[MOAB-dev] buildbot failure in moab-intel: failed test
Tim Tautges tautges at mcs.anl.gov
Wed May 22 09:07:52 CDT 2013
This is my problem, and I've been dragging my feet fixing it, so sorry all.  The problem is deeper than just linking
with the fortran compiler, as moab still requires a C++ runtime and that isn't linked by default by the fortran linker.
- tim
On 05/22/2013 02:14 AM, Xiabing Xu wrote:
> This seems to be a linker problem.
> libtool: link:*  icpc*  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o ScdMeshF90 ScdMeshF90.o ....
> ScdMeshF90.F90 is a fortran file, ifort should be used instead of icpc.
> Thanks,
> Xiabing
> On Tue, May 21, 2013 at 11:36 PM, <moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>> wrote:
>       Fathom <http://gnep.mcs.anl.gov:8010/>: moab-intel <http://gnep.mcs.anl.gov:8010/builders/moab-intel> build #196
>       <http://gnep.mcs.anl.gov:8010/builders/moab-intel/builds/196>
>     *Results:*	failed test
>     *Buildslave:*	gnep
>     *Revision:*	None
>     *Reason:*	The Nightly scheduler named 'moab-intel-nightly' triggered this build
>         Log Excerpt
>     make[4]: Nothing to be done for `check-am'.
>       ...make[3]: Entering directory `/disks/itaps-buildslave/moab-intel/build/MeshFiles'
>     make[3]: Nothing to be done for `check-am'.
>       ...Making check in itaps
>     make[2]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps'
>     Making check in imesh
>     make[3]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
>     make  check-am
>     make[4]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
>     make  testc_cbind MOAB_iMesh_unit_tests MOAB_iMesh_extensions_tests ScdMeshF90 ScdMeshF77 FindAdjacencyF90
>     make[5]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
>     icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT testc_cbind.o -MD -MP -MF .deps/testc_cbind.Tpo -c -o testc_cbind.o testc_cbind.cpp
>     mv -f .deps/testc_cbind.Tpo .deps/testc_cbind.Po
>     /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o testc_cbind testc_cbind.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gn
 u -lim
>       f -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux
 -gnu/4.
>     libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o testc_cbind testc_cbind.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../l
 ib64 -
>       L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
>     icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT MOAB_iMesh_unit_tests.o -MD -MP -MF .deps/MOAB_iMesh_unit_tests.Tpo -c -o MOAB_iMesh_unit_tests.o MOAB_iMesh_unit_tests.cpp
>     mv -f .deps/MOAB_iMesh_unit_tests.Tpo .deps/MOAB_iMesh_unit_tests.Po
>     /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr
 /lib/x
>       86_64-linux-gnu -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/
 lib/gcc
>     libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu
 /4.4.3
>       /../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
>     icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT MOAB_iMesh_extensions_tests.o -MD -MP -MF .deps/MOAB_iMesh_extensions_tests.Tpo -c -o MOAB_iMesh_extensions_tests.o MOAB_iMesh_extensions_tests.cpp
>     mv -f .deps/MOAB_iMesh_extensions_tests.Tpo .deps/MOAB_iMesh_extensions_tests.Po
>     /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/us
 r/lib
>       -L/usr/lib/x86_64-linux-gnu -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64
  -L. -L
>     libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_
 64-lin
>       ux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
>     	ifort -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -O2  -c -o ScdMeshF90.o ScdMeshF90.F90
>     /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o ScdMeshF90 ScdMeshF90.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu
 -limf
>       -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-g
 nu/4.4.
>     libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o ScdMeshF90 ScdMeshF90.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib
 64 -L/
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 0 has invalid symbol index 11
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 1 has invalid symbol index 12
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 2 has invalid symbol index 2
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 3 has invalid symbol index 2
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 4 has invalid symbol index 11
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 5 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 6 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 7 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 8 has invalid symbol index 2
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 9 has invalid symbol index 2
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 10 has invalid symbol index 12
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 11 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 12 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 13 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 14 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 15 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 16 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 17 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 18 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 19 has invalid symbol index 13
>     ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 20 has invalid symbol index 20
>     /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64/crt1.o: In function `_start':
>     (.text+0x20): undefined reference to `main'
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
