[MOAB-dev] commit/MOAB: rajeeja: Important changes needed in Version4.6
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri May 17 11:57:54 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c743ac29fc66/
Changeset:   c743ac29fc66
Branch:      Version4.6
User:        rajeeja
Date:        2013-05-17 18:56:10
Summary:     Important changes needed in Version4.6
Merge branch 'master' into Version4.6
Affected #:  129 files
diff --git a/.gitignore b/.gitignore
new file mode 100644
index 0000000..6d29b5e
--- /dev/null
+++ b/.gitignore
@@ -0,0 +1,187 @@
+MOABConfig.cmake
+moab.files
+config/test-driver
+moab.config
+moab.includes
+moab.creator*
+*.ccm
+*.cub
+aclocal.m4
+autom4te.cache/
+config.h
+config.h.in
+config.log
+config.lt
+config.status
+config/config.guess
+config/config.sub
+config/depcomp
+config/install-sh
+config/libtool.m4
+config/ltmain.sh
+config/ltoptions.m4
+config/ltsugar.m4
+config/ltversion.m4
+config/lt~obsolete.m4
+config/missing
+configure
+doc/config.tex
+doc/dev.dox
+doc/user.dox
+doc/user/*
+examples/examples.make
+itaps/iBase_f.h
+itaps/igeom/FBiGeom-Defs.inc
+itaps/imesh/iMesh-Defs.inc
+itaps/imesh/iMeshP_extensions_protos.h
+itaps/imesh/iMeshP_protos.h
+itaps/imesh/iMesh_extensions_protos.h
+itaps/imesh/iMesh_protos.h
+libtool
+moab.make
+src/FCDefs.h
+src/MBCN_protos.h
+src/MOAB_FCDefs.h
+src/moab/EntityHandle.hpp
+src/moab/Version.h
+src/moab/stamp-h2
+src/moab/stamp-h3
+src/parallel/moab_mpi_config.h
+src/parallel/stamp-h4
+src/stamp-h5
+stamp-h1
+tools/mbcoupler/tests/
+tools/mbzoltan/Config.moab
+tools/vtkMOABReader/CMakeLists.txt
+tools/vtkMOABReaderNew/CMakeLists.txt
+.deps
+Makefile.in
+Makefile
+*/Makefile.in
+*/Makefile
+*/**/Makefile.in
+*/**/Makefile
+.libs
+*.o
+*.log
+*.lo
+*.la
+*.a
+*.so
+include/*
+lib/*
+share/*
+bin/*
+examples/HelloMoabPar
+examples/TestExodusII
+itaps/igeom/FBiGeom_protos.h
+itaps/igeom/testSmooth2
+itaps/igeom/testSmoothGeom
+itaps/igeom/testgeom
+itaps/imesh/FindAdjacencyF90
+itaps/imesh/MOAB_iMeshP_unit_tests
+itaps/imesh/ScdMeshF77
+itaps/imesh/ScdMeshF90
+itaps/imesh/partest
+test/adaptive_kd_tree_tests
+test/bsp_tree_poly_test
+test/bsp_tree_test
+test/*.gen
+test/coords_connect_iterate
+test/cropvol_test
+test/dual/dual_test
+test/file_options_test
+test/geom_util_test
+test/gttool_test
+test/h5file/dump_sets
+test/h5file/h5legacy
+test/h5file/h5partial
+test/h5file/h5portable
+test/h5file/h5regression
+test/h5file/h5sets_test
+test/h5file/h5test
+test/h5file/h5varlen
+test/*.g
+test/homxform_test
+test/io/cub_file_test
+test/io/exodus_test
+test/io/gmsh_test
+test/io/ideas_test
+test/io/*.g
+test/io/nastran_test
+test/io/read_cgm_test
+test/io/read_nc
+test/io/read_ucd_nc
+test/io/readutil_test
+test/io/smf_test
+test/io/stl_test
+test/io/tqdcfr
+test/io/vtk_test
+test/kd_tree_test
+test/kd_tree_time
+test/kd_tree_tool
+test/mbcn_test
+test/mbfacet_test
+test/mbground_test
+test/mesh_set_test
+test/moab_test
+test/obb/obb_test
+test/obb/obb_time
+test/obb/obb_tree_tool
+test/obb_test
+test/oldinc/test_oldinc
+test/parallel/*.h5m
+test/parallel/*.vtk
+test/parallel/mbparallelcomm_test
+test/parallel/mhdf_parallel
+test/parallel/par_coupler_test
+test/parallel/par_intx_sph
+test/parallel/parallel_hdf5_test
+test/parallel/parallel_unit_tests
+test/parallel/parallel_write_test
+test/parallel/parmerge
+test/parallel/partcheck
+test/parallel/pcomm_serial
+test/parallel/pcomm_unit
+test/parallel/read_nc_par
+test/parallel/scdpart
+test/parallel/scdtest
+test/parallel/structured3
+test/parallel/uber_parallel_test
+test/parallel/ucdtrvpart
+test/perf/adj_time
+test/perf/perf
+test/perf/perftool
+test/perf/seqperf
+test/perf/tstt_perf_binding
+test/range_test
+test/reorder_test
+test/scdseq_test
+test/seq_man_test
+test/tag_test
+test/test_adj
+test/test_prog_opt
+test/var_len_test
+test/var_len_test_no_template
+test/xform_test
+tools/dagmc/pt_vol_test
+tools/dagmc/ray_fire_test
+tools/dagmc/test_geom
+tools/dagmc/update_coords
+tools/mbcoupler/*.h5m
+tools/mbcslam/case1_test
+tools/mbcslam/intersect1.h5m
+tools/mbcslam/intx.vtk
+tools/mbcslam/intx1.vtk
+tools/mbcslam/intx_in_plane_test
+tools/mbcslam/intx_on_sphere_test
+tools/mbcslam/lagr.h5m
+tools/mbcslam/spec_visu_test
+tools/mbcslam/spectral.vtk
+tools/mbcslam/spherical_area_test
+.project
+.cproject
+examples/*.h5m
+examples/ReduceExchangeTags
diff --git a/Makefile.am b/Makefile.am
index 33a99cf..1c91622 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -5,7 +5,7 @@ AUTOMAKE_OPTIONS = foreign
 ACLOCAL_AMFLAGS = -I config
 # Subdirectories to build
-SUBDIRS = src MeshFiles $(itaps_dir) tools test doc examples
+SUBDIRS = src MeshFiles $(itaps_dir) tools test doc
 if ENABLE_igeom
   itaps_dir_igeom = itaps
diff --git a/MeshFiles/unittest/disk.h5m b/MeshFiles/unittest/disk.h5m
index 0000000..ef19883
Binary files /dev/null and b/MeshFiles/unittest/disk.h5m differ
diff --git a/RELEASE_NOTES b/RELEASE_NOTES
index ca26bef..d10c95e 100644
--- a/RELEASE_NOTES
+++ b/RELEASE_NOTES
@@ -1,3 +1,5 @@
+Version 4.7pre:
 Version 4.6:
 * Removed deprecated functions from the Interface: (some overloaded variants of) query_interface, release_interface,
   tag_get_data, tag_set_data, tag_get_size.
diff --git a/config/compiler.m4 b/config/compiler.m4
index ce00d10..18df411 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -126,6 +126,8 @@ fi
 if test "xno" != "x$CHECK_FC"; then
   AC_PROG_FC
   AC_PROG_F77
+  AC_F77_LIBRARY_LDFLAGS
+  AC_FC_LIBRARY_LDFLAGS
 fi
 ]) # FATHOM_CHECK_COMPILERS
diff --git a/configure.ac b/configure.ac
index 7494691..1524b06 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1,7 +1,7 @@
 #                           Standard Stuff
-AC_INIT(MOAB, 4.6.0)
+AC_INIT(MOAB, 4.7.0pre)
 AC_CONFIG_SRCDIR([moab.make.in])
 AC_CONFIG_SRCDIR([MOABConfig.cmake.in])
 AC_CONFIG_MACRO_DIR([config])
@@ -67,6 +67,14 @@ if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
   AC_FC_WRAPPERS
 fi
+if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FLIBS"; then
+   LIBS="$LIBS $FLIBS"
+fi
+if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FCLIBS"; then
+   LIBS="$LIBS $FCLIBS"
+fi
 #                           Check for need for extra flags to support cray pointers
@@ -1163,6 +1171,8 @@ AC_SUBST([EXPORT_LTFLAGS])
 AC_SUBST([EXPORT_LDFLAGS])
 AC_SUBST([AM_CXXFLAGS])
 AC_SUBST([AM_CFLAGS])
+  AC_SUBST([AM_FCFLAGS])
+  AC_SUBST([AM_FFLAGS])
 AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
 AC_ARG_VAR([FC], [FORTRAN compiler command])
@@ -1208,10 +1218,6 @@ AC_CONFIG_FILES([Makefile
                  doc/user.dox
                  doc/dev.dox
                  doc/config.tex
-                 examples/Makefile
-                 examples/examples.make
-                 examples/simple/makefile
-                 examples/itaps/Makefile
                  MeshFiles/Makefile
                  MeshFiles/unittest/Makefile
                  MeshFiles/unittest/io/Makefile
diff --git a/doc/user.dox.in b/doc/user.dox.in
index 703ce6b..4fed19e 100644
--- a/doc/user.dox.in
+++ b/doc/user.dox.in
@@ -52,7 +52,7 @@ EXTRACT_ALL            = YES
 # If the EXTRACT_PRIVATE tag is set to YES all private members of a class
 # will be included in the documentation.
-EXTRACT_PRIVATE        = NO
+EXTRACT_PRIVATE        = YES
 # If the EXTRACT_STATIC tag is set to YES all static members of a file
@@ -112,7 +112,7 @@ STRIP_FROM_PATH        =
 # to NO (the default) then the documentation will be excluded.
 # Set it to YES to include the internal documentation.
-INTERNAL_DOCS          = NO
+INTERNAL_DOCS          = YES
 # If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
 # generate a class diagram (in Html and LaTeX) for classes with base or
@@ -123,12 +123,12 @@ CLASS_DIAGRAMS         = YES
 # If the SOURCE_BROWSER tag is set to YES then a list of source files will
 # be generated. Documented entities will be cross-referenced with these sources.
-SOURCE_BROWSER         = NO
+SOURCE_BROWSER         = YES
 # Setting the INLINE_SOURCES tag to YES will include the body
 # of functions and classes directly in the documentation.
-INLINE_SOURCES         = NO
+INLINE_SOURCES         = YES
 # Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
 # doxygen to hide any special comment blocks from generated source code
@@ -199,12 +199,12 @@ SORT_MEMBER_DOCS       = YES
 # member in the group (if any) for the other members of the group. By default
 # all members of a group must be documented explicitly.
-DISTRIBUTE_GROUP_DOC   = NO
+DISTRIBUTE_GROUP_DOC   = YES
 # The TAB_SIZE tag can be used to set the number of spaces in a tab.
 # Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE               = 8
+TAB_SIZE               = 4
 # The GENERATE_TODOLIST tag can be used to enable (YES) or
 # disable (NO) the todo list. This list is created by putting \todo
@@ -304,14 +304,14 @@ WARN_LOGFILE           =
 # directories like "/usr/src/myproject". Separate the files or directories
 # with spaces.
-INPUT                  = @top_srcdir@/src/moab \
+INPUT                  = @top_srcdir@/src @top_srcdir@/src/moab \
                          @top_srcdir@/src/parallel/moab \
                          @top_srcdir@/src/MBTagConventions.hpp \
                          @top_srcdir@/src/MBCN.h \
                          @top_srcdir@/src/MBEntityType.h \
                          @top_srcdir@/src/parallel/MBParallelConventions.h \
-                         @top_srcdir@/tools/dagmc/DagMC.hpp \
-                         @top_srcdir@/itaps @top_srcdir@/itaps/imesh
+                         @top_srcdir@/tools/ @top_srcdir@/tools/mbcoupler @top_srcdir@/tools/dagmc/DagMC.hpp \
+			 @top_srcdir@/itaps @top_srcdir@/itaps/imesh @top_srcdir@/examples
 # If the value of the INPUT tag contains directories, you can use the
 # FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
@@ -339,11 +339,11 @@ EXCLUDE                =
 EXCLUDE_PATTERNS       =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
+# The EXAMPLE_PATH tag can be used to specify one or more files or
 # directories that contain example code fragments that are included (see
 # the \include command).
-EXAMPLE_PATH           =
+EXAMPLE_PATH           =  @top_srcdir@/examples/
 # If the value of the EXAMPLE_PATH tag contains directories, you can use the
 # EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
@@ -458,7 +458,7 @@ BINARY_TOC             = NO
 # The TOC_EXPAND flag can be set to YES to add extra items for group members
 # to the contents of the Html help documentation and to the tree view.
-TOC_EXPAND             = NO
+TOC_EXPAND             = YES
 # The DISABLE_INDEX tag can be used to turn on/off the condensed index at
 # top of each HTML page. The value NO (the default) enables the index and
@@ -647,7 +647,7 @@ MACRO_EXPANSION        = NO
 # then the macro expansion is limited to the macros specified with the
 # PREDEFINED and EXPAND_AS_PREDEFINED tags.
-EXPAND_ONLY_PREDEF     = NO
+EXPAND_ONLY_PREDEF     = YES
 # If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
 # in the INCLUDE_PATH (see below) will be search if a #include is found.
@@ -808,7 +808,7 @@ DOT_CLEANUP            = YES
 # The SEARCHENGINE tag specifies whether or not a search engine should be
 # used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
+SEARCHENGINE           = YES
 # The CGI_NAME tag should be the name of the CGI script that
 # starts the search engine (doxysearch) with the correct parameters.
diff --git a/examples/A.1.ele b/examples/A.1.ele
deleted file mode 100644
index d742678..0000000
--- a/examples/A.1.ele
+++ /dev/null
@@ -1,31 +0,0 @@
-29  3  0
-   1      29     2     1
-   2       2    29    23
-   3      25    24    23
-   4      23    22     2
-   5      25    23    29
-   6       2    22     3
-   7       3    21     4
-   8      21     3    22
-   9       4    21    20
-  10       5     4    26
-  11      19    26     4
-  12      26    19    18
-  13      19     4    20
-  14       5    26    28
-  15      12    14    13
-  16      14    12    11
-  17      11    10     9
-  18       8    14     9
-  19       8    15    14
-  20       9    14    11
-  21       6    27     7
-  22      26    18    27
-  23       5    28     6
-  24      27    18     7
-  25      28    27     6
-  26      15     7    16
-  27       7    15     8
-  28      17     7    18
-  29       7    17    16
-# Generated by triangle A.poly
diff --git a/examples/A.1.node b/examples/A.1.node
index 31d09f1..0000000
--- a/examples/A.1.node
+++ /dev/null
@@ -1,31 +0,0 @@
-29  2  1  1
-   1    0.20000000000000001  -0.77639999999999998  -0.56999999999999995    1
-   2    0.22  -0.7732  -0.55000000000000004    1
-   3    0.24560000000000001  -0.75639999999999996  -0.51000000000000001    1
-   4    0.27760000000000001  -0.70199999999999996  -0.53000000000000003    1
-   5    0.48880000000000001  -0.20760000000000001  0.28000000000000003    1
-   6    0.50480000000000003  -0.20760000000000001  0.29999999999999999    1
-   7    0.74080000000000001  -0.73960000000000004  0    1
-   8    0.75600000000000001  -0.76119999999999999  -0.01    1
-   9    0.77439999999999998  -0.77239999999999998  0    1
-  10    0.80000000000000004  -0.77639999999999998  0.02    1
-  11    0.80000000000000004  -0.79239999999999999  0.01    1
-  12    0.57920000000000005  -0.79239999999999999  -0.20999999999999999    1
-  13    0.57920000000000005  -0.77639999999999998  -0.20000000000000001    1
-  14    0.62160000000000004  -0.77159999999999995  -0.14999999999999999    1
-  15    0.63360000000000005  -0.76280000000000003  -0.13    1
-  16    0.63919999999999999  -0.74439999999999995  -0.10000000000000001    1
-  17    0.62080000000000002  -0.68440000000000001  -0.059999999999999998    1
-  18    0.58720000000000006  -0.60440000000000005  -0.01    1
-  19    0.36080000000000001  -0.60440000000000005  -0.23999999999999999    1
-  20    0.31919999999999998  -0.70679999999999998  -0.39000000000000001    1
-  21    0.312  -0.73960000000000004  -0.42999999999999999    1
-  22    0.31840000000000002  -0.76119999999999999  -0.44    1
-  23    0.33439999999999998  -0.77159999999999995  -0.44    1
-  24    0.37119999999999997  -0.77639999999999998  -0.40999999999999998    1
-  25    0.37119999999999997  -0.79239999999999999  -0.41999999999999998    1
-  26    0.37440000000000001  -0.56999999999999995  -0.20000000000000001    1
-  27    0.57440000000000002  -0.56999999999999995  0    1
-  28    0.47360000000000002  -0.33079999999999998  0.14000000000000001    1
-  29    0.20000000000000001  -0.79239999999999999  -0.58999999999999997    1
diff --git a/examples/DirectAccessNoHoles.cpp b/examples/DirectAccessNoHoles.cpp
index 0000000..340efae
--- /dev/null
+++ b/examples/DirectAccessNoHoles.cpp
@@ -0,0 +1,186 @@
+/** @example DirectAccessNoHoles.cpp \n
+ * \brief Use direct access to MOAB data to avoid calling through API \n
+ * This example creates a 1d row of quad elements, such that all quad and vertex handles
+ * are contiguous in the handle space and in the database.  Then it shows how to get access
+ * to pointers to MOAB-native data for vertex coordinates, quad connectivity, tag storage,
+ * and vertex to quad adjacency lists.  This allows applications to access this data directly
+ * without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+ * vertices are moving), this can save significant execution time in applications.
+ *    -#  Initialize MOAB \n
+ *    -#  Create a quad mesh, as depicted above
+ *    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+ *    -#  Get connectivity, coordinate, tag1 iterators
+ *    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+ *    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+ *    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+ * <b>To compile</b>: \n
+ *    make DirectAccessNoHoles MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: ./DirectAccessNoHoles [-nquads <# quads>]\n
+#include "moab/Core.hpp"
+#include "moab/ProgOptions.hpp"
+#include "moab/ReadUtilIface.hpp"
+#include <map>
+#include <iostream>
+#include <assert.h>
+// Error routines for use with MOAB API
+#define CHKERR(CODE, MSG) do {if (MB_SUCCESS != (CODE)) {std::string errstr;  mbImpl->get_last_error(errstr);   \
+        std::cerr << errstr << std::endl; std::cerr << MSG << std::endl; return CODE;}} while(false)
+using namespace moab;
+ErrorCode create_mesh_no_holes(Interface *mbImpl, int nquads);
+int main(int argc, char **argv)
+    // get MOAB instance
+  Interface *mbImpl = new Core;
+  if (NULL == mbImpl) return 1;
+  int nquads = 1000;
+    // parse options
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("nquads,n"), std::string("Number of quads in the mesh (default = 1000"), &nquads);
+  opts.parseCommandLine(argc, argv);
+    // create simple structured mesh with hole, but using unstructured representation
+  ErrorCode rval = create_mesh_no_holes(mbImpl, nquads); CHKERR(rval, "Trouble creating mesh.");
+    // get all vertices and non-vertex entities
+  Range verts, quads;
+  rval = mbImpl->get_entities_by_handle(0, quads); CHKERR(rval, "Getting all entities.");
+  verts = quads.subset_by_dimension(0);
+  quads -= verts;
+    // create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts)
+  Tag tag1, tag2, tag3;
+  rval = mbImpl->tag_get_handle("tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT); CHKERR(rval, "Creating tag1.");
+  double def_val[3] = {0.0, 0.0, 0.0}; // need a default value for tag2 because we sum into it
+  rval = mbImpl->tag_get_handle("tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val); CHKERR(rval, "Creating tag2.");
+  int def_val_int = 0;  // need a default value for tag3 because we increment it
+  rval = mbImpl->tag_get_handle("tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int); CHKERR(rval, "Creating tag3.");
+    // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a count,
+    // which should be compared to the # entities you expect to verify there's only one chunk (no holes)
+  int count, vpere;
+  EntityHandle *conn_ptr;
+  rval = mbImpl->connect_iterate(quads.begin(), quads.end(), conn_ptr, vpere, count); CHKERR(rval, "connect_iterate.");
+  assert(count == (int) quads.size()); // should end up with just one contiguous chunk of quads
+  double *x_ptr, *y_ptr, *z_ptr;
+  rval = mbImpl->coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count); CHKERR(rval, "coords_iterate.");
+  assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
+  double *tag1_ptr, *tag2_ptr;
+  int *tag3_ptr;
+  rval = mbImpl->tag_iterate(tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr); CHKERR(rval, "tag1_iterate.");
+  rval = mbImpl->tag_iterate(tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr); CHKERR(rval, "tag2_iterate.");
+  rval = mbImpl->tag_iterate(tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr); CHKERR(rval, "tag3_iterate.");
+  const std::vector<EntityHandle> **adjs_ptr;
+  rval = mbImpl->adjacencies_iterate(verts.begin(), verts.end(), adjs_ptr, count); CHKERR(rval, "adjacencies_iterate.");
+    // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction because we know
+    // there aren't any holes in the handle spaces for verts or quads
+  EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin();
+    // iterate over elements, computing tag1 from coords positions
+  for (int i = 0; i < nquads; i++) {
+    tag1_ptr[3*i+0] = tag1_ptr[3*i+1] = tag1_ptr[3*i+2] = 0.0; // initialize position for this element
+    for (int j = 0; j < vpere; j++) { // loop over vertices in this element
+      int v_index = conn_ptr[vpere*i+j] - start_vert; // vert index is just the offset from start vertex
+      tag1_ptr[3*i+0] += x_ptr[v_index];
+      tag1_ptr[3*i+1] += y_ptr[v_index]; // sum vertex positions into tag1...
+      tag1_ptr[3*i+2] += z_ptr[v_index];
+    tag1_ptr[3*i+0] /= vpere;
+    tag1_ptr[3*i+1] /= vpere; // then normalize
+    tag1_ptr[3*i+2] /= vpere;
+  } // loop over elements in chunk
+    // Iterate through vertices, summing positions into tag2 on connected elements and incrementing vertex count
+  for (int v = 0; v < count; v++) {
+    const std::vector<EntityHandle> *avec = *(adjs_ptr+v);
+    for (std::vector<EntityHandle>::const_iterator ait = avec->begin(); ait != avec->end(); ait++) {
+        // *ait is the quad handle, its index is computed by subtracting the start quad handle
+      int a_ind = *ait - start_quad;
+      tag2_ptr[3*a_ind+0] += x_ptr[v];   // tag on each element is 3 doubles, x/y/z
+      tag2_ptr[3*a_ind+1] += y_ptr[v];
+      tag2_ptr[3*a_ind+2] += z_ptr[v];
+      tag3_ptr[a_ind]++;  // increment the vertex count
+    // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before
+    // At the same time, compare values of tag1 and tag2
+  int n_dis = 0;
+  for (Range::iterator q_it = quads.begin(); q_it != quads.end(); q_it++) {
+    int i = *q_it - start_quad;
+    for (int j = 0; j < 3; j++) tag2_ptr[3*i+j] /= (double)tag3_ptr[i];  // normalize by # verts
+    if (tag1_ptr[3*i] != tag2_ptr[3*i] || tag1_ptr[3*i+1] != tag2_ptr[3*i+1] || tag1_ptr[3*i+2] != tag2_ptr[3*i+2]) {
+      std::cout << "Tag1, tag2 disagree for element " << *q_it + i << std::endl;
+      n_dis++;
+  if (!n_dis) std::cout << "All tags agree, success!" << std::endl;
+    // Ok, we're done, shut down MOAB
+  delete mbImpl;
+  return 0;
+    // first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ReadUtilIface *read_iface;
+  ErrorCode rval = mbImpl->query_interface(read_iface); CHKERR(rval, "query_interface");
+  std::vector<double *> coords;
+  EntityHandle start_vert, start_elem, *connect;
+    // create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop over quads later
+  rval = read_iface->get_node_coords (3, 2*(nquads+1), 0, start_vert, coords); CHKERR(rval, "get_node_arrays");
+    // create quads
+  rval = read_iface->get_element_connect(nquads, 4, MBQUAD, 0, start_elem, connect); CHKERR(rval, "get_element_connect");
+    coords[0][2*i] = coords[0][2*i+1] = (double) i; // x values are all i
+    coords[1][2*i] = 0.0; coords[1][2*i+1] = 1.0; // y coords
+    coords[2][2*i] = coords[2][2*i+1] = (double) 0.0; // z values, all zero (2d mesh)
+    EntityHandle quad_v = start_vert + 2*i;
+    connect[4*i+0] = quad_v;
+    connect[4*i+1] = quad_v+2;
+    connect[4*i+2] = quad_v+3;
+    connect[4*i+3] = quad_v+1;
+    // last two vertices
+  coords[0][2*nquads] = coords[0][2*nquads+1] = (double) nquads;
+  coords[1][2*nquads] = 0.0; coords[1][2*nquads+1] = 1.0; // y coords
+  coords[2][2*nquads] = coords[2][2*nquads+1] = (double) 0.0; // z values, all zero (2d mesh)
+    // call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB
+  Range dum_range;
+  rval = mbImpl->get_adjacencies(&start_vert, 1, 2, false, dum_range); CHKERR(rval, "get_adjacencies");
+  assert(!dum_range.empty());
+  return MB_SUCCESS;
diff --git a/examples/DirectAccessNoHolesF90.F90 b/examples/DirectAccessNoHolesF90.F90
index 0000000..3cf5fa7
--- /dev/null
+++ b/examples/DirectAccessNoHolesF90.F90
@@ -0,0 +1,231 @@
+! @example DirectAccessNoHolesF90.F90 \n
+! \brief Use direct access to MOAB data to avoid calling through API, in Fortran90 \n
+! This example creates a 1d row of quad elements, such that all quad and vertex handles
+! are contiguous in the handle space and in the database.  Then it shows how to get access
+! to pointers to MOAB-native data for vertex coordinates, quad connectivity, and tag storage
+! (vertex to quad adjacency lists aren't accessible from Fortran because they are std::vector's).
+! This allows applications to access this data directly
+! without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+! vertices are moving), this can save significant execution time in applications.
+! Using direct access (or MOAB in general) from Fortran is complicated in two specific ways:
+! 1) There is no way to use arrays with specified dimension starting/ending values with ISO_C_BINDING;
+!    therefore, all arrays passed back from MOAB/iMesh must use 1-based indices; this makes it a bit
+!    more difficult to traverse the direct arrays.  In this example, I explicitly use indices that
+!    look like my_array(1+v_ind...) to remind users of this.
+! 2) Arithmetic on handles is complicated by the fact that Fortran has no unsigned integer type.  I get
+!    around this by assigning to a C-typed variable first, before the handle arithmetic.  This seems to
+!    work fine.  C-typed variables are part of the Fortran95 standard.
+!    -#  Initialize MOAB \n
+!    -#  Create a quad mesh, as depicted above
+!    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+!    -#  Get connectivity, coordinate, tag1 iterators
+!    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+!    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+!    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+! <b>To compile</b>: \n
+!    make DirectAccessNoHolesF90 MOAB_DIR=<installdir>  \n
+! <b>To run</b>: ./DirectAccessNoHolesF90 [-nquads <# quads>]\n
+#define CHECK(a) \
+  if (a .ne. iBase_SUCCESS) call exit(a)
+module freem
+  interface
+     subroutine c_free(ptr) bind(C, name='free')
+       use ISO_C_BINDING
+       type(C_ptr), value, intent(in) :: ptr
+     end subroutine c_free
+  end interface
+end module freem
+program DirectAccessNoHolesF90
+  use ISO_C_BINDING
+  use freem
+  implicit none
+#include "iMesh_f.h"
+  ! declarations
+  iMesh_Instance imesh
+  iBase_EntitySetHandle root_set
+  integer ierr, nquads, nquads_tmp, nverts
+  iBase_TagHandle tag1h, tag2h, tag3h
+  TYPE(C_PTR) verts_ptr, quads_ptr, conn_ptr, x_ptr, y_ptr, z_ptr, tag1_ptr, tag2_ptr, tag3_ptr, &
+       tmp_quads_ptr, offsets_ptr  ! pointers that are equivalence'd to arrays using c_f_pointer
+  real(C_DOUBLE), pointer :: x(:), y(:), z(:), tag1(:), tag2(:) ! arrays equivalence'd to pointers
+  integer, pointer :: tag3(:), offsets(:)                       ! arrays equivalence'd to pointers
+  iBase_EntityHandle, pointer :: quads(:), verts(:), conn(:), tmp_quads(:)  ! arrays equivalence'd to pointers
+  iBase_EntityArrIterator viter, qiter
+  integer(C_SIZE_T) :: startv, startq, v_ind, e_ind  ! needed to do handle arithmetic
+  integer count, vpere, e, i, j, v, offsets_size, tmp_quads_size, n_dis
+  character*120 opt
+  ! initialize interface and get root set
+  call iMesh_newMesh("", imesh, ierr); CHECK(ierr)
+  call iMesh_getRootSet(%VAL(imesh), root_set, ierr); CHECK(ierr)
+  ! create mesh
+  nquads_tmp = 1000
+  call create_mesh_no_holes(imesh, nquads_tmp, ierr); CHECK(ierr)
+  ! get all vertices and quads as arrays
+  nverts = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(0), %VAL(iBase_VERTEX), &
+       verts_ptr, nverts, nverts, ierr); CHECK(ierr)
+  call c_f_pointer(verts_ptr, verts, [nverts])
+  nquads = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(2), %VAL(iMesh_QUADRILATERAL), &
+       quads_ptr, nquads, nquads, ierr); CHECK(ierr)
+  call c_f_pointer(quads_ptr, quads, [nquads])
+  ! First vertex/quad is at start of vertex/quad list, and is offset for vertex/quad index calculation
+  startv = verts(1); startq = quads(1)
+  call c_free(quads_ptr)  ! free memory we allocated in MOAB
+  ! create tag1 (element-based avg), tag2 (vertex-based avg)
+  opt = 'moab:TAG_STORAGE_TYPE=DENSE moab:TAG_DEFAULT_VALUE=0'
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag1', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag1h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag2', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag2h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  ! Get iterator to verts, then pointer to coordinates
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_VERTEX), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nverts), %VAL(0), viter, ierr); CHECK(ierr)
+  call iMesh_coordsIterate(%VAL(imesh), %VAL(viter), x_ptr, y_ptr, z_ptr, count, ierr); CHECK(ierr)
+  CHECK(count-nverts) ! check that all verts are in one contiguous chunk
+  call c_f_pointer(x_ptr, x, [nverts]); call c_f_pointer(y_ptr, y, [nverts]); call c_f_pointer(z_ptr, z, [nverts])
+  ! Get iterator to quads, then pointers to connectivity and tags
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_FACE), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nquads), %VAL(0), qiter, ierr); CHECK(ierr)
+  call iMesh_connectIterate(%VAL(imesh), %VAL(qiter), conn_ptr, vpere, count, ierr); CHECK(ierr)
+  call c_f_pointer(conn_ptr, conn, [vpere*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag1h), %VAL(qiter), tag1_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag1_ptr, tag1, [3*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag2h), %VAL(qiter), tag2_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag2_ptr, tag2, [3*nquads])
+  ! iterate over elements, computing tag1 from coords positions; use (1+... in array indices for 1-based indexing
+  do i = 0, nquads-1
+     tag1(1+3*i+0) = 0.0; tag1(1+3*i+1) = 0.0; tag1(1+3*i+2) = 0.0 ! initialize position for this element
+     do j = 0, vpere-1 ! loop over vertices in this quad
+        v_ind = conn(1+vpere*i+j) ! assign to v_ind to allow handle arithmetic
+        v_ind = v_ind - startv ! vert index is just the offset from start vertex
+        tag1(1+3*i+0) = tag1(1+3*i+0) + x(1+v_ind)
+        tag1(1+3*i+1) = tag1(1+3*i+1) + y(1+v_ind) ! sum vertex positions into tag1...
+        tag1(1+3*i+2) = tag1(1+3*i+2) + z(1+v_ind)
+     end do
+     tag1(1+3*i+0) = tag1(1+3*i+0) / vpere;
+     tag1(1+3*i+1) = tag1(1+3*i+1) / vpere; ! then normalize
+     tag1(1+3*i+2) = tag1(1+3*i+2) / vpere;
+  end do ! loop over elements in chunk
+  ! Iterate through vertices, summing positions into tag2 on connected elements; get adjacencies all at once,
+  ! could also get them per vertex (time/memory tradeoff)
+  tmp_quads_size = 0
+  offsets_size = 0
+  call iMesh_getEntArrAdj(%VAL(imesh), verts, %VAL(nverts), %VAL(iMesh_QUADRILATERAL), &
+       tmp_quads_ptr, tmp_quads_size, tmp_quads_size, &
+       offsets_ptr, offsets_size, offsets_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_quads_ptr, tmp_quads, [tmp_quads_size])
+  call c_f_pointer(offsets_ptr, offsets, [offsets_size])
+  call c_free(verts_ptr)  ! free memory we allocated in MOAB
+  do v = 0, nverts-1
+     do e = 1+offsets(1+v), 1+offsets(1+v+1)-1  ! 1+ because offsets are in terms of 0-based arrays
+        e_ind = tmp_quads(e) ! assign to e_ind to allow handle arithmetic
+        e_ind = e_ind - startq ! e_ind is the quad handle minus the starting quad handle
+        tag2(1+3*e_ind+0) = tag2(1+3*e_ind+0) + x(1+v)
+        tag2(1+3*e_ind+1) = tag2(1+3*e_ind+1) + y(1+v)   ! tag on each element is 3 doubles, x/y/z
+        tag2(1+3*e_ind+2) = tag2(1+3*e_ind+2) + z(1+v)
+     end do
+  end do
+  call c_free(tmp_quads_ptr)  ! free memory we allocated in MOAB
+  call c_free(offsets_ptr)    ! free memory we allocated in MOAB
+  ! Normalize tag2 by vertex count (vpere); loop over elements using same approach as before
+  ! At the same time, compare values of tag1 and tag2
+  n_dis = 0
+  do e = 0, nquads-1
+     do j = 0, 2
+        tag2(1+3*e+j) = tag2(1+3*e+j) / vpere;  ! normalize by # verts
+     end do
+     if (tag1(1+3*e) .ne. tag2(1+3*e) .or. tag1(1+3*e+1) .ne. tag2(1+3*e+1) .or. tag1(1+3*e+2) .ne. tag2(1+3*i+2)) then
+        print *, "Tag1, tag2 disagree for element ", e
+        print *, "tag1: ", tag1(1+3*e), tag1(1+3*e+1), tag1(1+3*e+2)
+        print *, "tag2: ", tag2(1+3*e), tag2(1+3*e+1), tag2(1+3*e+2)
+        n_dis = n_dis + 1
+     end if
+  end do
+  if (n_dis .eq. 0) print *, 'All tags agree, success!'
+    ! Ok, we are done, shut down MOAB
+  call iMesh_dtor(%VAL(imesh), ierr)
+  return
+end program DirectAccessNoHolesF90
+subroutine create_mesh_no_holes(imesh, nquads, ierr)
+  use ISO_C_BINDING
+  use freem
+  implicit none
+  integer nquads, ierr
+  real(C_DOUBLE), pointer :: coords(:,:)
+  TYPE(C_PTR) connect_ptr, tmp_ents_ptr, stat_ptr
+  iBase_EntityHandle, pointer :: connect(:), tmp_ents(:)
+  integer, pointer :: stat(:)
+  integer nverts, tmp_size, stat_size, i
+  ! first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ! create verts, num is 2(nquads+1) because they're in a 1d row
+  nverts = 2*(nquads+1)
+  allocate(coords(0:2, 0:nverts-1))
+     coords(0,2*i) = i; coords(0,2*i+1) = i ! x values are all i
+     coords(1,2*i) = 0.0; coords(1,2*i+1) = 1.0 ! y coords
+     coords(2,2*i) = 0.0; coords(2,2*i+1) = 0.0 ! z values, all zero (2d mesh)
+  end do
+  ! last two vertices
+  coords(0, nverts-2) = nquads; coords(0, nverts-1) = nquads
+  coords(1, nverts-2) = 0.0; coords(1, nverts-1) = 1.0 ! y coords
+  coords(2, nverts-2) = 0.0; coords(2, nverts-1) = 0.0 ! z values, all zero (2d mesh)
+  tmp_size = 0
+  call iMesh_createVtxArr(%VAL(imesh), %VAL(nverts), %VAL(iBase_INTERLEAVED), &
+       coords, %VAL(3*nverts), tmp_ents_ptr, tmp_size, tmp_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_ents_ptr, tmp_ents, [nverts])
+  deallocate(coords)
+  allocate(connect(0:4*nquads-1))
+     connect(4*i+0) = tmp_ents(1+2*i)
+     connect(4*i+1) = tmp_ents(1+2*i+2)
+     connect(4*i+2) = tmp_ents(1+2*i+3)
+     connect(4*i+3) = tmp_ents(1+2*i+1)
+  end do
+  stat_size = 0
+  stat_ptr = C_NULL_PTR
+  ! re-use tmp_ents here; we know it'll always be larger than nquads so it's ok
+  call iMesh_createEntArr(%VAL(imesh), %VAL(iMesh_QUADRILATERAL), connect, %VAL(4*nquads), &
+       tmp_ents_ptr, tmp_size, tmp_size, stat_ptr, stat_size, stat_size, ierr); CHECK(ierr)
+  ierr = iBase_SUCCESS
+  call c_free(tmp_ents_ptr)
+  call c_free(stat_ptr)
+  deallocate(connect)
+  return
+end subroutine create_mesh_no_holes
diff --git a/examples/DirectAccessWithHoles.cpp b/examples/DirectAccessWithHoles.cpp
index 0000000..524c30f
--- /dev/null
+++ b/examples/DirectAccessWithHoles.cpp
@@ -0,0 +1,239 @@
+/** @example DirectAccess.cpp \n
+ * This example creates a 1d row of quad elements, with a user-specified number of "holes" (missing quads) in the row:
+ *  |      |      |      |(hole)|      |      |      |(hole)|      | ...
+ * This makes (nholes+1) contiguous runs of quad handles in the handle space
+ * This example shows how to use the xxx_iterate functions in MOAB (xxx = coords, connect, tag, adjacencies) to get
+ * direct pointer access to MOAB internal storage, which can be used without calling through the MOAB API.
+ *    -#  Create a quad mesh with holes, as depicted above
+ *    -#  Set up map from starting quad handle for a chunk to struct of (tag1_ptr, tag2_ptr, tag3_ptr), pointers to
+ *        the dense tag storage for those tags for the chunk
+ *    make DirectAccessWithHoles MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: ./DirectAccess [-nquads <# quads>] [-holes <# holes>]\n
+#include <map>
+ErrorCode create_mesh_with_holes(Interface *mbImpl, int nquads, int nholes);
+struct tag_struct {double *avg_ptr; int *nv_ptr;};
+  int nquads = 1000, nholes = 1;
+    // parse options
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("holes,H"), std::string("Number of holes in the element handle space (default = 1"), &nholes);
+  if (nholes >= nquads) {
+    std::cerr << "Number of holes needs to be < number of elements." << std::endl;
+    return 1;
+  ErrorCode rval = create_mesh_with_holes(mbImpl, nquads, nholes); CHKERR(rval, "Trouble creating mesh.");
+  Range verts, elems;
+  rval = mbImpl->get_entities_by_handle(0, elems); CHKERR(rval, "Getting all entities.");
+  verts = elems.subset_by_dimension(0);
+  elems -= verts;
+    // Get connectivity, coordinate, tag, and adjacency iterators
+  double *x_ptr, *y_ptr, *z_ptr, *tag1_ptr, *tag2_ptr;
+  int *tag3_ptr;
+    // First vertex is at start of range (ranges are sorted), and is offset for vertex index calculation
+  EntityHandle first_vert = *verts.begin();
+    // When iterating over elements, each chunk can have a different # vertices; also, count tells you how many
+    // elements are in the current chunk
+  int vpere, count;
+    // Get coordinates iterator, just need this once because we know verts handle space doesn't have holes
+    // Iterate through elements, computing midpoint based on vertex positions, set on element-based tag1
+    // Control loop by iterator over elem range
+  Range::iterator e_it = elems.begin();
+  while (e_it != elems.end()) {
+      // get conn_ptr, tag1_ptr for next contiguous chunk of element handles, and coords pointers for all verts
+    rval = mbImpl->connect_iterate(e_it, elems.end(), conn_ptr, vpere, count); CHKERR(rval, "connect_iterate.");
+    rval = mbImpl->tag_iterate(tag1, e_it, elems.end(), count, (void*&)tag1_ptr); CHKERR(rval, "tag1_iterate.");
+      // iterate over elements in this chunk
+    for (int i = 0; i < count; i++) {
+      tag1_ptr[0] = tag1_ptr[1] = tag1_ptr[2] = 0.0; // initialize position for this element
+        int v_index = conn_ptr[j] - first_vert; // vert index is just the offset from first vertex
+        tag1_ptr[0] += x_ptr[v_index];
+        tag1_ptr[1] += y_ptr[v_index]; // sum vertex positions into tag1...
+        tag1_ptr[2] += z_ptr[v_index];
+      tag1_ptr[0] /= vpere;
+      tag1_ptr[1] /= vpere; // then normalize
+      tag1_ptr[2] /= vpere;
+        // done with this element; advance connect_ptr and tag1_ptr to next element
+      conn_ptr += vpere;
+      tag1_ptr += 3;
+      // done with chunk; advance range iterator by count; will skip over gaps in range
+    e_it += count;
+  } // while loop over all elements
+    // Iterate over chunks the same as elements, even though we know we have only one chunk here, just to show
+    // how it's done
+    // Create a std::map from EntityHandle (first entity handle in chunk) to
+    // tag_struct (ptrs to start of avg/#verts tags for that chunk); then for a given entity handle, we can quickly
+    // find the chunk it's in using map::lower_bound; could have set up this map in earlier loop over elements, but do
+    // it here for clarity
+  std::map< EntityHandle, tag_struct> elem_map;
+  e_it = elems.begin();
+    tag_struct ts = {NULL, NULL};
+    rval = mbImpl->tag_iterate(tag2, e_it, elems.end(), count, (void*&)ts.avg_ptr); CHKERR(rval, "tag2_iterate.");
+    rval = mbImpl->tag_iterate(tag3, e_it, elems.end(), count, (void*&)ts.nv_ptr); CHKERR(rval, "tag3_iterate.");
+    elem_map[*e_it] = ts;
+    e_it += count;
+  Range::iterator v_it = verts.begin();
+  Range dum_range;
+  rval = mbImpl->get_adjacencies(&(*v_it), 1, 2, false, dum_range); CHKERR(rval, "get_adjacencies");
+  while (v_it != verts.end()) {
+      // get coords ptrs, adjs_ptr; can't set tag2_ptr by direct access, because of hole in element handle space
+    rval = mbImpl->coords_iterate(v_it, verts.end(), x_ptr, y_ptr, z_ptr, count); CHKERR(rval, "coords_iterate.");
+    rval = mbImpl->adjacencies_iterate(v_it, verts.end(), adjs_ptr, count); CHKERR(rval, "adjacencies_iterate.");
+          // get chunk that this element resides in; upper_bound points to the first element strictly > key, so get that and decrement
+          // (would work the same as lower_bound with an if-test and decrement)
+        std::map<EntityHandle, tag_struct>::iterator mit = elem_map.upper_bound(*ait); mit--;
+          // index of *ait in that chunk
+        int a_ind = *ait - (*mit).first;
+        tag_struct ts = (*mit).second;
+        ts.avg_ptr[3*a_ind]   += x_ptr[v];   // tag on each element is 3 doubles, x/y/z
+        ts.avg_ptr[3*a_ind+1] += y_ptr[v];
+        ts.avg_ptr[3*a_ind+2] += z_ptr[v];
+        ts.nv_ptr[a_ind]++;  // increment the vertex count
+    v_it += count;
+    // Normalize tag2 by vertex count; loop over elements using same approach as before
+    rval = mbImpl->tag_iterate(tag2, e_it, elems.end(), count, (void*&)tag2_ptr); CHKERR(rval, "tag2_iterate.");
+    rval = mbImpl->tag_iterate(tag3, e_it, elems.end(), count, (void*&)tag3_ptr); CHKERR(rval, "tag3_iterate.");
+        std::cout << "Tag1, tag2 disagree for element " << *e_it + i << std::endl;
+    e_it += count;
+  delete mbImpl;
+  return 0;
+    // create verts, num is 4(nquads+1) because they're in a 1d row; will initialize coords in loop over elems later
+    // create elems
+    for (int j = 0; j < 4; j++) connect[4*i+j] = quad_v+j; // connectivity of each quad is a sequence starting from quad_v
+    // now delete nholes elements, spaced approximately equally through mesh, so contiguous size is about nquads/(nholes+1)
+    // reinterpret start_elem as the next element to be deleted
+  int de = nquads / (nholes + 1);
+  for (int i = 0; i < nholes; i++) {
+    start_elem += de;
+    rval = mbImpl->delete_entities(&start_elem, 1); CHKERR(rval, "delete_entities");
diff --git a/examples/FileRead.cpp b/examples/FileRead.cpp
index bff9e28..0000000
--- a/examples/FileRead.cpp
+++ /dev/null
@@ -1,164 +0,0 @@
-#include <iostream>
-#include <fstream>
-#include <vector>
-#include <string>
-#include <sstream>
-#include "moab/Core.hpp"
-#include "moab/ReadUtilIface.hpp"
-using namespace std;
-using namespace moab;
-int comment(string & line)
-    // if a line starts with '#' is a comment
-    // eat white space characters
-    size_t found=line.find_first_not_of(" \t");
-    if (found==string::npos)
-	return 1; // empty line
-    if ('#'==line[found])
-        return 1; // a comment indeed
-    return 0; // a line with some data in it, then
-ErrorCode ReadTriangleOutput( Interface *mb, string fileBase ) {
-  // get the read interface from moab
-  ReadUtilIface *iface;
-  ErrorCode rval = mb->query_interface(iface);
-  if (MB_SUCCESS != rval)
-        cout<<"Can't get interface.\n";
-        return MB_FAILURE;
-  // Triangle default <name>.node
-  string nodeFileName = fileBase+".node";
-  ifstream nodeFile (nodeFileName.c_str());
-  if (!nodeFile.is_open())
-     cout<<"can't open node file .\n";
-     return MB_FILE_DOES_NOT_EXIST;
-  cout << "reading nodes from file " << nodeFileName.c_str() << endl;
-  string eleFileName = fileBase+".ele";
-  ifstream eleFile (eleFileName.c_str());
-  if (!eleFile.is_open())
-     cout<<"can't open element file .\n";
-  cout << "reading elements from file " << eleFileName.c_str() << endl;
-  string line;
-  // ignore comment lines that start with #
-  int num_nodes=0, num_triangles=0;
-  while(num_nodes==0)
-      getline(nodeFile, line);
-      if (comment(line))
-	continue;
-      stringstream tks(line);
-      tks >> num_nodes; // ignore the rest of the first line
-                        // maybe will read attributes some other time
-      cout << "num nodes:" << num_nodes << endl;
-  //  allocate a block of vertex handles and read xyz’s into them
-  //  we know the size of the node arrays, and this call will allocate
-  //   needed arrays, coordinate arrays
-  //   also, it will return a starting handle for the node sequence
-  vector<double*> arrays;
-  EntityHandle startv;
-  rval = iface->get_node_coords(2, num_nodes, 0, startv, arrays);
-  for (int i = 0; i < num_nodes; i++)
-        i--;// read one more line
-	continue;
-      stringstream tokens(line);
-      int nodeId;
-      tokens >> nodeId >> arrays[0][i] >> arrays[1][i] ;
-  // now read the element data from a different file
-  // first, find out how many elements are out there
-  // first line with data should have it
-  while(num_triangles==0)
-      getline(eleFile, line);
-	continue;
-      tks >> num_triangles; // ignore the rest of the line
-      cout << "num triangles:" << num_triangles << endl;
-  EntityHandle starte;
-  EntityHandle *starth; // the connectivity array that will get populated
-                          // with triangle data
-  // allocate block of triangle handles and read connectivity into them
-  rval = iface->get_element_connect(num_triangles, 3, MBTRI, 0, starte, starth);
-  for (int j = 0; j < num_triangles; j++)
-        j--;// read one more line
-	continue;
-      int eleId;
-      unsigned int node;
-      tokens >> eleId;
-      for (int k=0; k<3; k++)
-	  tokens >> node;
-          // vertex handles start at startv
-            starth[3*j+k] = startv + node - 1;
-  mb->release_interface(iface);
-  return MB_SUCCESS;
-//  Read Triangle output files
-//  Assume that the format is <filename>.node and <filename>.ele
-//   see  http://www.cs.cmu.edu/~quake/triangle.html for details
-int main(int argc, char **argv) {
-  if (3!=argc) {
-    cout << "Usage: " << argv[0] << " <filename><outFile> " << endl;
-    cout << "       <filename>  is the base file name; *.ele and *.node file are read; outFile is a file with an extension recognized by MOAB " << endl;
-    return 0;
-  string filename = argv[1];
-  char * outfile = argv[2];
-  // get MOAB instance and read the file
-  Core *mb = new Core();
-   ErrorCode rval = ReadTriangleOutput(mb, filename);
-   if (rval==MB_SUCCESS)
-     cout << "Writing output file " << outfile << endl;
-     mb->write_file(outfile);
-   return 0;
diff --git a/examples/GeomSetHierarchy.cpp b/examples/GeomSetHierarchy.cpp
index a49dafe..0000000
--- a/examples/GeomSetHierarchy.cpp
+++ /dev/null
@@ -1,83 +0,0 @@
-#include "moab/Range.hpp"
-#include "MBCN.hpp"
-#include "MBTagConventions.hpp"
-#include "moab/GeomTopoTool.hpp"
-const char *ent_names[] = {"Vertex", "Edge", "Face", "Region"};
-  if (1 == argc) {
-    std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
-    return 0;
-    // instantiate & load a file
-  moab::Interface *mb = new moab::Core();
-  moab::ErrorCode rval = mb->load_file(argv[1]);
-    // get the geometric topology tag handle
-  moab::Tag geom_tag, gid_tag;
-  rval = mb->tag_get_handle(GEOM_DIMENSION_TAG_NAME, 1, moab::MB_TYPE_INTEGER, geom_tag);
-  rval = mb->tag_get_handle(GLOBAL_ID_TAG_NAME, 1, moab::MB_TYPE_INTEGER, gid_tag);
-    // traverse the model, from dimension 3 downward
-  moab::Range psets, chsets;
-  std::vector<moab::EntityHandle> sense_ents;
-  std::vector<int> senses, pgids;
-  int dim, pgid, chgid;
-  void *dim_ptr = &dim;
-  int sense;
-  moab::GeomTopoTool gt(mb, true);
-  for (dim = 3; dim >= 0; dim--) {
-      // get parents at this dimension
-    chsets.clear();
-    rval = mb->get_entities_by_type_and_tag(0, MBENTITYSET,
-                                            &geom_tag, &dim_ptr, 1,
-                                            chsets, 1, false);
-      // for each child, get parents and do something with them
-    moab::Range::iterator ch_it, p_it;
-    for (ch_it = chsets.begin(); ch_it != chsets.end(); ch_it++) {
-        // get the children and put in child set list
-      psets.clear();
-      rval = mb ->get_parent_meshsets(*ch_it, psets);
-      rval = mb->tag_get_data(gid_tag, &(*ch_it), 1, &chgid);
-        // print # parents
-      std::cout << ent_names[dim] << " " << chgid << " has " << psets.size()
-                << " parents." << std::endl;
-      if (2 == dim) {
-        for (p_it = psets.begin(); p_it != psets.end(); p_it++) {
-          rval = mb->tag_get_data(gid_tag, &(*p_it), 1, &pgid);
-          rval = gt.get_sense(*ch_it, *p_it, sense);
-          if (moab::MB_SUCCESS != rval) continue;
-          std::cout << ent_names[dim+1] << " "   << pgid << ", "
-                    << ent_names[dim] << " " << chgid << " sense is: ";
-          if (1==sense) std::cout << "FORWARD" << std::endl;
-          else std::cout << "REVERSE" << std::endl;
-      else if (1 == dim) {
-        sense_ents.clear();
-        senses.clear();
-        rval = gt.get_senses(*ch_it, sense_ents, senses);
-        for (unsigned int i = 0; i < sense_ents.size(); i++) {
-          rval = mb->tag_get_data(gid_tag, &sense_ents[i], 1, &pgid);
-          if (-1 == senses[i]) std::cout << "REVERSED" << std::endl;
-          else if (0 == senses[i]) std::cout << "BOTH" << std::endl;
-          else if (1 == senses[i]) std::cout << "FORWARD" << std::endl;
-          else std::cout << "(invalid)" << std::endl;
diff --git a/examples/HelloMOAB.cpp b/examples/HelloMOAB.cpp
index 0000000..ebab971
--- /dev/null
+++ b/examples/HelloMOAB.cpp
@@ -0,0 +1,64 @@
+/** @example HelloMOAB.cpp
+ * Description: read a mesh, get the entities.\n
+ * HelloMOAB is a simple test file which is used to read meshes from VTK file and test how many entities there are.\n
+ * To run: ./HelloMOAB <meshfile>\n
+ * (default values can run if users don't specify a mesh file)
+using namespace std;
+string test_file_name = string(MESH_DIR) + string("/3k-tri-sphere.vtk");
+int main( int argc, char** argv )
+  Interface *iface = new Core;
+    // need option handling here for input filename
+  if (argc > 1){
+    //user has input a mesh file
+    test_file_name = argv[1];
+    //load the mesh from vtk file
+  ErrorCode rval = iface->load_mesh( test_file_name.c_str() );
+  assert( rval == MB_SUCCESS);
+    //get verts entities
+  Range verts;
+  rval = iface->get_entities_by_type(0, MBVERTEX, verts);
+    //get edge entities
+  Range edges;
+  rval = iface->get_entities_by_type(0, MBEDGE, edges);
+  assert(rval == MB_SUCCESS);
+    //get triangular entities
+  Range tri;
+  rval = iface->get_entities_by_type(0, MBTRI, tri);
+    //get quad entities
+  Range quads;
+  rval = iface->get_entities_by_type(0, MBQUAD, quads);
+    //get hex entities
+  Range hex;
+  rval = iface->get_entities_by_type(0, MBHEX, hex);
+   //output the number of entities
+  cout << "Number of vertices is " << verts.size() <<  endl;
+  cout << "Number of edges is " << edges.size() <<  endl;
+  cout << "Number of triangular faces is " << tri.size() <<  endl;
+  cout << "Number of quad faces is " << quads.size() <<  endl;
+  cout << "Number of hex is " << hex.size() <<  endl;
+  return 0;
diff --git a/examples/HelloMoabPar.cpp b/examples/HelloMoabPar.cpp
index 0000000..a5a71aa
--- /dev/null
+++ b/examples/HelloMoabPar.cpp
@@ -0,0 +1,154 @@
+/** @example HelloMoabPar.cpp \n
+ * \brief Read mesh into MOAB in parallel \n
+ * This example shows the simplest way of telling MOAB to read in parallel.
+ *    -#  Initialize MPI and get the rank and number of processors \n
+ *    -#  Process arguments (file name and options for parallel read) \n
+ *    -#  Load a partitioned file in parallel; \n
+ *    -#  retrieve shared entities on each processor \n
+ *    -#  Filter owned entities among shared ones on each processor \n
+ *    -#  Exchange ghost layers, and repeat the reports \n
+ *    make HelloMoabPar MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: mpiexec -np 4 HelloMoabPar \n
+ *  (depending on your configuration, LD_LIBRARY_PATH may need to contain <hdf5>/lib folder)
+#include "moab/ParallelComm.hpp"
+#include "MBParallelConventions.h"
+  MPI_Init(&argc, &argv);
+  int nprocs, rank;
+  MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  std::string filename;
+  std::string options;
+  if (3 != argc)
+    if (rank == 0)
+      std::cout << "Usage: " << argv[0] << " <filename><options (separated by;)>\n ";
+    /* this file has a partition with 4 parts */
+    filename = "../MeshFiles/unittest/disk.h5m";
+    /*  Options for reading
+     *  - read in parallel
+     *  - use PARALLEL_PARTITION tag
+     *  - resolve shared entities after reading
+    options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
+  else
+    filename = argv[1];
+    options = argv[2];
+  if (rank == 0)
+    std::cout << "reading file " << filename << "\n  with options:" << options <<
+      "\n  on " << nprocs << " processors\n";
+  // get MOAB instance and read the file with the specified options
+  ErrorCode rval = mbImpl->load_file(filename.c_str(), 0, options.c_str());
+  if (rval != MB_SUCCESS) return 1;
+  // get the ParallelComm instance
+  ParallelComm* pcomm = ParallelComm::get_pcomm(mbImpl, 0);
+  MPI_Comm comm = pcomm->comm();
+  if (0 == pcomm) return 1;
+  // get all shared entities with other processors
+  Range shared_ents;
+  rval = pcomm->get_shared_entities(-1, // -1 means all other processors                                    Range &shared_ents,
+      shared_ents);
+  /* Among shared entities, get those owned by the current processor
+   * For this, use a filter operation;
+   * Each shared entity is owned by exactly one processor;
+   * An entity could be simply-shared (with exactly one other processor) or
+   *  multi-shared.
+  Range owned_entities;
+  rval = pcomm->filter_pstatus(shared_ents, // pass entities that we want to filter
+      PSTATUS_NOT_OWNED, // status we are looking for
+      PSTATUS_NOT, // operation applied ; so it will return owned entities (!not_owned = owned)
+      -1, // this means all processors
+      &owned_entities);
+  unsigned int nums[4]={0}; // to store the owned entities per dimension
+  for (int i=0; i<3; i++)
+    nums[i]=(int)owned_entities.num_of_dimension(i);
+  int * rbuf;
+  if (rank==0)
+    rbuf = (int *)malloc(nprocs*4*sizeof(int));
+  MPI_Gather( nums, 4, MPI_INT, rbuf, 4, MPI_INT, 0, comm);
+  // print the stats gathered:
+  if (rank == 0)
+    for (int i=0; i<nprocs; i++)
+      std::cout << " shared, owned entities on proc " << i << " :" << rbuf[4*i] << " verts, " <<
+          rbuf[4*i+1] << " edges, " << rbuf[4*i+2] << " faces\n";
+   * Now exchange 1 layer of ghost elements, using vertices as bridge
+   *   we could have done this as part of reading process, by passing an extra read option
+   *    ";PARALLEL_GHOSTS=2.0.1.0"
+  rval = pcomm->exchange_ghost_cells(2, // int ghost_dim,
+                                     0, // int bridge_dim,
+                                     1, //int num_layers,
+                                     0, //int addl_ents,
+                                     true); // bool store_remote_handles);
+  // repeat the reports, after ghost exchange
+  shared_ents.clear();
+  owned_entities.clear();
+        shared_ents);
+        PSTATUS_NOT,
+        -1,
+        &owned_entities);
+  // find out how many shared entities of each dimension are owned on this processor
+  // gather the statistics on processor 0
+  if (rank == 0)
+    std::cout << " \n\n After exchanging one ghost layer: \n";
+    free(rbuf);
+  MPI_Finalize();
+  return 0;
diff --git a/examples/KDTree.cpp b/examples/KDTree.cpp
index f402ca1..0000000
--- a/examples/KDTree.cpp
+++ /dev/null
@@ -1,154 +0,0 @@
-/* Simple example of use of moab::AdaptiveKDTree class.
-   Given a hexahedral mesh, find the hexahedron containing each
-   input position.
-#include "moab/AdaptiveKDTree.hpp"
-#include "moab/GeomUtil.hpp"
-#include <string>
-const double EPSILON = 1e-6; // tolerance to use in intersection checks
-// Help with error handling.  Given ErrorCode, print
-// corresponding string and any available message.
-void print_error( moab::Interface& mb, moab::ErrorCode err )
-  std::string message;
-  std::string code;
-  if (moab::MB_SUCCESS != mb.get_last_error( message ))
-    message.clear();
-  code = mb.get_error_string(err);
-  std::cerr << "Error: " << code << std::endl;
-  if (!message.empty())
-    std::cerr << "  " << message << std::endl;
-// Print diagnostic info for unexpected failures.
-#define CHKERR(err) do { if (moab::MB_SUCCESS != (err)) { \
-  print_error( mb, (err) ); \
-  std::cerr << "Unexpected failure at: " << __FILE__ << ":" << __LINE__ << std::endl; \
-  return 2; \
-  } } while (false)
-// Given an entity set and a point, find the hex contained in the
-// entity set which in turn contains the specified point.  Returns
-// 0 if point is not in any hexahedron.
-moab::EntityHandle hex_containing_point( moab::Interface& mb,
-                                         moab::EntityHandle set,
-                                         const double point[3] );
-// Print hex containing point.
-void print_hex( moab::Interface& mb, moab::EntityHandle hex );
-int main( )
-    // Ask user for file to read
-  std::string filename;
-  std::cout << "Hex mesh file name: ";
-  std::cin >> filename;
-    // Read file into MOAB instance
-  moab::ErrorCode rval;
-  moab::Core moab;
-  moab::Interface& mb = moab;
-  rval = mb.load_file( filename.c_str() );
-  if (moab::MB_SUCCESS != rval) {
-    print_error(mb,rval);
-    std::cerr << filename << ": file load failed" << std::endl;
-    return 1;
-    // Get all hex elemeents
-  moab::Range elems;
-  rval = mb.get_entities_by_type( 0, moab::MBHEX, elems ); CHKERR(rval);
-  if (elems.empty()) {
-    std::cerr << filename << ": file containd no hexahedra" << std::endl;
-    return 1;
-    // Build a kD-tree from hex elements
-  moab::EntityHandle tree_root;
-  moab::AdaptiveKDTree tool( &mb );
-  rval = tool.build_tree( elems, tree_root ); CHKERR(rval);
-    // Loop forever (or until EOF), asking user for a point
-    // to query and printing the hex element containing that
-    // point.
-  for (;;) {
-    double point[3];
-    std::cout << "Point coordinates: ";
-    if (!(std::cin >> point[0] >> point[1] >> point[2]))
-      break;
-    moab::EntityHandle leaf;
-    rval = tool.leaf_containing_point( tree_root, point, leaf ); CHKERR(rval);
-    moab::EntityHandle hex = hex_containing_point( mb, leaf, point );
-    if (0 == hex)
-      std::cout << "Point is not contained in any hexahedron." << std::endl;
-    else
-      print_hex( mb, hex );
-  return 0;
-  moab::CartVect pt(point); // input location
-  moab::CartVect coords[8]; // coordinates of corners of hexahedron
-  const moab::EntityHandle* conn; // hex connectivity
-  int conn_len;
-    // Get hexes in leaf
-  std::vector<moab::EntityHandle> hexes;
-  rval = mb.get_entities_by_type( set, moab::MBHEX, hexes ); CHKERR(rval);
-    // Check which hex the point is in
-  std::vector<moab::EntityHandle>::const_iterator i;
-  for (i = hexes.begin(); i != hexes.end(); ++i) {
-    rval = mb.get_connectivity( *i, conn, conn_len ); CHKERR(rval);
-    rval = mb.get_coords( conn, 8, &coords[0][0] ); CHKERR(rval);
-    if (moab::GeomUtil::point_in_trilinear_hex( coords, pt, EPSILON ))
-      return *i;
-    // Return 0 if no hex contains point.
-  return 0;
-    // Get MOAB's internal ID for hex element
-  int id = mb.id_from_handle(hex);
-    // Get vertex handles for hex corners
-  int conn_len;
-  mb.get_connectivity( hex, conn, conn_len );
-    // Get coordinates of vertices
-  double coords[3*8];
-  mb.get_coords( conn, 8, coords );
-    // Print
-  std::cout << " Point is in hex " << id << " with corners: " << std::endl;
-  for (int i = 0; i < 8; ++i) {
-    std::cout << " (" << coords[3*i]
-              << ", " << coords[3*i+1]
-              << ", " << coords[3*i+2]
-              << ")" << std::endl;
diff --git a/examples/Makefile.am b/examples/Makefile.am
index d0a33b9..0000000
--- a/examples/Makefile.am
+++ /dev/null
@@ -1,68 +0,0 @@
-# NOTE:  The 'makefile' in the *installed* examples directory is generated
-#        using the install-data-hook target below.  This logic assumes that:
-#        1) All examples are listed in check_PROGRAMS
-#        2) All examples have a single source file with the same name (case
-#           sensitive) as the example executable with a .cpp suffix.
-check_PROGRAMS = FileRead \
-                 GeomSetHierarchy \
-                 GetEntities \
-                 KDTree \
-		 ObbTree \
-                 SetsNTags \
-                 SkinMesh \
-                 SurfArea
-SRCDIR = $(top_srcdir)/examples
-LDADD = ../src/libMOAB.la
-AM_CPPFLAGS += -I../src \
-               -I$(srcdir)/../src \
-               -I$(srcdir)/../src/parallel \
-               -I$(srcdir)/../src/oldinc \
-               -DSRCDIR=$(SRCDIR)
-FileRead_SOURCES = FileRead.cpp
-GeomSetHierarchy_SOURCES = GeomSetHierarchy.cpp
-GetEntities_SOURCES = simple/GetEntities.cpp
-SetsNTags_SOURCES = SetsNTags.cpp
-SkinMesh_SOURCES = SkinMesh.cpp
-SurfArea_SOURCES = SurfArea.cpp
-KDTree_SOURCES = KDTree.cpp
-ObbTree_SOURCES = ObbTree.cpp
-exampledir = ${docdir}/examples
-nobase_example_DATA = \
-               examples.make \
-               FileRead.cpp \
-               GeomSetHierarchy.cpp \
-               simple/GetEntities.cpp \
-               simple/makefile \
-               KDTree.cpp \
-	       ObbTree.cpp \
-               SetsNTags.cpp \
-               SkinMesh.cpp \
-               SurfArea.cpp
-if ENABLE_imesh
-  imesh_DIR = itaps
-else
-  imesh_DIR =
-endif
-SUBDIRS = $(imesh_DIR)
-ex_make = $(DESTDIR)$(exampledir)/makefile
-install-data-hook:
-	$(AM_V_at)rm -f $(ex_make)
-	$(AM_V_at)mv $(DESTDIR)$(exampledir)/examples.make $(ex_make)
-	$(AM_V_at)echo "all: $(check_PROGRAMS)" >>$(ex_make)
-	$(AM_V_at)rule='	$$(CXX) -o $$@ $$< $$(CXXFLAGS) $$(MOAB_INCLUDES) $$(MOAB_LIBS_LINK)'; \
-	for example in $(check_PROGRAMS); do \
-	  echo >>$(ex_make); \
-	  echo "$${example}: $${example}.cpp" >>$(ex_make); \
-	  echo "$$rule" >>$(ex_make); \
-	done
-uninstall-hook:
-	$(AM_V_at)rm -f $(DESTDIR)$(exampledir)/makefile
diff --git a/examples/ObbTree.cpp b/examples/ObbTree.cpp
index 220681f..0000000
--- a/examples/ObbTree.cpp
+++ /dev/null
@@ -1,80 +0,0 @@
-// simple example construct obb tree and ray-tracing the tree
-// it reads triangle mesh, construct obb tree and get intersection distances
-#include "moab/OrientedBoxTreeTool.hpp"
-#include <math.h>
-  if (1 == argc) {
-    return 0;
-  // instantiate & load a mesh from a file
-  moab::Core *mb = new moab::Core();
-  moab::ErrorCode rval = mb->load_mesh(argv[1]);
-  // get all triangles
-  moab::Range tris;
-  //moab::OrientedBoxTreeTool::Settings settings;
-  rval = mb->get_entities_by_type( 0, moab::MBTRI, tris );
-  if (rval != moab::MB_SUCCESS) {
-    std::cerr << "Couldn't get triangles." << std::endl;
-    return 1;
-  // build OBB trees for all triangles
-  moab::OrientedBoxTreeTool tool(mb);
-  //rval = tool.build(tris, tree_root, &settings);
-  rval = tool.build(tris, tree_root);
-    std::cerr << "Could'nt build tree." << std::endl;
-    return 1;
-  // build box
-  double box_center[3], box_axis1[3], box_axis2[3], box_axis3[3], pnt_start[3], ray_length;
-  rval = tool.box(tree_root, box_center, box_axis1, box_axis2, box_axis3);
-    std::cerr << "Couldn't get box for tree root set.";
-    return 1;
-  ray_length = 2.*sqrt(box_axis1[0]*box_axis1[0] + box_axis1[1]*box_axis1[1] +
-		       box_axis1[2]*box_axis1[2]);
-  // do ray-tracing from box center side to x direction
-  std::vector<double> intersections;
-  std::vector<moab::EntityHandle> intersection_facets;
-  for (int i=0; i<3; i++)
-    pnt_start[i] = box_center[i]-box_axis1[i];
-  if (ray_length>0) // normalize ray direction
-    for (int j=0; j<3; j++)
-      box_axis1[j]=2*box_axis1[j]/ray_length;
-  rval = tool.ray_intersect_triangles(intersections, intersection_facets,
-				      tree_root, 10e-12, pnt_start, box_axis1,
-				      &ray_length);
-    std::cerr << "Couldn't ray tracing.";
-    return 1;
-  std::cout << "ray start point: " << pnt_start[0] << " "
-	    << pnt_start[1] << " " << pnt_start[2] << std::endl;
-  std::cout << " ray direction: " << box_axis1[0] << " " << box_axis1[1] << " " << box_axis1[2] << "\n";
-  std::cout << "# of intersections : " << intersections.size() << std::endl;
-  std::cout << "intersection distances are on";
-  for (unsigned int i = 0; i < intersections.size(); i++) {
-    std::cout << " " << intersections[i];
-  std::cout << " of ray length " << ray_length << std::endl;
-  return 0;
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
