[MOAB-dev] crash with clang compiler
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Jun  3 15:13:52 CDT 2013
Rajeev Jain <jain at mcs.anl.gov> writes:
> I use clang compilers.
What Clang compiler?  The output below shows a 6-year old version of gcc.
> Haven't seen the error that you see.
> ==> gcc -v
> Using built-in specs.
> Target: i686-apple-darwin11
> Configured with: /private/var/tmp/llvmgcc42/llvmgcc42-2336.11~182/src/configure --disable-checking --enable-werror --prefix=/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2 --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-prefix=llvm- --program-transform-name=/^[cg][^.-]*$/s/$/-4.2/ --with-slibdir=/usr/lib --build=i686-apple-darwin11 --enable-llvm=/private/var/tmp/llvmgcc42/llvmgcc42-2336.11~182/dst-llvmCore/Developer/usr/local --program-prefix=i686-apple-darwin11- --host=x86_64-apple-darwin11 --target=i686-apple-darwin11 --with-gxx-include-dir=/usr/include/c++/4.2.1
> Thread model: posix
> gcc version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.11.00)
