[MOAB-dev] commit/MOAB: 5 new changesets
    commits-noreply at bitbucket.org
    Mon Jul  1 10:26:35 CDT 2013
5 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5a6d96e9d5a2/
Changeset:   5a6d96e9d5a2
Branch:      None
User:        iulian07
Date:        2013-06-28 23:50:15
Summary:     create polygons, not quads, for MPAS test
interestingly enough, it was working fine with MBQUAD instead of MBPOLYGON
Down deep, in sequence manager, we were creating quads (type 3, MBQUAD), but
with connectivity 5 or 6, so it was a different sequence than the regular
 4-node one for quads.
And in our logic, we were considering the nodes in sequence, as if it were
for a polygon.
So, MOAB can accept 5, or 6-node quads.
Affected #:  1 file
diff --git a/tools/mbcslam/intx_mpas.cpp b/tools/mbcslam/intx_mpas.cpp
index f29ff34..ee9b3c2 100644
--- a/tools/mbcslam/intx_mpas.cpp
+++ b/tools/mbcslam/intx_mpas.cpp
@@ -102,7 +102,7 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface=
 * mb,
       new_conn[i] =3D newNodes[v1];
     EntityHandle new_poly;
-    rval =3D mb->create_element(MBQUAD, new_conn, nnodes, new_poly);
+    rval =3D mb->create_element(MBPOLYGON, new_conn, nnodes, new_poly);
     if (MB_SUCCESS !=3D rval)
       return rval;
     rval =3D mb->add_entities(lagr_set, &new_poly, 1);
https://bitbucket.org/fathomteam/moab/commits/444731940716/
Changeset:   444731940716
Branch:      None
User:        iulian07
Date:        2013-06-28 23:59:18
Summary:     make the mpas test work in parallel in the mbcslam folder too
Affected #:  2 files
diff --git a/test/parallel/par_intx_sph.cpp b/test/parallel/par_intx_sph.cpp
index bf5cbb8..f5c4b22 100644
--- a/test/parallel/par_intx_sph.cpp
+++ b/test/parallel/par_intx_sph.cpp
@@ -5,8 +5,7 @@
  *  the mesh is read in parallel; lagrangian mesh is manufactured on the f=
ly (part of the test), in
  *    a different set.
- *  lagrangian mesh will be located on the euler mesh; intersections will =
be performed on the
- *  euler mesh
+ *  intersections will be performed on the euler mesh
  *  Created on: Nov 14, 2012
=20
@@ -45,7 +44,6 @@ std::string input_mesh_file("Homme_2pt.h5m"); // input fi=
le, partitioned correct
 std::string mpas_file("mpas_p8.h5m");
 double CubeSide =3D 6.; // the above file starts with cube side 6; radius =
depends on cube side
 double radius;
-void test_intx_in_parallel();
 void test_intx_in_parallel_elem_based();
 void test_intx_mpas();
=20
@@ -75,7 +73,7 @@ int main(int argc, char **argv)
       index++;
-  //result +=3D RUN_TEST(test_intx_in_parallel);
   radius =3D CubeSide/2*sqrt(3.);
   result +=3D RUN_TEST(test_intx_in_parallel_elem_based);
   radius =3D1.;
@@ -157,67 +155,7 @@ ErrorCode  manufacture_lagrange_mesh_on_sphere(Interfa=
ce * mb, EntityHandle eule
=20
   return rval;
-  std::string opts =3D std::string("PARALLEL=3DREAD_PART;PARTITION=3DPARAL=
LEL_PARTITION")+
-      std::string(";PARALLEL_RESOLVE_SHARED_ENTS");
-  Core moab;
-  Interface & mb =3D moab;
-  EntityHandle euler_set;
-  ErrorCode rval;
-  rval =3D mb.create_meshset(MESHSET_SET, euler_set);
-  CHECK_ERR(rval);
-  std::string example(TestDir + "/" +  input_mesh_file);
-  rval =3D mb.load_file(example.c_str(), &euler_set, opts.c_str());
-  ParallelComm* pcomm =3D ParallelComm::get_pcomm(&mb, 0);
-  CHECK_ERR(rval);
-  rval =3D pcomm->check_all_shared_handles();
-  CHECK_ERR(rval);
-  // everybody will get a LOC tag, including the non owned entities; so ex=
change tags is not required for LOC (here)
-  rval =3D manufacture_lagrange_mesh_on_sphere(&mb, euler_set);
-  CHECK_ERR(rval);
-=20
-  Intx2MeshOnSphere worker(&mb);
=20
-  //double radius=3D CubeSide/2 * sqrt(3.) ; // input
-  worker.SetRadius(radius);
-  worker.set_box_error(EPS1);//
-  //worker.SetEntityType(MBQUAD);
-  worker.SetErrorTolerance(radius*1.e-8);
-  worker.locate_departure_points(euler_set);
-  // we need to make sure the covering set is bigger than the euler mesh
-  EntityHandle covering_lagr_set;
-  rval =3D mb.create_meshset(MESHSET_SET, covering_lagr_set);
-  CHECK_ERR(rval);
-  rval =3D worker.create_departure_mesh(covering_lagr_set);
-  CHECK_ERR(rval);
-  int rank =3D pcomm->proc_config().proc_rank();
-  std::stringstream ss;
-  ss<<"partial" << rank<<".vtk";
-  mb.write_file(ss.str().c_str(), 0, 0, &covering_lagr_set, 1);
-  EntityHandle outputSet;
-  rval =3D mb.create_meshset(MESHSET_SET, outputSet);
-  CHECK_ERR(rval);
-  rval =3D worker.intersect_meshes(covering_lagr_set, euler_set, outputSet=
-  CHECK_ERR(rval);
-  //std::string opts_write("PARALLEL=3DWRITE_PART");
-  //rval =3D mb.write_file("manuf.h5m", 0, opts_write.c_str(), &outputSet,=
 1);
-  std::string opts_write("");
-  std::stringstream outf;
-  outf<<"intersect" << rank<<".h5m";
-  rval =3D mb.write_file(outf.str().c_str(), 0, 0, &outputSet, 1);
-  CHECK_ERR(rval);
LEL_PARTITION")+
index f29ff34..73494c4 100644
@@ -21,6 +21,12 @@
=20
 #include "CslamUtils.hpp"
=20
+#ifdef MESHDIR
+std::string TestDir( STRINGIFY(MESHDIR) );
+#else
+std::string TestDir(".");
+#endif
 // for M_PI
 #include <math.h>
=20
@@ -30,7 +36,7 @@
 using namespace moab;
 // some input data
 double gtol =3D 1.e-9; // this is for geometry tolerance
-std::string input_mesh_file("mpas.vtk"); // input file, plain vtk, mpas on=
 sphere
 // radius is always 1?
 //double CubeSide =3D 6.; // the above file starts with cube side 6; radiu=
s depends on cube side
 double t =3D 0.1, delta_t =3D 0.1; // check the script
@@ -115,8 +121,10 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interfac=
e * mb,
=20
+  MPI_Init(&argc, &argv);
=20
-  const char *filename_mesh1 =3D STRINGIFY(SRCDIR) "/mpas.vtk";
+  std::string fileN=3D TestDir + "/mpas_p8.h5m";
+  const char *filename_mesh1 =3D fileN.c_str();
   if (argc > 1)
     int index =3D 1;
@@ -137,23 +145,30 @@ int main(int argc, char **argv)
       index++;
-  std::cout << " case 1: use -gtol " << gtol << " -dt " << delta_t <<
-      " -input " << filename_mesh1 << "\n";
+  // start copy
+  std::string opts =3D std::string("PARALLEL=3DREAD_PART;PARTITION=3DPARAL=
LEL_PARTITION")+
+            std::string(";PARALLEL_RESOLVE_SHARED_ENTS");
   Core moab;
   ErrorCode rval;
-  if (MB_SUCCESS !=3D rval)
-    return 1;
+  CHECK_ERR(rval);
=20
-  rval =3D mb.load_file(filename_mesh1, &euler_set);
=20
-    return 1;
+  rval =3D mb.load_file(filename_mesh1, &euler_set, opts.c_str());
+  ParallelComm* pcomm =3D ParallelComm::get_pcomm(&mb, 0);
+  CHECK_ERR(rval);
+  rval =3D pcomm->check_all_shared_handles();
+  CHECK_ERR(rval);
+  // end copy
+  int rank =3D pcomm->proc_config().proc_rank();
+  if (0=3D=3Drank)
+    std::cout << " case 1: use -gtol " << gtol << " -dt " << delta_t <<
+        " -input " << filename_mesh1 << "\n";
=20
   // everybody will get a DP tag, including the non owned entities; so exc=
   EntityHandle lagrange_set;
@@ -168,7 +183,10 @@ int main(int argc, char **argv)
     return 1;
=20
-  rval =3D mb.write_file("lagr.h5m", 0, 0, &lagrange_set, 1);
+  std::stringstream ste;
+  ste<<"lagr0" << rank<<".h5m";
+  rval =3D mb.write_file(ste.str().c_str(), 0, 0, &euler_set, 1);
     std::cout << "can't write lagr set\n";
=20
@@ -178,10 +196,7 @@ int main(int argc, char **argv)
=20
=20
   worker.SetErrorTolerance(gtol);
-  std::cout << "error tolerance epsilon_1=3D" << gtol << "\n";
=20
@@ -202,6 +217,8 @@ int main(int argc, char **argv)
   std::cout << " Arrival area: " << arrival_area
       << "  intersection area:" << intx_area << " rel error: "
       << fabs((intx_area - arrival_area) / arrival_area) << "\n";
+  MPI_Finalize();
     return 1;
=20
https://bitbucket.org/fathomteam/moab/commits/bf2a0dee10dd/
Changeset:   bf2a0dee10dd
Branch:      None
User:        iulian07
Date:        2013-06-29 00:00:28
Summary:     Merge branch 'master' of bitbucket.org:iulian07/moab
Affected #:  1 file
index 73494c4..69c60dd 100644
@@ -108,7 +108,7 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface=
 * mb,
       return rval;
https://bitbucket.org/fathomteam/moab/commits/7451a26b6316/
Changeset:   7451a26b6316
Branch:      None
User:        iulian07
Date:        2013-06-29 19:53:03
Summary:     the mpas example can run in parallel in mbcslam folder
it is using the 8-part partition mpas_p8.h5m file; by default it runs in
serial, but it can be run in parallel with mpiexec -np <np> ...
Affected #:  1 file
index 69c60dd..4bc742a 100644
@@ -18,6 +18,8 @@
 #include <math.h>
 #include "moab/ProgOptions.hpp"
 #include "MBTagConventions.hpp"
+#include "TestUtil.hpp"
+#include "moab/ParallelComm.hpp"
=20
=20
@@ -42,7 +44,7 @@ double gtol =3D 1.e-9; // this is for geometry tolerance
=20
 ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
-    EntityHandle euler_set, EntityHandle & lagr_set)
+    EntityHandle euler_set)
   ErrorCode rval =3D MB_SUCCESS;
=20
@@ -62,58 +64,53 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface=
 * mb,
     return rval;
=20
-  // create new set
-  rval =3D mb->create_meshset(MESHSET_SET, lagr_set);
-    return rval;
=20
-  // get the coordinates of the old mesh, and move it around the sphere ac=
cording to case 1
+  Tag tagh =3D 0;
+  std::string tag_name("DP");
+  rval =3D mb->tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, M=
B_TAG_DENSE | MB_TAG_CREAT);
+  CHECK_ERR(rval);
+  void *data; // pointer to the LOC in memory, for each vertex
+  int count;
+  rval =3D mb->tag_iterate(tagh, connecVerts.begin(), connecVerts.end(), c=
ount, data);
+  CHECK_ERR(rval);
+  // here we are checking contiguity
+  assert(count =3D=3D (int) connecVerts.size());
+  double * ptr_DP=3D(double*)data;
+  // get the coordinates of the old mesh, and move it around the sphere in=
 the same way as in the
+  // python script
   // now put the vertices in the right place....
   //int vix=3D0; // vertex index in new array
-  // first create departure points (vertices in the lagrange mesh)
-  // then connect them in quads
-  std::map<EntityHandle, EntityHandle> newNodes;
-  for (Range::iterator vit =3D connecVerts.begin(); vit !=3D connecVerts.e=
nd();
-      vit++)
+  double t=3D0.1, T=3D5;// check the script
+  double time =3D0.05;
+  double rot=3D M_PI/10;
+  for (Range::iterator vit=3DconnecVerts.begin();vit!=3DconnecVerts.end();=
 vit++ )
-    EntityHandle oldV =3D *vit;
+    EntityHandle oldV=3D*vit;
     CartVect posi;
-    rval =3D mb->get_coords(&oldV, 1, &(posi[0]));
-      return rval;
-    // cslam utils, case 1
-    CartVect newPos;
-    departure_point_case1(posi, t, delta_t, newPos);
-    newPos =3D radius * newPos;
-    EntityHandle new_vert;
-    rval =3D mb->create_vertex(&(newPos[0]), new_vert);
-      return rval;
-    newNodes[oldV] =3D new_vert;
-  EntityHandle new_conn[MAXEDGES]; // up to 10, for the time being
-  for (Range::iterator it =3D polygons.begin(); it !=3D polygons.end(); it=
-    EntityHandle q =3D *it;
-    int nnodes;
-    const EntityHandle * conn4;
-    rval =3D mb->get_connectivity(q, conn4, nnodes);
-      return rval;
-    for (int i =3D 0; i < nnodes; i++)
-      EntityHandle v1 =3D conn4[i];
-      new_conn[i] =3D newNodes[v1];
-    EntityHandle new_poly;
-    rval =3D mb->create_element(MBPOLYGON, new_conn, nnodes, new_poly);
-      return rval;
-    rval =3D mb->add_entities(lagr_set, &new_poly, 1);
-      return rval;
+    rval =3D mb->get_coords(&oldV, 1, &(posi[0]) );
+    CHECK_ERR(rval);
+    // do some mumbo jumbo, as in python script
+    SphereCoords sphCoord =3D cart_to_spherical(posi);
+    double lat1 =3D sphCoord.lat-2*M_PI*t/T; // 0.1/5
+    double uu =3D 3*radius/ T * pow(sin(lat1), 2)*sin(2*sphCoord.lon)*cos(=
M_PI*t/T);
+    uu+=3D2*M_PI*cos(sphCoord.lon)/T;
+    double vv =3D 3*radius/T*(sin(2*lat1))*cos(sphCoord.lon)*cos(M_PI*t/T);
+    double vx =3D -uu*sin(sphCoord.lon)-vv*sin(sphCoord.lat)*cos(sphCoord.=
lon);
+    double vy =3D -uu*cos(sphCoord.lon)-vv*sin(sphCoord.lat)*sin(sphCoord.=
lon);
+    double vz =3D vv*cos(sphCoord.lat);
+    posi =3D posi + time * CartVect(vx, vy, vz);
+    double x2=3D posi[0]*cos(rot)-posi[1]*sin(rot);
+    double y2=3D posi[0]*sin(rot) + posi[1]*cos(rot);
+    CartVect newPos(x2, y2, posi[2]);
+    double len1=3D newPos.length();
+    newPos =3D radius*newPos/len1;
+    ptr_DP[0]=3DnewPos[0];
+    ptr_DP[1]=3DnewPos[1];
+    ptr_DP[2]=3DnewPos[2];
+    ptr_DP+=3D3; // increment to the next node
=20
   return rval;
@@ -170,16 +167,24 @@ int main(int argc, char **argv)
=20
-  // everybody will get a DP tag, including the non owned entities; so exc=
-  EntityHandle lagrange_set;
-  rval =3D manufacture_lagrange_mesh_on_sphere(&mb, euler_set, lagrange_se=
t);
+  rval =3D manufacture_lagrange_mesh_on_sphere(&mb, euler_set);
     return 1;
-  rval =3D mb.write_file("lagrIni.h5m", 0, 0, &lagrange_set, 1);
-   std::cout << "can't write lagr set\n";
=20
-  rval =3D enforce_convexity(&mb, lagrange_set);
+  EntityHandle covering_lagr_set;
+  rval =3D mb.create_meshset(MESHSET_SET, covering_lagr_set);
+  CHECK_ERR(rval);
+  Intx2MeshOnSphere worker(&mb);
+  double radius =3D 1.; // input
+  worker.SetRadius(radius);
+  worker.SetErrorTolerance(gtol);
+  rval =3D worker.create_departure_mesh_2nd_alg(euler_set, covering_lagr_s=
et);
+  CHECK_ERR(rval);
+  rval =3D enforce_convexity(&mb, covering_lagr_set);
     return 1;
=20
@@ -190,25 +195,17 @@ int main(int argc, char **argv)
=20
-  double radius =3D 1.; // input
-  worker.SetErrorTolerance(gtol);
     return 1;
-  rval =3D worker.intersect_meshes(lagrange_set, euler_set, outputSet);
+  rval =3D worker.intersect_meshes(covering_lagr_set, euler_set, outputSet=
     return 1;
=20
-  outf << "intersect1" << ".h5m";
+  outf << "intersect0" << rank << ".h5m";
     std::cout << "can't write output\n";
https://bitbucket.org/fathomteam/moab/commits/21c49a09a583/
Changeset:   21c49a09a583
Branch:      master
User:        iulian07
Date:        2013-07-01 17:20:37
Summary:     Merge branch 'master' of bitbucket.org:fathomteam/moab
Affected #:  6 files
diff --git a/doc/DG/moabDG.h b/doc/DG/moabDG.h
index d2e14f0..1091094 100644
--- a/doc/DG/moabDG.h
+++ b/doc/DG/moabDG.h
@@ -1,10 +1,45 @@
-/*! \page developerguide Developer's Guide (MOAB 4.6)
-=20
-  \subpage dg-contents
-=20
-  \subpage dg-figures
+/*! \page developerguide Developer's Guide (MOAB 4.6)
+=20
+  \subpage dg-contents
+=20
+  \subpage dg-figures
+  \subpage dg-tables
+/*!  \page dg-contents Table of Contents
+  \subpage sequence-info
+  \subpage meta-data-info
+/*!  \page dg-figures List of Figures
+    \ref figure1
+    \ref figure2
+    \ref figure3
+/*!  \page dg-tables List of Tables
+    \ref table1
+    \ref table2
+    \ref table3
+    \ref table4
+    \ref table5
+    \ref table6
=20
-  \page dg-contents Table of Contents
+/*!  \page sequence-info Sequence Info
=20
   \ref sequence
=20
@@ -14,10 +49,9 @@
=20
   \ref sets
=20
-  \section sequence  1. EntitySequence & SequenceData
+  \section sequence  EntitySequence & SequenceData=20
=20
   \subsection figure1 Figure 1: EntitySequences For One SequenceData
 The <I>SequenceData</I> class manages as set of arrays of per-entity value=
s. Each
 <I>SequenceData</I> has a start and end handle denoting the block of entit=
ies for which
 the arrays contain data. The arrays managed by a <I>SequenceData</I> insta=
nce are
@@ -77,9 +111,9 @@ a feature. Sequences for which the corresponding data ca=
nnot be used to store
 new entities (e.g. structured mesh discussed in a later section) will retu=
rn -1 or
 some other invalid value.
=20
- \ref dg-contents
+ \ref sequence-info "Top"
=20
-  \section manager 2. TypeSequenceManager & SequenceManager=20
+  \section manager TypeSequenceManager & SequenceManager=20
=20
 The <I>TypeSequenceManager</I> class maintains an organized set of <I>Enti=
tySequence</I>
 instances and corresponding <I>SequenceData</I> instances. It is used to m=
anage
@@ -141,119 +175,920 @@ such as allocating the correct <I>EntitySequence</I=
> subtype for a given <I>Enti
=20
 <sup>2</sup>Given rule four for the data managed by a <I>TypeSequenceManag=
er</I>, any <I>SequenceData</I> for which all handles are allocated will be=
 referenced by exactly one <I>EntitySequence</I>.
=20
-  \ref dg-contents
- \section s-mesh 3. Structured Mesh
-Structured mesh storage is implemented using subclasses of <I>SequenceData=
</I>:
-<I>ScdElementData</I> and <I>ScdVertexData</I>. The <I>StructuredElementSe=
q</I> class is
-used to access the structured element connectivity. A standard <I>VertexSe=
quence</I>
-instance is used to access the ScdVertexData because the vertex data stora=
ge
-is the same as for unstructured mesh.
-  \ref dg-contents
-  \section sets 4. Entity Sets
-- MeshSetSequence
-The <I>MeshSetSequence</I> class is the same as most other subclasses of <=
-in that it utilizes SequenceData to store its data. A single array in the =
<I>SequenceData</I>
-is used to store instances of the MeshSet class, one per allocated <I>Enti=
tyHandle</I>.
-<I>SequenceData</I> allocates all of its managed arrays using malloc and f=
ree as
-simple arrays of bytes. <I>MeshSetSequence</I> does in-place construction =
and de-
-struction of <I>MeshSet</I> instances within that array. This is similar t=
o what is
-done by <I>std::vector</I> and other container classes that may own more s=
torage
-than is required at a given time for contained objects.
-- MeshSet
-  \subsection figure3 Figure 3: SequenceManager and Related Classes
-The <I>MeshSet</I> class is used to represent a single entity set instance=
 in MOAB.
-The class is optimized to minimize storage (further possible improvements =
in
-storage size are discussed later.)
-Figure 3 shows the memory layout of an instance of the <I>MeshSet</I> clas=
s.
-The flags member holds the set creation bit flags: <I>MESHSET_TRACK_OWNER<=
/I>,
-<I>MESHSET_SET</I>, and <I>MESHSET_ORDERED</I>. The presence of the <I>MES=
HSET_TRACK_OWNER</I>
-indicates that reverse links from the contained entities back to the ownin=
g set
-should be maintained in the adjacency list of each entity. The <I>MESHSET_=
SET</I>
-and <I>MESHSET_ORDERED</I> bits are mutually exclusive, and as such most c=
ode only
-tests for the <I>MESHSET_ORDERED</I>, meaning that in practice the <I>MESH=
SET_SET</I> bit is
-ignored. <I>MESHSET_ORDERED</I> indicates that the set may contain duplica=
te handles
-and that the order that the handles are added to the set should be preserv=
ed.
-In practice, such sets are stored as a simple list of handles. <I>MESHSET_=
SET</I> (or in
-practice, the lack of <I>MESHSET_ORDERED</I>) indicates that the order of =
the handles
-need not be preserved and that the set may not contain duplicate handles. =
Such
-sets are stored in a sorted range-compacted format similar to that of the =
Range
-class.
-The memory for storing contents, parents, and children are each handled in
-the same way. The data in the class is composed of a 2-bit =E2=80=98size=
=E2=80=99 field and two
-values, where the two values may either be two handles or two pointers. Th=
e size
-bit-fields are grouped together to reduce the required amount of memory. I=
f the
-numerical value of the 2-bit size field is 0 then the corresponding list i=
s empty.
-If the 2-bit size field is either 1 or 2, then the contents of the corresp=
onding list
-are stored directly in the corresponding two data fields of the MeshSet ob=
ject.
-If the 2-bit size field has a value of 3 (11 binary), then the correspondi=
ng two
-data fields store the begin and end pointers of an external array of handl=
es.
-The number of handles in the external array can be obtained by taking the
-difference of the start and end pointers. Note that unlike <I>std::vector<=
/I>, we
-do not store both an allocated and used size. We store only the =E2=80=98u=
sed=E2=80=99 size
-and call std::realloc whenever the used size is modified, thus we rely on =
the
-std::malloc implementation in the standard C library to track =E2=80=98all=
ocated=E2=80=99 size
-for us. In practice this performs well but does not return memory to the =
=E2=80=98system=E2=80=99
-when lists shrink (unless they shrink to zero). This overall scheme could =
exhibit
-poor performance if the size of one of the data lists in the set frequentl=
y changes
-between less than two and more than two handles, as this will result in fr=
equent
-releasing and re-allocating of the memory for the corresponding array.
-If the <I>MESHSET_ORDERED</I> flag is not present, then the set contents l=
ist (parent
-and child lists are unaffected) is stored in a range-compacted format. In =
this
-format the number of handles stored in the array is always a multiple of t=
wo.
-Each consecutive pair of handles indicate the start and end, inclusive, of=
 a range
-of handles contained in the set. All such handle range pairs are stored in=
 sorted
-order and do not overlap. Nor is the end handle of one range ever one less=
 than
-the start handle of the next. All such =E2=80=98adjacent=E2=80=99 range pa=
irs are merged into a
-single pair. The code for insertion and removal of handles from range-form=
atted
-set content lists is fairly complex. The implementation will guarantee tha=
t a
-given call to insert entities into a range or remove entities from a range=
 is never
-worse than O(ln n) + O(m + n), where =E2=80=98n=E2=80=99 is the number of =
handles to insert
-and =E2=80=98m=E2=80=99 is the number of handles already contained in the =
set. So it is generally
-much more efficient to build Ranges of handles to insert (and remove) and =
call
-MOAB to insert (or remove) the entire list at once rather than making may
-calls to insert (or remove) one or a few handles from the contents of a se=
t.
-The set storage could probably be further minimized by allowing up to six
-handles in one of the lists to be elided. That is, as there are six potent=
ial =E2=80=98slots=E2=80=99
-in the MeshSet object then if two of the lists are empty it should be poss=
ible to store up to six values of the remaining list directly in the MeshSe=
t object.
-However, the additional runtime cost of such complexity could easily outwe=
igh
-any storage advantage. Further investigation into this has not been done b=
ecause
-the primary motivation for the storage optimization was to support binary =
trees.
-Another possible optimization of storage would be to remove the <I>MeshSet=
</I>
-object entirely and instead store the data in a =E2=80=98blocked=E2=80=99 =
format. The corre-
-sponding <I>SequenceData</I> would contain four arrays: flags, parents, ch=
ildren, and
-contents instead of a single array of <I>MeshSet</I> objects. If this were=
 done then
-no storage need ever be allocated for parent or child links if none of the=
 sets
-in a <I>SequenceData</I> has parent or child links. The effectiveness of t=
he storage
-reduction would depend greatly on how sets get grouped into <I>SequenceDat=
as</I>.
-This alternate storage scheme might also allow for better cache utilizatio=
n as it
-would group like data together. It is often the case that application code=
 that
-is querying the contents of one set will query the contents of many but ne=
ver
-query the parents or children of any set. Or that an application will quer=
y only
-parent or child links of a set without every querying other set properties=
. The
-downside of this solution is that it makes the implementation a little les=
s mod-
-ular and maintainable because the existing logic contained in the <I>MeshS=
et</I> class
-would need to be spread throughout the <I>MeshSetSequence</I> class.
-  \ref dg-contents
-  \page dg-figures List of Figures
-  \ref figure1
-  \ref figure2
-  \ref figure3
+ \section s-mesh Structured Mesh
+Structured mesh storage is implemented using subclasses of <I>SequenceData=
</I>:
+<I>ScdElementData</I> and <I>ScdVertexData</I>. The <I>StructuredElementSe=
q</I> class is
+used to access the structured element connectivity. A standard <I>VertexSe=
quence</I>
+instance is used to access the ScdVertexData because the vertex data stora=
ge
+is the same as for unstructured mesh.
+  \section sets Entity Sets
+- MeshSetSequence
+The <I>MeshSetSequence</I> class is the same as most other subclasses of <=
+in that it utilizes SequenceData to store its data. A single array in the =
<I>SequenceData</I>
+is used to store instances of the MeshSet class, one per allocated <I>Enti=
tyHandle</I>.
+<I>SequenceData</I> allocates all of its managed arrays using malloc and f=
ree as
+simple arrays of bytes. <I>MeshSetSequence</I> does in-place construction =
and de-
+struction of <I>MeshSet</I> instances within that array. This is similar t=
o what is
+done by <I>std::vector</I> and other container classes that may own more s=
torage
+than is required at a given time for contained objects.
+- MeshSet
+  \subsection figure3 Figure 3: SequenceManager and Related Classes
+The <I>MeshSet</I> class is used to represent a single entity set instance=
 in MOAB.
+The class is optimized to minimize storage (further possible improvements =
in
+storage size are discussed later.)
+Figure 3 shows the memory layout of an instance of the <I>MeshSet</I> clas=
s.
+The flags member holds the set creation bit flags: <I>MESHSET_TRACK_OWNER<=
/I>,
+<I>MESHSET_SET</I>, and <I>MESHSET_ORDERED</I>. The presence of the <I>MES=
+indicates that reverse links from the contained entities back to the ownin=
g set
+should be maintained in the adjacency list of each entity. The <I>MESHSET_=
SET</I>
+and <I>MESHSET_ORDERED</I> bits are mutually exclusive, and as such most c=
ode only
+tests for the <I>MESHSET_ORDERED</I>, meaning that in practice the <I>MESH=
SET_SET</I> bit is
+ignored. <I>MESHSET_ORDERED</I> indicates that the set may contain duplica=
te handles
+and that the order that the handles are added to the set should be preserv=
ed.
+In practice, such sets are stored as a simple list of handles. <I>MESHSET_=
SET</I> (or in
+practice, the lack of <I>MESHSET_ORDERED</I>) indicates that the order of =
the handles
+need not be preserved and that the set may not contain duplicate handles. =
Such
+sets are stored in a sorted range-compacted format similar to that of the =
Range
+class.
+The memory for storing contents, parents, and children are each handled in
+the same way. The data in the class is composed of a 2-bit =E2=80=98size=
+values, where the two values may either be two handles or two pointers. Th=
e size
+bit-fields are grouped together to reduce the required amount of memory. I=
f the
+numerical value of the 2-bit size field is 0 then the corresponding list i=
s empty.
+If the 2-bit size field is either 1 or 2, then the contents of the corresp=
onding list
+are stored directly in the corresponding two data fields of the MeshSet ob=
ject.
+If the 2-bit size field has a value of 3 (11 binary), then the correspondi=
ng two
+data fields store the begin and end pointers of an external array of handl=
es.
+The number of handles in the external array can be obtained by taking the
+difference of the start and end pointers. Note that unlike <I>std::vector<=
/I>, we
+do not store both an allocated and used size. We store only the =E2=80=98u=
sed=E2=80=99 size
+and call std::realloc whenever the used size is modified, thus we rely on =
the
+std::malloc implementation in the standard C library to track =E2=80=98all=
+for us. In practice this performs well but does not return memory to the =
+when lists shrink (unless they shrink to zero). This overall scheme could =
exhibit
+poor performance if the size of one of the data lists in the set frequentl=
y changes
+between less than two and more than two handles, as this will result in fr=
equent
+releasing and re-allocating of the memory for the corresponding array.
+If the <I>MESHSET_ORDERED</I> flag is not present, then the set contents l=
ist (parent
+and child lists are unaffected) is stored in a range-compacted format. In =
this
+format the number of handles stored in the array is always a multiple of t=
wo.
+Each consecutive pair of handles indicate the start and end, inclusive, of=
 a range
+of handles contained in the set. All such handle range pairs are stored in=
 sorted
+order and do not overlap. Nor is the end handle of one range ever one less=
 than
+the start handle of the next. All such =E2=80=98adjacent=E2=80=99 range pa=
+single pair. The code for insertion and removal of handles from range-form=
atted
+set content lists is fairly complex. The implementation will guarantee tha=
t a
+given call to insert entities into a range or remove entities from a range=
 is never
+worse than O(ln n) + O(m + n), where =E2=80=98n=E2=80=99 is the number of =
handles to insert
+and =E2=80=98m=E2=80=99 is the number of handles already contained in the =
+much more efficient to build Ranges of handles to insert (and remove) and =
call
+MOAB to insert (or remove) the entire list at once rather than making may
+calls to insert (or remove) one or a few handles from the contents of a se=
t.
+The set storage could probably be further minimized by allowing up to six
+handles in one of the lists to be elided. That is, as there are six potent=
+in the MeshSet object then if two of the lists are empty it should be poss=
t object.
+However, the additional runtime cost of such complexity could easily outwe=
igh
+any storage advantage. Further investigation into this has not been done b=
ecause
+the primary motivation for the storage optimization was to support binary =
trees.
+Another possible optimization of storage would be to remove the <I>MeshSet=
</I>
+object entirely and instead store the data in a =E2=80=98blocked=E2=80=99 =
format. The corre-
+sponding <I>SequenceData</I> would contain four arrays: flags, parents, ch=
ildren, and
+contents instead of a single array of <I>MeshSet</I> objects. If this were=
 done then
+no storage need ever be allocated for parent or child links if none of the=
 sets
+in a <I>SequenceData</I> has parent or child links. The effectiveness of t=
he storage
+reduction would depend greatly on how sets get grouped into <I>SequenceDat=
as</I>.
+This alternate storage scheme might also allow for better cache utilizatio=
n as it
+would group like data together. It is often the case that application code=
 that
+is querying the contents of one set will query the contents of many but ne=
ver
+query the parents or children of any set. Or that an application will quer=
y only
+parent or child links of a set without every querying other set properties=
. The
+downside of this solution is that it makes the implementation a little les=
s mod-
+ular and maintainable because the existing logic contained in the <I>MeshS=
et</I> class
+would need to be spread throughout the <I>MeshSetSequence</I> class.
+/*! \page meta-data-info I/O and Meta-Data Storage Conventions in MOAB
+  <Center><H3> Timothy J. Tautges </H3></Center>
+    \ref meta-introduction
+    \ref meta-conventions
+    \ref meta-options
+    \ref meta-references
+    \ref appendixA
+    \ref appendixB
+    \ref appendixC
+    \ref appendixD
+    \ref appendixE
+  \section meta-introduction  Introduction
+The Mesh-Oriented datABase (MOAB) is a library for representing finite ele=
ment and other types of mesh data [1].  Various types of meta-data are ofte=
n used in conjunction with a mesh.  Examples include boundary condition gro=
upings, material types, and provenance information for the mesh.  Because t=
he data model used in MOAB is so abstract, conventions are useful for descr=
ibing how meta-data is stored into that data model.  This document describe=
s those conventions for several types of data commonly found in meshes stor=
ed in MOAB.  Because the data models used by MOAB and iMesh, the ITAPS mesh=
 interface [2], are so similar, the conventions described here apply almost=
 unmodified to iMesh as well as to MOAB.
+The meshes represented in MOAB originate in a variety of forms, including =
mesh read from files of various formats (e.g. CUBIT =E2=80=9C.cub=E2=80=9D =
file, VTK, etc.) as well as mesh written into MOAB directly by various soft=
ware libraries (e.g. MeshKit).  Although there is no standard for naming or=
 storing meta-data with a mesh, there is a great deal of commonality in the=
 types of meta-data typically found with mesh data.  This document describe=
s conventions that have been established for commonly encountered meta-data=
.  Various mesh readers implemented in MOAB attempt to read meta-data from =
a file and write it into the MOAB data model using these conventions.  Alth=
ough there is no requirement to store a given type of meta-data in the form=
 described here, a number of services have been written to handle meta-data=
 using these conventions, no matter the source of the meta-data being proce=
ssed.
+Several specific tools are often used in concert with MOAB and bear specia=
l mention here.  The CUBIT toolkit generates finite element meshes, and sav=
es them to a native save file (referred to as a =E2=80=9C.cub=E2=80=9D file=
) which MOAB is able to read.  Reading CUBIT meshes into MOAB through the .=
cub file format is preferred over other formats, since most other mesh form=
ats written by CUBIT do not save most meta-data.  The MeshKit library also =
generates mesh using CGM and MOAB, and uses the same conventions for storin=
g meshes into MOAB.  Finally, MOAB includes a CGM reader which can read a g=
eometric model into a faceted representation in MOAB.  Meta-data from all t=
hese tools are stored in MOAB using the conventions described here.=20
+The MOAB data model consists of the following basic types:
+- <B>Entity</B>: The basic elements of topology, e.g. vertex, edge, triang=
le, tetrahedron, etc.  MOAB represents all types in the finite element zoo,=
 plus polygons and polyhedra.
+- <B>Entity Set</B>: An arbitrary collection of entities and other sets.  =
Sets can have parent/child relations with other sets, and these relations a=
re distinct from =E2=80=9Ccontains=E2=80=9D relations.
+- <B>Interface</B>: The interface object through which other entities are =
accessed, in the sense of object-oriented-programming.  iMesh refers to the=
 interface as the =E2=80=9Croot=E2=80=9D set.
+- <B>Tag</B>: A piece of data that can be assigned a distinct value to eac=
h entity and entity set, and to the interface itself.  Tags have a prescrib=
ed name, size in bytes, and data type; allowed data types are integer, doub=
le, entity handle, and byte or opaque.
+The following section describes each meta-data tag convention in detail; t=
hese conventions are also summarized in Table 1.
+  \ref meta-data-info "Top"
+  \section meta-conventions  Meta-Data Conventions
+Meta-data is stored in MOAB and iMesh in the form of tags applied to eithe=
r entities or entity sets.  For meta-data represented as entity sets, the c=
ontents of those sets are determined by the convention, with tags on those =
sets identifying them with the convention and adding any other semantic dat=
a.
+Each meta-data convention is described in a subsection below.  Each conven=
tion begins with a short description of:
+- Whether tags associated with the convention are assigned to entities or =
entity sets
+- The tag(s) associated with the convention; information for each tag incl=
udes the name, the data type (I=3Dinteger, D=3Ddouble, C=3Dcharacter, H=3Dh=
andle), and the tag length.  Tag lengths are specified after an asterisk (*=
); for example, C*32 implies a tag with character type and length 32.  Unsp=
ecified lengths correspond to length one.
+<H3>Name</H3>
+(Data: Entity sets, entities; Tag(s): NAME/C*32)
+Character strings are used in many different contexts in applications.  MO=
AB uses the =E2=80=9CNAME=E2=80=9D tag to store character strings used to n=
ame entities.  This tag is of byte-type and is of length 32 bytes.  Note th=
at the string stored in this tag may or may not be terminated with a NULL c=
haracter.  It is always prudent account for missing NULL terminator, to avo=
id buffer overflow errors in the application.  Applications are free to def=
ine their own version of the NAME tag with a longer length, though this def=
inition may conflict with other services attempting to use this tag with th=
e conventional size.  Applications needing a string tag with a longer or va=
riable length can also use MOAB=E2=80=99s variable-length tag type, though =
this will not be compatible with iMesh.
+<H3>Title </H3>
+(Data: Entity sets (file or instance); Tag(s): TITLE/C*strlen)
+The title tag is meant to hold the overall identifier of a mesh, written a=
t generation time or read from a file generated with a non-MOAB tool.  The =
tag length is variable, and is set by the application directly (by calling =
the tag_create function) or indirectly (by embedding the title in a file re=
ad by MOAB).
+<H3> Global Identifier </H3>
+(Data: Entity sets, entities; Tag(s): GLOBAL_ID/I)
+Global identifiers are used in many different contexts in applications.  G=
eometric model entities are identified by dimension and id, e.g. =E2=80=9CV=
olume 1=E2=80=9D.  Mesh vertices and elements are identified similarly in m=
esh generation codes.  Boundary conditions and material types are identifie=
d similarly.  This tag is used to store such information.  This tag is curr=
ently stored in a 32-byte integer, though this may change in the future.
+<H3> Geometric Model Information </H3>
+(Data: Entity sets; Tag(s): GEOM_DIMENSION/I, GLOBAL_ID/I, NAME/C*32, CATE=
GORY/C*32, GEOM_SENSE_2(EH[2]), GEOM_SENSE_N_ENTS(EH*N), GEOM_SENSE_N_SENSE=
S(I*N))
+Mesh generation is often performed starting from a geometric model, repres=
ented in some form of CAD engine.  Many of the meshes used by MOAB are gene=
rated based on the CGM library.  Geometric models contain both topological =
information (the topological entities in the geometric model) and shape inf=
ormation (the geometric shape of those entities), as well as other meta-dat=
a written to the entities in a model.  When a mesh is read from a CUBIT .cu=
b file, meta-data from the geometric model is read and represented in the M=
OAB data model, as described below. <B> Note that although MOAB reads and r=
epresents meta-data associated with the geometric model, it does not repres=
ent the geometric model itself.</B>  Therefore, shape-related information, =
e.g. the arc length of an edge or surface normal at a given point, can be r=
etrieved only from the model represented in CGM or another geometric modeli=
ng engine.
+The information contained in a geometric model, read into and represented =
in MOAB, consists of:
+- Model entities (vertex, edge, face, volume)
+- Topological relationships between model entities
+- Groups of model entities
+- Model entity/group ids
+- Model entity/group names
+The storage of this information into MOAB's data model is described for ea=
ch type is described below.
+- <B>Entities </B>
+Entities in the geometric model (VERTEX, EDGE, FACE, VOLUME) are each repr=
esented by an entity set<sup>1</sup>.  These sets are tagged with the =E2=
=80=9CGEOM_DIMENSION=E2=80=9D tag, with integer value equal to the topologi=
cal dimension of the entity (VERTEX =3D 0, EDGE =3D 1, etc.)  These sets co=
ntain the mesh owned by the corresponding entity in the geometric model.  N=
ote this does not include mesh owned by bounding entities; thus, the set fo=
r a FACE will not contain the mesh vertices owned by bounding EDGEs in the =
geometric model.  These sets may or may not contain mesh entities of interm=
ediate dimension, e.g. mesh edges owned by a FACE or faces owned by a VOLUM=
E, depending on the application generating the mesh or the file from which =
the mesh was read.  These sets are all set-types, i.e. the order of entitie=
s in the sets is not significant, except in the case of EDGE sets, where or=
der of the mesh vertices and edges corresponds to the relative order of ver=
tices and edges at the time of mesh generation.  In MOAB, these sets are no=
n-tracking by default, i.e. entities do not have knowledge of which geometr=
y sets they are members of.
+<sup>1</sup>Body-type entities from CUBIT are not explicitly represented i=
n MOAB.
+- <B> Topological Relationships </B>
+In the geometric model, each FACE is bounded by zero or more EDGEs; other =
topological relationships between geometric entities exist in a similar man=
ner.  These relationships are embedded in the data model using parent/child=
 relations between entity sets.  For example, the entity set corresponding =
to a FACE will have child sets, each corresponding to a bounding EDGE, and =
parent sets, each corresponding to a VOLUME bounded by that FACE.  The rela=
tive order of sets in those parent/child lists is not significant, thus, =
=E2=80=9Cloops=E2=80=9D bounding a FACE cannot reliably be inferred from th=
is data.
+- <B> Groups </B>
+Geometric entities are sometimes assigned to application-specific groups. =
 These groups are represented using entity sets, tagged with a =E2=80=9CGRO=
UP=E2=80=9D tag whose value equals the group id.  Group sets are =E2=80=9Cs=
et=E2=80=9D-type, and are not tracking sets.  These sets contain the sets c=
orresponding to geometric entities contained in the groups in the geometric=
 model, as well as any mesh entities assigned to the group.
+<H4> Sense </H4>
+A geometric face has a natural orientation, indicated by the direction of =
the normal to the face; similarly, edges have a natural orientation determi=
ned by the direction of the tangent.  When faces bound regions, or edges bo=
und faces, they do so with a sense; if a region includes a face with forwar=
d sense, that means the face's natural normal direction points out of the v=
olume.  If a face includes an edge with forward sense, that means that if o=
ne moves along the edge in the direction of its tangent, the material of th=
e face is on the left hand side.  The sense of a face (edge) with respect t=
o a region (face) it bounds is stored using tags on the face (edge).
+Most models allow a face to be part of only two regions.  Therefore, to st=
ore the sense of a face with respect to regions including it, a tag with tw=
o values is used.  This tag is named GEOM_SENSE_2, and has 2 EntityHandle v=
alues.  The first value corresponds to the entity set for the region for wh=
ich that face has a forward sense, and the second to the region for which t=
hat face has a reverse sense.
+Edges can bound more than two faces.  Therefore, two variable-length tags =
are used, one to store the EntityHandles of the faces the edge bounds, and =
the other to store the sense with which the edge bounds the corresponding f=
ace.  These tags are named GEOM_SENSE_N_ENTS and GEOM_SENSE_N_SENSES, respe=
ctively.  These are stored as variable-length tags; see the MOAB user's gui=
de for information on how to work with tags of this type.=20
+The following sense values are used:
+- 0: forward
+- 1: reverse
+- -1: unnknown
+<H3> Material Type </H3>
+(Data: Entity sets; Tag(s): MATERIAL_SET/I)
+Most finite element and other PDE-based analysis codes require a material =
type for each cell or element in the simulation.  MOAB uses entity sets to =
store this information, in the form of entity sets.  The MATERIAL_SET tag i=
s used to identify these sets.  The value of this tag is conventionally an =
integer; in most cases this stores a user-assigned identifier associated wi=
th that material.=20
+CUBIT assigns material types using what it calls =E2=80=9Celement blocks=
=E2=80=9D, with each element block given a user-assigned id number and opti=
onally a name.  The CUBIT and Exodus file readers in MOAB read element bloc=
ks into MATERIAL_SET sets. =20
+In CUBIT, materials are typically assigned by assigning geometric volumes =
to element blocks.  Therefore, material sets often contain entity sets corr=
esponding to those volumes.  Thus, a materrial set in MOAB is unlikely to c=
ontain mesh entities directly; rather, that set contains other sets which c=
ontain mesh entities.  In these cases, mesh entities can be retrieved by pa=
ssing a =E2=80=9Crecursive=E2=80=9D flag to the appropriate function (MOAB)=
, or by calling the getEntitiesRec extension function (iMesh) provided by M=
OAB.
+<H3> Boundary Conditions (Dirichlet, Neumann)</H3>
+Data: Entity sets; Tag(s): DIRICHLET_SET/I, NEUMANN_SET/I)
+Boundary conditions are often specified in terms of geometric model entiti=
es, similar to material types.  MOAB uses entity sets to store this informa=
tion as well.  The DIRICHLET_SET and NEUMANN_SET tags are used to represent=
 Dirichlet- and Neumann-type boundary condition sets, resp.  By convention,=
 Neumann sets usually contain (indirectly) intermediate-dimension entities =
like edges in a 2D mesh or faces in a 3D mesh, while Dirichlet sets usually=
 contain vertices.  In addition, Neumann sets are represented as sets of fa=
ces, rather than as sides of elements.  Faces can be ordered =E2=80=9Cforwa=
rd=E2=80=9D or =E2=80=9Creverse=E2=80=9D with respect to one of the boundin=
g elements, depending on whether the right-hand normal points into or out o=
f the element.  Forward-sense faces are added to the Neumann set.  Reverse-=
sense faces are put into a separate set; that set is tagged with the NEUSET=
_SENSE tag, with value =3D -1; and that reverse set is added to the Neumman=
n set.
+<H3> Parallel Mesh Constructs </H3>
+(Data: Entity sets, entities; Tag(s): PARALLEL_PART/I, PARALLEL_PARTITION/=
I, PSTATUS/C*1, PARALLEL_SHARED_PROC/I, PARALLEL/SHARED_HANDLE/H, PARALLEL_=
SHARED_PROCS/I*NP, PARALLEL_SHARED_HANDLES/H*NP)
+On a parallel computer, MOAB can represent the mesh on each processor as w=
ell as information about entities shared with neighboring processors.  Some=
 of this information is also relevant even when the mesh is represented on =
a serial machine.  MOAB uses several tag and set conventions to describe th=
e parallel nature of a mesh.  This information is summarized here; for a mo=
re complete description of MOAB=E2=80=99s parallel mesh representation and =
functionality, see [ref-moabpar].
+- <B> Parallel partition, parts </B>
+Most parallel mesh applications use a domain decomposition approach, where=
 each processor solves for a subset of the domain.  The set of entities sol=
ved by a given processor is referred to as a part, and the collection of pa=
rts together is called the partition.  MOAB stores each part in an entity s=
et, marked with the PARALLEL_PART tag, whose value is the rank of the proce=
ssor assigned that part; an entity set which contains all part sets is give=
n the PARALLEL_PARTITION tag, whose value is currently meaningless.  The MB=
Zoltan tool included as a tool in MOAB can partition a mesh for parallel so=
lution, and writes the partition to the mesh in the form of parts and parti=
tions.  Both these types of sets can be accessed in a serial mesh, e.g. for=
 visualization.
+- <B> Part interfaces </B>
+When a partitioned mesh has been loaded on a parallel computer, the part o=
n a given processor may share portions of its boundary with parts on other =
processors.  These shared regions are called part interfaces, and are also =
represented using entity sets.  These sets are marked with the PARALLEL_INT=
ERFACE tag, whose value is currently meaningless.
+- <B> Shared processor and handle </B>
+For entities shared between processors, it is helpful to know locally whic=
h other processor shares an entity, and what the entity=E2=80=99s handle is=
 on the remote processor.  There are two cases which are useful to distingu=
ish, first where an entity is shared with only one other processor (referre=
d to as shared), and second when a processor is shared by more than one oth=
er processor (referred to as multi-shared).   Shared entities are given the=
 PARALLEL_SHARED_PROC and PARALLEL_SHARED_HANDLE tags, which store the rank=
 of the sharing processor and the handle of the entity on that processor, r=
espectively.  Multi-shared entities are marked with the PARALLEL_SHARED_PRO=
CS and PARALLEL_SHARED_HANDLES tags; these tags have a length NP assigned a=
t compile time in MOAB, with default values of -1 for processor rank and ze=
ro for handle (which are each invalid values for the corresponding data).  =
The processors/handles sharing a given entity are then written on the front=
 of the arrays.  So, for example, an entity on processor rank 0, shared by =
processors 1 and 2, would have a PARALLEL_SHARED_PROCS tag whose values wou=
ld be [1, 2, -1, -1, =E2=80=A6], with PARALLEL_SHARED_HANDLES values of [m,=
 n, 0, 0, =E2=80=A6], where m and n would be the handles of that entity on =
processors 1 and 2.  The shared versions of these tags are =E2=80=9Cdense=
=E2=80=9D, with default values which denote unshared entities.  The multi-s=
hared tags are sparse tags in MOAB, with no default value.
+- <B> Parallel status </B>
+In addition to the tags above, MOAB also defines the PSTATUS tag, whose bi=
ts contain information about the parallel status of a given entity.  Starti=
ng with least significant bit, these bits represent whether an entity is 1)=
 not owned, 2) shared, 3) multi-shared, 4) interface, 5) a ghost entity.  T=
he first bit being set indicates =E2=80=9Cnot owned=E2=80=9D so that the de=
fault value for this tag, of zero, corresponds to an owned, unshared entity=
, which will be the state of most entities on a given processor.
+<H3>Structured Mesh Parameters </H3>
+MOAB has a structured mesh interface for creating structured mesh (see =E2=
=80=9CScdInterface.hpp=E2=80=9D header file in MOAB source code).  Along wi=
th an internal representation that is more memory-efficient (since it does =
not need to store connectivity), MOAB also creates and tags entity sets wit=
h structured mesh parameters, which can be accessed through the normal tag =
and set interface.  The following tags are used:
+- <B>BOX_DIMS</B>: This tag stores the ijk coordinates of the lower and up=
per corner of the structured mesh box(es).
+- <B>GLOBAL_BOX_DIMS</B>: If specified when the structured mesh is created=
, a tag with this name stores the global box dimensions (which may be diffe=
rent than the local box dimensions).
+- <B>BOX_PERIODIC</B>: Stores whether the box is periodic in the i (BOX_PE=
RIODIC[0]) and j (BOX_PERIODIC[1]) directions.
+- <B>__BOX_SET</B>: Pointer to the ScdBox instance corresponding to this e=
ntity set.<sup>2</sup>
+Although the structured mesh is not saved as such in HDF5-format files, th=
e entity sets and corresponding tags will be saved and restored.
+<sup>2</sup>The double-underscore in the tag name implies that this tag wi=
ll not be saved in a file, in this case because the ScdBox instances are no=
t preserved in a file.
+<H3>Spectral Mesh Constructs </H3>
+The Spectral Element Method (SEM) is a high-order method, using a polynomi=
al Legendre interpolation basis with Gauss-Lobatto quadrature points, in co=
ntrast to the Lagrange basis used in (linear) finite elements.  A spectral =
mesh with order O contains quadrilateral or hexahedral elements comprised o=
f (O+1)d vertices.  Spectral meshes are usually represented in one of two w=
ays, either as coarse elements which point to an array of higher-order vert=
ices (and with corner vertices represented in the normal manner), or as lin=
ear quads/hexes formed from the higher-order vertices, with each original c=
oarse quad/hex represented by Od fine quads/hexes.  Similarly, the spectral=
 variables, which are normally computed at fine vertex positions, are store=
d either on those vertices, or in lexicographically-ordered arrays on eleme=
nts (with tag values repeated on neighboring elements).  MOAB can read spec=
tral meshes from a variety of formats (at this time, including CAM-SE, HOMM=
E, and Nek5000).  Which of the above two representations are controlled by =
read options and are indicated by certain tags:
+- SPECTRAL_MESH: read option indicating that spectral elements should be r=
epresented as coarse linear quads/hexes and each element containing an arra=
y of lexicographically-ordered vertex handles
+- TAG_SPECTRAL_ELEMENTS: read option; if given, spectral variables are rep=
resented as lexicographically-ordered arrays on elements
+- TAG_SPECTRAL_VERTICES: read option; if given, spectral variables are rep=
resented as tags on vertices
+- CONN=3D<filename>: in CAM-SE, the connectivity of the spectral mesh is s=
tored by default in a file named =E2=80=9CHommeMapping.nc=E2=80=9D; this op=
tion can be given to read the connectivity from a different file
+- SPECTRAL_VERTICES: tag name for array of vertex handles
+- SPECTRAL_ORDER: tag name for spectral order, written to file set or (if =
no file set given) to interface after a spectral mesh is read
+  \section meta-options Reader/Writer Options
+All mesh file readers and writers in MOAB take an option string as an argu=
ment.  By default, the semicolon (=E2=80=9C;=E2=80=9D) delimits individual =
options in the option string.  Options used in multiple readers are describ=
ed in this section; the options enabled in specific readers/writers are des=
cribed in the corresponding appendix at the end of this document.
+<H3>variable=3D<var_name>[,...]</H3>
+By default, all field data stored with the mesh is read with the mesh, and=
 stored as tags on the associated mesh entities.  This option lists specifi=
c variables that should be read along with the mesh (note also the =E2=80=
=9Cnomesh=E2=80=9D option, described elsewhere in this document).  The vari=
able name listed will be read into a tag with the same name.  For time-depe=
ndent variables, the time step number will be appended to the variable name=
 to form the tag name.  If no =E2=80=9Ctimestep=E2=80=9D or =E2=80=9Ctimeva=
l=E2=80=9D option is given, all time steps will be read, resulting in sever=
al tags being created.  If the =E2=80=9Cnomesh=E2=80=9D option is given, th=
e application must pass the entity set resulting from the original mesh rea=
d in to the function, that this set must contain the mesh read only from th=
at file.  The mesh in the file is checked against the mesh in the set to ve=
rify that the two correspond.  The special name =E2=80=9CMOAB_ALL_VARIABLES=
=E2=80=9D can be used to indicate that all variables should be read.  Multi=
ple variable names can be specified, separated from each other by commas.
+<H3>nomesh </H3>
+Indicates that no mesh should be read from the file.  This option is used =
in conjunction with the =E2=80=9Cvariable=3D=E2=80=9D option, to read varia=
bles and assign them as tags to a previously-read mesh.  If this option is =
used, applications should pass an entity set to the read function, which sh=
ould contain the mesh previously read from the file.
+<H3>timestep=3D<step_number>[, ...] </H3>
+Read the time step number whose time value is equal to or greater than the=
 specified time value, for the specified variable(s).  Tag names for the va=
riable(s) will be formed by appending the time step number to the variable =
name.  Multiple time step values can be specified, separated from each othe=
r by commas.
+  \section meta-references References
+[1]	T.J. Tautges, R. Meyers, K. Merkley, C. Stimpson, and C. Ernst, MOAB: =
A Mesh-Oriented Database, Sandia National Laboratories, 2004.
+[2]	L. Diachin, A. Bauer, B. Fix, J. Kraftcheck, K. Jansen, X. Luo, M. Mil=
ler, C. Ollivier-Gooch, M.S. Shephard, T. Tautges, and H. Trease, =E2=80=9C=
Interoperable mesh and geometry tools for advanced petascale simulations,=
=E2=80=9D Journal of Physics: Conference Series,  vol. 78, 2007, p. 012015.
+\ref meta-data-info "Top"
+  \section appendixA Appendix A: Summary
+  \subsection table1 Table 1: Summary of MOAB meta-data conventions.
+<table border=3D"1">
+<tr>
+<th>Convention</th>
+<th>Applies to (E=3Dent, S=3Dset)</th>
+<th>Tag(s) (type/length)</th>
+<th>Description</th>
+</tr>
+<tr>
+<td>Name</td>
+<td>E, S</td>
+<td>NAME/C*32</td>
+<td></td>
+</tr>
+<tr>
+<td>Title</td>
+<td>S</td>
+<td>TITLE/C*strlen</td>
+<td>Title of mesh</td>
+</tr>
+<tr>
+<td>Global identifier</td>
+<td>E, S</td>
+<td>GLOBAL_ID/I</td>
+<td></td>
+</tr>
+<tr>
+<td>Geometric topology</td>
+<td>S</td>
+<td>GEOM_DIMENSION/I, GLOBAL_ID/I,
+NAME/C*32,
+CATEGORY/C*32.
+GEOM_SENSE_2/EH[2],
+GEOM_SENSE_N_ENTS/EH*N,
+GEOM_SENSE_N_SENSES/I*N</td>
+<td>Sets contain mesh owned by that entity; parent/child links to bounded/=
bounding entities in geometric model</td>
+</tr>
+<tr>
+<td>Material type</td>
+<td>S</td>
+<td>MATERIAL_SET/I</td>
+<td>Set contains entities or sets assigned a common material type</td>
+</tr>
+<tr>
+<td>Boundary condition</td>
+<td>S</td>
+<td>DIRICHLET_SET/I, NEUMANN_SET/I</td>
+<td>Set contains entities or sets assigned a particular boundary condition=
; neumann sets usually contain edges (2D) or faces (3D)</td>
+</tr>
+<tr>
+<td>Parallel mesh constructs</td>
+<td>E, S</td>
+<td>PARALLEL_PART/I, PARALLEL_PARTITION/I, PSTATUS/C*1, PARALLEL_SHARED_PR=
OC/I, PARALLEL/SHARED_HANDLE/H, PARALLEL_SHARED_PROCS/I*NP, PARALLEL_SHARED=
_HANDLES/H*NP</td>
+<td> Data which describes parallel mesh</td>
+</tr>
+<tr>
+<td>Structured mesh constructs</td>
+<td>S</td>
+<td>BOX_DIMS/I*6, GLOBAL_BOX_DIMS/I*6, BOX_PERIODIC/2*I, __BOX_SET/O</td>
+<td>Data describing structured mesh </td>
+</tr>
+<tr>
+<td>Spectral mesh constructs </td>
+<td>E, S</td>
+<td>SPECTRAL_ORDER/I, SPECTRAL_VERTICES/I*(O+1)^2</td>
+<td>Data marking spectral mesh constructs</td>
+</tr>
+</table>
+=20
+  \ref meta-introduction "Back to Introduction"
+  \subsection table2 Table 2: Summary of MOAB conventional tag names, type=
s, and purposes.  Data types are I=3Dinteger, D=3Ddouble, C=3Dcharacter, H=
=3Dentity handle,O=3Dopaque.  Data type with *x denote length of x elements=
 of that data type.
+<Table border=3D"1">
+<tr>
+<th>Tag name</th>
+<th>Data type</th>
+<th>Applies to (E=3Dentity, S=3Dset)</th>
+<th>Purpose</th>
+</tr>
+<tr>
+<td>BOX_DIMS</td>
+<td>I*6</td>
+<td>S</td>
+<td>Lower and upper ijk dimensions of box, ordered (ilo, jlo, klo, ihi, jh=
i, khi)</td>
+</tr>
+<tr>
+<td>BOX_PERIODIC</td>
+<td>I*2</td>
+<td>S</td>
+<td>Indicates whether box is periodic in i (BOX_PERIODIC[0]) or j (BOX_PER=
IODIC[1])</td>
+</tr>
+<tr>
+<td>__BOX_SET</td>
+<td>O</td>
+<td>S</td>
+<td>Pointer to corresponding ScdBox instance</td>
+</tr>
+<tr>
+<td>CATEGORY</td>
+<td>C*32</td>
+<td>S</td>
+<td>String describing purpose of set; examples include =E2=80=9Cgroup=E2=
=80=9D, =E2=80=9Cvertex=E2=80=9D, =E2=80=9Cedge=E2=80=9D, =E2=80=9Csurface=
=E2=80=9D, =E2=80=9Cvolume=E2=80=9D</td>
+</tr>
+<tr>
+<td>DIRICHLET_SET </td>
+<td>I</td>
+<td>SO</td>
+<td>Entities or sets with common boundary condition</td>
+</tr>
+<tr>
+<td>GEOM_DIMENSION</td>
+<td>I</td>
+<td>S</td>
+<td>Identifies mesh entities resolving a given geometric model entity</td>
+</tr>
+<tr>
+<td>GEOM_SENSE_2</td>
+<td>EH*2</td>
+<td>S</td>
+<td> Stored on face-type geometric topology sets, values store regions hav=
ing forward and reverse sense</td>
+</tr>
+<tr>
+<td>GEOM_SENSE_N_ENTS</td>
+<td>EH*N</td>
+<td>S</td>
+<td>Stored on edge-type geometric topology sets, values store faces whose =
senses are stored in GEOM_SENSE_N_SENSES.</td>
+</tr>
+<tr>
+<td>GEOM_SENSE_N_SENSES</td>
+<td>I*N</td>
+<td>S</td>
+<td>Stored on edge-type geometric topology sets, values store senses of th=
e edge with respect to faces stored in GEOM_SENSE_N_ENTS.</td>
+</tr>
+<tr>
+<td>GLOBAL_ID</td>
+<td>I</td>
+<td>E,S</td>
+<td>Application-specific entity id</td>
+</tr>
+<tr>
+<td>MATERIAL_SET</td>
+<td>I</td>
+<td>S</td>
+<td>Entities or sets grouped by material type</td>
+</tr>
+<tr>
+<td>NAME</td>
+<td>C*32</td>
+<td>E, S</td>
+<td>User-assigned entity name(s); multiple names delimited with ?</td>
+</tr>
+<tr>
+<td>NEUMANN_SET</td>
+<td>I</td>
+<td>S</td>
+<td>Entities or sets with common boundary condition </td>
+</tr>
+<tr>
+<td>PARALLEL_PART </td>
+<td>I</td>
+<td>S</td>
+<td>Represent a part in a partition</td>
+</tr>
+<tr>
+<td>PARALLEL_PARTITION</td>
+<td>I</td>
+<td>S</td>
+<td>Represents a partition of the mesh for parallel solution, which is a c=
ollection of parts</td>
+</tr>
+<tr>
+<td>__PARALLEL_SHARED_HANDLEd</td>
+<td>H</td>
+<td>E, S</td>
+<td> Handle of this entity/set on sharing processor</td>
+</tr>
+<tr>
+<td>__PARALLEL_SHARED_PROC</td>
+<td>I</td>
+<td>E,S</td>
+<td>Rank of other processor sharing this entity/set </td>
+</tr>
+</table>
+  \section appendixB Appendix B: CCMIO (Star-CD, Star-CCM+) Reader/Writer =
Conventions
+  \subsection table3 Table 3: Translation between CCMIO options and MOAB t=
ags.
+<tr>
+<th> Set Type</th>
+<th>CCMIO Construct</th>
+<th>MOAB Tag Name, Type</th>
+</tr>
+<tr>
+<td rowspan=3D"2">File set / Interface</td>
+<td>Title (option)</td>
+<td>=E2=80=9CTitle=E2=80=9D (C*32)</td>
+</tr>
+<tr>
+<td>CreatingProgram</td>
+<td>=E2=80=9CCreatingProgram=E2=80=9D (C*32)</td>
+</tr>
+<tr>
+<td rowspan=3D"13">Material sets</td>
+<td>Index</td>
+</tr>
+<tr>
+<td>Label<sup>1</sup></td>
+<td>NAME</td>
+</tr>
+<tr>
+<td>MaterialId</td>
+<td>=E2=80=9CMaterialId=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>Radiation</td>
+<td>=E2=80=9CRadiation=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>PorosityId</td>
+<td>=E2=80=9CPorosityId=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>SpinId</td>
+<td>=E2=80=9CSpinId=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>GroupId</td>
+<td>=E2=80=9CGroupId=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>ColorIdx</td>
+<td>=E2=80=9CColorIdx=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>ProcessorId</td>
+<td>=E2=80=9CProcessorId=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>LightMaterial</td>
+<td>=E2=80=9CLightMaterial=E2=80=9D (I)</td>
+</tr>
+<tr>
+<td>FreeSurfaceMaterial</td>
+<td>=E2=80=9CThickness=E2=80=9D (F)</td>
+</tr>
+<tr>
+<td>Thickness</td>
+</tr>
+<tr>
+<td>MaterialType</td>
+<td>=E2=80=9CMaterialType=E2=80=9D (C*32)</td>
+</tr>
+<tr>
+<td rowspan=3D"5">Neumann sets</td>
+<td>Index</td>
+</tr>
+<tr>
+<td>Label</td>
+</tr>
+<tr>
+<td>BoundaryName</td>
+<td>NAME</td>
+</tr>
+<tr>
+<td>BoundaryType</td>
+<td>=E2=80=9CBoundaryType=E2=80=9D (C*32)</td>
+</tr>
+<tr>
+<td>ProstarRegionNumber</td>
+<td>=E2=80=9CProstarRegionNumber=E2=80=9D (I)</td>
+</tr>
+</table>
+Notes:
+1. If no name is present, labels the material group with =E2=80=9CMaterial=
X=E2=80=9D, where X is the index of that group.
+  \section appendixC Appendix C: ExodusII Reader/Writer Conventions=20
+  \subsection table4 Table 4: Translation between ExodusII constructs and =
MOAB tags.
+<tr>
+<th> Data Type</th>
+<th>ExodusII Construct</th>
+</tr>
+<tr>
+<td></td>
+<td>QA records</td>
+<td>=E2=80=9CqaRecord=E2=80=9D (C*(v))<sup>2</sup></td>
+</tr>
+<tr>
+<td rowspan=3D"2">Material sets</td>
+<td>Block number</td>
+</tr>
+<tr>
+<td>Block element type</td>
+<td>Entity type, # vertices per entity</td>
+</tr>
+<tr>
+<td rowspan=3D"2">Dirichlet sets<sup>3</sup></td>
+<td>Nodeset number</td>
+<td>DIRICHLET_SET</td>
+</tr>
+<tr>
+<td>Distribution factors</td>
+<td>=E2=80=9CdistFactor=E2=80=9D (D*(v))<sup>1</sup></td>
+</tr>
+<tr>
+<td>Neumann sets</td>
+<td>Sideset number</td>
+</tr>
+<tr>
+<td rowspan=3D"2">Neumann sets, reverse faces3<sup>3</sup></td>
+</tr>
+<tr>
+<td>Sides</td>
+<td>SENSE</td>
+</tr>
+<tr>
+<td>Nodes, elements</td>
+<td>node_num_map, elem_map</td>
+<td>GLOBAL_ID on nodes/elements</td>
+</tr>
+</table>
+Notes:
+-# Variable-length tag used for distribution factors; length for each set =
is the number of entities in
+each set, such that there is one distribution factor for each entity in th=
e set.
+-# QA records are stored as variable-length tags on file set specified on =
read. Tag is a
+concatenation of QA record strings into a single string, with '\0' used to=
 delimit lines.
+-# MOAB represents sidesets as sets of faces, rather than as sides of elem=
ents. Faces can be
+ordered =E2=80=9Cforward=E2=80=9D or =E2=80=9Creverse=E2=80=9D with respec=
t to one of the bounding elements, depending on
+whether the right-hand normal points into or out of the element. Forward-s=
+to the Neumann set. Reverse-sense faces are put into a separate set; that =
set is tagged with the SENSE tag, with value =3D -1; and that reverse set i=
s added to the Neummann set.
+  \section appendixD Appendix D: NC (Climate Data) Reader/Writer Conventio=
ns
+The climate data reader in MOAB reads files with the '.nc' filename extens=
ion. By default, this reader
+reads the whole mesh in the file and creates it as structured mesh in MOAB=
, with the mesh accessible
+through MOAB's structured mesh interface. By default, all variables and ti=
mesteps are read from the
+file, and written as tags on the mesh vertices from that file. This behavi=
or is controlled by the
+=E2=80=9Cvariable=E2=80=9D, =E2=80=9Cnomesh=E2=80=9D, =E2=80=9Ctimestep=E2=
=80=9D, and =E2=80=9Ctimeval=E2=80=9D options described earlier in this doc=
ument. If MOAB
+is compiled for parallel execution and configured with a pnetcdf reader, t=
he mesh is read in parallel,
+with a 1D or 2D decomposition designed to balance read performance and com=
munication interface
+size (for details on the partitioning method used, see the src/io/ReadNC.c=
pp source file).
+Mesh is put into the entity set provided to the load_file function. This e=
ntity set is also annotated with
+various tags representing information read from the file. These tags are d=
escribed in Table 5.
+Several other things to note about reading climate data files into MOAB:
+- Time-dependent variables: MOAB currently has no mechanism for time-depen=
dent tags. Therefore, time-dependent variables are represented using one ta=
g per timestep, with the tag name set as the variable name plus the timeste=
p index. Thus, the first few timesteps for the variable TEMPERATURE would b=
e represented in tags named TEMPERATURE0, TEMPERATURE1, etc.
+- Cell- and face-centered variables: The climate data reader currently doe=
s not do cell- and face-
+centered variables correctly.
+  \subsection table5 Table 5: Summary of MOAB conventional tag names, type=
=3Dentity handle. Data type with *x denote length of x elements of that dat=
a type; data type with *var denote variable-length tag. Tag names with two =
underscores prepended (=E2=80=9C__=E2=80=9D) denote tags not written to a f=
ile by MOAB.
+<tr>
+<th> Tag name </th>
+<th>Data type </th>
+<th> Applies to (E=3Dentity, S=3Dset) </th>
+<th>Purpose </th>
+</tr>
+<tr>
+<td>__NUM_DIMS </td>
+<td>I</td>
+<td>S</td>
+<td>The number of dimensions in the netcdf file.</td>
+</tr>
+<tr>
+<td>__NUM_VARS</td>=20
+<td>I</td>
+<td>S</td>
+<td>The number of variables in the netcdf file.</td>
+</tr>
+<tr>
+<td>__DIM_NAMES </td>
+<td>C*var </td>
+<td>S </td>
+<td>The dimension names, concatenated into a
+character string, with '\0' terminating each name.
+ </td>
+</tr>
+<tr>
+<td>__DIM_NAMES=20
+</td>
+<td>C*var</td>
+<td>S</td>
+<td>The variable names, concatenated into a character
+string, with '\0' terminating each name.
+</td>
+</tr>
+<tr>
+<td><dim_name>=20
+</td>
+<td>(I or=20
+D)*va=20
+</td>
+<td>S</td>
+<td>For each dimension, the values for the dimension.
+The data type for this tag corresponds to that in the
+netcdf file. The length of this tag is the number of
+values stored for the dimension in the netcdf file.</td>
+</tr>
+<tr>
+<td>__<dim_name>_LOC_MIN MAX</td>=20
+<td>2*(I or D)</td>
+<td>S</td>
+<td>The indices (0-based) of the local min and max
+values of dimension stored locally. For spatial
+dimensions like lon or lat, this will store the
+minimum and maximum indices in the loca</td>
+</tr>
+<tr>
+<td >__<dim_name>_LOC_VAL </td>=20
+<td>(I or D)*var </td>
+<td>S</td>
+<td>The indices (0-based) of the dimension stored
+locally. This tag only makes sense for dimensions
+that can be read in multiple pieces, such as time.
+Only one of __<dim_name>_LOC_VALS and
+_LOC_MIN_MAX can be used for a given
+dimension.
+</tr>
+<tr>
+<td>__<var_name>_DIMS=20
+</td>
+<td>C*n=20
+</td>
+<td>S</td>
+<td>For each variable, the tag handles for the
+dimensions defining this variable, in netcdf
+ordering (last dimension varying fastest). The
+length of this tag, n, is # dimensions for the
+variable * sizeof(TagHandle).
+</td>
+</tr>
+<tr>
+<td><var_name><timestep_ind>=20
+</td>
+<td>(data type)</td>
+<td>E</td>
+<td>Values of the variable for timestep <timestep_ind>
+for vertices. The data type of this tag corresponds
+to that of the variable from the netcdf file.
+Timestep index is 0-based.
+</td>
+</tr>
+<tr>
+<td>__GLOBAL_ATTRIBS=20
+</td>
+<td>C*Var=20
+</td>
+<td>S</td>
+<td>The global attributes, concatenated into a character
+string, with =E2=80=98\0=E2=80=99 terminating each attribute name, =E2=80=
=98;=E2=80=99
+       separating the data type and value, and =E2=80=98;=E2=80=99
+          separating one name/data type/value from the next.
+</td>
+</tr>
+<tr>
+<td>__GLOBAL_ATTRIBS_LEN=20
+</td>
+<td>I*Var=20
+</td>
+<td>S</td>
+<td>A vector of integers, marking the end position of
+each attribute (name/data type/value) in __GLOBAL_ATTRIBS tag.
+</td>
+</tr>
+<tr>
+<td>__<var_name>_ATTRIBS=20
+</td>
+<td>C*Var
+</td>
+<td>S</td>
+<td>The variable attributes, concatenated into a
+character string, with =E2=80=98\0=E2=80=99 terminating each attribute
+   name, =E2=80=98;=E2=80=99 separating the data type and value, and =E2=
=80=98;=E2=80=99
+</td>
+</tr>
+<tr>
+<td>__<var_name>_ATTRIBS_LEN=20
+</td>
+<td>I*Var
+</td>
+<td>S</td>
+__<var_name>_ATTRIBS tags
+</td>
+</tr>
+</table>
+  \section appendixE Appendix E: Nek5000 Reader/Writer Conventions
+Nek5000, or Nek, is a code that uses the spectral element method to model =
fluid, heat transfer,
+electromagnetics, and other physics. Nek uses unstructured hexahedral mesh=
es, with each hex element
+resolved by a structured grid of =E2=80=9CGauss Lebato Legendre=E2=80=9D (=
GLL) points. Nek can read meshes through
+MOAB, and can output physics variables and GLL points through MOAB as well.
+Since fluid is a single material in Nek, no material sets are needed. Boun=
dary conditions are mapped to
+Nek's cbc array using Neumann sets and a user-provided =E2=80=9Cusr_moab2n=
ek=E2=80=9D subroutine (for an example
+of this subroutine, see examples/moab/pipe.usr in the Nek source code). GL=
L point locations and fluid
+variables on those points are stored in tags on the hex elements. All hex =
elements have the same
+number of GLL points. The number of GLL points in each direction is stored=
 in a tag on the mesh
+instance. These tags are described in Table 6.
+GLL point locations and fluid variables are stored in lexicographic order,=
 similar to their storage order
+inside the Nek code.
+  \subsection table6 Table 6: Summary of MOAB conventional tag names, type=
s, and purposes for Nek. Data types are I=3Dinteger, D=3Ddouble, C=3Dcharac=
ter, H=3Dentity handle. Data type with *x denote length of x elements of th=
at data type; data type with *var denote variable-length tag. Tag names wit=
h two underscores prepended (=E2=80=9C__=E2=80=9D) denote tags not written =
to a file by MOAB.
+<tr>
+<th>Purpose</th>
+</tr>
+<tr>
+<td>SEM_DIMS</td>
+<td>I*3</td>
+<td>S</td>
+<td>The dimensions of the GLL mesh in each hex
+element.
+</td>
+</tr>
+<tr>
+<td>SEM_X</td>
+<td>D*nx*ny*nz</td>
+<td>E</td>
+<td>X position of GLL points (having nx*ny*nz
+values)
+</td>
+</tr>
+<tr>
+<td>SEM_Y</td>
+<td>E</td>
+<td>Y position of GLL points (having nx*ny*nz values)</td>
+</tr>
+<tr>
+<td>SEM_Z</td>
+<td>E</td>
+<td>Z position of GLL points (having nx*ny*nz values)</td>
+</tr>
+<tr>
+<td>VEL_X</td>
+<td>E</td>
+<td>Fluid velocities in the x direction for GLL point
+array (having nx*ny*nz values)</td>
+</tr>
+<tr>
+<td>VEL_Y</td>
+<td>E</td>
+<td>Fluid velocities in the y direction for GLL point
+</tr>
+<tr>
+<td>VEL_Z</td>
+<td>E</td>
+<td>Fluid velocities in the z direction for GLL point
+</tr>
+<tr>
+<td>TEMP</td>
+<td>E</td>
+<td>Fluid temperature for GLL point array (having
+nx*ny*nz values)
+</td>
+</tr>
+<tr>
+<td>PRESS</td>
+<td>E</td>
+<td>Fluid pressure for GLL point array (having
+nx*ny*nz values)
+</td>
+</tr>
+</table>
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 38b4130..a1993c9 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -31,8 +31,8 @@
     PolyElementSeq.cpp
     Range.cpp
     RangeSeqIntersectIter.cpp
-    ReadUtil.cpp
     ReaderWriterSet.cpp
+    ReadUtil.cpp
     ScdElementData.cpp
     ScdInterface.cpp
     ScdVertexData.cpp
@@ -56,11 +56,40 @@
     VertexSequence.cpp
     WriteUtil.cpp
+  add_subdirectory( io )
+  set ( MOABIO_LIB_SRCS
+    io/IODebugTrack.cpp
+    io/ExoIIUtil.cpp
+    io/FileTokenizer.cpp
+    io/GmshUtil.cpp
+    io/ReadABAQUS.cpp
+    io/ReadGmsh.cpp
+    io/ReadIDEAS.cpp
+    io/ReadMCNP5.cpp
+    io/ReadNASTRAN.cpp
+    io/ReadSmf.cpp
+    io/ReadSms.cpp
+    io/ReadSTL.cpp
+    io/ReadTemplate.cpp
+    io/ReadTetGen.cpp
+    io/ReadTxt.cpp
+    io/ReadVtk.cpp
+    io/SMF_State.cpp
+    io/Tqdcfr.cpp
+    io/VtkUtil.cpp
+    io/WriteAns.cpp
+    io/WriteGMV.cpp
+    io/WriteGmsh.cpp
+    io/WriteSTL.cpp
+    io/WriteSmf.cpp
+    io/WriteTemplate.cpp
+    io/WriteVtk.cpp
   include_directories(
     ${MOAB_SOURCE_DIR}/src
-    ${MOAB_BINARY_DIR}/src
     ${MOAB_SOURCE_DIR}/src/io
-    ${MOAB_BINARY_DIR}/src/io
+    ${MOAB_SOURCE_DIR}/src/parallel
=20
   if ( MOAB_USE_MPI )
@@ -82,12 +111,73 @@
   set_source_files_properties( ${MOAB_LIB_SRCS}
     COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
+#  target_link_libraries( MOAB moabio )
+  if ( MOAB_USE_NETCDF )
+    find_package( NetCDF )
+    if ( NetCDF_FOUND )
+      set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
+        ${MOABIO_LIB_SRCS}
+        io/ReadNCDF.cpp
+        io/WriteNCDF.cpp
+        io/WriteSLAC.cpp
+      include_directories(
+        ${NetCDF_INCLUDE_DIRECTORIES}
+    endif ( NetCDF_FOUND )
+  endif ( MOAB_USE_NETCDF )
+  if ( MOAB_USE_HDF )
+    # HDF5
+    find_package( HDF5 )
+    if ( HDF5_FOUND )
+      set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
+      check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
+        io/HDF5Common.cpp
+        io/ReadHDF5.cpp
+        io/ReadHDF5Dataset.cpp
+        io/ReadHDF5VarLen.cpp
+        io/WriteHDF5.cpp
+#      if ( MOAB_USE_MPI AND MPI_FOUND )
+#        set ( MOABIO_LIB_SRCS
+#          ${MOABIO_LIB_SRCS}
+#          src/parallel/WriteHDF5Parallel.cpp
+#      endif (MOAB_USE_MPI AND MPI_FOUND)
+        ${HDF5_INCLUDE_DIRECTORIES}
+        io/mhdf/include
+      add_subdirectory( io/mhdf )
+    endif ( HDF5_FOUND )
+  endif ( MOAB_USE_HDF )
+  set_source_files_properties( ${MOABIO_LIB_SRCS}
+    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
   add_library( MOAB
     ${MOAB_LIB_SRCS}
- =20
-  add_subdirectory( io )
-  target_link_libraries( MOAB moabio )
+  if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
+    MESSAGE( "Adding NetCDF dependency libraries: ${NetCDF_LIBRARIES}" )
+    target_link_libraries( MOAB ${NetCDF_LIBRARIES} )
+  endif ( MOAB_USE_NETCDF AND NetCDF_FOUND )
+  if ( MOAB_USE_HDF AND HDF5_FOUND )
+    MESSAGE( "Adding NetCDF dependency libraries: ${HDF5_LIBRARIES}" )
+#    add_dependencies( MOAB mhdf  )
+    target_link_libraries( MOAB mhdf ${HDF5_LIBRARIES} )
+  endif ( MOAB_USE_HDF AND HDF5_FOUND )
=20
     add_subdirectory( parallel )
diff --git a/src/io/CMakeLists.txt b/src/io/CMakeLists.txt
deleted file mode 100644
index d6c3e44..0000000
--- a/src/io/CMakeLists.txt
+++ /dev/null
@@ -1,90 +0,0 @@
-  # MOAB Library
-  set ( MOABIO_LIB_SRCS
-    ExoIIUtil.cpp
-    FileTokenizer.cpp
-    GmshUtil.cpp
-    ReadABAQUS.cpp
-    ReadGmsh.cpp
-    ReadIDEAS.cpp
-    ReadMCNP5.cpp
-    ReadNASTRAN.cpp
-    ReadSmf.cpp
-    ReadSms.cpp
-    ReadSTL.cpp
-    ReadTemplate.cpp
-    ReadTetGen.cpp
-    ReadTxt.cpp
-    ReadVtk.cpp
-    SMF_State.cpp
-    Tqdcfr.cpp
-    VtkUtil.cpp
-    WriteAns.cpp
-    WriteGMV.cpp
-    WriteGmsh.cpp
-    WriteSTL.cpp
-    WriteSmf.cpp=20
-    WriteTemplate.cpp
-    WriteVtk.cpp
-  include_directories(
-    ${MOAB_SOURCE_DIR}/src
-    ${MOAB_SOURCE_DIR}/src/parallel
-    ${MOAB_BINARY_DIR}/src/parallel
-  if ( MOAB_USE_NETCDF )
-    find_package( NetCDF )
-    if ( NetCDF_FOUND )
-      set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
-        ${MOABIO_LIB_SRCS}
-        ReadNCDF.cpp
-        WriteNCDF.cpp
-        WriteSLAC.cpp
-        ${NetCDF_INCLUDE_DIRECTORIES}
-    endif ( NetCDF_FOUND )
-  endif ( MOAB_USE_NETCDF )
-  if ( MOAB_USE_HDF )
-    # HDF5
-    find_package( HDF5 )
-    if ( HDF5_FOUND )
-      set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
-      check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
-        ReadHDF5.cpp
-        WriteHDF5.cpp
-        ${HDF5_INCLUDE_DIRECTORIES}
-        ${MOAB_SOURCE_DIR}/mhdf/include
-      add_subdirectory( mhdf )
-    endif ( HDF5_FOUND )
-  endif ( MOAB_USE_HDF )
-  set_source_files_properties( ${MOABIO_LIB_SRCS}
-    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
-  add_library( moabio
-  if ( MOAB_USE_HDF AND HDF5_FOUND )
-    target_link_libraries( moabio
-      mhdf
-      ${HDF5_LIBRARIES}
-  endif ( MOAB_USE_HDF AND HDF5_FOUND )
-  if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
-      ${NetCDF_LIBRARIES}
-  endif ( MOAB_USE_NETCDF AND NetCDF_FOUND )
diff --git a/src/parallel/CMakeLists.txt b/src/parallel/CMakeLists.txt
index 598b6fc..7583885 100644
--- a/src/parallel/CMakeLists.txt
+++ b/src/parallel/CMakeLists.txt
@@ -5,8 +5,14 @@ set( moab_PARALLEL_SRCS
   ReadParallel.cpp
   gs.cpp
   TupleList.cpp
+  SharedSetData.cpp
=20
+include_directories(
 if ( MOAB_USE_HDF AND MOAB_HDF_HAVE_PARALLEL )
     ${moab_PARALLEL_SRCS}
@@ -45,38 +51,3 @@ target_link_libraries( MOABpar
   ${MPI_EXTRA_LIBRARY}
=20
-if ( MOAB_USE_MPI AND MPI_FOUND )
-  add_executable ( mbparallelcomm_test mbparallelcomm_test.cpp )
-  target_link_libraries( mbparallelcomm_test MOAB )
-  set_source_files_properties( mbparallelcomm_test.cpp
-    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
-  add_test( TestParallelComm-BcastDelete
-    ${MPIEXEC} ${MPIEXEC_NUMPROC_FLAG} 2 ${MPIEXEC_PREFLAGS}
-    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} 0 $=
{MOAB_SOURCE_DIR}/parallel/ptest.cub )
-  add_test( TestParallelComm-ReadDelete
-    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -1 =
${MOAB_SOURCE_DIR}/parallel/ptest.cub )
-  add_test( TestParallelComm-ReadParallel
-    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -2 =
-  add_test( TestParallelComm-Broadcast
-    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -3 =
-  add_executable ( parallel_unit_tests parallel_unit_tests.cpp )
-  target_link_libraries( parallel_unit_tests MOAB )
-    ${EXECUTABLE_OUTPUT_PATH}/parallel_unit_tests ${MPIEXEC_POSTFLAGS} ${M=
-  set_source_files_properties( parallel_unit_tests.cpp
-    add_executable( mhdf_parallel mhdf_parallel.c )
-    target_link_libraries( mhdf_parallel MOAB MOABpar mhdf )
-    add_test( TestMHDFParallel ${EXECUTABLE_OUTPUT_PATH}/mhdf_parallel )
-    set_source_files_properties( mhdf_parallel.c
-endif ( MOAB_USE_MPI AND MPI_FOUND )
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index ec908b9..348bad0 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -7234,7 +7234,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsign=
ed int>& shared_procs,
       RRA("Failure in waitall in tag exchange.");
  =20
-    myDebug->tprintf(1, "Exiting exchange_tags");
+    myDebug->tprintf(1, "Exiting reduce_tags");
=20
     return MB_SUCCESS;
diff --git a/test/CMakeLists.txt b/test/CMakeLists.txt
index 030c3b4..3b1d28d 100644
--- a/test/CMakeLists.txt
+++ b/test/CMakeLists.txt
@@ -2,9 +2,7 @@
=20
=20
   add_executable( moab_test MBTest.cpp )
@@ -43,3 +41,39 @@
   add_test( TestBSPTree ${EXECUTABLE_OUTPUT_PATH}/bsp_tree_test )
=20
=20
+if ( MOAB_USE_MPI AND MPI_FOUND )
+  add_executable ( mbparallelcomm_test mbparallelcomm_test.cpp )
+  target_link_libraries( mbparallelcomm_test MOAB )
+  set_source_files_properties( mbparallelcomm_test.cpp
+    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
+  add_test( TestParallelComm-BcastDelete
+    ${MPIEXEC} ${MPIEXEC_NUMPROC_FLAG} 2 ${MPIEXEC_PREFLAGS}
+    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} 0 $=
+  add_test( TestParallelComm-ReadDelete
+    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -1 =
+  add_test( TestParallelComm-ReadParallel
+    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -2 =
+  add_test( TestParallelComm-Broadcast
+    ${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -3 =
+    add_executable( mhdf_parallel mhdf_parallel.c )
+    target_link_libraries( mhdf_parallel MOAB MOABpar mhdf )
+    add_test( TestMHDFParallel ${EXECUTABLE_OUTPUT_PATH}/mhdf_parallel )
+    set_source_files_properties( mhdf_parallel.c
+  add_executable ( parallel_unit_tests parallel_unit_tests.cpp )
+  target_link_libraries( parallel_unit_tests MOAB )
+    ${EXECUTABLE_OUTPUT_PATH}/parallel_unit_tests ${MPIEXEC_POSTFLAGS} ${M=
+  set_source_files_properties( parallel_unit_tests.cpp
+endif ( MOAB_USE_MPI AND MPI_FOUND )
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
