[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Thu May 30 09:06:10 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e04b9a9621be/
Changeset:   e04b9a9621be
Branch:      None
User:        danwu
Date:        2013-05-30 15:55:46
Summary:     Add a smallish CAM-FV file fv26x46x72.t.3.nc for unit testing
Affected #:  1 file
diff --git a/MeshFiles/unittest/io/fv26x46x72.t.3.nc b/MeshFiles/unittest/io/fv26x46x72.t.3.nc
new file mode 100644
index 0000000..15ba5b4
Binary files /dev/null and b/MeshFiles/unittest/io/fv26x46x72.t.3.nc differ
https://bitbucket.org/fathomteam/moab/commits/c3595c2c3b33/
Changeset:   c3595c2c3b33
Branch:      master
User:        danwu
Date:        2013-05-30 16:02:08
Summary:     Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #:  3 files
diff --git a/configure.ac b/configure.ac
index c9d6387..130e4a9 100644
--- a/configure.ac
+++ b/configure.ac
@@ -41,6 +41,7 @@ else
   AM_SILENT_RULES(no)
 fi
+AC_C_BIGENDIAN
 # Check if platform is BlueGene
 AC_MSG_CHECKING([if platform is IBM BlueGene])
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index ef01b16..833b15b 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -39,6 +39,9 @@
 #include <sstream>
 #include <assert.h>
 #include <string.h>
+#ifdef HAVE_CONFIG_H
+#include <config.h>
+#endif
 namespace moab {
@@ -145,14 +148,54 @@ void Tqdcfr::FREADC( unsigned num_ents ) {
   FREADCA( num_ents, &char_buf[0] );
+// used for swapping
+static void swap8_voff(long *data)
+  unsigned char tmp, *cdat = (unsigned char *) data;
+  tmp = cdat[0]; cdat[0] = cdat[7], cdat[7] = tmp;
+  tmp = cdat[1]; cdat[1] = cdat[6], cdat[6] = tmp;
+  tmp = cdat[2]; cdat[2] = cdat[5], cdat[5] = tmp;
+  tmp = cdat[3]; cdat[3] = cdat[4], cdat[4] = tmp;
+static void swap4_uint(unsigned int *data)
+  tmp = cdat[0]; cdat[0] = cdat[3], cdat[3] = tmp;
+  tmp = cdat[1]; cdat[1] = cdat[2], cdat[2] = tmp;
+/*static void swap2_ushort(unsigned short *data)
+  tmp = cdat[0]; cdat[0] = cdat[1], cdat[1] = tmp;
 void Tqdcfr::FREADIA( unsigned num_ents, unsigned int* array ) {
   unsigned rval = fread( array, sizeof(unsigned int), num_ents, cubFile );
   IO_ASSERT( rval == num_ents );
+  if (swapForEndianness)
+    unsigned int  * pt=array;
+    for (unsigned int i=0; i<num_ents; i++ )
+      swap4_uint((unsigned int *)pt);
+      pt++;
 void Tqdcfr::FREADDA( unsigned num_ents, double* array ) {
   unsigned rval = fread( array, sizeof(double), num_ents, cubFile );
+    double  * pt=array;
+      swap8_voff((long *)pt);
+      pt++;
 void Tqdcfr::FREADCA( unsigned num_ents, char* array ) {
@@ -172,7 +215,7 @@ ReaderIface* Tqdcfr::factory( Interface* iface )
 Tqdcfr::Tqdcfr(Interface *impl)
     : cubFile(NULL), globalIdTag(0), geomTag(0), uniqueIdTag(0),
       blockTag(0), nsTag(0), ssTag(0), attribVectorTag(0), entityNameTag(0),
-      categoryTag(0), hasMidNodesTag(0), printedSeqWarning(false), printedElemWarning(false)
+      categoryTag(0), hasMidNodesTag(0), swapForEndianness(false), printedSeqWarning(false), printedElemWarning(false)
   assert(NULL != impl);
   mdbImpl = impl;
@@ -1576,13 +1619,26 @@ ErrorCode Tqdcfr::read_file_header()
     // read file header
   FSEEK(4);
-  FREADI(6);
-  fileTOC.fileEndian = uint_buf[0];
-  fileTOC.fileSchema = uint_buf[1];
-  fileTOC.numModels = uint_buf[2];
-  fileTOC.modelTableOffset = uint_buf[3];
-  fileTOC.modelMetaDataOffset = uint_buf[4];
-  fileTOC.activeFEModel = uint_buf[5];
+  // read tthe first int from the file
+  // if it is 0, it is littleEndian
+  unsigned rval = fread( &fileTOC.fileEndian, sizeof(unsigned int), 1, cubFile );
+  IO_ASSERT( rval == 1 );
+#ifdef WORDS_BIGENDIAN
+  if (fileTOC.fileEndian==0)
+    swapForEndianness=true;
+#else
+  if (fileTOC.fileEndian!=0)
+#endif
+  if (debug)
+    std::cout << " swapping ? " << swapForEndianness << "\n";
+  FREADI(5);
+  //fileTOC.fileEndian = uint_buf[0];
+  fileTOC.fileSchema = uint_buf[0];
+  fileTOC.numModels = uint_buf[1];
+  fileTOC.modelTableOffset = uint_buf[2];
+  fileTOC.modelMetaDataOffset = uint_buf[3];
+  fileTOC.activeFEModel = uint_buf[4];
   if (debug) fileTOC.print();
   return MB_SUCCESS;
diff --git a/src/io/Tqdcfr.hpp b/src/io/Tqdcfr.hpp
index 1b4188f..eaf28ea 100644
--- a/src/io/Tqdcfr.hpp
+++ b/src/io/Tqdcfr.hpp
@@ -287,6 +287,7 @@ public:
     attribVectorTag, entityNameTag, categoryTag, hasMidNodesTag;
   std::map<int, EntityHandle> uidSetMap;
   std::map<int, EntityHandle> gidSetMap[6];
+  bool swapForEndianness;
   std::vector<unsigned int> uint_buf;
   int *int_buf;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
