[MOAB-dev] commit/MOAB: danwu: Revision d018f20 has caused some ParGAL tests for Eulerian Spectral grid to fail. To detect such kind of regressions, MOAB unit test read_nc.cpp is updated to check some values of tag T0 read from camEul26x48x96.t3.nc. This new test will pass on revisions before d018f20, fail on revision d018f20, and pass on revisions after f6aef30.
commits-noreply at bitbucket.org
Wed Jul 17 13:50:28 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/cea389befaf8/
Changeset: cea389befaf8
Branch: master
User: danwu
Date: 2013-07-17 20:49:57
Summary: Revision d018f20 has caused some ParGAL tests for Eulerian Spectral grid to fail. To detect such kind of regressions, MOAB unit test read_nc.cpp is updated to check some values of tag T0 read from camEul26x48x96.t3.nc. This new test will pass on revisions before d018f20, fail on revision d018f20, and pass on revisions after f6aef30.
Affected #: 1 file
diff --git a/test/io/read_nc.cpp b/test/io/read_nc.cpp
index 558958c..caff6a4 100644
--- a/test/io/read_nc.cpp
+++ b/test/io/read_nc.cpp
@@ -13,6 +13,7 @@ static const char example_fv[] = "/io/fv26x46x72.t.3.nc";
#ifdef USE_MPI
#include "moab_mpi.h"
+#include "moab/ParallelComm.hpp"
#endif
// CAM-EUL
@@ -40,7 +41,7 @@ int main(int argc, char* argv[])
if (fail)
return 1;
#else
- argv[0] = argv[argc - argc]; // to remove the warnings in serial mode about unused variables
+ argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables
#endif
result += RUN_TEST(test_read_eul_all);
@@ -58,7 +59,8 @@ int main(int argc, char* argv[])
#ifdef USE_MPI
fail = MPI_Finalize();
- if (fail) return 1;
+ if (fail)
+ return 1;
#endif
return result;
@@ -76,7 +78,7 @@ void test_read_eul_all()
rval = mb.load_file(example_eul, NULL, opts.c_str());
CHECK_ERR(rval);
- // check for proper tags
+ // Check for proper tags
Tag Ttag0, Ttag1, coordTag;
rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
CHECK_ERR(rval);
@@ -100,13 +102,58 @@ void test_read_eul_onevar()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
rval = mb.tag_get_handle("T1", 26, MB_TYPE_DOUBLE, Ttag1);
CHECK_ERR(rval);
+ // Check values of tag T0 (first level) at some strategically chosen places below
+ int rank = 0;
+ int procs = 1;
+#ifdef USE_MPI
+ ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+ rank = pcomm->proc_config().proc_rank();
+ procs = pcomm->proc_config().proc_size();
+#endif
+ const double eps = 0.0001;
+ double val[4 * 26];
+ if (1 == procs) {
+ Range global_quads;
+ rval = mb.get_entities_by_type(0, MBQUAD, global_quads);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)4608, global_quads.size());
+ EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[4559], global_quads[48], global_quads[4607]};
+ rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 4, val);
+ CHECK_REAL_EQUAL(252.8529, val[0], eps); // First global quad
+ CHECK_REAL_EQUAL(205.3905, val[26], eps); // 4660th global quad
+ CHECK_REAL_EQUAL(252.7116, val[52], eps); // 49th global quad
+ CHECK_REAL_EQUAL(200.6828, val[78], eps); // Last global quad
+ else if (2 == procs) {
+ Range local_quads;
+ rval = mb.get_entities_by_type(0, MBQUAD, local_quads);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)2304, local_quads.size());
+ EntityHandle local_quad_ents[] = {local_quads[0], local_quads[2303]};
+ rval = mb.tag_get_data(Ttag0, &local_quad_ents[0], 2, val);
+ if (0 == rank) {
+ CHECK_REAL_EQUAL(252.8529, val[0], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(205.3905, val[26], eps); // Last local quad, 4660th global quad
+ else if (1 == rank) {
+ CHECK_REAL_EQUAL(252.7116, val[0], eps); // First local quad, 49th global quad
+ CHECK_REAL_EQUAL(200.6828, val[26], eps); // Last local quad, last global quad
void test_read_eul_onetimestep()
@@ -121,7 +168,7 @@ void test_read_eul_onetimestep()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_EQUAL(rval, MB_TAG_NOT_FOUND);
@@ -135,7 +182,7 @@ void test_read_eul_nomesh()
Core moab;
Interface& mb = moab;
- // need a set for nomesh to work right
+ // Need a set for nomesh to work right
EntityHandle set;
ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
CHECK_ERR(rval);
@@ -148,7 +195,7 @@ void test_read_eul_nomesh()
rval = mb.load_file(example_eul, &set, opts.c_str());
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -156,12 +203,12 @@ void test_read_eul_nomesh()
- // now read 2nd timestep with nomesh option
+ // Now read 2nd timestep with nomesh option
opts = orig + std::string(";VARIABLE=T;TIMESTEP=1;NOMESH");
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -171,7 +218,7 @@ void test_read_eul_novars()
Core moab;
EntityHandle set;
CHECK_ERR(rval);
@@ -188,7 +235,7 @@ void test_read_eul_novars()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
@@ -203,12 +250,12 @@ void test_read_eul_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -225,7 +272,7 @@ void test_read_fv_all()
rval = mb.load_file(example_fv, NULL, opts.c_str());
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -233,7 +280,7 @@ void test_read_fv_all()
CHECK_ERR(rval);
- rval=mb.tag_get_handle("COORDS", 3, MB_TYPE_DOUBLE, coordTag);
+ rval = mb.tag_get_handle("COORDS", 3, MB_TYPE_DOUBLE, coordTag);
CHECK_ERR(rval);
@@ -249,7 +296,7 @@ void test_read_fv_onevar()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -270,7 +317,7 @@ void test_read_fv_onetimestep()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
@@ -284,7 +331,7 @@ void test_read_fv_nomesh()
Core moab;
EntityHandle set;
CHECK_ERR(rval);
@@ -297,7 +344,7 @@ void test_read_fv_nomesh()
rval = mb.load_file(example_fv, &set, opts.c_str());
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -305,12 +352,12 @@ void test_read_fv_nomesh()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -320,7 +367,7 @@ void test_read_fv_novars()
Core moab;
EntityHandle set;
CHECK_ERR(rval);
@@ -337,7 +384,7 @@ void test_read_fv_novars()
CHECK_ERR(rval);
Tag Ttag0, Ttag1;
@@ -352,12 +399,12 @@ void test_read_fv_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -365,7 +412,7 @@ void test_read_fv_novars()
ErrorCode get_options(std::string& opts)
#ifdef USE_MPI
- // use parallel options
+ // Use parallel options
opts = std::string(";;PARALLEL=READ_PART;PARTITION_METHOD=SQIJ");
return MB_SUCCESS;
#else
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
