(int newval) and int member_variable(), respectively.
+   - Enumeration values should be all captitalized, with underscores avoided if possible (the enumeration name indicates
+     the general purpose of the enumeration, so e.g. we use EQUAL, not EQUAL_MESH)
+ - Source code should not contain tabs or MS-DOS newlines; tabs and other indentations should be set to a width of 2 spaces.
+   For general tips on how to set your editor for this, see the %MOAB-dev discussion starting with <a href="https://lists.mcs.anl.gov/mailman/private/moab-dev/2011/000519.html">this message</a>.
+ - Each class header should be fully commented; that includes:
+   - A \\file comment block at the top of the file; DO NOT include things like Author and Date blocks; this stuff is available
+     from subversion if we really need to know.
+   - A \\class comment block, formatted like those in the %MOAB core classes.  THE FIELDS AFTER THE CLASS NAME ARE VERY IMPORTANT,
+     as they tell developers how to include the class declaration in their code.  This information goes into the "Detailed
+     Description" portion of the class documentation.  This block should include any features or limitations of the class.
+     Eventually, we'll impose some standard boilerplate that each meshing class should use.
+     Until then, please keep this block to around a paragraph.
+   - Each function in both the public and private interfaces should be commented, INCLUDING ANY ARGUMENTS AND RETURN VALUES.
+     See the %MOAB classes for examples of how to format these comments.  As a rule of thumb, your code should run through
+     Doxygen without generating any warnings; in fact, Doxygen is sometimes helpful at pointing out inconsistencies in your
+     class declaration.
+ - Developers should avoid using \#include in header files, as they propagate dependencies more widely than necessary.  The only
+   cases where other includes are needed are to import the declaration for a parent class, and to declare types used as
+   non-pointer and non-reference function arguments.  In most cases, a forward-declaration statement (e.g. 'class MKCore')
+   will suffice.
+ - Naming classes and other top-level constructs:
+   - No names should be added to the global namespace.  Everything should be
+     in the MOAB namespace.  An exception can be made for names with a static
+     scope declared in a .cpp file, but class member functions never have a
+     static scope.
+   - Names should be kept as private as possible.  If declaring a struct or
+     utility class that is used internally by some other class, consider
+     defining it in the .cpp file of the main class or a separate header
+     only included in that .cpp file and using (if necessary) only forward
+     delcarations (e.g. \c struct \c Point3D;) in the header file used
+     by other code.  If that is not possible, then consider nesting the
+     definitions such that the scope of the name is limited to that of the
+     class using it.
+   - Any names introduced into the top-level MOAB namespace should be
+     sufficiently unique to avoid conflicts with other code.  If you must
+     introduce a class to the top-level Meshkit namespace, don't choose
+     an overly genereric name like \c Point3D .
+ - Constants and Macros
+   - Don't use a pre-processor macro where a const variable or an inline or
+     template function will suffice.
+     There is absolutely benefit to the former over the later with modern
+     compilers.  Further, using  macros bypasses typechecking that the compiler
+     would otherwise do for you and if used in headers, introduce names into
+     the global rather than Meshkit namespace.
+   - Don't define constants that are already provided by standard libraries.
+     For example, use \c M_PI as defined in \c math.h rather than defining
+     your own constant.
+\section commits Making Repository Commits
+As a general rule, developers should update frequently, and commit changes often.  However, the repository should always remain
+in a state where the code can be compiled.  Most of the time, the code should also successfully execute "make check" run from the
+top-level directory.  If you commit code that violates this principal, it should be your first priority to return the repository
+code to a compilable state, and your second priority to make sure "make check" runs without errors.
+Commits to the repository should also come with a non-trivial, useful, non-verbose log message.  Oftentimes the best way to generate
+this message is to run 'svn diff > diffs', and edit the diffs file to remove specific line changes but include a comment on
+each file that changed.  Many times it is helpful to state that 'make check runs successfully' at the end of the log message.
+Although it would be possible and many software projects do it, we prefer not to force successful execution of the test suite
+before every commit.  Developers should make every effort to avoid having to impose this constraint, by running a make check
+Top: \ref index
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
