[MOAB-dev] problem with --disable-fortran
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Jun  3 09:16:31 CDT 2013
Please also *always* send the config.log, that helps figure out what failed (it also contains the configure options
used).  Thanks.
- tim
On 06/01/2013 09:38 AM, Lorenzo Alessio Botti wrote:
> Dear all,
> it seems that the --disable-fortran flag is not working anymore
> digihabia:moab-4.6.0 ihabia$ ./configure --disable-fortran --disable-imesh --with-mpi=/Users/ihabia/src2/mpich2-1.5/mpich2/ --with-hdf5=/Users/ihabia/src2/hdf5-1.8.10/hdf5/
> checking build system type... i386-apple-darwin12.3.0
> checking host system type... i386-apple-darwin12.3.0
> checking target system type... i386-apple-darwin12.3.0
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... config/install-sh -c -d
> checking for gawk... no
> checking for mawk... no
> checking for nawk... no
> checking for awk... awk
> checking whether make sets $(MAKE)... yes
> checking for sed... sed
> checking for style of include used by make... GNU
> configure: error: Cannot find MPI compiler.  Try specifying $FC
> Any suggestion?
> I'd like to avoid fortran on OSX.
> I have configured mpich with as follows
> ./configure --disable-fc --disable-f77 --prefix=/Users/ihabia/src2/mpich2-1.5/mpich2/
> One more question, which version of HDF5 is suggested to use with moab 4.6.0?
> Thanks for help.
> Lorenzo
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
