[MOAB-dev] commit/MOAB: iulian07: logic for endianness for cubit file reader
commits-noreply at bitbucket.org
Tue May 28 21:55:50 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c629a6173906/
Changeset: c629a6173906
Branch: master
User: iulian07
Date: 2013-05-29 04:47:33
Summary: logic for endianness for cubit file reader
the endianness of the system is determined by using a macro
AC_C_BIGENDIAN
swapping is done if the file is little endian and system is big endian, or if
the file is bigendian and system is little endian
I did not test yet a big endian file.
tests are fine for our ptest.cub file from repository (little endian)
on both linux workstation and BG/Q
the endianness in the file is determined from the first integer after
the magic word "cube".
Right now, assume that a little endian file has that first integer as 0.
Affected #: 3 files
diff --git a/configure.ac b/configure.ac
index c9d6387..130e4a9 100644
--- a/configure.ac
+++ b/configure.ac
@@ -41,6 +41,7 @@ else
AM_SILENT_RULES(no)
fi
+AC_C_BIGENDIAN
# Check if platform is BlueGene
AC_MSG_CHECKING([if platform is IBM BlueGene])
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index ef01b16..6d23b3e 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -42,7 +42,7 @@
namespace moab {
-static bool debug = false;
+static bool debug = true;
//const int ACIS_DIMS[] = {-1, 3, -1, 2, -1, -1, 1, 0, -1, -1};
const char Tqdcfr::geom_categories[][CATEGORY_TAG_SIZE] =
{"Vertex\0", "Curve\0", "Surface\0", "Volume\0"};
@@ -145,14 +145,54 @@ void Tqdcfr::FREADC( unsigned num_ents ) {
FREADCA( num_ents, &char_buf[0] );
+// used for swapping
+static void swap8_voff(long *data)
+ unsigned char tmp, *cdat = (unsigned char *) data;
+ tmp = cdat[0]; cdat[0] = cdat[7], cdat[7] = tmp;
+ tmp = cdat[1]; cdat[1] = cdat[6], cdat[6] = tmp;
+ tmp = cdat[2]; cdat[2] = cdat[5], cdat[5] = tmp;
+ tmp = cdat[3]; cdat[3] = cdat[4], cdat[4] = tmp;
+static void swap4_uint(unsigned int *data)
+ tmp = cdat[0]; cdat[0] = cdat[3], cdat[3] = tmp;
+ tmp = cdat[1]; cdat[1] = cdat[2], cdat[2] = tmp;
+/*static void swap2_ushort(unsigned short *data)
+ tmp = cdat[0]; cdat[0] = cdat[1], cdat[1] = tmp;
void Tqdcfr::FREADIA( unsigned num_ents, unsigned int* array ) {
unsigned rval = fread( array, sizeof(unsigned int), num_ents, cubFile );
IO_ASSERT( rval == num_ents );
+ if (swapForEndianness)
+ unsigned int * pt=array;
+ for (unsigned int i=0; i<num_ents; i++ )
+ swap4_uint((unsigned int *)pt);
+ pt++;
void Tqdcfr::FREADDA( unsigned num_ents, double* array ) {
unsigned rval = fread( array, sizeof(double), num_ents, cubFile );
+ double * pt=array;
+ swap8_voff((long *)pt);
+ pt++;
void Tqdcfr::FREADCA( unsigned num_ents, char* array ) {
@@ -172,7 +212,7 @@ ReaderIface* Tqdcfr::factory( Interface* iface )
Tqdcfr::Tqdcfr(Interface *impl)
: cubFile(NULL), globalIdTag(0), geomTag(0), uniqueIdTag(0),
blockTag(0), nsTag(0), ssTag(0), attribVectorTag(0), entityNameTag(0),
- categoryTag(0), hasMidNodesTag(0), printedSeqWarning(false), printedElemWarning(false)
+ categoryTag(0), hasMidNodesTag(0), swapForEndianness(false), printedSeqWarning(false), printedElemWarning(false)
assert(NULL != impl);
mdbImpl = impl;
@@ -1576,13 +1616,26 @@ ErrorCode Tqdcfr::read_file_header()
// read file header
FSEEK(4);
- FREADI(6);
- fileTOC.fileEndian = uint_buf[0];
- fileTOC.fileSchema = uint_buf[1];
- fileTOC.numModels = uint_buf[2];
- fileTOC.modelTableOffset = uint_buf[3];
- fileTOC.modelMetaDataOffset = uint_buf[4];
- fileTOC.activeFEModel = uint_buf[5];
+ // read tthe first int from the file
+ // if it is 0, it is littleEndian
+ unsigned rval = fread( &fileTOC.fileEndian, sizeof(unsigned int), 1, cubFile );
+ IO_ASSERT( rval == 1 );
+#ifdef WORDS_BIGENDIAN
+ if (fileTOC.fileEndian==0)
+ swapForEndianness=true;
+#else
+ if (fileTOC.fileEndian!=0)
+#endif
+ if (debug)
+ std::cout << " swapping ? " << swapForEndianness << "\n";
+ FREADI(5);
+ //fileTOC.fileEndian = uint_buf[0];
+ fileTOC.fileSchema = uint_buf[0];
+ fileTOC.numModels = uint_buf[1];
+ fileTOC.modelTableOffset = uint_buf[2];
+ fileTOC.modelMetaDataOffset = uint_buf[3];
+ fileTOC.activeFEModel = uint_buf[4];
if (debug) fileTOC.print();
return MB_SUCCESS;
diff --git a/src/io/Tqdcfr.hpp b/src/io/Tqdcfr.hpp
index 1b4188f..eaf28ea 100644
--- a/src/io/Tqdcfr.hpp
+++ b/src/io/Tqdcfr.hpp
@@ -287,6 +287,7 @@ public:
attribVectorTag, entityNameTag, categoryTag, hasMidNodesTag;
std::map<int, EntityHandle> uidSetMap;
std::map<int, EntityHandle> gidSetMap[6];
+ bool swapForEndianness;
std::vector<unsigned int> uint_buf;
int *int_buf;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
