[MOAB-dev] commit/MOAB: vijaysm: Remove sub_directory src/io for Cmake configuration.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Jul 5 13:15:35 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f5c032b73ebf/
Changeset:   f5c032b73ebf
Branch:      master
User:        vijaysm
Date:        2013-07-05 20:15:03
Summary:     Remove sub_directory src/io for Cmake configuration.
Affected #:  1 file
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index a1993c9..65862a8 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -57,7 +57,6 @@
     WriteUtil.cpp
-  add_subdirectory( io )
   set ( MOABIO_LIB_SRCS
     io/IODebugTrack.cpp
     io/ExoIIUtil.cpp
@@ -169,13 +168,10 @@
   if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
-    MESSAGE( "Adding NetCDF dependency libraries: ${NetCDF_LIBRARIES}" )
     target_link_libraries( MOAB ${NetCDF_LIBRARIES} )
   endif ( MOAB_USE_NETCDF AND NetCDF_FOUND )
   if ( MOAB_USE_HDF AND HDF5_FOUND )
-    MESSAGE( "Adding NetCDF dependency libraries: ${HDF5_LIBRARIES}" )
-#    add_dependencies( MOAB mhdf  )
     target_link_libraries( MOAB mhdf ${HDF5_LIBRARIES} )
   endif ( MOAB_USE_HDF AND HDF5_FOUND )
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
