[MOAB-dev] Remove duplicates
Iulian Grindeanu
iulian at mcs.anl.gov
Thu Jul 18 08:27:45 CDT 2013
----- Original Message -----
| Hi All
| Does anyone know of a convenient way of removing duplicate entities
| from a range, lets say for example I had an MBRange that i had
| inserted two MBEntityHandles to, that had the same services that
| define the entity, but consequently had different handles.
| Obviously I could parse this list and compare the vertex definition
| of every entity against every other, this would be N^2. Is there a
| standard moab function for this?
| Thanks
| Andy
| Sent from my Samsung Galaxy Note™, an AT&T LTE smartphone
Probably you can use MergeMesh tool; You have to pass a tolerance for vertex merging; It will take care of merging higher dimensional entities too.
It is creating a kdtree, so searching by position is not O(N^2), after the kd tree creation.
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130718/3f8134fe/attachment.html>
